OVH nvm disk problem
Discussion in 'Dedicated server hosting' started by hardousse, Dec 4, 2020.
  1. hardousse
    hardousse Active Member
    165
    35
    Sweden
    7:41 PM
    1.11.*
    10.1*
    Hi
    First time I order dedicted from ovh
    Rise-LE-5 Cyber Monday
    • Intel Xeon E3-1230v6 - 4 c/8 t
      3.50GHz/3.90GHz
    • 2 x 450GB NVMe softRAID SSD
    • 16GB DDR4 ECC 2,400 MHz
    • 500Mbit/s bandwidth
    But when I check name disk I get this
    power_cycles : 50
    power_on_hours : 12,755
    other disk
    power_cycles : 49
    power_on_hours : 8,602
    its new server it's normal get old disk?
    Anyone had situation like this
    48,902
    11,190
    2:41 AM
  3. hardousse
    165
    35
    Sweden
    7:41 PM
    1.11.*
    10.1*
    "Devices" : [
          "DevicePath" : "/dev/nvme0n1",
          "Firmware" : "MDV10290",
          "Index" : 0,
          "ModelNumber" : "INTEL SSDPE2MX450G7",
          "ProductName" : "NULL",
          "SerialNumber" : "BTPF82540017450RGN",
          "UsedBytes" : 450098159616,
          "MaximumLBA" : 879097968,
          "PhysicalSize" : 450098159616,
          "SectorSize" : 512
          "DevicePath" : "/dev/nvme1n1",
          "Index" : 1,
          "SerialNumber" : "BTPF825500CK450RGN",
          "SectorSize" : 512
    critical_warning                    : 0
    temperature                         : 20 C
    available_spare                     : 98%
    available_spare_threshold           : 10%
    percentage_used                     : 0%
    data_units_read                     : 9,638,325
    data_units_written                  : 10,376,704
    host_read_commands                  : 100,376,656
    host_write_commands                 : 164,921,046
    controller_busy_time                : 0
    power_cycles                        : 50
    power_on_hours                      : 12,768
    unsafe_shutdowns                    : 1
    media_errors                        : 0
    num_err_log_entries                 : 0
    Warning Temperature Time            : 0
    Critical Composite Temperature Time : 0
    Thermal Management T1 Trans Count   : 0
    Thermal Management T2 Trans Count   : 0
    Thermal Management T1 Total Time    : 0
    Thermal Management T2 Total Time    : 0
  4. hardousse
    165
    35
    Sweden
    7:41 PM
    1.11.*
    10.1*
    Any idea why is so much hours in new server ?
    48,902
    11,190
    2:41 AM
    Yeah as expected very little writes in bytes but hours on is expected as the drive model is Intel P3520 NVMe which is 2016 model IntelĀ® SSD DC P3520 Series (450GB, 2.5in PCIe 3.0 x4, 3D1, MLC) Product Specifications so OVH probably buy drives in very large bulk orders. The servers might have been just online for standby for their guaranteed 120s deployment from orders etc. You don't expect OVH to actually build the server at time of order and guaranteed it to be available within 120 seconds? :)
    There's only 50 power cycles too :)
  6. hardousse
    165
    35
    Sweden
    7:41 PM
    1.11.*
    10.1*
    Thank you for information.
    Best ragards:)
    48,902
    11,190
    2:41 AM
    Also note Intel P3520 is MLC nand based so more durable and than newer TLC nand.
