Upgrade Nginx no modules directory on fresh install centos7 64bit
Discussion in 'Install & Upgrades or Pre-Install Questions' started by BusyBee, Jul 3, 2017.
  1. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    Hi guys,
    do you have any experience like this on centos 7 fresh install - using stable script then upgrade to beta.
    i dont see any "modules" directory
    [23:14][[email protected] conf]# cd /usr/local/nginx
    [23:14][[email protected] nginx]# ls
    client_body_temp conf fastcgi_temp html logs scgi_temp uwsgi_temp
    • CentOS Version: i.e. CentOS7 64bit
    • Centmin Mod Version Installed: fresh install from 123.08 into 123.09beta01
    • Nginx Version Installed: 1.13.2
    • PHP Version Installed: 5.6.30
    • MariaDB MySQL Version Installed: 10.0.31
    • Host at Linode
    • Persistent Config: never use custom config - cat: /etc/centminmod/custom_config.inc: No such file or directory
    • When was last time updated Centmin Mod code base ? :
    1. fresh install using stable then upgrade to beta
    2. upgrade nginx show error
    make[1]: Leaving directory `/svr-setup/nginx-1.13.2'
    make: *** [build] Error 2
    real 0m4.074s
    user 0m1.307s
    sys 0m0.767s
    Sun Jul 2 22:53:11 UTC 2017
    Error: 2, Nginx make failed
    report errors on the forums at community.centminmod.com/forums/8/
    total used free shared buff/cache available
    Mem: 3948 174 2183 21 1590 3455
    Swap: 255 0 255
    CPU: Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz (2)
    version increment history
    1.2.3-eva2000.09.005 #Sun Jul 2 22:14:07 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul 2 22:15:03 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul 2 22:47:48 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul 2 22:48:04 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul 2 22:52:39 UTC 2017
    last Centmin Mod local git commit entry
    /usr/local/src/centminmod /svr-setup/nginx-1.13.2
    [23:14][[email protected] nginx]# nginx -t
    nginx: [emerg] dlopen() "/usr/local/nginx/modules/ngx_http_image_filter_module.so" failed (/usr/local/nginx/modules/ngx_http_image_filter_module.so: cannot open shared object file: No such file or directory) in /usr/local/nginx/conf/dynamic-modules.conf:4
    regards,
    busybee
    38,019
    8,348
    10:34 AM
    For posting code you might want to use CODE tags for code How to use forum BBCODE code tags :)
    Make sure after switch to centmin mod 123.09beta01, then you exit centmin.sh menu and re-run centmin.sh menu option 4 to recompile nginx as updated code doesn't register until next centmin.sh run
    To troubleshoot, you need to check the the nginx upgrade log at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the nginx_upgrade.log log. You can see full details at How to troubleshoot Centmin Mod initial install issues
    also what's output of
    nginx -t
    when you run centmin.sh menu option 4 there's a nginx upgrade log timestamped at /root/centminlogs
    if you type this command it lists all logs in date ascending order so latest log at bottom
    ls -lArt /root/centminlogs
    so copy the entire contents of latest nginx_upgrade log to gist.github.com or pastebin.com
    you can use grep to filter the logs, i.e. look for nginx_upgrade in log name
    ls -lahrt /root/centminlogs/ | grep nginx_upgrade
    -rw-r--r--  1 root root 3.2M Oct 11 15:55 centminmod_1.2.3-eva2000.09.001_111016-155345_nginx_upgrade.log
    -rw-r--r--  1 root root 672K Oct 11 22:06 centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    So the last nginx upgrade log was named centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log and located at /root/centminlogs/centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    then use cat command to output the contents of that log
    cat /root/centminlogs/centminmod_1.2.3-eva2000.09.001_111016-220515_nginx_upgrade.log
    then select and copy and paste output to pastebin.com or gist.github.com file to share. If your SSH client's scroll buffer isn't large enough using cat might not output the entire log file contents, so you may need to download the log and use local text editor to open and copy and paste.
    so only need content of one specific log, in this case most recent nginx_upgrade.log log
  3. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    LOL, sure george, im an old IRC lovers, its been a while using forum software again lots changes and new features...
    Let me read your complete explanation, its gonna take a while.
    cheers,
    busybee
  4. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    this is the output (finger cross using BBcode) :)
    nginx -t
    Do you want to run YUM install checks ?  [y/n]
    This will increase your upgrade duration time wise.
    Check the change log centminmod.com/changelog.html
    to see if any Nginx or PHP related new additions
    which require checking YUM prequisites are met.
    If no new additions made, you can skip the
    YUM install check to speed up upgrade time.
     [y/n]: **********************************************************************
    * Nginx Update script - Included in Centmin Extras
    * Version: 1.2.3-eva2000.09.005 - Date: 31/05/2017 - Copyright 2011-2017 CentminMod.com
    This software comes with no warranty of any kind. You are free to use
    it for both personal and commercial use as licensed under the GPL.
    Nginx Upgrade - Would you like to continue? [y/n] y
    Install which version of Nginx? (version i.e. type 1.13.2): 1.13.2
                _   _         _                   _           _
               | \ | |  __ _ (_) _ __  __  __    / \   _   _ | |_  ___
               |  \| | / _` || || '_ \ \ \/ /   / _ \ | | | || __|/ _ \
               | |\  || (_| || || | | | >  <   / ___ \| |_| || |_| (_) |
               |_| \_| \__, ||_||_| |_|/_/\_\ /_/   \_\\__,_| \__|\___/
                       |___/
            ____                _                     ____                __
           | __ )   __ _   ___ | | __ _   _  _ __    / ___| ___   _ __   / _|
           |  _ \  / _` | / __|| |/ /| | | || '_ \  | |    / _ \ | '_ \ | |_
           | |_) || (_| || (__ |   < | |_| || |_) | | |___| (_) || | | ||  _|
           |____/  \__,_| \___||_|\_\ \__,_|| .__/   \____|\___/ |_| |_||_|
                                            |_|
                ____   _                   _                _
               |  _ \ (_) _ __  ___   ___ | |_  ___   _ __ (_)  ___  ___
               | | | || || '__|/ _ \ / __|| __|/ _ \ | '__|| | / _ \/ __|
               | |_| || || |  |  __/| (__ | |_| (_) || |   | ||  __/\__ \
               |____/ |_||_|   \___| \___| \__|\___/ |_|   |_| \___||___/
    backup NGINX CONF...
    backup NGINX Install Directory /usr/local/nginx...
    backup of Nginx Install Directory /usr/local/nginx located at /usr/local/nginxbackup/nginxdirbackup/nginx_020717-225237
    backup of Nginx CONF located at /usr/local/nginxbackup/confbackup/conf_020717-225237
    total 264K
    -rw-r--r-- 1 root root 3.6K Jul  2 19:17 win-utf
    -rw-r--r-- 1 root root 2.2K Jul  2 19:17 koi-win
    -rw-r--r-- 1 root root 2.8K Jul  2 19:17 koi-utf
    -rw-r--r-- 1 root root 3.9K Jul  2 19:17 mime.types.default
    -rw-r--r-- 1 root root 3.9K Jul  2 19:17 mime.types.bak-020717-194125
    -rw-r--r-- 1 root root 1007 Jul  2 19:17 fastcgi_params.default
    -rw-r--r-- 1 root root 1.1K Jul  2 19:17 fastcgi.conf
    -rw-r--r-- 1 root root  664 Jul  2 19:17 uwsgi_params
    -rw-r--r-- 1 root root 1.1K Jul  2 19:17 fastcgi.conf.default
    -rw-r--r-- 1 root root  664 Jul  2 19:17 uwsgi_params.default
    -rw-r--r-- 1 root root  636 Jul  2 19:17 scgi_params.default
    -rw-r--r-- 1 root root 2.6K Jul  2 19:17 nginx.conf.default
    -rw-r--r-- 1 root root  888 Jul  2 19:17 wpffpc.conf
    -rw-r--r-- 1 root root  292 Jul  2 19:17 vts_mainserver.conf
    -rw-r--r-- 1 root root 1.3K Jul  2 19:17 staticfiles.conf
    -rw-r--r-- 1 root root  110 Jul  2 19:17 ssl-include.conf
    -rw-r--r-- 1 root root 2.4K Jul  2 19:17 pscontrol
    -rw-r--r-- 1 root root  884 Jul  2 19:17 proxy.conf
    -rw-r--r-- 1 root root  362 Jul  2 19:17 phpstatus.conf
    -rw-r--r-- 1 root root 2.4K Jul  2 19:17 phpssl.conf
    -rw-r--r-- 1 root root 3.3K Jul  2 19:17 php-pool5.conf
    -rw-r--r-- 1 root root 3.3K Jul  2 19:17 php-pool4.conf
    -rw-r--r-- 1 root root 3.3K Jul  2 19:17 php-pool3.conf
    -rw-r--r-- 1 root root 3.3K Jul  2 19:17 php-pool2.conf
    drwxr-xr-x 2 root root 4.0K Jul  2 19:17 phpfpmd
    -rw-r--r-- 1 root root 2.6K Jul  2 19:17 phpalt.conf
    -rw-r--r-- 1 root root 5.7K Jul  2 19:17 pagespeed.conf
    -rw-r--r-- 1 root root 1.5K Jul  2 19:17 pagespeedadmin.conf
    -rw-r--r-- 1 root root  283 Jul  2 19:17 geoip.conf
    -rw-r--r-- 1 root root 1.3K Jul  2 19:17 fastcgi_params
    -rw-r--r-- 1 root root  140 Jul  2 19:17 fastcgi_param_https_map.conf
    -rw-r--r-- 1 root root 1.2K Jul  2 19:17 errorpage.conf
    -rw-r--r-- 1 root root  496 Jul  2 19:17 drop.conf
    -rw-r--r-- 1 root root 4.4K Jul  2 19:17 block.conf
    -rw-r--r-- 1 root root 4.0K Jul  2 19:17 htpasswd.py
    -rw-r--r-- 1 root root    0 Jul  2 19:17 htpasswd
    -rw-r--r-- 1 root root   10 Jul  2 19:42 sitestatus.conf
    -rw-r--r-- 1 root root  645 Jul  2 19:42 maintenance.conf
    -rw-r--r-- 1 root root   37 Jul  2 19:42 503include-only.conf
    -rw-r--r-- 1 root root  362 Jul  2 19:42 503include-main.conf
    -rw-r--r-- 1 root root 4.1K Jul  2 19:44 mime.types
    -rw-r--r-- 1 root root  107 Jul  2 19:51 ssl_include.conf
    -rw-r--r-- 1 root root    0 Jul  2 19:52 pre-staticfiles-local-techieguide.net.conf
    -rw-r--r-- 1 root root   60 Jul  2 20:27 htpasswd_opcache
    -rw-r--r-- 1 root root  212 Jul  2 20:27 include_opcache.conf
    -rw-r--r-- 1 root root    0 Jul  2 20:27 pre-staticfiles-local-forum.thecus.com.conf
    -rw-r--r-- 1 root root 3.3K Jul  2 20:37 php.conf-oldversion_020717-202425
    -rw-r--r-- 1 root root   27 Jul  2 20:40 vts_http.conf
    -rw-r--r-- 1 root root   25 Jul  2 20:40 vts_server.conf
    -rw-r--r-- 1 root root  131 Jul  2 20:40 pagespeedstatslog.conf
    -rw-r--r-- 1 root root    0 Jul  2 20:41 dynamic-modules-includes.conf
    -rw-r--r-- 1 root root    0 Jul  2 21:01 pre-staticfiles-local-thechefandme.net.conf
    drwxr-x--- 3 root root 4.0K Jul  2 21:06 wpincludes
    -rw-r--r-- 1 root root 3.3K Jul  2 21:06 php-wpsc.conf
    -rw-r--r-- 1 root root  624 Jul  2 21:06 wpcacheenabler_map.conf
    -rw-r--r-- 1 root root 3.8K Jul  2 21:06 php-rediscache.conf
    -rw-r--r-- 1 root root 3.8K Jul  2 21:06 php-rediscache-shortttl.conf
    drwxr-xr-x 6 root root 4.0K Jul  2 21:06 ssl
    -rw-r--r-- 1 root root    0 Jul  2 21:07 pre-staticfiles-local-techandmi.com.conf
    -rw-r--r-- 1 root root    0 Jul  2 21:07 pre-staticfiles-global.conf
    -rw-r--r-- 1 root root 1.1K Jul  2 21:07 redisupstream.conf
    drwxr-xr-x 7 root root 4.0K Jul  2 21:08 autoprotect
    -rw-r--r-- 1 root root  669 Jul  2 22:50 pagespeedhandler.conf
    -rw-r--r-- 1 root root 3.7K Jul  2 22:50 nginx.conf
    drwxr-xr-x 2 root root 4.0K Jul  2 22:50 conf.d
    -rw-r--r-- 1 root root  363 Jul  2 22:52 dynamic-modules.conf
    -rwxr-xr-x 1 root root 1.5K Jul  2 22:52 htpasswd.sh
    * ngx_pagespeed parity update tasks
    ls: cannot access /usr/local/nginx/modules: No such file or directory
    * Updating nginx
    Installing nginx Modules / Prerequisites...
