SSL Own certificate and HTTP Public Key Pinning
Discussion in 'Domains, DNS, Email & SSL Certificates' started by ModeltogTossen, Mar 12, 2016.
  1. ModeltogTossen
    313
    97
    Denmark
    4:01 AM
    1.9.12
    10.0.23
    Hello sirs..
    Trying hard to get my head around some understanding of this HPKP stuff.
    When a site is created in CMM - it also gets HPKP generated commented out - like this:
    #add_header Public-Key-Pins 'pin-sha256="iAohr08REOhE8EBXYthVZyxrIE/yuZbTNz/8+c5JBeE="; pin-sha256="bgLN5U0V2ougSd/t2WghRaaU8Yx3xMTMxNOp0bHqHiI="; max-age=86400';
    My question is - If I replace the self-signed certificate with one from, lets say letsencrypt or Comodo, do I still use the auto-generated HPKP keys or do I need to generate another one and replace it? As now I think I need to replace it because that key is generated out of the self-signed crt, right?
    If I need to replaced it - what is the command to do so?
    Have found something like this but is that correct?
    openssl x509 -pubkey < MyOwn.crt | openssl pkey -pubin -outform der | openssl dgst -sha256 -binary | base64
    Hope for some feedback from anyone who have fiddle with that or can point me in some directions.
    Thanks in advance for participate.
    55,903
    12,281
    12:01 PM
    needs replacing the HPKP keys completely - you can see see clues as to how nginx vhost generation on centmin.sh menu option 2 does it on lines 68-90 of inc/nginx_addvhost.inc
