Nginx PageSpeed PageSpeed isn't compressing images even with tweaked conf.
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by cr0, Sep 10, 2017.
    59,325
    12,510
    12:39 AM
    turn of pagespeed globally first
    pscontrol off
    then see if commented out pagespeed 3 include lines work.. remember to do this in both https and non-https vhosts as cloudflare talks to non-https if you use flexible ssl
  2. cr0
    cr0 Member
    38
    4:39 PM
    It's set to Full (strict) mode and "Always use HTTPS".
    Just did it and can't see any pagespeed headers when performing
    curl -I http://domain.com
    59,325
    12,510
    12:39 AM
    k then just concentrate on nginx https vhost then as cloudflare talking to https backend origin.
  4. cr0
    cr0 Member
    38
    4:39 PM
    Ah, alright. Here's the ssl.conf (I tried pscontrol off + uncommenting those 3 lines + /etc/init.d/nginx restart but no pagespeed in headers)
    PHP:
    # Centmin Mod Getting Started Guide
    # must read http://centminmod.com/getstarted.html
    # For SPDY SSL Setup
    # read http://centminmod.com/nginx_configure_https_ssl_spdy.html
    # redirect from www to non-www  forced SSL
    # uncomment, save file and restart Nginx to enable
    # if unsure use return 302 before using return 301
    # server {
    #   server_name MYDOMAIN.com www.MYDOMAIN.com;
    #    return 302 https://$server_name$request_uri;
    server {
    listen 443 ssl http2;
    ssl_dhparam /usr/local/nginx/conf/ssl/MYDOMAIN.com/dhparam.pem;
    ssl_certificate      /usr/local/nginx/conf/ssl/MYDOMAIN.com/public.pem;
    ssl_certificate_key  /usr/local/nginx/conf/ssl/MYDOMAIN.com/private.key;
      include /
    usr/local/nginx/conf/ssl_include.conf;
    http2_max_field_size 16k;
    http2_max_header_size 32k;
    # mozilla recommended
    ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
    ssl_prefer_server_ciphers   on;
    #add_header Alternate-Protocol  443:npn-spdy/3;
      # before enabling HSTS line below read centminmod.com/nginx_domain_dns_setup.html#hsts
      #add_header Strict-Transport-Security "max-age=31536000; includeSubdomains;";
      #add_header X-Frame-Options SAMEORIGIN;
      #add_header X-Xss-Protection "1; mode=block" always;
      #add_header X-Content-Type-Options "nosniff" always;
      #spdy_headers_comp 5;
    ssl_buffer_size 1369;
    ssl_session_tickets on;
    # enable ocsp stapling
      #resolver 8.8.8.8 8.8.4.4 valid=10m;
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/MYDOMAIN.com/MYDOMAIN.com-trusted.crt;
    # ngx_pagespeed & ngx_pagespeed handler
    include /usr/local/nginx/conf/pagespeed.conf;
    include /
    usr/local/nginx/conf/pagespeedhandler.conf;
    include /
    usr/local/nginx/conf/pagespeedstatslog.conf;
      # limit_conn limit_per_ip 16;
      # ssi  on;
    access_log /home/nginx/domains/MYDOMAIN.com/log/access.log combined buffer=256k flush=5m;
    error_log /home/nginx/domains/MYDOMAIN.com/log/error.log;
      include /
    usr/local/nginx/conf/autoprotect/MYDOMAIN.com/autoprotect-MYDOMAIN.com.conf;
    root /home/nginx/domains/MYDOMAIN.com/public;
    # uncomment cloudflare.conf include if using cloudflare for
      # server and/or vhost site
      #include /usr/local/nginx/conf/cloudflare.conf;
    include /usr/local/nginx/conf/503include-main.conf;
      include /
    usr/local/nginx/conf/wpincludes/MYDOMAIN.com/wpcacheenabler_MYDOMAIN.com.conf;
    #include /usr/local/nginx/conf/wpincludes/MYDOMAIN.com/wpsupercache_MYDOMAIN.com.conf;
      # https://community.centminmod.com/posts/18828/
      #include /usr/local/nginx/conf/wpincludes/MYDOMAIN.com/rediscache_MYDOMAIN.com.conf;
    location / {
      include /
    usr/local/nginx/conf/503include-only.conf;
    # Enables directory listings when index file not found
      #autoindex  on;
      # for wordpress super cache plugin
      #try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $uri/ /index.php?q=$uri&$args;
      # for wp cache enabler plugin
    try_files $cache_enabler_uri $uri $uri$custom_subdir/index.php?$args
    # Wordpress Permalinks
      #try_files $uri $uri/ /index.php?q=$uri&$args;
      # Nginx level redis Wordpress
      #try_files $uri $uri/ /index.php?$args;
    location ~* /(wp-login\.php) {
    limit_req zone=xwplogin burst=1 nodelay;
    #limit_conn xwpconlimit 30;
    auth_basic "Private";
    auth_basic_user_file /home/nginx/domains/MYDOMAIN.com/htpasswd_wplogin;
        include /
