MariaDB not starting because of tmpdir
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by R0rke, Nov 13, 2017.
  1. R0rke
    R0rke Member
    163
    20
    Iran
    8:36 PM
    1.11.1
    10.1
    PHP:
    -- Unit mariadb.service has begun starting up.
    Nov 12 23:09:30 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:30 140638684657920 [Note] /usr/sbin/mysqld (mysqld 10.1.28-MariaDBstarting as process 12
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBUsing mutexes to ref count buffer pool pages
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBThe InnoDB memory heap is disabled
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBMutexes and rw_locks use GCC atomic builtins
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBGCC builtin __atomic_thread_fence() is used for memory b
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBCompressed tables use zlib 1.2.7
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBUsing Linux native AIO
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [NoteInnoDBUsing SSE crc32 instructions
    Nov 12 23
    :09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [ERRORmysqldCan't create/write to file '/home/mysqltmp/ib9JGmz7' (E
    Nov 12 23:09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 7fe8fed73900  InnoDB: Error: unable to create temporary file; errno: 13
    Nov 12 23:09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [ERROR] Plugin '
    InnoDB' init function returned error.
    InnoDB' registration as a STORAGE ENGINE failed.
    Nov 12 23:09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [Note] Plugin '
    FEEDBACK' is disabled.
    Nov 12 23:09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [ERROR] Unknown/unsupported storage engine: InnoDB
    Nov 12 23:09:31 SomEhOst.co mysqld[12418]: 2017-11-12 23:09:31 140638684657920 [ERROR] Aborting
    Nov 12 23:09:31 SomEhOst.co polkitd[640]: Unregistered Authentication Agent for unix-process:12163:1105571 (system bus name :1.184, object path /org/f
    Nov 12 23:09:31 SomEhOst.co systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
    Nov 12 23:09:31 SomEhOst.co systemd[1]: Failed to start MariaDB database server.
    just a fresh install for client .
    i just use this command : chown -R mysql:mysql mysqltmp + chmod 0777 mysqltmp
    45,681
    10,372
    2:36 PM
  3. R0rke
    R0rke Member
    163
    20
    Iran
    8:36 PM
    1.11.1
    10.1
    you are my hero . fixed ;)
    i think MariaDB must fix this bug ?
