WebPerf Optimizing Image Sizes for faster page load times with optimise-images.sh
Discussion in 'Web Development & Web Performance' started by eva2000, Apr 29, 2017.
    12,579
    10:50 PM
    You're welcome. Ah yes case insensitive matches ! Thanks
  2. fabianski
    fabianski Member
    102
    14
    9:50 AM
    Is single image optimization not supported?
    I'm using the plugin shor0814/image-optimiser-plugin to optimize the new images that are sent in wordpress.
    The plugin tries to do automatic optimization using the direct path to the image but this apparently does not work
    $scriptlocation = "/usr/sbin";
    $scriptname = "optimise-images-plugin.sh";
    $outname = $scriptlocation.$scriptname." optimise ".$file;
    I did a test to optimize a single image directly by ssh did not work either
    /usr/sbin/optimise-images.sh optimise /home/nginx/domains/domain.org/public/wp-content/uploads/2019/06//image.jpg
    No results are reported when I ran this command...
    12,579
    10:50 PM
    wrong thread then, you're using a fork of my optimise-images.sh created by @ShawnH so best to ask in Wordpress - Optimise Images modification and plugin
    but for my optimise-image.sh yes single image isn't supported only directory level
  4. fabianski
    fabianski Member
    102
    14
    9:50 AM
  5. elargento
    elargento Member
    353
    9:50 AM
    Why mkdir -p /home/nginx/domains/domain.com/public/images is needed? is it a temporary folder?
    12,579
    10:50 PM
    where's this comming from ?
  7. elargento
    elargento Member
    353
    9:50 AM
    I don't understand if this folder is used for temporary files or if the up
    I mean, how can I optimize the images on several subfolders by overwriting the old ones with the new optimized images?
    12,579
    10:50 PM
    that's an example, meaning I created that directory to test images in that directory for my example
    see instructions at Unattended Subdirectory Runs
  9. Mak Adang
    Mak Adang Member
    62
    20
    7:50 PM
    1.9.0
    10.0.18-MariaDB
    12,579
    10:50 PM
  11. elargento
    elargento Member
    353
    9:50 AM
    Eva, what does ./optimise-images.sh {install} do?
    12,579
    10:50 PM
    Updated April 5, 2020: optimise-images.sh with basic Dockerfile support which was contributed by developer from Upcloud via pull request at Add Dockerfile by scop ยท Pull Request #3 ยท centminmod/optimise-images. Which means you can technically run optimise-images.sh on non-CentOS systems i.e. via Docker on Ubuntu build a CentOS 7 image.
    How to install and use Docker is left up to end user to learn.
    Build local Dockerfile image
    docker build --tag optimise-images:1.0 .
    Resulting Docker images
    docker images
    REPOSITORY          TAG                 IMAGE ID            CREATED             SIZE
    optimise-images     1.0                 f338939fb838        30 seconds ago      574MB
    centos              7                   5e35e350aded        4 months ago        203MB
    Would need to use docker volume to map system directory to docker container image directory if using optimise-images.sh within a docker container.
    So for /home/optimise-benchmarks system directory full of images to profile it, you would run:
    docker run --rm -it -v /home/optimise-benchmarks:/home/optimise-benchmarks optimise-images:1.0 optimise-images.sh profile /home/optimise-benchmarks
    To optimise the directory
    docker run --rm -it -v /home/optimise-benchmarks:/home/optimise-benchmarks optimise-images:1.0 optimise-images.sh optimise /home/optimise-benchmarks
    Profile mode run:
    image profile
    image name : width : height : quality : transparency : image depth (bits) : size : user: group
    images in /home/optimise-benchmarks
    logged at /home/optimise-logs/profile-log-050420-015006.log
    image : bees.png : 444 : 258 : 92 : False : 8 : 175256 : root : root
    image : dslr_canon_eos_m6_1.jpg : 1200 : 800 : 82 : False : 8 : 161442 : root : root
    image : dslr_nikon_d7200_1.jpg : 2048 : 1365 : 82 : False : 8 : 377126 : root : root
    image : dslr_nikon_d7200_2.jpg : 1365 : 2048 : 82 : False : 8 : 520565 : root : root
    image : png24-image1.png : 600 : 400 : 92 : False : 8 : 386063 : root : root
    image : png24-interlaced-image1.png : 600 : 400 : 92 : False : 8 : 443931 : root : root
    image : samsung_s7_mobile_1.jpg : 2048 : 1536 : 82 : False : 8 : 259901 : root : root
    image : webp-study-source-firebreathing.png : 1024 : 752 : 92 : False : 8 : 1194070 : root : root
    Original or Existing Images:
    | Avg width | Avg height | Avg quality | Avg size   | Total size (Bytes) | Total size (KB) |
    | 1166      | 945        | 87          | 439794     | 3518354            | 3436            |
    ImageMagick Resource Limits
    Version: ImageMagick 6.9.11-3 Q16 x86_64 2020-03-30
    Resource limits:
      Width: 214.7MP
      Height: 214.7MP
      List length: unlimited
      Area: 3.8543GP
      Memory: 1.79481GiB
      Map: 3.58962GiB
      Disk: unlimited
      File: 786432
      Thread: 2
      Throttle: 0
      Time: unlimited
    Completion Time: 0.58 seconds
    Optimise mode run:
    !!! Important !!!