    usr/local/nginx/conf/php-wpsc.conf;
        #include /usr/local/nginx/conf/php-rediscache.conf;
    # prepare for letsencrypt
        # https://community.centminmod.com/posts/17774/
    location ~ /.well-known location ~ /.well-known/acme-challenge/(.*) { more_set_headers    "Content-Type: text/plain"; } }
    location ~* /(xmlrpc\.php) {
    limit_req zone=xwprpc burst=45 nodelay;
    include /usr/local/nginx/conf/php-wpsc.conf;
      include /
    usr/local/nginx/conf/wpincludes/MYDOMAIN.com/wpsecure_MYDOMAIN.com.conf;
      include /
    include /usr/local/nginx/conf/pre-staticfiles-local-MYDOMAIN.com.conf;
      include /
    usr/local/nginx/conf/pre-staticfiles-global.conf;
      include /
    usr/local/nginx/conf/staticfiles.conf;
      include /
    usr/local/nginx/conf/drop.conf;
    #include /usr/local/nginx/conf/errorpage.conf;
    include /usr/local/nginx/conf/vts_server.conf;
    59,325
    12,510
    12:39 AM
    you're editing /usr/local/nginx/conf/conf.d/MYDOMAIN.com.ssl.conf right ?
    vhost looks good..
    59,325
    12,510
    12:39 AM
    also try testing via browser's private incognito session to makes sure browser hasn't cached anything
  7. cr0
    cr0 Member
    38
    4:39 PM
    I think the issue that it's not working is because I used the command pscontrol off.. So it won't matter if those 3 lines were uncommented. Reenabling it after editing pagespeed.conf (pagespeed set to on) does the same result, no way to access to global admin with a working console, only if I uncomment the 3rd line.
    Nope, not working either.
    Yes.
    EDIT:
    Can it be due to bad installation? I mean, because of the initial host setup for vhost's.
    59,325
    12,510
    12:39 AM
    try adding allow serverip to handler whitelisting too as well as accessing it from yourdomain.com/pagespeed_global_admin
    59,325
    12,510
    12:39 AM
    for example in /usr/local/nginx/conf/pagespeedhandler.conf
    if my ISP IP address is 192.168.0.99 and server IP address is xxx.xxx.xxx.xxx, then I will add allow 192.168.0.99 and xxx.xxx.xxx.xxx to existing config to end up as follows:
    location /ngx_pagespeed_statistics { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; deny all; }
    location /ngx_pagespeed_global_statistics { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; deny all; }
    location /ngx_pagespeed_message { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; deny all; }
    location /pagespeed_console { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; deny all; }
    location ~ ^/pagespeed_admin { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; deny all; }
    location ~ ^/pagespeed_global_admin { allow 127.0.0.1; allow 192.168.0.99; allow xxx.xxx.xxx.xxx; all
  10. cr0
    cr0 Member
    38
    4:39 PM
    Nope, still the same, with uncommented lines I got 403 forbidden error, with 3 of them commented I got
    Failed to load PageSpeed Console because:
    StatisticsLogging is not enabled.
    LogDir is not set.
    pagespeedhandler.conf:
    PHP:
    #  Ensure requests for pagespeed optimized resources go to the pagespeed
    #  handler and no extraneous headers get set.
    location "\.pagespeed\.([a-z]\.)?[a-z]{2}\.[^.]{10}\.[^.]+" add_header "" ""; }
    location "^/pagespeed_static/" { }
    location "^/ngx_pagespeed_beacon$" { }
    location /ngx_pagespeed_statistics allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    location /ngx_pagespeed_global_statistics allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    location /ngx_pagespeed_message allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    location /pagespeed_console allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    location ~ ^/pagespeed_admin allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    location ~ ^/pagespeed_global_admin allow 127.0.0.1allow mypublicipallow serverspublicipdeny all; }
    59,325
    12,510
    12:39 AM
    you ran
    pscontrol on
    that means ip is incorrect, double check your ISP ip at https://tools.keycdn.com/geo to make sure it makes the allow ip
    59,325
    12,510
    12:39 AM
    59,325
    12,510
    12:39 AM
    for cloudflare realip, can also setup Beta Branch - csfcf.sh - automate Cloudflare Nginx & CSF Firewall setups
    it's already in vhost
    uncomment last line include file
  14. cr0
    cr0 Member
    38
    4:39 PM
    THAT'S IT! All that hassle for uncommenting a single line. THANK YOU.
