Beta Branch fix PostgreSQL EOL repo 404 errors and add PG 18 support in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Feb 8, 2026.
    60,125
    12,587
    11:25 AM
    - add pgsql_disable_eol_repos() to disable archived PGDG repos (PG 9.6-13)
    that return 404
    - supports EL7 yum-config-manager and EL8/9 dnf config-manager syntax
    - add PostgreSQL 18 installation block for EL8/9
    - update default POSTGRESQL_BRANCHVER from 17 to 18 and PDOPGSQL_PHPVER
    from 11 to 18
    - update auto-detection to newest-first order (18, 17, 16, 15, 14,
    then legacy)
    - remove all EL6 dead code and unreachable inner OS branches from
    PG 16/17 blocks
    140.00beta01 branch
