Master Branch add CLOUDFLARE_ZLIBRAUTOMAX='n' disable auto raise gzip compression b…
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jun 20, 2018.
    60,096
    12,585
    8:40 PM
    add CLOUDFLARE_ZLIBRAUTOMAX='n' disable auto raise gzip compression by default
    Add CLOUDFLARE_ZLIBRAUTOMAX='n' by default to disable the new change implemented at https://community.centminmod.com/threads/optimise-nginx-default-gzip-compression-level-when-cloudflare-zlib-used.14962/ by default unless folks want to enable it via persistent config file /etc/centminmod/custom_config.inc the variable, CLOUDFLARE_ZLIBRAUTOMAX='n' prior to recompiling nginx via centmin.sh menu option 4. This is because I realise some folks don't want to auto raise nginx gzip compression level to 9 out of box and prefer the old method which is what this change does by setting to CLOUDFLARE_ZLIBRAUTOMAX='n' by default