    Now the last thing that's missing is this:
    staticfile is included and everything is right, cloudflare is off, I'm not sure what's the problem here.
    Also, is it normal to have some CSS's unminified?
    59,325
    12,510
    12:39 AM
    check pagespeed admin console message log page if you enabled it via
    pagespeed MessageBufferSize Nginx PageSpeed - CentminMod.com LEMP Nginx web stack for CentOS and debug filter Nginx PageSpeed - PageSpeed isn't compressing images even with tweaked conf.
    ngx_pagespeed needs a number of page reloads until it fully optimises assets where it can - it won't be instant
    rest of ngx_pagespeed usage will be left to you so good to read
    test with gtmetrix.com and webpagetest.org to double check
    59,325
    12,510
    12:39 AM
    one possibility is the autoprotect include file /usr/local/nginx/conf/autoprotect/MYDOMAIN.com/autoprotect-MYDOMAIN.com.conf in vhost as outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all
    include /usr/local/nginx/conf/autoprotect/MYDOMAIN.com/autoprotect-MYDOMAIN.com.conf;
    what is in it's contents via cat command
    cat /usr/local/nginx/conf/autoprotect/MYDOMAIN.com/autoprotect-MYDOMAIN.com.conf
    could be auto generated location contexts took priority over expires set in staticfiles.conf include and missing some expires entries though unlikely
    59,325
    12,510
    12:39 AM
    i think i know what the expires issue is it's related to centmin.sh menu option 22's generated /usr/local/nginx/conf/wpincludes/${vhostname}/wpsecure_${vhostname}.conf include file where ${vhostname} = your domain name
    if you edit your /usr/local/nginx/conf/wpincludes/${vhostname}/wpsecure_${vhostname}.conf
    find your woocommerce location context and add staticfiles.conf include just below existing php.conf include file to it so it looks like
    so end result is
    # Whitelist Exception for https://wordpress.org/plugins/woocommerce/
    location ~ ^/wp-content/plugins/woocommerce/ {
      # below include file needs to be manually created at that path and to be uncommented
      # by removing the hash # in front of below line to take effect. This wpwhitelist_common.conf
      # allows you to add commonly shared settings to all wp plugin location matches which
      # whitelist php processing access at /usr/local/nginx/conf/wpincludes/${vhostname}/wpsecure_${vhostname}.conf
      #include /usr/local/nginx/conf/wpincludes/${vhostname}/wpwhitelist_common.conf;
    restart nginx
    does woocommerce directories static files get an expiry header ?
  18. cr0
    cr0 Member
    38
    4:39 PM
    After checking on Caching Checker - Test your website's browser caching settings, yes they do.
    https://MYDOMAIN.com/wp-content/plugins/woocommerce/assets/fonts/star.woff 30 days
    Yeah! I will be checking out the logs, now that they're working :):):):)
  19. cr0
    cr0 Member
    38
    4:39 PM
    PHP:
    # /home/nginx/domains/MYDOMAIN.com/public/wp-content/plugins/akismet
    location /wp-content/plugins/akismet/ {
    location ~ ^/wp-content/plugins/akismet/(.+/)?(form|akismet)\.(css|js)$ { allow allexpires 30d;}
    location ~ ^/wp-content/plugins/akismet/(.+/)?(.+)\.(png|gif)$ { allow allexpires 30d;}
    location ~* /wp-content/plugins/akismet/.*\.php$ {
        include /
    usr/local/nginx/conf/php.conf;
    allow 127.0.0.1;
    deny all;
    # /home/nginx/domains/MYDOMAIN.com/public/wp-content/uploads/wc-logs
    location ~* ^/wp-content/uploads/wc-logs/ { allow 127.0.0.1deny all; }
    # /home/nginx/domains/MYDOMAIN.com/public/wp-content/uploads/sucuri
    location ~* ^/wp-content/uploads/sucuri/ { allow 127.0.0.1deny all; }
    # /home/nginx/domains/MYDOMAIN.com/public/wp-content/uploads/woocommerce_uploads
    location ~* ^/wp-content/uploads/woocommerce_uploads/ { allow 127.0.0.1deny all; }
    59,325
    12,510
    12:39 AM
