[Solved] Nginx On a upgrade nginx with kernel 5.2 aio appears twice
Discussion in 'Bug Reports' started by EckyBrazzz, Sep 13, 2019.
    190
    11:34 AM
    Hi there,
    Just upgraded (recompiled) nginx and php but my nginx was offline
    sendfile off;
    aio on;
    aio on;
    As far as I know, send file should be on and, yes aio on; should only appear once:D
    My /etc/centminmod/custom_config.inc has
    NGINX_IOURING_PATCH='y
    55,811
    12,272
    12:34 AM
    55,811
    12,272
    12:34 AM
    sendfile should be off if NGINX_IOURING_PATCH='y' is set
    you can delete the log you uploaded now, got your email
    just updated 123.09beta01 with a possible fix for duplicate aio on directives
