Nginx Optimizing TLS over TCP to reduce latency: TLS dynamic record sizing
Discussion in 'Nginx and PHP-FPM news & discussions' started by rdan, Jun 10, 2016.
    4,128
    2:32 PM
    Am i missing something?
    Result:
    NGINX_DYNAMICTLS ?
    I just update Centminmod to latest version and then i was recompile...
    Where is it?
    Or is it just a patch that will not output anything as a module does?
    12,579
    9:32 PM
    It isn't something that shows up in nginx -V output.. it's just a patch. If you want to really see if it's working test in webpagetest.org/gtmetrix like Matt and I did and/or do tcpdump of the port 443 traffic for test requests and inspect in wireshark.
  3. knguyen2015
    knguyen2015 New Member
    11
    7:32 AM
    1.12.1
    15.1
    I won't work with nginx 1.13.9 anymore.
    12,579
    9:32 PM
    Which version of Centmin Mod you using 123.08stable or 123.09beta01 ? NGINX_DYNAMICTLS='y' option to enable Cloudflare Dynamic TLS Record Size patch on Nginx recompile with centmin.sh menu option 4 will only work with Centmin Mod 123.09beta01 based Nginx and not 123.08stable.
    What you mean it's not providing the performance savings it was before 1.13.9 or you mean wont' compile with the patch ? Works fine here with my Centmin Mod Nginx 1.13.9 install.
    At end of centmin.sh menu option 4 installs, you get a list of logs created including one for a time stamped patch nginx log which contains the following at /root/centminlogs/patch_patchnginx_250218-141920.log for patch details
    Patching Nginx for Dynamic TLS Size Support
    Cloudflare Nginx Dynamic TLS patch
    https://github.com/cloudflare/sslconfig/raw/master/patches/nginx__dynamic_tls_records.patch
    patch -p1 < /usr/local/src/centminmod/patches/cloudflare/nginx__dynamic_tls_records_1011005.patch
    patching file src/event/ngx_event_openssl.c
    Hunk #1 succeeded at 1174 (offset 43 lines).
    Hunk #2 succeeded at 1713 (offset 43 lines).
    Hunk #3 succeeded at 1849 (offset 43 lines).
    patching file src/event/ngx_event_openssl.h
    Hunk #1 succeeded at 60 with fuzz 1 (offset 6 lines).
    Hunk #2 succeeded at 95 (offset 6 lines).
    Hunk #3 succeeded at 108 (offset 6 lines).
    patching file src/http/modules/ngx_http_ssl_module.c
    Hunk #1 succeeded at 234 (offset 1 line).
    Hunk #2 succeeded at 594 (offset 26 lines).
    Hunk #3 succeeded at 664 (offset 26 lines).
    Hunk #4 succeeded at 858 (offset 26 lines).
    patching file src/http/modules/ngx_http_ssl_module.h
    Using Nginx 1.13.9
