Beta Branch - enable PHP GD AVIF support by default for PHP >=8.1 in EL8/EL9 in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 27, 2024.
    12,579
    9:06 PM
    - set PHP_LIBGD_EXTERNAL='y' to enable by default to use newer libgd 2.3.3. To disable set PHP_LIBGD_EXTERNAL='n' in the persistent config file /etc/centminmod/custom_config.inc prior to initial install or prior to running centmin.sh menu option 5 PHP recompile/upgrade/downgrades.
    - add and enable by default, PHP_GD_AVIF='y' for PHP >=8.1 in EL8/EL9 OSes. To disable set PHP_GD_AVIF='n' in the persistent config file /etc/centminmod/custom_config.inc prior to initial install or prior to running centmin.sh menu option 5 PHP recompile/upgrade/downgrades.
    php --ri gd
    gd
    GD Support => enabled
    GD headers Version => 2.3.3
    GD library Version => 2.3.3
    FreeType Support => enabled
    FreeType Linkage => with freetype
    GIF Read Support => enabled
    GIF Create Support => enabled
    JPEG Support => enabled
    PNG Support => enabled
    WBMP Support => enabled
    XPM Support => enabled
    XBM Support => enabled
    WebP Support => enabled
    AVIF Support => enabled
    TGA Read Support => enabled
    gd.jpeg_ignore_warning => On => On
    140.00beta01 branch