              ____  _                  _      _   _         _
             / ___|| |__    ___   ___ | | __ | \ | |  __ _ (_) _ __  __  __
            | |    | '_ \  / _ \ / __|| |/ / |  \| | / _` || || '_ \ \ \/ /
            | |___ | | | ||  __/| (__ |   <  | |\  || (_| || || | | | >  <
             \____||_| |_| \___| \___||_|\_\ |_| \_| \__, ||_||_| |_|/_/\_\
                                                     |___/
                       __  __             _         _
                      |  \/  |  ___    __| | _   _ | |  ___  ___
                      | |\/| | / _ \  / _` || | | || | / _ \/ __|
                      | |  | || (_) || (_| || |_| || ||  __/\__ \
                      |_|  |_| \___/  \__,_| \__,_||_| \___||___/
    NGX_DYNAMICCHECK nginx_upgrade.inc
    /svr-setup
    nginx dynamic module support detected
    Check for old ngx_pagespeed master branch existence
    Check for missing nginx modules
    Download ngx-fancyindex-0.4.0.tar.gz ...
    ngx-fancyindex 0.4.0 Archive found, skipping download...
    ngx-fancyindex-0.4.0.tar.gz valid file.
    --2017-07-02 22:52:48--  https://centminmod.com/centminmodparts/nginx/modules/ngx-fancyindex-0.4.0.tar.gz
    Resolving centminmod.com... 139.162.29.188
    Connecting to centminmod.com|139.162.29.188|:443... connected.
    Length: 18419 (18K) [application/octet-stream]
    Saving to: ‘ngx-fancyindex-0.4.0.tar.gz’
         0K .......... .......                                    100% 95.8M=0s
    2017-07-02 22:52:48 (95.8 MB/s) - ‘ngx-fancyindex-0.4.0.tar.gz’ saved [18419/18419]
    Download done.
    Download ngx_cache_purge-2.3.tar.gz ...
    ngx_cache_purge 2.3 Archive found, skipping download...
    ngx_cache_purge-2.3.tar.gz valid file.
    Download Nginx-accesskey-2.0.3.tar.gz ...
    Nginx-accesskey 2.0.3 Archive found, skipping download...
    Nginx-accesskey-2.0.3.tar.gz valid file.
    Download nginx-http-concat-master.tar.gz ...
    nginx-http-concat-master.tar.gz Archive found, skipping download...
    nginx-http-concat-master.tar.gz valid file.
    Download headers-more-v0.32.tar.gz ...
    headers-more-v0.32.tar.gz Archive found, skipping download...
    headers-more-v0.32.tar.gz valid file.
    Download nginx-sticky-master.tar.gz ...
    nginx-sticky-master.tar.gz Archive found, skipping download...
    nginx-sticky-master.tar.gz valid file.
    mv: cannot move ‘nginx-goodies-nginx-sticky-module-ng-08a395c66e42’ to ‘nginx-sticky-module-master/nginx-goodies-nginx-sticky-module-ng-08a395c66e42’: Directory not empty
    Download nginx-upstream-check-0.3.0.tar.gz ...
    nginx-upstream-check-0.3.0.tar.gz Archive found, skipping download...
    nginx-upstream-check-0.3.0.tar.gz valid file.
    Download ngx_http_redis-0.3.7.tar.gz ...
    ngx_http_redis Archive found, skipping download...
    ngx_http_redis-0.3.7.tar.gz valid file.
    Download pcre-8.40.tar.gz ...
    pcre-8.40.tar.gz Archive found, skipping download...
    pcre-8.40.tar.gz valid file.
    Download nginx-dav-ext-module-0.0.3.tar.gz ...
    nginx-dav-ext-module-0.0.3.tar.gz Archive found, skipping download...
    nginx-dav-ext-module-0.0.3.tar.gz valid file.
    Check for pagespeed nginx module download file
    Check for pagespeed PSOL library
    Check for gperf tools + libunwind download files
    Check for openresty modules
                   ____                          _  _  _
                  / ___| ___   _ __ ___   _ __  (_)| |(_) _ __    __ _
                 | |    / _ \ | '_ ` _ \ | '_ \ | || || || '_ \  / _` |
                 | |___| (_) || | | | | || |_) || || || || | | || (_| |
                  \____|\___/ |_| |_| |_|| .__/ |_||_||_||_| |_| \__, |
                                         |_|                     |___/
                     _      _  _                 ____  ____   _
                    | |    (_)| |__   _ __  ___ / ___|/ ___| | |
                    | |    | || '_ \ | '__|/ _ \\___ \\___ \ | |
                    | |___ | || |_) || |  |  __/ ___) |___) || |___
                    |_____||_||_.__/ |_|   \___||____/|____/ |_____|
    Compiling LibreSSL...
    CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /svr-setup/libressl-2.5.4/missing aclocal-1.15 -I m4
    /svr-setup/libressl-2.5.4/missing: line 81: aclocal-1.15: command not found
    WARNING: 'aclocal-1.15' is missing on your system.
             You should only need it if you modified 'acinclude.m4' or
             'configure.ac' or m4 files included by 'configure.ac'.
             The 'aclocal' program is part of the GNU Automake package:
             <http://www.gnu.org/software/automake>
             It also requires GNU Autoconf, GNU m4 and Perl in order to run:
             <http://www.gnu.org/software/autoconf>
             <http://www.gnu.org/software/m4/>
             <http://www.perl.org/>
    make: *** [aclocal.m4] Error 127
    checking build system type... x86_64-pc-linux-gnu
    checking host system type... x86_64-pc-linux-gnu
    checking for a BSD-compatible install... /bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether make supports nested variables... yes
    checking whether make supports nested variables... (cached) yes
    checking for gcc... ccache /usr/bin/clang -ferror-limit=0
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether ccache /usr/bin/clang -ferror-limit=0 accepts -g... yes
    checking for ccache /usr/bin/clang -ferror-limit=0 option to accept ISO C89... none needed
    checking whether ccache /usr/bin/clang -ferror-limit=0 understands -c and -o together... yes
    checking for style of include used by make... GNU
    checking dependency style of ccache /usr/bin/clang -ferror-limit=0... gcc3
    checking for ccache /usr/bin/clang -ferror-limit=0 option to accept ISO C99... none needed
    checking for ccache /usr/bin/clang -ferror-limit=0 option to accept ISO Standard C... (cached) none needed
    checking how to print strings... printf
    checking for fgrep... /bin/grep -F
    checking for ld used by ccache /usr/bin/clang -ferror-limit=0... /usr/bin/ld
    checking if the linker (/usr/bin/ld) is GNU ld... yes
    checking for BSD- or MS-compatible name lister (nm)... /bin/nm -B
    checking the name lister (/bin/nm -B) interface... BSD nm
    checking whether ln -s works... yes
    checking the maximum length of command line arguments... 1572864
    checking whether the shell understands some XSI constructs... yes
    checking whether the shell understands "+="... yes
    checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
    checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
    checking for /usr/bin/ld option to reload object files... -r
    checking for objdump... objdump
    checking how to recognize dependent libraries... pass_all
    checking for dlltool... no
    checking how to associate runtime and link libraries... printf %s\n
    checking for ar... ar
    checking for archiver @FILE support... @
    checking for strip... strip
    checking for ranlib... ranlib
    checking command to parse /bin/nm -B output from ccache /usr/bin/clang -ferror-limit=0 object... ok
    checking for sysroot... no
    checking for mt... no
    checking if : is a manifest tool... no
    checking how to run the C preprocessor... ccache /usr/bin/clang -ferror-limit=0 -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking for dlfcn.h... yes
    checking for objdir... .libs
    checking if ccache /usr/bin/clang -ferror-limit=0 supports -fno-rtti -fno-exceptions... yes
    checking for ccache /usr/bin/clang -ferror-limit=0 option to produce PIC... -fPIC -DPIC
    checking if ccache /usr/bin/clang -ferror-limit=0 PIC flag -fPIC -DPIC works... yes
    checking if ccache /usr/bin/clang -ferror-limit=0 static flag -static works... no
    checking if ccache /usr/bin/clang -ferror-limit=0 supports -c -o file.o... yes
    checking if ccache /usr/bin/clang -ferror-limit=0 supports -c -o file.o... (cached) yes
    checking whether the ccache /usr/bin/clang -ferror-limit=0 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
    checking whether -lc should be explicitly linked in... no
    checking dynamic linker characteristics... GNU/Linux ld.so
    checking how to hardcode library paths into programs... immediate
    checking whether stripping libraries is possible... yes
    checking if libtool supports shared libraries... yes
    checking whether to build shared libraries... yes
    checking whether to build static libraries... yes
    checking if ccache /usr/bin/clang -ferror-limit=0 supports "-fno-strict-overflow"... yes
    checking if ccache /usr/bin/clang -ferror-limit=0 supports "-D_FORTIFY_SOURCE=2"... no
    checking if /usr/bin/ld -m elf_x86_64 supports "-Wl,-z,relro"... yes
    checking if /usr/bin/ld -m elf_x86_64 supports "-Wl,-z,now"... yes
    checking if ccache /usr/bin/clang -ferror-limit=0 supports "-fstack-protector-strong"... no
    checking if ccache /usr/bin/clang -ferror-limit=0 supports "-fstack-protector-all"... yes
    checking whether AS supports .note.GNU-stack... yes
    checking if compiling with clang... yes
    checking whether CC supports -Wno-pointer-sign... yes
    checking for symlink... yes
    checking for funopen... no
    checking err.h usability... yes
    checking err.h presence... yes
    checking for err.h... yes
    checking readpassphrase.h usability... no
    checking readpassphrase.h presence... no
    checking for readpassphrase.h... no
    checking for asprintf... yes
    checking for getpagesize... yes
    checking for inet_ntop... yes
    checking for inet_pton... yes
    checking for memmem... yes
    checking for readpassphrase... no
    checking for reallocarray... no
    checking for recallocarray... no
    checking for strlcat... no
    checking for strlcpy... no
    checking for strndup... yes
    checking for strnlen... yes
    checking for strsep... yes
    checking for strtonum... no
    checking for timegm... yes
    checking for _mkgmtime... no
    checking for accept4... yes
    checking for pipe2... yes
    checking for pledge... no
    checking for poll... yes
    checking for socketpair... yes
    checking for arc4random... no
    checking for arc4random_buf... no
    checking for arc4random_uniform... no
    checking for explicit_bzero... no
    checking for getauxval... yes
    checking for getentropy... no
    checking for timingsafe_bcmp... no
    checking for timingsafe_memcmp... no
    checking for getauxval... (cached) yes
    checking for library containing clock_gettime... none required
    checking for clock_gettime... yes
    checking for library containing dl_iterate_phdr... none required
    checking for dl_iterate_phdr... yes
    checking whether va_copy exists... yes
    checking whether __va_copy exists... yes
    checking for library containing b64_ntop... no
    checking for library containing __b64_ntop... -lresolv
    checking for b64_ntop... yes
    generating ./crypto/crypto_portable.sym ...
