WebPerf Optimizing Image Sizes for faster page load times with optimise-images.sh
Discussion in 'Web Development & Web Performance' started by eva2000, Apr 29, 2017.
  1. kinhatula
    kinhatula New Member
    9
    7:50 PM
    sorry, can I ask you a question? where is add this code into file domain.com.ssl.conf or domain.com.conf ?
    location /webp {
    #pagespeed off;
    autoindex on;
    add_header X-Robots-Tag "noindex, nofollow";
    location ~* ^/webp/.+\.(png|jpe?g)$ {
    expires 30d;
    add_header Vary "Accept-Encoding";
    add_header Cache-Control "public, no-transform";
    try_files $uri$webp_extension $uri =404;
    12,579
    10:50 PM
  3. kinhatula
    9
    7:50 PM
    thanks eva2000
  4. dcg
    dcg Member
    68
    24
    Florida, USA
    8:50 AM
    1.21.x
    10.3.x
    FYI
    Mozjpeg needs a tar zxf after source download for installing.
    echo "installing mozjpeg"
      cd /usr/src
      wget https://github.com/mozilla/mozjpeg/releases/download/v3.2-pre/mozjpeg-3.2-release-source.tar.gz
    #need tar zxf of source to which extracts to mozjpeg
      cd mozjpeg
      ./configure
      make -s
      make -s install
      MOZJPEG_BIN='/opt/mozjpeg/bin/jpegtran'
      echo "installed mozjpeg"
    optimise-images/optimise-images.sh at master · centminmod/optimise-images · GitHub
    12,579
    10:50 PM
    thanks @dcg for the heads up :)
  6. Revenge
    Revenge Active Member
    469
    93
    Portugal
    1:50 PM
    1.9.x
    10.1.x
    12,579
    10:50 PM
  8. pamamolf
    4,128
    3:50 PM
    @Revenge
    Is this something you can enable at IPB or a plugin is needed ?
  9. pamamolf
    4,128
    3:50 PM
    @eva2000
    Need some help on this please :)
    I was check the documentation and i am ready to try it with my target to be:
    1)Run and optimize only jpg images with the option to do lossless optimization and then with the option at 90% to keep quality - (the files must keep the original names so they still working after optimization and no other files must be created)
    I think jpegoptim will be ok for my case.....
    2)
    Run and optimize only png images with the option to do lossless optimization and then with the option at 90% to keep quality - (the files must keep the original names so they still working after optimization and no other files must be created)
    I think optipng will be ok for my case.....
    Can you please help me on what i must edit to archive the above scenarios?
    Thank you
    12,579
    10:50 PM
    for GitHub - centminmod/optimise-images: Batch image resizer, optimiser and profiler using ImageMagick convert, OptiPNG, JpegOptim and optional ZopfliPNG, Guetzli and MozJPEG., best way to figure out what you need is practice on a test directory of a few images. If you don't have images to test, you can use benchmark-mode to test a preset number of images and just edit options and retest each time optimise-images/benchmark-mode.md at master · centminmod/optimise-images · GitHub
    the default options are explained and listed at GitHub - centminmod/optimise-images: Batch image resizer, optimiser and profiler using ImageMagick convert, OptiPNG, JpegOptim and optional ZopfliPNG, Guetzli and MozJPEG. pay attention to PNG image quality it's value doesn't mean some thing as JPG = PNG 92 = png:compression-level=9 and png:compression-strategy=2 so leave as is it isn't percentage value
    Also script itself has comments explaining options optimise-images/optimise-images.sh at master · centminmod/optimise-images · GitHub
    so if you only want to optimize without resizing at jpg = 90% then
    IMAGICK_RESIZE='n'
    IMAGICK_QUALITY='90'
    with resize for images only over 2048x2048
    IMAGICK_RESIZE='y'
    Also you may want to enable ADD_COMMENT='y' to skip previously optimised images optimise-images/skip-optimised-images-180817.md at master · centminmod/optimise-images · GitHub
  11. pamamolf
    4,128
    3:50 PM
    But that will offer Imagick optimization correct?
    Isn't better to use Jpegoptim? If yes how can i disable Imagick ?
    Thank you
    12,579
    10:50 PM
    Jpegoptim uses IMAGICK_QUALITY for quality value too as ImageMagick does resize and quality first and then passes it to Jpegoptim for further optimisation
    example for one image optimise-images/benchmark-mode.md at master · centminmod/optimise-images · GitHub
    ### dslr_canon_eos_77d_1.jpg (jpg) ###
    /usr/bin/convert -define registry:temporary-path=/home/imagicktmp dslr_canon_eos_77d_1.jpg -define jpeg:size=4096x4096 -filter Triangle -define filter:support=2 -define jpeg:fancy-upsampling=off -unsharp 0.25x0.08+8.3+0.045 -interlace none -strip -resize 2048x2048\> dslr_canon_eos_77d_1.jpg
    dslr_canon_eos_77d_1.jpg 2048x1365 24bit N JFIF  [OK] 388216 --> 388147 bytes (0.02%), optimized.
    Not much savings as you can probably just set JPEGOPTIM='n' and let ImageMagick do the optimisation
    difference in completion time in benchmark mode for JPEGOPTIM enabled (default) vs disabled
    default JPEGOPTIM='y'
    ./optimise-images.sh bench
    Benchmarked Completeion Time: 38.54 seconds
    disabled JPEGOPTIM='n'
    Benchmarked Completeion Time: 39.32 seconds
    taking into account variance between runs not much difference
    but JPEGOPTIM='y' needs to be enabled if you set no resize as that is what is used to optimise image - this would be a bug i should force JPEGOPTIM='y' when IMAGICK_RESIZE='n' is set
  13. Revenge
    469
    93
    Portugal
    1:50 PM
    1.9.x
    10.1.x
    Currently they gfycat is supported by default. You don't need to do nothing.
    Imgur they needed to remove the support for now.
    Im using a plugin where i can manually add more.
  14. pamamolf
    4,128
    3:50 PM
    For lossless can i use it as:
    12,579
    10:50 PM
    lossless != 100% quality for jpg at least close but not the same
    optimise-images.sh doesn't do lossless at the moment for JPG and PNG other than WebP conversions via IMAGICK_WEBPLOSSLESS='n' but loss WebP images can actually be larger than original JPG/PNG image it was converted from so lossless WebP is disabled by default.
    lossless for web based served graphics is useless and just wastes space and bandwidth. Visitors aren't going to notice a difference between 80-90% JPG or PNG optimised for the web versus lossless image.
  16. pamamolf
    4,128
    3:50 PM
    Is the "install" parameter the first one to use before i use the "optimise" parameter?
    12,579
    10:50 PM
    install is only if you want source compile ImageMagick7, guetzli, mozjpeg and butteraugli. ImageMagick7 is alot slower than ImageMagick6 so not needed.
  18. pamamolf
    4,128
    3:50 PM
    Ok all good ! :)
    The only one that the script needs is the working on sub directories .....the current solution is not the easier one.....
    Using optipng and jpegoptim i was able to archive that by:
    Can't be done something like this on the script so we will have it ready to optimize also sub directories?
    12,579
    10:50 PM
    actually pretty much similar but only way right now GitHub - centminmod/optimise-images: Batch image resizer, optimiser and profiler using ImageMagick convert, OptiPNG, JpegOptim and optional ZopfliPNG, Guetzli and MozJPEG.
  20. sannin
    sannin New Member
    14
    10:50 PM
    1.7.3
    MariaDB 10
    Hey thanx for this script!
    Many times i have seen people upload images with capitalized extension, for example "pic1.JPG" . You could use "-iname" in find command to include those images too.