    Have you made a backup of images in /home/optimise-benchmarks? [y/n]: y
    image optimisation start
    ### samsung_s7_mobile_1.jpg (jpg) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp samsung_s7_mobile_1.jpg -define jpeg:size=4096x4096 -filter triangle -define filter:support=2 -define jpeg:fancy-upsampling=off -unsharp 0.25x0.08+8.3+0.045 -interlace none -strip -set comment optimised -resize 2048x2048\> samsung_s7_mobile_1.jpg
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 jpegoptim -p --max=82 samsung_s7_mobile_1.jpg
    samsung_s7_mobile_1.jpg 2048x1536 24bit N JFIF  [OK] 260188 --> 260142 bytes (0.02%), optimized.
    ### dslr_canon_eos_m6_1.jpg (jpg) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp dslr_canon_eos_m6_1.jpg -define jpeg:size=4096x4096 -filter triangle -define filter:support=2 -define jpeg:fancy-upsampling=off -unsharp 0.25x0.08+8.3+0.045 -interlace none -strip -set comment optimised -resize 2048x2048\> dslr_canon_eos_m6_1.jpg
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 jpegoptim -p --max=82 dslr_canon_eos_m6_1.jpg
    dslr_canon_eos_m6_1.jpg 1200x800 24bit N JFIF  [OK] 161453 --> 161388 bytes (0.04%), optimized.
    ### dslr_nikon_d7200_1.jpg (jpg) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp dslr_nikon_d7200_1.jpg -define jpeg:size=4096x4096 -filter triangle -define filter:support=2 -define jpeg:fancy-upsampling=off -unsharp 0.25x0.08+8.3+0.045 -interlace none -strip -set comment optimised -resize 2048x2048\> dslr_nikon_d7200_1.jpg
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 jpegoptim -p --max=82 dslr_nikon_d7200_1.jpg
    dslr_nikon_d7200_1.jpg 2048x1365 24bit N JFIF  [OK] 376994 --> 376881 bytes (0.03%), optimized.
    ### dslr_nikon_d7200_2.jpg (jpg) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp dslr_nikon_d7200_2.jpg -define jpeg:size=4096x4096 -filter triangle -define filter:support=2 -define jpeg:fancy-upsampling=off -unsharp 0.25x0.08+8.3+0.045 -interlace none -strip -set comment optimised -resize 2048x2048\> dslr_nikon_d7200_2.jpg
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 jpegoptim -p --max=82 dslr_nikon_d7200_2.jpg
    dslr_nikon_d7200_2.jpg 1365x2048 24bit N JFIF  [OK] 520648 --> 520648 bytes (0.00%), skipped.
