MariaDB not running
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by hitman, Jan 29, 2015.
  1. hitman
    hitman Member
    126
    11
    6:46 AM
    hello
    i installed centmin on a new vps
    my problem is that if i run in ssh "mysql" or "mysqladmin"
    i get --command not found--
    and if i try to update mariaDB i get
    file: file://///etc/yum.repos.d/centalt.repo, line 1
    'exclude=mariadb*\n'
    55,424
    12,257
    1:46 PM
    which version of centmin mod and where did you download it from ? from centminmod.com or from github.com ?
    reason is centalt.repo should now be disabled by default on .07 stable and .08 betas as centalt is no longer in use as the repo is broken so the file shouldn't exist
    if it doesn't it probably prevented MariaDB from installing, so best to do a fresh CentOS OS reload, and install again :)
  3. hitman
    hitman Member
    126
    11
    6:46 AM
    i installed through centminmod.com
    yum -y install bc wget unzip nano yum-plugin-fastestmirror
    cd /usr/local/src
    wget http://centminmod.com/download/centmin-v1.2.3-eva2000.07.zip
    edit
    i reinstalled OS and centmin
    at the end of centmin isntallation i get
    inc/mysqlsecure.inc: line 7: mysql: command not found
    inc/mysqlsecure.inc: line 8: mysql: command not found
    inc/mysqlsecure.inc: line 9: mysql: command not found
    inc/mysqlsecure.inc: line 10: mysql: command not found
  4. hitman
    hitman Member
    126
    11
    6:46 AM
    additional to the above
    at the end of installation it says that
    mysql root user password set
    etc
    *MariaDB security setup completed[
    but when i try to run "mysql" or "mysqladmin" i get --command not found--
    55,424
    12,257
    1:46 PM
  6. hitman
    hitman Member
    126
    11
    6:46 AM
    55,424
    12,257
    1:46 PM
    EPEL yum repository failed to download/install which prevented MariaDB's YUM repo further down the track from installing too
    [1;32;40m* CentOS 6.x detected installing EPEL Repo
    (B[m*************************************************
    Error: epel-release-6-8.noarch.rpm not found !!! Download now......
    2015-01-29 04:34:20 URL:http://mirror.sfo12.us.leaseweb.net/epel/6/i386/epel-release-6-8.noarch.rpm [14540/14540] -> "epel-release-6-8.noarch.rpm" [1]
    [1;33;40mDownload done.
    (B[mError: Cannot retrieve metalink for repository: epel. Please verify its path and try again
    [1;32;40mError: problem with epel-release-6-8.noarch.rpm install.
    (B[m
    MariaDB 5.5 YUM install...
    yum -q -y --disableplugin=fastestmirror,downloadonly install MariaDB-client MariaDB-common MariaDB-compat MariaDB-devel MariaDB-server MariaDB-shared
    Error: Cannot retrieve repository metadata (repomd.xml) for repository: epel. Please verify its path and try again
    Centmin Mod .08 betas fixed the MariaDB failure by preventing EPEL's failure from affecting MariaDB install centminmod/mariadb_install.inc at 123.08centos7beta01 · centminmod/centminmod · GitHub but .07 stable doesn't have that work around.
    But still root problem is EPEL yum repo failed and that is relied upon by other installed software. So will need to investigate why, could be just the mirror that EPEL serves to you is down.
    btw who's the web host for server ?
  8. hitman
    hitman Member
    126
    11
    6:46 AM
    so if i reinstall OS and install EPEL Repository prior to centmin installation do you think i will not be having this problem?
    55,424
    12,257
    1:46 PM
  10. hitman
    hitman Member
    126
    11
    6:46 AM
    problem solved :D
    i also run this command so the repo will be added without https but with http
    sudo sed -i "s/mirrorlist=https/mirrorlist=http/" /etc/yum.repos.d/epel.repo