    checking if BSWAP4 builds without __STRICT_ALIGNMENT... no
    checking if .gnu.warning accepts long strings... yes
    checking size of time_t... 8
    checking that generated files are newer than configure... done
    configure: creating ./config.status
    config.status: creating Makefile
    config.status: creating include/Makefile
    config.status: creating include/openssl/Makefile
    config.status: creating crypto/Makefile
    config.status: creating ssl/Makefile
    config.status: creating tls/Makefile
    config.status: creating tests/Makefile
    config.status: creating apps/Makefile
    config.status: creating apps/ocspcheck/Makefile
    config.status: creating apps/openssl/Makefile
    config.status: creating apps/nc/Makefile
    config.status: creating man/Makefile
    config.status: creating libcrypto.pc
    config.status: creating libssl.pc
    config.status: creating libtls.pc
    config.status: creating openssl.pc
    config.status: executing depfiles commands
    config.status: executing libtool commands
    ln: failed to create symbolic link ‘/etc/ssl/openssl.cnf’: File exists
    -rw-r--r-- 1 root root 44 Jul  2 22:52 /root/centminlogs/centminmod_libresslinstalltime_020717-225237.log
              _                 _  _  _     _              _          _  _
             | | _   _   __ _  (_)(_)| |_  (_) _ __   ___ | |_  __ _ | || |
             | || | | | / _` | | || || __| | || '_ \ / __|| __|/ _` || || |
             | || |_| || (_| | | || || |_  | || | | |\__ \| |_| (_| || || |
             |_| \__,_| \__,_|_/ ||_| \__| |_||_| |_||___/ \__|\__,_||_||_|
                             |__/
    ngx-fancyindex 0.3.1 Archive found, skipping download...
    ngx-fancyindex-ngx-fancyindex/
    ngx-fancyindex-ngx-fancyindex/.gitignore
    ngx-fancyindex-ngx-fancyindex/.todo
    ngx-fancyindex-ngx-fancyindex/HACKING.rst
    ngx-fancyindex-ngx-fancyindex/LICENSE
    ngx-fancyindex-ngx-fancyindex/README.rst
    ngx-fancyindex-ngx-fancyindex/config
    ngx-fancyindex-ngx-fancyindex/nginx-0.6-support.patch
    ngx-fancyindex-ngx-fancyindex/ngx_http_fancyindex_module.c
    ngx-fancyindex-ngx-fancyindex/template.awk
    ngx-fancyindex-ngx-fancyindex/template.h
    ngx-fancyindex-ngx-fancyindex/template.html
    ngx_cache_purge 2.1 Archive found, skipping download...
    ngx_cache_purge-2.3/
    ngx_cache_purge-2.3/CHANGES
    ngx_cache_purge-2.3/config
    ngx_cache_purge-2.3/LICENSE
    ngx_cache_purge-2.3/ngx_cache_purge_module.c
    ngx_cache_purge-2.3/README.md
    ngx_cache_purge-2.3/t/
    ngx_cache_purge-2.3/TODO.md
    ngx_cache_purge-2.3/t/proxy1.t
    ngx_cache_purge-2.3/t/proxy1_vars.t
    ngx_cache_purge-2.3/t/proxy2.t
    ngx_cache_purge-2.3/t/proxy2_vars.t
    nginx-accesskey-2.0.3/
    nginx-accesskey-2.0.3/config
    nginx-accesskey-2.0.3/ngx_http_accesskey_module.c
    grep: /svr-setup/nginx-1.13.2/auto/modules: No such file or directory
         ____                          _  _         _   _         _
        / ___| ___   _ __ ___   _ __  (_)| |  ___  | \ | |  __ _ (_) _ __  __  __
       | |    / _ \ | '_ ` _ \ | '_ \ | || | / _ \ |  \| | / _` || || '_ \ \ \/ /
       | |___| (_) || | | | | || |_) || || ||  __/ | |\  || (_| || || | | | >  <
        \____|\___/ |_| |_| |_|| .__/ |_||_| \___| |_| \_| \__, ||_||_| |_|/_/\_\
                               |_|                         |___/
    Compiling nginx...
    Initializing download: http://nginx.org/download/nginx-1.13.2.tar.gz
    File size: 985802 bytes
    Opening output file nginx-1.13.2.tar.gz
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [ 136.4KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 190.3KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 213.1KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 289.1KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 284.4KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 351.6KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 346.5KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [ 383.9KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [ 371.0KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [ 403.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [ 396.8KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [ 430.6KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [ 409.0KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [ 442.6KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [ 423.2KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [ 413.8KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [ 437.3KB/s]
    [ 88%]  .......
    Connection 1 finished
    Connection 3 finished
    Connection 0 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,... ..........  [ 422.8KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [ 335.7KB/s]
    [ 98%]  .......... ..
    Downloaded 962.7 Kilobyte in 3 seconds. (318.94 KB/s)
    nginx-1.13.2/
    nginx-1.13.2/auto/
    nginx-1.13.2/conf/
    nginx-1.13.2/contrib/
    nginx-1.13.2/src/
    nginx-1.13.2/configure
    nginx-1.13.2/LICENSE
    nginx-1.13.2/README
    nginx-1.13.2/html/
    nginx-1.13.2/man/
    nginx-1.13.2/CHANGES.ru
    nginx-1.13.2/man/nginx.8
    nginx-1.13.2/html/50x.html
    nginx-1.13.2/html/index.html
    nginx-1.13.2/src/core/
    nginx-1.13.2/src/event/
    nginx-1.13.2/src/http/
    nginx-1.13.2/src/mail/
    nginx-1.13.2/src/misc/
    nginx-1.13.2/src/os/
    nginx-1.13.2/src/stream/
    nginx-1.13.2/src/stream/ngx_stream_geo_module.c
    nginx-1.13.2/src/stream/ngx_stream.c
    nginx-1.13.2/src/stream/ngx_stream.h
    nginx-1.13.2/src/stream/ngx_stream_limit_conn_module.c
    nginx-1.13.2/src/stream/ngx_stream_access_module.c
    nginx-1.13.2/src/stream/ngx_stream_core_module.c
    nginx-1.13.2/src/stream/ngx_stream_geoip_module.c
    nginx-1.13.2/src/stream/ngx_stream_handler.c
    nginx-1.13.2/src/stream/ngx_stream_proxy_module.c
    nginx-1.13.2/src/stream/ngx_stream_log_module.c
    nginx-1.13.2/src/stream/ngx_stream_map_module.c
    nginx-1.13.2/src/stream/ngx_stream_split_clients_module.c
    nginx-1.13.2/src/stream/ngx_stream_realip_module.c
    nginx-1.13.2/src/stream/ngx_stream_return_module.c
    nginx-1.13.2/src/stream/ngx_stream_script.c
    nginx-1.13.2/src/stream/ngx_stream_script.h
    nginx-1.13.2/src/stream/ngx_stream_ssl_preread_module.c
    nginx-1.13.2/src/stream/ngx_stream_ssl_module.c
    nginx-1.13.2/src/stream/ngx_stream_ssl_module.h
    nginx-1.13.2/src/stream/ngx_stream_upstream.c
    nginx-1.13.2/src/stream/ngx_stream_upstream.h
    nginx-1.13.2/src/stream/ngx_stream_upstream_least_conn_module.c
    nginx-1.13.2/src/stream/ngx_stream_upstream_zone_module.c
    nginx-1.13.2/src/stream/ngx_stream_upstream_hash_module.c
    nginx-1.13.2/src/stream/ngx_stream_upstream_round_robin.c
    nginx-1.13.2/src/stream/ngx_stream_upstream_round_robin.h
    nginx-1.13.2/src/stream/ngx_stream_variables.c
    nginx-1.13.2/src/stream/ngx_stream_variables.h
    nginx-1.13.2/src/stream/ngx_stream_write_filter_module.c
    nginx-1.13.2/src/os/unix/
    nginx-1.13.2/src/os/unix/ngx_atomic.h
    nginx-1.13.2/src/os/unix/ngx_alloc.c
    nginx-1.13.2/src/os/unix/ngx_alloc.h
    nginx-1.13.2/src/os/unix/ngx_darwin_config.h
    nginx-1.13.2/src/os/unix/ngx_channel.c
    nginx-1.13.2/src/os/unix/ngx_channel.h
    nginx-1.13.2/src/os/unix/ngx_daemon.c
    nginx-1.13.2/src/os/unix/ngx_darwin.h
    nginx-1.13.2/src/os/unix/ngx_darwin_sendfile_chain.c
    nginx-1.13.2/src/os/unix/ngx_darwin_init.c
    nginx-1.13.2/src/os/unix/ngx_file_aio_read.c
    nginx-1.13.2/src/os/unix/ngx_dlopen.c
    nginx-1.13.2/src/os/unix/ngx_dlopen.h
    nginx-1.13.2/src/os/unix/ngx_errno.c
    nginx-1.13.2/src/os/unix/ngx_errno.h
    nginx-1.13.2/src/os/unix/ngx_freebsd.h
    nginx-1.13.2/src/os/unix/ngx_files.c
    nginx-1.13.2/src/os/unix/ngx_files.h
    nginx-1.13.2/src/os/unix/ngx_freebsd_sendfile_chain.c