    ### bees.png (png) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp bees.png -interlace none -set comment optimised -define png:compression-filter=5 -define png:compression-level=9 -define png:compression-strategy=2 -resize 2048x2048\> bees.png
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 optipng -o2 bees.png -preserve -out bees.png
    Output IDAT size = 175199 bytes (no change)
    Output file size = 175480 bytes (60 bytes = 0.03% decrease)
    ### webp-study-source-firebreathing.png (png) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp webp-study-source-firebreathing.png -interlace none -set comment optimised -define png:compression-filter=5 -define png:compression-level=9 -define png:compression-strategy=2 -resize 2048x2048\> webp-study-source-firebreathing.png
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 optipng -o2 webp-study-source-firebreathing.png -preserve -out webp-study-source-firebreathing.png
    Output IDAT size = 1194013 bytes (5679 bytes decrease)
    Output file size = 1194294 bytes (6111 bytes = 0.51% decrease)
    ### png24-image1.png (png) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp png24-image1.png -interlace none -set comment optimised -define png:compression-filter=5 -define png:compression-level=9 -define png:compression-strategy=2 -resize 2048x2048\> png24-image1.png
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 optipng -o2 png24-image1.png -preserve -out png24-image1.png
    Output IDAT size = 386006 bytes (no change)
    Output file size = 386287 bytes (132 bytes = 0.03% decrease)
    ### png24-interlaced-image1.png (png) ###
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 /usr/bin/convert -define registry:temporary-path=/home/imagicktmp png24-interlaced-image1.png -interlace plane -set comment optimised -define png:compression-filter=5 -define png:compression-level=9 -define png:compression-strategy=2 -resize 2048x2048\> png24-interlaced-image1.png
    /bin/nice -n 10 /usr/bin/ionice -c2 -n7 optipng -o2 png24-interlaced-image1.png -preserve -out png24-interlaced-image1.png
    Output IDAT size = 443874 bytes (2304 bytes decrease)
    Output file size = 444155 bytes (2460 bytes = 0.55% decrease)
    Completion Time: 22.58 seconds
    image profile
    logged at /home/optimise-logs/profile-log-050420-020515.log
    image : bees.png : 444 : 258 : 92 : False : 8 : 175480 : root : root
    image : dslr_canon_eos_m6_1.jpg : 1200 : 800 : 82 : False : 8 : 161388 : root : root
    image : dslr_nikon_d7200_1.jpg : 2048 : 1365 : 82 : False : 8 : 376881 : root : root
    image : dslr_nikon_d7200_2.jpg : 1365 : 2048 : 82 : False : 8 : 520648 : root : root
    image : png24-image1.png : 600 : 400 : 92 : False : 8 : 386287 : root : root
    image : png24-interlaced-image1.png : 600 : 400 : 92 : False : 8 : 444155 : root : root
    image : samsung_s7_mobile_1.jpg : 2048 : 1536 : 82 : False : 8 : 260142 : root : root
    image : webp-study-source-firebreathing.png : 1024 : 752 : 92 : False : 8 : 1194294 : root : root
    | 1166      | 945        | 87          | 439909     | 3519275            | 3437            |
    Resource limits:
      Width: 214.7MP
      Height: 214.7MP
      Area: 3.8543GP
      Memory: 1.79481GiB
      Map: 3.58962GiB
      Disk: unlimited
      File: 786432
      Thread: 2
      Throttle: 0
      Time: unlimited
    Completion Time: 0.59 seconds
  13. gabel
    gabel Member
    68
    38
    1:50 PM
    1.9.9
    MariaDB 10
    hey @eva2000 quick question, it still doesn't support subdirectories? Was using another tool but would like to use yours since I like your stuff but I have images split in directories/subdirectories so almost impossible doing them 1 by 1
    12,579
    10:50 PM
    Yeah it's still one directory at a time so no sub directory support. You can programmatically script it to so subdirectories as outlined at centminmod/optimise-images
    and also example with wordpress script for /upload directory and subdirectories centminmod/optimise-images
  15. omrtozd
    omrtozd New Member
    16
    7
    3:50 PM
    Is it possible to use this with Amazon S3? I have Amazon S3 plugin on my WordPress website, it stores the images on Amazon S3 and serves images with Cloudflare. I wonder if I can use optimise-images.sh with this setup.
    12,579
    10:50 PM
    Unfortunately not only local files not remote.
  17. Max
    Max Member
    130
    5
    1:50 PM
    Hello,
    how can i set the optimise-images.sh script to work very slowly?
    or is there a better free alternative to optimise-images.sh?
    Thank you
    12,579
    10:50 PM
    can you elaborate on what you want it to do?
