Beta Branch part 2 prep work for optional GCC 10 support in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Mar 17, 2021.
    46,427
    10,551
    8:12 AM
    - better compatibility for GCC 10 compilations of Nginx, PHP and added GCC 10 support for compression tool routine centmin.sh menu option 17 and openssl builds for Nginx
    - updated optional zlib_ng Nginx optional support including GCC 10 support (zlib_ng currently not working 100%)
    123.09beta01 branch
  2. hazehs
    hazehs Member
    31
    10:12 PM
    NGINX 1.18
    MariaDB 10.4
    Isnt there a way to compile GCC yourself and then use it ?
    Or installing it from other .deb prebuilts ?
    regards
    46,427
    10,551
    8:12 AM
    That's what I have done in past if GCC YUM packages aren't available via official YUM distros, I build my own custom GCC YUM/RPM packages Beta Branch - Testing GCC 8, GCC 9 & Clang 5/6/7 compiler for Centmin Mod Nginx & PHP-FPM. So that Centmin Mod Nginx and compile routines are ready for newer GCC versions when new GCC versions are available publicly. But rather than polute end users servers with tests, I do this privately until official public GCC YUM packages are out via SCL.
    .deb is for Ubuntu/Debian. FYI, Centmin Mod is CentOS/RPM only
  4. hazehs
    hazehs Member
    31
    10:12 PM
    NGINX 1.18
    MariaDB 10.4
    Yeah, i know that you did that before.
    Do you have any Script which is compatible with centminmod to compile gcc 10 ? im not familar with yum/centos.
    Mostly iim not familar with yum/centos.
    Using mostly only arch, sometimes debian and ubuntu, but dont like them really much.
    46,427
    10,551
    8:12 AM
    Nothing that I'm willing to provide public support for. It's only really for my private use for testing GCC 10+ and Clang compiler compatibility with Centmin Mod.