    nginx-1.13.2/src/os/unix/ngx_freebsd_config.h
    nginx-1.13.2/src/os/unix/ngx_freebsd_init.c
    nginx-1.13.2/src/os/unix/ngx_gcc_atomic_sparc64.h
    nginx-1.13.2/src/os/unix/ngx_gcc_atomic_amd64.h
    nginx-1.13.2/src/os/unix/ngx_gcc_atomic_ppc.h
    nginx-1.13.2/src/os/unix/ngx_linux_sendfile_chain.c
    nginx-1.13.2/src/os/unix/ngx_gcc_atomic_x86.h
    nginx-1.13.2/src/os/unix/ngx_linux.h
    nginx-1.13.2/src/os/unix/ngx_linux_aio_read.c
    nginx-1.13.2/src/os/unix/ngx_linux_config.h
    nginx-1.13.2/src/os/unix/ngx_linux_init.c
    nginx-1.13.2/src/os/unix/ngx_posix_config.h
    nginx-1.13.2/src/os/unix/ngx_os.h
    nginx-1.13.2/src/os/unix/ngx_solaris_config.h
    nginx-1.13.2/src/os/unix/ngx_posix_init.c
    nginx-1.13.2/src/os/unix/ngx_process.c
    nginx-1.13.2/src/os/unix/ngx_process.h
    nginx-1.13.2/src/os/unix/ngx_process_cycle.c
    nginx-1.13.2/src/os/unix/ngx_process_cycle.h
    nginx-1.13.2/src/os/unix/ngx_readv_chain.c
    nginx-1.13.2/src/os/unix/ngx_recv.c
    nginx-1.13.2/src/os/unix/ngx_send.c
    nginx-1.13.2/src/os/unix/ngx_setaffinity.c
    nginx-1.13.2/src/os/unix/ngx_setaffinity.h
    nginx-1.13.2/src/os/unix/ngx_setproctitle.c
    nginx-1.13.2/src/os/unix/ngx_setproctitle.h
    nginx-1.13.2/src/os/unix/ngx_shmem.c
    nginx-1.13.2/src/os/unix/ngx_shmem.h
    nginx-1.13.2/src/os/unix/ngx_socket.c
    nginx-1.13.2/src/os/unix/ngx_socket.h
    nginx-1.13.2/src/os/unix/ngx_solaris.h
    nginx-1.13.2/src/os/unix/ngx_solaris_init.c
    nginx-1.13.2/src/os/unix/ngx_sunpro_amd64.il
    nginx-1.13.2/src/os/unix/ngx_thread_cond.c
    nginx-1.13.2/src/os/unix/ngx_thread.h
    nginx-1.13.2/src/os/unix/ngx_solaris_sendfilev_chain.c
    nginx-1.13.2/src/os/unix/ngx_sunpro_atomic_sparc64.h
    nginx-1.13.2/src/os/unix/ngx_sunpro_sparc64.il
    nginx-1.13.2/src/os/unix/ngx_sunpro_x86.il
    nginx-1.13.2/src/os/unix/ngx_thread_mutex.c
    nginx-1.13.2/src/os/unix/ngx_thread_id.c
    nginx-1.13.2/src/os/unix/ngx_udp_recv.c
    nginx-1.13.2/src/os/unix/ngx_time.c
    nginx-1.13.2/src/os/unix/ngx_time.h
    nginx-1.13.2/src/os/unix/ngx_udp_sendmsg_chain.c
    nginx-1.13.2/src/os/unix/ngx_udp_send.c
    nginx-1.13.2/src/os/unix/ngx_writev_chain.c
    nginx-1.13.2/src/os/unix/ngx_user.c
    nginx-1.13.2/src/os/unix/ngx_user.h
    nginx-1.13.2/src/misc/ngx_google_perftools_module.c
    nginx-1.13.2/src/misc/ngx_cpp_test_module.cpp
    nginx-1.13.2/src/mail/ngx_mail_handler.c
    nginx-1.13.2/src/mail/ngx_mail.c
    nginx-1.13.2/src/mail/ngx_mail.h
    nginx-1.13.2/src/mail/ngx_mail_auth_http_module.c
    nginx-1.13.2/src/mail/ngx_mail_core_module.c
    nginx-1.13.2/src/mail/ngx_mail_imap_handler.c
    nginx-1.13.2/src/mail/ngx_mail_imap_module.c
    nginx-1.13.2/src/mail/ngx_mail_imap_module.h
    nginx-1.13.2/src/mail/ngx_mail_parse.c
    nginx-1.13.2/src/mail/ngx_mail_pop3_handler.c
    nginx-1.13.2/src/mail/ngx_mail_pop3_module.c
    nginx-1.13.2/src/mail/ngx_mail_pop3_module.h
    nginx-1.13.2/src/mail/ngx_mail_proxy_module.c
    nginx-1.13.2/src/mail/ngx_mail_smtp_handler.c
    nginx-1.13.2/src/mail/ngx_mail_smtp_module.c
    nginx-1.13.2/src/mail/ngx_mail_smtp_module.h
    nginx-1.13.2/src/mail/ngx_mail_ssl_module.c
    nginx-1.13.2/src/mail/ngx_mail_ssl_module.h
    nginx-1.13.2/src/http/modules/
    nginx-1.13.2/src/http/ngx_http_cache.h
    nginx-1.13.2/src/http/ngx_http.c
    nginx-1.13.2/src/http/ngx_http.h
    nginx-1.13.2/src/http/ngx_http_core_module.c
    nginx-1.13.2/src/http/ngx_http_config.h
    nginx-1.13.2/src/http/ngx_http_postpone_filter_module.c
    nginx-1.13.2/src/http/ngx_http_copy_filter_module.c
    nginx-1.13.2/src/http/ngx_http_core_module.h
    nginx-1.13.2/src/http/ngx_http_file_cache.c
    nginx-1.13.2/src/http/ngx_http_header_filter_module.c
    nginx-1.13.2/src/http/ngx_http_parse.c
    nginx-1.13.2/src/http/ngx_http_special_response.c
    nginx-1.13.2/src/http/ngx_http_request.c
    nginx-1.13.2/src/http/ngx_http_request.h
    nginx-1.13.2/src/http/ngx_http_request_body.c
    nginx-1.13.2/src/http/ngx_http_script.c
    nginx-1.13.2/src/http/ngx_http_script.h
    nginx-1.13.2/src/http/ngx_http_variables.c
    nginx-1.13.2/src/http/ngx_http_upstream.c
    nginx-1.13.2/src/http/ngx_http_upstream.h
    nginx-1.13.2/src/http/v2/
    nginx-1.13.2/src/http/ngx_http_upstream_round_robin.c
    nginx-1.13.2/src/http/ngx_http_upstream_round_robin.h
    nginx-1.13.2/src/http/ngx_http_variables.h
    nginx-1.13.2/src/http/ngx_http_write_filter_module.c
    nginx-1.13.2/src/http/v2/ngx_http_v2_module.c
    nginx-1.13.2/src/http/v2/ngx_http_v2.c
    nginx-1.13.2/src/http/v2/ngx_http_v2.h
    nginx-1.13.2/src/http/v2/ngx_http_v2_filter_module.c
    nginx-1.13.2/src/http/v2/ngx_http_v2_huff_decode.c
    nginx-1.13.2/src/http/v2/ngx_http_v2_huff_encode.c
    nginx-1.13.2/src/http/v2/ngx_http_v2_module.h
    nginx-1.13.2/src/http/v2/ngx_http_v2_table.c
    nginx-1.13.2/src/http/modules/ngx_http_addition_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_access_module.c
    nginx-1.13.2/src/http/modules/ngx_http_charset_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_auth_basic_module.c
    nginx-1.13.2/src/http/modules/ngx_http_auth_request_module.c
    nginx-1.13.2/src/http/modules/ngx_http_autoindex_module.c
    nginx-1.13.2/src/http/modules/ngx_http_browser_module.c
    nginx-1.13.2/src/http/modules/ngx_http_not_modified_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_chunked_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_dav_module.c
    nginx-1.13.2/src/http/modules/ngx_http_degradation_module.c
    nginx-1.13.2/src/http/modules/ngx_http_empty_gif_module.c
    nginx-1.13.2/src/http/modules/ngx_http_fastcgi_module.c
    nginx-1.13.2/src/http/modules/ngx_http_flv_module.c
    nginx-1.13.2/src/http/modules/ngx_http_geo_module.c
    nginx-1.13.2/src/http/modules/ngx_http_geoip_module.c
    nginx-1.13.2/src/http/modules/ngx_http_gunzip_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_gzip_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_gzip_static_module.c
    nginx-1.13.2/src/http/modules/ngx_http_headers_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_image_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_index_module.c
    nginx-1.13.2/src/http/modules/ngx_http_limit_conn_module.c
    nginx-1.13.2/src/http/modules/ngx_http_limit_req_module.c
    nginx-1.13.2/src/http/modules/ngx_http_log_module.c
    nginx-1.13.2/src/http/modules/ngx_http_map_module.c
    nginx-1.13.2/src/http/modules/ngx_http_memcached_module.c
    nginx-1.13.2/src/http/modules/ngx_http_mp4_module.c
    nginx-1.13.2/src/http/modules/ngx_http_random_index_module.c
    nginx-1.13.2/src/http/modules/ngx_http_proxy_module.c
    nginx-1.13.2/src/http/modules/ngx_http_upstream_ip_hash_module.c
    nginx-1.13.2/src/http/modules/ngx_http_range_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_realip_module.c
    nginx-1.13.2/src/http/modules/ngx_http_referer_module.c
    nginx-1.13.2/src/http/modules/ngx_http_rewrite_module.c
    nginx-1.13.2/src/http/modules/ngx_http_scgi_module.c
    nginx-1.13.2/src/http/modules/ngx_http_secure_link_module.c
    nginx-1.13.2/src/http/modules/ngx_http_slice_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_split_clients_module.c
    nginx-1.13.2/src/http/modules/perl/
    nginx-1.13.2/src/http/modules/ngx_http_ssi_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_ssi_filter_module.h
    nginx-1.13.2/src/http/modules/ngx_http_ssl_module.c
    nginx-1.13.2/src/http/modules/ngx_http_ssl_module.h
    nginx-1.13.2/src/http/modules/ngx_http_static_module.c
    nginx-1.13.2/src/http/modules/ngx_http_stub_status_module.c
    nginx-1.13.2/src/http/modules/ngx_http_sub_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_upstream_hash_module.c
    nginx-1.13.2/src/http/modules/ngx_http_xslt_filter_module.c
    nginx-1.13.2/src/http/modules/ngx_http_upstream_keepalive_module.c