  19. Max
    Max Member
    130
    5
    1:50 PM
    load average under 1
    even with skip already optimized load go over 1
    [09:09][root@host.mojobox.org ~]# /root/tools/optimise-images/optimise-images.sh optimise  /home/nginx/domains/mojobus.org/public/wp-content/uploads/
    logged at /home/optimise-logs/optimise-log-010224-091052.log
    ### lifepo4-batterie-fuer-wohnmobile.jpg (jpg) skip already optimised ###
    ### PXL_20230527_140333304-113x150.jpg (jpg) skip already optimised ###
    ### PXL_20230526_091618691-113x150.jpg (jpg) skip already optimised ###
    ### IMG_20230504_164316_480-113x150.jpg (jpg) skip already optimised ###
    ### nach-langer-zeit-wieder-richtung-sueden-3-113x150.jpg (jpg) skip already optimised ###
    ### 2023-05-11-16.22.36-113x150.jpg (jpg) skip already optimised ###
    ### PXL_20230521_101423140-113x150.jpg (jpg) skip already optimised ###
    ### PXL_20230521_101251729-113x150.jpg (jpg) skip already optimised ###
    ### 2023-04-24-14.11.31-113x150.jpg (jpg) skip already optimised ###
    ### signal-2023-04-30-173526-2-150x113.jpeg (jpeg) skip already optimised ###
    ### Tusky_1684233800374_NHY4OLW5ZE-113x150.jpg (jpg) skip already optimised ###
    ### Tusky_1684233571296_LEEC8LHDCZ-113x150.jpg (jpg) skip already optimised ###
    ### Tusky_1684225735351_WNUMU9XU6B-113x150.jpg (jpg) skip already optimised ###
    ### take-the-long-way-homelalalalalasupertramp-113x150.jpg (jpg) skip already optimised ###
    ### fantomas-in-canaveral-spanien-113x150.jpg (jpg) skip already optimised ###
    ### WomoMobil-Balu-Elektronik-Motor-Getriebe-Test-13.jpg (jpg) skip already optimised ###
    ### southern-road-113x150.jpg (jpg) skip already optimised ###
    ### 2023-southbound-road-trip-3-150x113.jpg (jpg) skip already optimised ###
    ### 2023-apr-22-south-4-113x150.jpg (jpg) skip already optimised ###
    ### 2023-south-trip-5-113x150.jpg (jpg) skip already optimised ###
    ### nach-langer-zeit-wieder-richtung-sueden-7-113x150.jpg (jpg) skip already optimised ###
    ### canaveral-spanische-pferde-entdeckt-150x43.jpg (jpg) skip already optimised ###
    ### signal-2023-04-30-173526-e1682869086281-150x46.jpeg (jpeg) skip already optimised ###
    ### IMG_20200627_103700_9-113x150.jpg (jpg) skip already optimised ###
    ### IMG_20200623_175230_3-113x150.jpg (jpg) skip already optimised ###
    ### IMG_20200619_162339_5-113x150.jpg (jpg) skip already optimised ###
    ### sunnenuntergang-mit-leon-7-150x150.jpg (jpg) skip already optimised ###
    ### sunnenuntergang-mit-leon-8-150x150.jpg (jpg) skip already optimised ###
    ### minimalistisch-im-van-unterwegs-oder-wie-man-auch-mit-weniger-kleidung-super-auskommt-150x100.jpg (jpg) skip already optimised ###
    ### IMG_20210116_113313_4-113x150.jpg (jpg) skip already optimised ###
    ### IMG_20210116_101143_3-150x113.jpg (jpg) skip already optimised ###
    ### IMG_20210115_170015_7-113x150.jpg (jpg) skip already optimised ###
    ^C
    12,579
    10:50 PM
    That's by design for fastest possible processing of image optimisations. How many CPU cores do you have available? If you have more than 1 CPU core, you can try using
    taskset to limit it to one specific CPU core Taskset: Linux Command Guide for CPU Affinity Mastery
    Or you can slow it down drammatically but would take forever to process the images if you have alot. On line 1448 of optimise-images.sh optimise-images/optimise-images.sh at master ยท centminmod/optimise-images you can insert a sleep command
    this is line 1447 and 1448
      find "$WORKDIR" -maxdepth ${MAXDEPTH}${FIND_IMGAGEOPT} \( -name '*.jpg' -o -name '*.png' -o -name '*.jpeg' \) | while read i; do
        file=$(basename "${i}")
    you'd add a 1 second sleep command
        sleep 1
    adjust the sleep value as needed so 0.5 is 1/2 a second, 1.5 is one and a half seconds etc.
