Nginx PageSpeed Pagespeed didn't work for me
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Maester Aemon, Mar 24, 2016.
  1. Maester Aemon
    Maester Aemon New Member
    20
    12:22 PM
    1.9.12
    Pagespeed version included in the centmin.sh did not work for me.
    It never got recognized when trying to start nginx.
    If anyone is having the same problem, try changing the version to
    NGXPGSPEED_VER='1.9.32.13-beta'
    NGINX_PAGESPEEDPSOL_VER='1.9.32.13'
    That fixed it for me.
    54,909
    12,240
    9:22 PM
  3. Maester Aemon
    20
    12:22 PM
    1.9.12
    I used this to install centminmod
    yum -y install git wget nano bc unzip
    cd /usr/local/src
    git clone https://github.com/centminmod/centminmod.git centminmod
    cd centminmod
    54,909
    12,240
    9:22 PM
  5. Maester Aemon
    20
    12:22 PM
    1.9.12
    Do you think that I may encouter problems with my solution?
    Should I go with 123.09 and re-install it?
    54,909
    12,240
    9:22 PM
    don't need to reinstall if you already loaded data onto vps server - just follow 1st post instructions at Beta Branch - Centmin Mod .09 beta branch Testing | Centmin Mod Community to update to 123.09beta01. However, if it's virgin vps with no data, a reload of OS and reinstall of 123.09beta01 would be better :)
    Getting Started Guide step 19 outlines also how to keep Centmin Mod code updated or how to switch version branches.
    Centmin Mod LEMP stack's script code is constantly updated for improvements, bug fixes and security fixes so keeping the Centmin Mod code up to date is important. With Centmin Mod 1.2.3-eva2000.08) (123.08stable) and higher releases, a newly added centmin.sh menu option 23 allows much easier code updates and version branch swicthing via Git backed environment you can setup. For full details read the following links:
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to. You can easily update within a Centmin Mod version branch or switch version branches via centmin.sh menu option 23 outlined here.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at How to upgrade Centmin Mod software installed on your server.