    nginx-1.13.2/src/http/modules/ngx_http_upstream_least_conn_module.c
    nginx-1.13.2/src/http/modules/ngx_http_upstream_zone_module.c
    nginx-1.13.2/src/http/modules/ngx_http_uwsgi_module.c
    nginx-1.13.2/src/http/modules/ngx_http_userid_filter_module.c
    nginx-1.13.2/src/http/modules/perl/Makefile.PL
    nginx-1.13.2/src/http/modules/perl/nginx.pm
    nginx-1.13.2/src/http/modules/perl/nginx.xs
    nginx-1.13.2/src/http/modules/perl/typemap
    nginx-1.13.2/src/http/modules/perl/ngx_http_perl_module.c
    nginx-1.13.2/src/http/modules/perl/ngx_http_perl_module.h
    nginx-1.13.2/src/event/modules/
    nginx-1.13.2/src/event/ngx_event_accept.c
    nginx-1.13.2/src/event/ngx_event.c
    nginx-1.13.2/src/event/ngx_event.h
    nginx-1.13.2/src/event/ngx_event_openssl_stapling.c
    nginx-1.13.2/src/event/ngx_event_connect.c
    nginx-1.13.2/src/event/ngx_event_connect.h
    nginx-1.13.2/src/event/ngx_event_openssl.c
    nginx-1.13.2/src/event/ngx_event_openssl.h
    nginx-1.13.2/src/event/ngx_event_pipe.c
    nginx-1.13.2/src/event/ngx_event_pipe.h
    nginx-1.13.2/src/event/ngx_event_posted.c
    nginx-1.13.2/src/event/ngx_event_posted.h
    nginx-1.13.2/src/event/ngx_event_timer.c
    nginx-1.13.2/src/event/ngx_event_timer.h
    nginx-1.13.2/src/event/modules/ngx_win32_select_module.c
    nginx-1.13.2/src/event/modules/ngx_devpoll_module.c
    nginx-1.13.2/src/event/modules/ngx_epoll_module.c
    nginx-1.13.2/src/event/modules/ngx_eventport_module.c
    nginx-1.13.2/src/event/modules/ngx_kqueue_module.c
    nginx-1.13.2/src/event/modules/ngx_poll_module.c
    nginx-1.13.2/src/event/modules/ngx_select_module.c
    nginx-1.13.2/src/core/ngx_array.c
    nginx-1.13.2/src/core/nginx.c
    nginx-1.13.2/src/core/nginx.h
    nginx-1.13.2/src/core/ngx_conf_file.c
    nginx-1.13.2/src/core/ngx_array.h
    nginx-1.13.2/src/core/ngx_buf.c
    nginx-1.13.2/src/core/ngx_buf.h
    nginx-1.13.2/src/core/ngx_connection.c
    nginx-1.13.2/src/core/ngx_conf_file.h
    nginx-1.13.2/src/core/ngx_config.h
    nginx-1.13.2/src/core/ngx_module.c
    nginx-1.13.2/src/core/ngx_file.c
    nginx-1.13.2/src/core/ngx_connection.h
    nginx-1.13.2/src/core/ngx_core.h
    nginx-1.13.2/src/core/ngx_cpuinfo.c
    nginx-1.13.2/src/core/ngx_crc.h
    nginx-1.13.2/src/core/ngx_crc32.c
    nginx-1.13.2/src/core/ngx_crc32.h
    nginx-1.13.2/src/core/ngx_crypt.c
    nginx-1.13.2/src/core/ngx_crypt.h
    nginx-1.13.2/src/core/ngx_cycle.c
    nginx-1.13.2/src/core/ngx_cycle.h
    nginx-1.13.2/src/core/ngx_parse.h
    nginx-1.13.2/src/core/ngx_file.h
    nginx-1.13.2/src/core/ngx_hash.c
    nginx-1.13.2/src/core/ngx_hash.h
    nginx-1.13.2/src/core/ngx_inet.c
    nginx-1.13.2/src/core/ngx_inet.h
    nginx-1.13.2/src/core/ngx_list.c
    nginx-1.13.2/src/core/ngx_list.h
    nginx-1.13.2/src/core/ngx_log.c
    nginx-1.13.2/src/core/ngx_log.h
    nginx-1.13.2/src/core/ngx_md5.c
    nginx-1.13.2/src/core/ngx_md5.h
    nginx-1.13.2/src/core/ngx_murmurhash.c
    nginx-1.13.2/src/core/ngx_module.h
    nginx-1.13.2/src/core/ngx_open_file_cache.c
    nginx-1.13.2/src/core/ngx_murmurhash.h
    nginx-1.13.2/src/core/ngx_slab.h
    nginx-1.13.2/src/core/ngx_open_file_cache.h
    nginx-1.13.2/src/core/ngx_output_chain.c
    nginx-1.13.2/src/core/ngx_palloc.c
    nginx-1.13.2/src/core/ngx_palloc.h
    nginx-1.13.2/src/core/ngx_parse.c
    nginx-1.13.2/src/core/ngx_thread_pool.c
    nginx-1.13.2/src/core/ngx_parse_time.c
    nginx-1.13.2/src/core/ngx_parse_time.h
    nginx-1.13.2/src/core/ngx_proxy_protocol.c
    nginx-1.13.2/src/core/ngx_proxy_protocol.h
    nginx-1.13.2/src/core/ngx_queue.c
    nginx-1.13.2/src/core/ngx_queue.h
    nginx-1.13.2/src/core/ngx_radix_tree.c
    nginx-1.13.2/src/core/ngx_radix_tree.h
    nginx-1.13.2/src/core/ngx_rbtree.c
    nginx-1.13.2/src/core/ngx_rbtree.h
    nginx-1.13.2/src/core/ngx_regex.c
    nginx-1.13.2/src/core/ngx_regex.h
    nginx-1.13.2/src/core/ngx_resolver.c
    nginx-1.13.2/src/core/ngx_resolver.h
    nginx-1.13.2/src/core/ngx_rwlock.c
    nginx-1.13.2/src/core/ngx_rwlock.h
    nginx-1.13.2/src/core/ngx_sha1.c
    nginx-1.13.2/src/core/ngx_sha1.h
    nginx-1.13.2/src/core/ngx_shmtx.c
    nginx-1.13.2/src/core/ngx_shmtx.h
    nginx-1.13.2/src/core/ngx_slab.c
    nginx-1.13.2/src/core/ngx_spinlock.c
    nginx-1.13.2/src/core/ngx_string.c
    nginx-1.13.2/src/core/ngx_string.h
    nginx-1.13.2/src/core/ngx_syslog.c
    nginx-1.13.2/src/core/ngx_syslog.h
    nginx-1.13.2/src/core/ngx_thread_pool.h
    nginx-1.13.2/src/core/ngx_times.c
    nginx-1.13.2/src/core/ngx_times.h
    nginx-1.13.2/contrib/geo2nginx.pl
    nginx-1.13.2/contrib/README
    nginx-1.13.2/contrib/unicode2nginx/
    nginx-1.13.2/contrib/vim/
    nginx-1.13.2/contrib/vim/ftdetect/
    nginx-1.13.2/contrib/vim/ftplugin/
    nginx-1.13.2/contrib/vim/indent/
    nginx-1.13.2/contrib/vim/syntax/
    nginx-1.13.2/contrib/vim/syntax/nginx.vim
    nginx-1.13.2/contrib/vim/indent/nginx.vim
    nginx-1.13.2/contrib/vim/ftplugin/nginx.vim
    nginx-1.13.2/contrib/vim/ftdetect/nginx.vim
    nginx-1.13.2/contrib/unicode2nginx/koi-utf
    nginx-1.13.2/contrib/unicode2nginx/win-utf
    nginx-1.13.2/contrib/unicode2nginx/unicode-to-nginx.pl
    nginx-1.13.2/conf/fastcgi.conf
    nginx-1.13.2/conf/fastcgi_params
    nginx-1.13.2/conf/koi-utf
    nginx-1.13.2/conf/koi-win
    nginx-1.13.2/conf/mime.types
    nginx-1.13.2/conf/nginx.conf
    nginx-1.13.2/conf/scgi_params
    nginx-1.13.2/conf/uwsgi_params
    nginx-1.13.2/conf/win-utf
    nginx-1.13.2/auto/cc/
    nginx-1.13.2/auto/have_headers
    nginx-1.13.2/auto/define
    nginx-1.13.2/auto/endianness
    nginx-1.13.2/auto/feature
    nginx-1.13.2/auto/lib/
    nginx-1.13.2/auto/os/
    nginx-1.13.2/auto/headers
    nginx-1.13.2/auto/include
    nginx-1.13.2/auto/init
    nginx-1.13.2/auto/install
    nginx-1.13.2/auto/types/
    nginx-1.13.2/auto/make
    nginx-1.13.2/auto/nohave
    nginx-1.13.2/auto/options
    nginx-1.13.2/auto/sources
    nginx-1.13.2/auto/stubs
    nginx-1.13.2/auto/summary
    nginx-1.13.2/auto/threads
    nginx-1.13.2/auto/unix
    nginx-1.13.2/auto/types/uintptr_t
    nginx-1.13.2/auto/types/sizeof
    nginx-1.13.2/auto/types/typedef
    nginx-1.13.2/auto/types/value
    nginx-1.13.2/auto/os/conf
    nginx-1.13.2/auto/os/darwin
    nginx-1.13.2/auto/os/freebsd
    nginx-1.13.2/auto/os/linux
    nginx-1.13.2/auto/os/solaris
    nginx-1.13.2/auto/os/win32
    nginx-1.13.2/auto/lib/geoip/
    nginx-1.13.2/auto/lib/conf
    nginx-1.13.2/auto/lib/google-perftools/
    nginx-1.13.2/auto/lib/libatomic/
    nginx-1.13.2/auto/lib/libgd/
    nginx-1.13.2/auto/lib/libxslt/
    nginx-1.13.2/auto/lib/openssl/
    nginx-1.13.2/auto/lib/make
    nginx-1.13.2/auto/lib/pcre/
    nginx-1.13.2/auto/lib/perl/
    nginx-1.13.2/auto/lib/zlib/
    nginx-1.13.2/auto/lib/zlib/makefile.bcc
    nginx-1.13.2/auto/lib/zlib/conf
    nginx-1.13.2/auto/lib/zlib/makefile.msvc
    nginx-1.13.2/auto/lib/zlib/makefile.owc
    nginx-1.13.2/auto/lib/perl/conf
    nginx-1.13.2/auto/lib/perl/make
    nginx-1.13.2/auto/lib/pcre/makefile.bcc
    nginx-1.13.2/auto/lib/pcre/conf
    nginx-1.13.2/auto/lib/pcre/makefile.msvc
    nginx-1.13.2/auto/lib/pcre/makefile.owc
    nginx-1.13.2/auto/lib/openssl/makefile.bcc
    nginx-1.13.2/auto/lib/openssl/conf
    nginx-1.13.2/auto/lib/openssl/makefile.msvc
    nginx-1.13.2/auto/lib/libxslt/conf
    nginx-1.13.2/auto/lib/libgd/conf
    nginx-1.13.2/auto/lib/libatomic/conf
    nginx-1.13.2/auto/lib/libatomic/make
    nginx-1.13.2/auto/lib/google-perftools/conf
    nginx-1.13.2/auto/lib/geoip/conf
    nginx-1.13.2/auto/cc/clang
    nginx-1.13.2/auto/cc/acc
    nginx-1.13.2/auto/cc/bcc
    nginx-1.13.2/auto/cc/ccc
    nginx-1.13.2/auto/cc/conf
    nginx-1.13.2/auto/cc/gcc
    nginx-1.13.2/auto/cc/icc
    nginx-1.13.2/auto/cc/msvc
    nginx-1.13.2/auto/cc/name
    nginx-1.13.2/auto/cc/owc
    nginx-1.13.2/auto/cc/sunc
    make: *** No rule to make target `clean'.  Stop.
