Wordpress Optimus could not find images. cURL library not detected?
Discussion in 'Blogs & CMS usage' started by Doni, Mar 9, 2018.
  1. Doni
    Doni Member
    39
    12:14 PM
    nginx/1.7.4
    mysql Ver 15.1 Distrib 5.5.39-MariaDB, for Linux (x86_64) using readline 5.1
    Hi Eva,
    I have a lil bit problem with Optimus plugins that comes with the default instalation of the wordpress. Its seems that the plugins could not find the images, so it could not optimize it.
    Ive got a warning on wordpress dashboard that optimus cUrl library is need.
    Optimus requires the cURL-Library. Please contact your hosting provider to get cURL installed.
    I check on my server it seemd the curl library is installed properly.
    [17:58]# curl -V
    curl 7.29.0 (x86_64-redhat-linux-gnu) libcurl/7.29.0 NSS/3.28.4 zlib/1.2.7 libidn/1.28 libssh2/1.4.3
    Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smtp smtps telnet tftp
    Features: AsynchDNS GSS-Negotiate IDN IPv6 Largefile NTLM NTLM_WB SSL libz unix-sockets
    Can you help me with this. Thanks
    45,406
    10,302
    3:14 PM
    Does the plugin require shell_exec php function ? Centmin Mod disables shell_exec php function by default for security in your PHP-FPM config file at /usr/local/etc/php-fpm.conf (you can use command shortcut fpmconf to invoke nano text editor opening & editing /usr/local/etc/php-fpm.conf )
    to disable command out the line with semi-colon
    ;php_admin_value[disable_functions] = shell_exec
    restart php-fpm with command shortcut
    fpmrestart
    or usual service restart
    service php-fpm restart
    Also check if PHP was compiled with curl support which it should do using phpinfo page for curl section or php command below
    php --ri curl
    output if curl exists and supported in PHP
    php --ri curl
    curl
    cURL support => enabled
    cURL Information => 7.29.0
    Age => 3
    Features
    AsynchDNS => Yes
    CharConv => No
    Debug => No
    GSS-Negotiate => Yes
    IDN => Yes
    IPv6 => Yes
    krb4 => No
    Largefile => Yes
    libz => Yes
    NTLM => Yes
    NTLMWB => Yes
    SPNEGO => No
    SSL => Yes
    SSPI => No
    TLS-SRP => No
    Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp
    Host => x86_64-redhat-linux-gnu
    SSL Version => NSS/3.28.4
    ZLib Version => 1.2.7
    libSSH Version => libssh2/1.4.3
  3. Doni
    Doni Member
    39
    12:14 PM
    nginx/1.7.4
    I've check /usr/local/etc/php-fpm.conf and the shell_exec php function is not disable
    And php --ri curl give me this:
    curl
    Age => 3
    Features
    AsynchDNS => Yes
    CharConv => No
    Debug => No
    IDN => Yes
    IPv6 => Yes
    krb4 => No
    Largefile => Yes
    libz => Yes
    NTLM => Yes
    NTLMWB => Yes
    SPNEGO => No
    SSL => Yes
    SSPI => No
    TLS-SRP => No
    I'm really not sure whats the problem, because i've done instalation with centmin menu 22, and the optimus plugin that come along with the instalation never gave me a problem.
    Oh fyi, i'm using Centmin Mod Menu 123.09beta01
  4. pamamolf
    3,857
    378
    8:14 AM
    Nginx-1.17.x
    It is disabled:
    You may want to remove the shell_exec and restart phpfpm...
    45,406
    10,302
    3:14 PM
    Might want to contact Optimus developers and see if something changed code detection wise at their end
