Nginx PageSpeed No threading detected. Own threads: 1 Rewrite, 1 Expensive Rewrite.
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Jr Day, Feb 10, 2016.
  1. Jr Day
    Jr Day New Member
    7
    3:59 AM
    1.8.0
    I found errors in the log file:
    [ngx_pagespeed 1.9.32.2-4321] No threading detected. Own threads: 1 Rewrite, 1 Expensive Rewrite.
    Why is that?
    55,948
    5:59 AM
    they aren't errors just verbose info which was previously hidden and accidentally re-enabled in display
    1.9.32.2 is old now, you need to update to 1.9.32.13 for security and other bug fixes Nginx PageSpeed - ngx_pagespeed 1.9.32.13 beta security update ! | Centmin Mod Community :)
    I'd update your centmin mod base code too
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
  3. Jr Day
    Jr Day New Member
    7
    3:59 AM
    1.8.0
    Thank you very much!