    Nginx Patch Time - 1 seconds delay
    to allow you to patch files
    1013002
                              _   _         _
                                     |___/
                   ____                __  _
                  / ___| ___   _ __   / _|(_)  __ _  _   _  _ __  ___
                 | |    / _ \ | '_ \ | |_ | | / _` || | | || '__|/ _ \
                 | |___| (_) || | | ||  _|| || (_| || |_| || |  |  __/
                  \____|\___/ |_| |_||_|  |_| \__, | \__,_||_|   \___|
                                              |___/
    detected 1.1.0f
              ____  _                  _      _   _         _
                                                     |___/
                     ____                                   _
                    |  _ \  _   _  _ __    __ _  _ __ ___  (_)  ___
                    | | | || | | || '_ \  / _` || '_ ` _ \ | | / __|
                    | |_| || |_| || | | || (_| || | | | | || || (__
                    |____/  \__, ||_| |_| \__,_||_| |_| |_||_| \___|
                            |___/
                          __  __             _         _
                      ____                                     _
                     / ___|  _   _  _ __   _ __    ___   _ __ | |_
                     \___ \ | | | || '_ \ | '_ \  / _ \ | '__|| __|
                      ___) || |_| || |_) || |_) || (_) || |   | |_
                     |____/  \__,_|| .__/ | .__/  \___/ |_|    \__|
                                   |_|    |_|
    NGX_DYNAMICCHECK nginx_configure
    1013002
    1013002
    1013002
    /svr-setup /svr-setup/nginx-1.13.2
    /svr-setup/ngx_cache_purge-2.3 /svr-setup/nginx-1.13.2
    patching ngx_cache_purge for community.centminmod.com/threads/11598/
    patch -p0 < /usr/local/src/centminmod/patches/ngx-cache-purge/ngx-cache-purge-1116.patch
    patching file ngx_cache_purge_module.c
    patching ngx_cache_purge for nginx 1.11.6+
    1013002
    14
    /svr-setup/redis2-nginx-module-0.14/src
    /svr-setup/memc-nginx-module-0.18/src
    1013002
    /svr-setup/echo-nginx-module-0.60/src /svr-setup/nginx-1.13.2
    2017-07-02 22:52:59 URL:https://gist.githubusercontent.com/centminmod/c2519f3cfdeff90196a13a3188ef0cfa/raw/ngx_http_echo_request_info.c [11197/11197] -> "ngx_http_echo_request_info.c" [1]
    total 192K
    drwxrwxr-x 2 root root 4.0K Jul  2 22:52 .
    drwxrwxr-x 5 root root 4.0K Jun 30  2016 ..
    -rw-rw-r-- 1 root root 2.5K Jun 30  2016 ddebug.h
    -rw-rw-r-- 1 root root 8.1K Jun 30  2016 ngx_http_echo_echo.c
    -rw-rw-r-- 1 root root  758 Jun 30  2016 ngx_http_echo_echo.h
    -rw-rw-r-- 1 root root 7.6K Jun 30  2016 ngx_http_echo_filter.c
    -rw-rw-r-- 1 root root  311 Jun 30  2016 ngx_http_echo_filter.h
    -rw-rw-r-- 1 root root 4.8K Jun 30  2016 ngx_http_echo_foreach.c
    -rw-rw-r-- 1 root root  458 Jun 30  2016 ngx_http_echo_foreach.h
    -rw-rw-r-- 1 root root  12K Jun 30  2016 ngx_http_echo_handler.c
    -rw-rw-r-- 1 root root  383 Jun 30  2016 ngx_http_echo_handler.h
    -rw-rw-r-- 1 root root 4.4K Jun 30  2016 ngx_http_echo_location.c
    -rw-rw-r-- 1 root root  380 Jun 30  2016 ngx_http_echo_location.h
    -rw-rw-r-- 1 root root  19K Jun 30  2016 ngx_http_echo_module.c
    -rw-rw-r-- 1 root root 4.0K Jun 30  2016 ngx_http_echo_module.h
    -rw-r--r-- 1 root root  11K Jul  2 22:52 ngx_http_echo_request_info.c
    -rw-rw-r-- 1 root root 1.1K Jun 30  2016 ngx_http_echo_request_info.h
    -rw-rw-r-- 1 root root 4.6K Jun 30  2016 ngx_http_echo_sleep.c
    -rw-rw-r-- 1 root root  435 Jun 30  2016 ngx_http_echo_sleep.h
    -rw-rw-r-- 1 root root  22K Jun 30  2016 ngx_http_echo_subrequest.c
    -rw-rw-r-- 1 root root  612 Jun 30  2016 ngx_http_echo_subrequest.h
    -rw-rw-r-- 1 root root 2.1K Jun 30  2016 ngx_http_echo_timer.c
    -rw-rw-r-- 1 root root  336 Jun 30  2016 ngx_http_echo_timer.h
    -rw-rw-r-- 1 root root 6.5K Jun 30  2016 ngx_http_echo_util.c
    -rw-rw-r-- 1 root root 1.5K Jun 30  2016 ngx_http_echo_util.h
    -rw-rw-r-- 1 root root 2.7K Jun 30  2016 ngx_http_echo_var.c
    -rw-rw-r-- 1 root root  155 Jun 30  2016 ngx_http_echo_var.h
    patching echo nginx module for nginx 1.11.11+
    /usr/lib64/libatomic_ops.a found
    Check existing server string:
    static u_char ngx_http_server_string[] = "Server: nginx" CRLF;
    static u_char ngx_http_server_build_string[] = "Server: " NGINX_VER_BUILD CRLF;
    Change server string to nginx centminmod
    NGX_MAX_ERROR_STR value
    #define NGX_MAX_ERROR_STR   2048
    net.ipv4.tcp_fastopen = 3
    TCPOFODrop  TCPOFOMerge  TCPChallengeACK  TCPSYNChallenge  TCPFastOpenActive  TCPFastOpenActiveFail
    0           1            1                1                0                  0
    689:    gcf->country = GeoIP_open((char *) value[1].data, GEOIP_MEMORY_CACHE);
    744:    gcf->org = GeoIP_open((char *) value[1].data, GEOIP_MEMORY_CACHE);
    805:    gcf->city = GeoIP_open((char *) value[1].data, GEOIP_MEMORY_CACHE);
    export CC="ccache /usr/bin/clang -ferror-limit=0"
    export CXX="ccache /usr/bin/clang++ -ferror-limit=0"
    export CCACHE_CPP2=yes
    CLANG_CCOPT=' -Wno-sign-compare -Wno-string-plus-int -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion -Wno-c++11-compat-deprecated-writable-strings -Wno-write-strings'
      -m64                                  [enabled]
      -m80387                               [enabled]
      -m96bit-long-double                   [enabled]
      -mabm                                 [enabled]
      -maes                                 [enabled]
      -malign-stringops                     [enabled]
      -march=                               core-avx2
      -mavx                                 [enabled]
      -mavx2                                [enabled]
      -mbmi                                 [enabled]
      -mbmi2                                [enabled]
      -mcx16                                [enabled]
      -mf16c                                [enabled]
      -mfancy-math-387                      [enabled]
      -mfentry                              [enabled]
      -mfma                                 [enabled]
      -mfp-ret-in-387                       [enabled]
      -mfsgsbase                            [enabled]
      -mfxsr                                [enabled]
      -mglibc                               [enabled]
      -mhard-float                          [enabled]
      -mieee-fp                             [enabled]
      -mlong-double-80                      [enabled]
      -mlzcnt                               [enabled]
      -mmovbe                               [enabled]
      -mpclmul                              [enabled]
      -mpopcnt                              [enabled]
      -mpush-args                           [enabled]
      -mrdrnd                               [enabled]
      -mred-zone                            [enabled]
      -msahf                                [enabled]
      -msse                                 [enabled]
      -msse2                                [enabled]
      -msse3                                [enabled]
      -msse4                                [enabled]
      -msse4.1                              [enabled]
      -msse4.2                              [enabled]
      -mssse3                               [enabled]
      -mstackrealign                        [enabled]
      -mtls-direct-seg-refs                 [enabled]
      -mtune=                               generic
      -mxsave                               [enabled]
      -mxsaveopt                            [enabled]
    dynamic module directory at /usr/local/nginx/modules
    nginx configure options (alternate ordering):
    ./configure --with-ld-opt="-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib" --with-cc-opt="-m64 -mtune=native -DTCP_FASTOPEN=23 -g -O3 -fstack-protector -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-sign-compare -Wno-string-plus-int -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion -Wno-c++11-compat-deprecated-writable-strings -Wno-write-strings -gsplit-dwarf" --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.0 --add-module=../ngx_cache_purge-2.3 --add-module=../ngx_devel_kit-0.3.0 --add-module=../set-misc-nginx-module-0.31 --add-module=../echo-nginx-module-0.60 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-module=../headers-more-nginx-module-0.32 --with-pcre=../pcre-8.40 --with-pcre-jit --with-zlib=../zlib-1.2.11 --with-http_ssl_module --with-http_v2_module --with-openssl=../libressl-2.5.4
    checking for OS
     + Linux 4.9.15-x86_64-linode81 x86_64
    checking for C compiler ... found
     + using Clang C compiler
     + clang version: 3.4.2 (tags/RELEASE_34/dot2-final)
    checking for --with-ld-opt="-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib" ... found
    checking for -Wl,-E switch ... found
    checking for gcc builtin atomic operations ... found
    checking for C99 variadic macros ... found
    checking for gcc variadic macros ... found
    checking for gcc builtin 64 bit byteswap ... found
    checking for unistd.h ... found
    checking for inttypes.h ... found
    checking for limits.h ... found
    checking for sys/filio.h ... not found
    checking for sys/param.h ... found
    checking for sys/mount.h ... found
    checking for sys/statvfs.h ... found
    checking for crypt.h ... found
    checking for Linux specific features
    checking for epoll ... found
    checking for EPOLLRDHUP ... found
    checking for EPOLLEXCLUSIVE ... not found
    checking for O_PATH ... found
    checking for sendfile() ... found
    checking for sendfile64() ... found
    checking for sys/prctl.h ... found
    checking for prctl(PR_SET_DUMPABLE) ... found
    checking for crypt_r() ... found
    checking for sys/vfs.h ... found
    checking for nobody group ... found
    checking for poll() ... found
    checking for /dev/poll ... not found
    checking for kqueue ... not found
    checking for crypt() ... not found
    checking for crypt() in libcrypt ... found
    checking for F_READAHEAD ... not found
    checking for posix_fadvise() ... found
    checking for O_DIRECT ... found
    checking for F_NOCACHE ... not found
    checking for directio() ... not found
    checking for statfs() ... found
    checking for statvfs() ... found
    checking for dlopen() ... not found
    checking for dlopen() in libdl ... found
    checking for sched_yield() ... found
    checking for sched_setaffinity() ... found
    checking for SO_SETFIB ... not found
    checking for SO_REUSEPORT ... found
    checking for SO_ACCEPTFILTER ... not found
    checking for SO_BINDANY ... not found
    checking for IP_BIND_ADDRESS_NO_PORT ... not found
    checking for IP_TRANSPARENT ... found
    checking for IP_BINDANY ... not found
    checking for IP_RECVDSTADDR ... not found
    checking for IP_SENDSRCADDR ... not found
    checking for IP_PKTINFO ... found
    checking for IPV6_RECVPKTINFO ... found
    checking for TCP_DEFER_ACCEPT ... found
    checking for TCP_KEEPIDLE ... found
    checking for TCP_FASTOPEN ... found
    checking for TCP_INFO ... found
    checking for accept4() ... found
    checking for eventfd() ... found
    checking for int size ... 4 bytes
    checking for long size ... 8 bytes
    checking for long long size ... 8 bytes
    checking for void * size ... 8 bytes
    checking for uint32_t ... found
    checking for uint64_t ... found
    checking for sig_atomic_t ... found
    checking for sig_atomic_t size ... 4 bytes
    checking for socklen_t ... found
    checking for in_addr_t ... found
    checking for in_port_t ... found
    checking for rlim_t ... found
    checking for uintptr_t ... uintptr_t found
    checking for system byte ordering ... little endian
    checking for size_t size ... 8 bytes
    checking for off_t size ... 8 bytes
    checking for time_t size ... 8 bytes
    checking for AF_INET6 ... found
    checking for setproctitle() ... not found
    checking for pread() ... found
    checking for pwrite() ... found
    checking for pwritev() ... found
    checking for sys_nerr ... found
    checking for localtime_r() ... found
    checking for posix_memalign() ... found
    checking for memalign() ... found
    checking for mmap(MAP_ANON|MAP_SHARED) ... found
    checking for mmap("/dev/zero", MAP_SHARED) ... found
    checking for System V shared memory ... found
    checking for POSIX semaphores ... not found
    checking for POSIX semaphores in libpthread ... found
    checking for struct msghdr.msg_control ... found
    checking for ioctl(FIONBIO) ... found
    checking for struct tm.tm_gmtoff ... found
    checking for struct dirent.d_namlen ... not found
    checking for struct dirent.d_type ... found
    checking for sysconf(_SC_NPROCESSORS_ONLN) ... found
    checking for openat(), fstatat() ... found
    checking for getaddrinfo() ... found
    configuring additional modules
    adding module in ../ngx_cache_purge-2.3
     + ngx_http_cache_purge_module was configured
    adding module in ../ngx_devel_kit-0.3.0
     + ngx_devel_kit was configured
    adding module in ../set-misc-nginx-module-0.31
    found ngx_devel_kit for ngx_set_misc; looks good.
