Nginx [PATCH] Fix error when building a Nginx source RPM with custom Zlib - Nginx 1.13.7
Discussion in 'Nginx and PHP-FPM news & discussions' started by buik, Dec 12, 2017.
    12,579
    9:06 PM
    Use ldd on nginx binary
  2. Revenge
    Revenge Active Member
    469
    93
    Portugal
    12:06 PM
    1.9.x
    10.1.x
    Against the compiled nginx binary:
    ldd /opt/sbin/nginx
            linux-vdso.so.1 =>  (0x00007ffe9ea75000)
            libdl.so.2 => /lib64/libdl.so.2 (0x00007f7072046000)
            libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f7071e2a000)
            libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f7071bf3000)
            libc.so.6 => /lib64/libc.so.6 (0x00007f7071830000)
            /lib64/ld-linux-x86-64.so.2 (0x00007f707224a000)
            libfreebl3.so => /lib64/libfreebl3.so (0x00007f707162d000)
    Against the Nginx installed with Yum:
    ldd /usr/sbin/nginx
            linux-vdso.so.1 =>  (0x00007ffdb31b9000)
            libdl.so.2 => /lib64/libdl.so.2 (0x00007fe129bcb000)
            libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe1299af000)
            libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007fe129778000)
            libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fe129516000)
            libssl.so.10 => /lib64/libssl.so.10 (0x00007fe1292a4000)
            libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007fe128e43000)
            libz.so.1 => /lib64/libz.so.1 (0x00007fe128c2d000)
            libc.so.6 => /lib64/libc.so.6 (0x00007fe12886a000)
            /lib64/ld-linux-x86-64.so.2 (0x00007fe12a122000)
            libfreebl3.so => /lib64/libfreebl3.so (0x00007fe128667000)
            libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007fe12841a000)
            libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007fe128132000)
            libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007fe127f2e000)
            libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007fe127cfb000)
            libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007fe127aed000)
            libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007fe1278e9000)
            libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fe1276cf000)
            libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fe1274a8000)
    12,579
    9:06 PM
    Yeah IIRC now, you won't see it as Cloudflare zlib is statically compiled into Nginx binary now. You can easily verify if Cloudflare zlib is working with Nginx through benchmarking/load testing Nginx via wrk, siege etc testing compressed HTTP(S) requests with header Accept-Encoding: gzip like I did at 123.09beta01 Updated Nginx zlib routine with optional Cloudflare zlib support. Do a before and after test to see the difference.
  4. Revenge
    469
    93
    Portugal
    12:06 PM
    1.9.x
    10.1.x
    Ya, i will do a test later today. But its what i thought, its built in nginx and because of that does not show in ldd.
