Sysadmin OpenVZ 7 Kernel info
Discussion in 'System Administration' started by eva2000, Apr 30, 2019.
    44,742
    10,200
    3:17 PM
    @jcat you mentioned OpenVZ 7 kernel supports IPSET unlike OpenVZ 6 so wondering if you can provide some information for outputs for these commands
    echo "$(uname -r) ($(uname -r | awk -F. '{ printf("%d%03d%03d%03d\n", $1,$2,$3,$4); }'))"
    find /lib/modules/`uname -r` -name 'ipset'
    Example
    /lib/modules/3.10.0-957.10.1.el7.x86_64/kernel/net/netfilter/ipset
    2.6.32-042stab127.2 (2006032002)
    3.10.0-957.10.1.el7.x86_64 (3010000010)
    5.0.7-1.el7.elrepo.x86_64 (5000007000)
    With this info, will be adding proper IPSET detection support to Centmin Mod 123.09beta01 for OpenVZ7 systems like I already do for non-OpenVZ6 systems (KVM/XEN etc) :)
  2. jcat
    jcat Member
    130
    New Jersey
    1:17 AM
    Sorry, I need to fix my notifications, here is the info:
    # echo "$(uname -r) ($(uname -r | awk -F. '{ printf("%d%03d%03d%03d\n", $1,$2,$3,$4); }'))"
    3.10.0-862.20.2.vz7.73.29 (3010000020)
    In container:
    # find /lib/modules/`uname -r` -name 'ipset'
    find: '/lib/modules/3.10.0-862.20.2.vz7.73.29': No such file or directory
    # find -iname '*ipset*'
    ./var/lib/yum/yumdb/i/4dff69a3bc73f6e185c9da0de4b6733305f3af86-ipset-libs-6.38-3.el7_6-x86_64
    ./var/lib/yum/yumdb/i/a9b00ab0b2f59115bffebd10b9c2b454dacb46df-ipset-6.38-3.el7_6-x86_64
    ./usr/share/doc/ipset-6.38
    ./usr/share/doc/ipset-libs-6.38
    ./usr/share/man/man8/ipset.8.gz
    ./usr/include/linux/netfilter/ipset
    ./usr/src/kernels/3.10.0-957.5.1.el7.x86_64/include/config/net/ematch/ipset.h
    ./usr/src/kernels/3.10.0-957.5.1.el7.x86_64/include/uapi/linux/netfilter/ipset
    ./usr/src/kernels/3.10.0-957.5.1.el7.x86_64/include/linux/netfilter/ipset
    ./usr/src/kernels/3.10.0-957.5.1.el7.x86_64/net/netfilter/ipset
    ./usr/sbin/ipset
    ./usr/lib64/libipset.so.11.1.0
    on node:
    /lib/modules/3.10.0-862.20.2.vz7.73.29/kernel/net/netfilter/ipset
    If you want access to a vm, happy to provide one as well just toss me an ssh key :)
    44,742
    10,200
    3:17 PM
    Should be fine, I updated 123.09beta01 code to just use kernel version + /proc/user_beancounters file existence to determine if IPSET on OpenVZ7 is supported so should have CSF Firewall auto enabling IPSET support when OpenVZ 7 with 3.10 kernel is detected like Centmin Mod does for KVM/XEN and bare metal dedicated servers :)
  4. jcat
    jcat Member
    130
    New Jersey
    1:17 AM
    the ipset package isn't installed by default so may want to check for the package as well first otherwise csf will go capoot but can simply install with
    yum install ipset
    44,742
    10,200
    3:17 PM
    Ah yes !!!!
    edit: oh already has a check for that
            # openvz7's 3.10 linux kernels support IPSET
            if [[ ! -f /usr/sbin/ipset ]]; then
                # CSF now has ipset support to offload large IP address numbers
                # from iptables so uses less server resources to handle many IPs
                # does not work with OpenVZ VPS so only implement for non-OpenVZ
                yum -q -y install ipset ipset-devel
                sed -i 's/LF_IPSET = \"0\"/LF_IPSET = \"1\"/' /etc/csf/csf.conf
                setiplimits
            elif [[ -f /usr/sbin/ipset ]]; then
                setiplimits
            fi
    but adding one to installers too
  6. jcat
    jcat Member
    130
    New Jersey
    1:17 AM
    Of course you do, ya damn magician :)
    44,742
    10,200
    3:17 PM
    I swear probably 30-50% of centmin mod's code is just extra logic to make things smarter than plain bash script :D