     + ngx_http_set_misc_module was configured
    adding module in ../echo-nginx-module-0.60
     + ngx_http_echo_module was configured
    adding module in ../redis2-nginx-module-0.14
     + ngx_http_redis2_module was configured
    adding module in ../ngx_http_redis-0.3.7
     + ngx_http_redis_module was configured
    adding module in ../memc-nginx-module-0.18
     + ngx_http_memc_module was configured
    adding module in ../srcache-nginx-module-0.31
     + ngx_http_srcache_filter_module was configured
    adding module in ../headers-more-nginx-module-0.32
     + ngx_http_headers_more_filter_module was configured
    configuring additional dynamic modules
    adding module in ../ngx-fancyindex-0.4.0
     + ngx_http_fancyindex_module was configured
    checking for GD library ... found
    checking for GD WebP support ... not found
    checking for GeoIP library ... found
    checking for GeoIP IPv6 support ... found
    checking for atomic_ops library ... found
    creating objs/Makefile
    Configuration summary
      + using threads
      + using PCRE library: ../pcre-8.40
      + using OpenSSL library: ../libressl-2.5.4
      + using zlib library: ../zlib-1.2.11
      + using system libatomic_ops library
      nginx path prefix: "/usr/local/nginx"
      nginx binary file: "/usr/local/sbin/nginx"
      nginx modules path: "/usr/local/nginx/modules"
      nginx configuration prefix: "/usr/local/nginx/conf"
      nginx configuration file: "/usr/local/nginx/conf/nginx.conf"
      nginx pid file: "/usr/local/nginx/logs/nginx.pid"
      nginx error log file: "/usr/local/nginx/logs/error.log"
      nginx http access log file: "/usr/local/nginx/logs/access.log"
      nginx http client request body temporary files: "client_body_temp"
      nginx http proxy temporary files: "proxy_temp"
      nginx http fastcgi temporary files: "fastcgi_temp"
      nginx http uwsgi temporary files: "uwsgi_temp"
      nginx http scgi temporary files: "scgi_temp"
    Sun Jul  2 22:53:07 UTC 2017
    Success: Nginx configure ok
                _   _         _                __  __         _
               | \ | |  __ _ (_) _ __  __  __ |  \/  |  __ _ | | __ ___
               |  \| | / _` || || '_ \ \ \/ / | |\/| | / _` || |/ // _ \
               | |\  || (_| || || | | | >  <  | |  | || (_| ||   <|  __/
               |_| \_| \__, ||_||_| |_|/_/\_\ |_|  |_| \__,_||_|\_\\___|
                       |___/
    make -f objs/Makefile
    make[1]: Entering directory `/svr-setup/nginx-1.13.2'
    cd ../pcre-8.40 \
    && if [ -f Makefile ]; then make distclean; fi \
    && CC="ccache /usr/bin/clang -ferror-limit=0" CFLAGS="-O2 -pipe " \
    ./configure --disable-shared  --enable-jit
    cd ../libressl-2.5.4 \
    && if [ -f Makefile ]; then make clean; fi \
    && ./config --prefix=/svr-setup/nginx-1.13.2/../libressl-2.5.4/.openssl no-shared  \
    && make \
    && make install_sw LIBDIR=lib
    make[2]: Entering directory `/svr-setup/libressl-2.5.4'
    make[2]: *** [aclocal.m4] Error 127
    make[2]: Leaving directory `/svr-setup/libressl-2.5.4'
    make[1]: *** [../libressl-2.5.4/.openssl/include/openssl/ssl.h] Error 2
    make[1]: *** Waiting for unfinished jobs....
    make[2]: Entering directory `/svr-setup/pcre-8.40'
    test -z "pcre_chartables.c testsavedregex teststderr testtemp* testtry testNinput testtrygrep teststderrgrep testNinputgrep" || rm -f pcre_chartables.c testsavedregex teststderr testtemp* testtry testNinput testtrygrep teststderrgrep testNinputgrep
    test -z "libpcre.la   libpcreposix.la libpcrecpp.la" || rm -f libpcre.la   libpcreposix.la libpcrecpp.la
     rm -f pcretest pcregrep
    rm -rf .libs _libs
    rm -f *.o
     rm -f pcre_jit_test pcrecpp_unittest pcre_scanner_unittest pcre_stringpiece_unittest
    test -z "pcre_jit_test.log pcrecpp_unittest.log pcre_scanner_unittest.log pcre_stringpiece_unittest.log RunTest.log RunGrepTest.log" || rm -f pcre_jit_test.log pcrecpp_unittest.log pcre_scanner_unittest.log pcre_stringpiece_unittest.log RunTest.log RunGrepTest.log
    rm -f *.lo
    test -z "pcre_jit_test.trs pcrecpp_unittest.trs pcre_scanner_unittest.trs pcre_stringpiece_unittest.trs RunTest.trs RunGrepTest.trs" || rm -f pcre_jit_test.trs pcrecpp_unittest.trs pcre_scanner_unittest.trs pcre_stringpiece_unittest.trs RunTest.trs RunGrepTest.trs
    rm -f *.tab.c
    rm -f ./so_locations
    test -z "test-suite.log" || rm -f test-suite.log
    test -z "libpcre.pc libpcre16.pc libpcre32.pc libpcreposix.pc libpcrecpp.pc pcre-config pcre.h pcre_stringpiece.h pcrecpparg.h" || rm -f libpcre.pc libpcre16.pc libpcre32.pc libpcreposix.pc libpcrecpp.pc pcre-config pcre.h pcre_stringpiece.h pcrecpparg.h
    rm -f config.h stamp-h1
    rm -f libtool config.lt
    rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
    test . = "." || test -z "" || rm -f
    rm -f cscope.out cscope.in.out cscope.po.out cscope.files
    rm -f config.status config.cache config.log configure.lineno config.status.lineno
    rm -rf ./.deps
    rm -f Makefile
    make[2]: Leaving directory `/svr-setup/pcre-8.40'
    checking the archiver (ar) interface... ar
    checking for gcc... (cached) ccache /usr/bin/clang -ferror-limit=0
    checking whether we are using the GNU C compiler... (cached) yes
    checking whether ccache /usr/bin/clang -ferror-limit=0 accepts -g... (cached) yes
    checking for ccache /usr/bin/clang -ferror-limit=0 option to accept ISO C89... (cached) none needed
    checking whether ccache /usr/bin/clang -ferror-limit=0 understands -c and -o together... (cached) yes
    checking dependency style of ccache /usr/bin/clang -ferror-limit=0... (cached) gcc3
    checking whether we are using the GNU C++ compiler... yes
    checking whether ccache /usr/bin/clang++ -ferror-limit=0 accepts -g... yes
    checking dependency style of ccache /usr/bin/clang++ -ferror-limit=0... gcc3
    checking for int64_t... yes
    checking build system type... x86_64-unknown-linux-gnu
    checking host system type... x86_64-unknown-linux-gnu
    checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
    checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
    checking for dlltool... dlltool
    checking for a working dd... /bin/dd
    checking how to truncate binary pipes... /bin/dd bs=4096 count=1
    checking whether to build shared libraries... no
    checking how to run the C++ preprocessor... ccache /usr/bin/clang++ -ferror-limit=0 -E
    checking for ld used by ccache /usr/bin/clang++ -ferror-limit=0... /usr/bin/ld -m elf_x86_64
    checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
    checking whether the ccache /usr/bin/clang++ -ferror-limit=0 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
    checking for ccache /usr/bin/clang++ -ferror-limit=0 option to produce PIC... -fPIC -DPIC
    checking if ccache /usr/bin/clang++ -ferror-limit=0 PIC flag -fPIC -DPIC works... yes
    checking if ccache /usr/bin/clang++ -ferror-limit=0 static flag -static works... no
    checking if ccache /usr/bin/clang++ -ferror-limit=0 supports -c -o file.o... yes
    checking if ccache /usr/bin/clang++ -ferror-limit=0 supports -c -o file.o... (cached) yes
    checking dynamic linker characteristics... (cached) GNU/Linux ld.so
    checking whether the -Werror option is usable... yes
    checking for simple visibility declarations... yes
    checking for ANSI C header files... (cached) yes
    checking limits.h usability... yes
    checking limits.h presence... yes
    checking for limits.h... yes
    checking for sys/types.h... (cached) yes
    checking for sys/stat.h... (cached) yes
    checking dirent.h usability... yes
    checking dirent.h presence... yes
    checking for dirent.h... yes
    checking windows.h usability... no
    checking windows.h presence... no
    checking for windows.h... no
    checking for alias support in the linker... no
    checking string usability... yes
    checking string presence... yes
    checking for string... yes
    checking bits/type_traits.h usability... no
    checking bits/type_traits.h presence... no
    checking for bits/type_traits.h... no
    checking type_traits.h usability... no
    checking type_traits.h presence... no
    checking for type_traits.h... no
    checking for strtoq... yes
    checking for long long... yes
    checking for unsigned long long... yes
    checking for an ANSI C-conforming const... yes
    checking for size_t... yes
    checking for bcopy... yes
    checking for memmove... yes
    checking for strerror... yes
    checking zlib.h usability... yes
    checking zlib.h presence... yes
    checking for zlib.h... yes
    checking for gzopen in -lz... yes
    checking bzlib.h usability... yes
    checking bzlib.h presence... yes
    checking for bzlib.h... yes
    checking for libbz2... yes
    checking for the pthreads library -lpthreads... no
    checking whether pthreads work without any flags... no
    checking whether pthreads work with -Kthread... no
    checking whether pthreads work with -kthread... no
    checking for the pthreads library -llthread... no
    checking whether pthreads work with -pthread... yes
    checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
    checking if more special flags are required for pthreads... no
    checking for PTHREAD_PRIO_INHERIT... yes
    config.status: creating libpcre.pc
    config.status: creating libpcre16.pc
    config.status: creating libpcre32.pc
    config.status: creating libpcreposix.pc
    config.status: creating libpcrecpp.pc
    config.status: creating pcre-config
    config.status: creating pcre.h
    config.status: creating pcre_stringpiece.h
    config.status: creating pcrecpparg.h
    config.status: creating config.h
    config.status: executing script-chmod commands
    config.status: executing delete-old-chartables commands
    pcre-8.40 configuration summary:
        Install prefix .................. : /usr/local
        C preprocessor .................. : ccache /usr/bin/clang -ferror-limit=0 -E
        C compiler ...................... : ccache /usr/bin/clang -ferror-limit=0
        C++ preprocessor ................ : ccache /usr/bin/clang++ -ferror-limit=0 -E
        C++ compiler .................... : ccache /usr/bin/clang++ -ferror-limit=0
        Linker .......................... : /usr/bin/ld -m elf_x86_64
        C preprocessor flags ............ :
        C compiler flags ................ : -pthread -O2 -pipe  -fvisibility=hidden
        C++ compiler flags .............. : -O2 -fvisibility=hidden -fvisibility-inlines-hidden
        Linker flags .................... :
        Extra libraries ................. :
        Build 8 bit pcre library ........ : yes
        Build 16 bit pcre library ....... : no
        Build 32 bit pcre library ....... : no
        Build C++ library ............... : yes
        Enable JIT compiling support .... : yes
        Enable UTF-8/16/32 support ...... : no
        Unicode properties .............. : no
        Newline char/sequence ........... : lf
        \R matches only ANYCRLF ......... : no
        EBCDIC coding ................... : no
        EBCDIC code for NL .............. : n/a
        Rebuild char tables ............. : no
        Use stack recursion ............. : yes
        POSIX mem threshold ............. : 10
        Internal link size .............. : 2
        Nested parentheses limit ........ : 250
        Match limit ..................... : 10000000
        Match limit recursion ........... : MATCH_LIMIT
        Build shared libs ............... : no
        Build static libs ............... : yes
        Use JIT in pcregrep ............. : yes
        Buffer size for pcregrep ........ : 20480
        Link pcregrep with libz ......... : no
        Link pcregrep with libbz2 ....... : no
        Link pcretest with libedit ...... : no
        Link pcretest with libreadline .. : no
        Valgrind support ................ : no
        Code coverage ................... : no
    make[1]: Leaving directory `/svr-setup/nginx-1.13.2'
    make: *** [build] Error 2
    real    0m4.074s
    user    0m1.307s
    sys     0m0.767s
    Sun Jul  2 22:53:11 UTC 2017
    Error: 2, Nginx make failed
    report errors on the forums at community.centminmod.com/forums/8/
    Mem:           3948         174        2183          21        1590        3455
    Swap:           255           0         255
    CPU: Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz (2)
    version increment history
    1.2.3-eva2000.09.005 #Sun Jul  2 22:14:07 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul  2 22:15:03 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul  2 22:47:48 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul  2 22:48:04 UTC 2017
    1.2.3-eva2000.09.005 #Sun Jul  2 22:52:39 UTC 2017
    last Centmin Mod local git commit entry
    /usr/local/src/centminmod /svr-setup/nginx-1.13.2
    0fa2c11 George Liu Mon, 3 Jul 2017 07:09:56 +1000
    update staticfiles.conf disable html location context
    25      0       .gitignore
    162     0       Extras/axivo_install.sh
    41      0       README.md
    4170    0       addons/acmetool.sh
    157     0       addons/avginstall.sh
    218     0       addons/customcurl.sh
    200     0       addons/devtoolset-4.sh
    200     0       addons/devtoolset-6.sh
    424     0       addons/ffmpeg.sh
    275     0       addons/geoip.sh
    155     0       addons/git2_install.sh
    167     0       addons/golang.sh
    129     0       addons/ioncube.sh
    159     0       addons/ius-repo.sh
    208     0       addons/linfo.sh
    288     0       addons/maldet.sh
    231     0       addons/modsecurity.sh
    492     0       addons/mysqladmin_shell.sh
    326     0       addons/nodejs.sh
    165     0       addons/opendkim.sh
    378     0       addons/passenger.sh
    199     0       addons/python27_install.sh
    175     0       addons/python34_install.sh
    420     0       addons/rclone.sh
    455     0       addons/wget.sh
    216     0       addons/wpcli.sh
    2987    0       centmin.sh
    656     0       changes.html
    17      0       command_shortcuts.txt
    19      0       config/apc/apc-min.ini
    19      0       config/apc/apc.ini
    6       0       config/etc/resolv.conf
    124     0       config/htpasswdgen/htpasswd.py
    260     0       config/memcached/memcached
    103     0       config/memcached/memcached-socketfix.patch
    16      0       config/memcached/memcached1425.patch
    23      0       config/memcached/memcached1426.patch
    259     0       config/memcached/memcached2
    70      0       config/memcached/twemcache
    70      0       config/memcached/twemcache2
    231     0       config/motd/dmotd.sh
    126     0       config/mysql/my-mdb-4gb.cnf
    126     0       config/mysql/my-mdb-min.cnf
    126     0       config/mysql/my-mdb.cnf
    169     0       config/mysql/my-mdb10-16gb.cnf
    169     0       config/mysql/my-mdb10-32gb.cnf
    169     0       config/mysql/my-mdb10-4gb.cnf
    169     0       config/mysql/my-mdb10-64gb-8c.cnf
    169     0       config/mysql/my-mdb10-64gb.cnf
    169     0       config/mysql/my-mdb10-8gb.cnf
    169     0       config/mysql/my-mdb10-min.cnf
    169     0       config/mysql/my-mdb10.cnf
    141     0       config/mysql/my-mdb55-4gb.cnf
    141     0       config/mysql/my-mdb55-min.cnf
    141     0       config/mysql/my-mdb55.cnf
    59      0       config/mysql/my.cnf
    10      0       config/nginx/503include-main.conf
    1       0       config/nginx/503include-only.conf
    169     0       config/nginx/block.conf
    13      0       config/nginx/blockbots.conf
    158     0       config/nginx/botlimit.conf
    21      0       config/nginx/cloudflare.conf
    43      0       config/nginx/conf.d/demodomain.com.conf
    48      0       config/nginx/conf.d/virtual.conf
    9       0       config/nginx/drop.conf
    46      0       config/nginx/errorpage.conf
    7       0       config/nginx/fastcgi_param_https_map.conf
    34      0       config/nginx/fastcgi_params
    5       0       config/nginx/geoip.conf
    20      0       config/nginx/maintenance.conf
    143     0       config/nginx/nginx.conf
    178     0       config/nginx/pagespeed.conf
    39      0       config/nginx/pagespeedadmin.conf
    11      0       config/nginx/pagespeedhandler.conf
    89      0       config/nginx/php-pool2.conf
    89      0       config/nginx/php-pool3.conf
    89      0       config/nginx/php-pool4.conf
    89      0       config/nginx/php-pool5.conf
    89      0       config/nginx/php.conf
    75      0       config/nginx/phpalt.conf
    55      0       config/nginx/phpfpmd/phpfpm_pool2.conf
    55      0       config/nginx/phpfpmd/phpfpm_pool3.conf
    55      0       config/nginx/phpfpmd/phpfpm_pool4.conf
    55      0       config/nginx/phpfpmd/phpfpm_pool5.conf
    67      0       config/nginx/phpssl.conf
    8       0       config/nginx/phpstatus.conf
    24      0       config/nginx/proxy.conf
    113     0       config/nginx/pscontrol
    1       0       config/nginx/sitestatus.conf
    25      0       config/nginx/ssl/.gitignore
    3       0       config/nginx/ssl_include.conf
    63      0       config/nginx/staticfiles.conf
    1       0       config/nginx/vts_http.conf
    14      0       config/nginx/vts_mainserver.conf
    1       0       config/nginx/vts_server.conf
    4       0       config/nginx/webp.conf
    37      0       config/nginx/wpffpc.conf
    28      0       config/nsd/master/demo.com.zone
    36      0       config/nsd/nsd.conf
    102     0       config/php-fpm/php-fpm-2pools.conf
    103     0       config/php-fpm/php-fpm-min-2pools.conf
    66      0       config/php-fpm/php-fpm-min.conf
    227     0       config/php-fpm/php-fpm-min.conf-fullcomments
    66      0       config/php-fpm/php-fpm-minond.conf
    6       0       config/php-fpm/php-fpm-minond_readme.txt
    67      0       config/php-fpm/php-fpm.conf
    227     0       config/php-fpm/php-fpm.conf-fullcomments
    310     0       config/php-fpm/php-fpm.conf.default
    176     0       config/sendmail/sendmail.mc
    16      0       config/setio/reads.ini
    16      0       config/setio/writes.ini
    53      0       config/xcache/xcache-min.ini
    53      0       config/xcache/xcache-min_php54.ini
    53      0       config/xcache/xcache.ini
    53      0       config/xcache/xcache3.ini
    53      0       config/xcache/xcache3_php54.ini
    23      0       config/xcache/xcache_admin_setup_instructions.txt
    53      0       config/xcache/xcache_php54.ini
    20      0       config/yum/yum.conf
    5       0       config/yum_mirrors/epel_history.txt
    13      0       config/yum_mirrors/mariadb_history.txt
    761     0       config/zendopcache/opcache.php
    19      0       config/zendopcache/zendopcache-min.ini
    19      0       config/zendopcache/zendopcache.ini
    177     0       config/zram/zram
    40      0       cron/diskalert
    -       -       downloads/curlrpms.zip
    -       -       downloads/ffmpeg-depends.zip
    -       -       downloads/hiredis-rpms.zip
    -       -       downloads/rpms.zip
    -       -       downloads/svr-setup.zip
    317     0       example/custom_config.inc
    1       0       giturl.txt
    64      0       htdocs/custom_errorpages/401.html
    64      0       htdocs/custom_errorpages/403.html
    64      0       htdocs/custom_errorpages/404.html
    64      0       htdocs/custom_errorpages/500.html
    64      0       htdocs/custom_errorpages/502.html
    64      0       htdocs/custom_errorpages/503.html
    -       -       htdocs/custom_errorpages/503.jpg
    64      0       htdocs/custom_errorpages/504.html
    64      0       htdocs/custom_errorpages/50x.html
    66      0       htdocs/custom_errorpages/maintenance.html
    -       -       htdocs/default/cmlogo.png
    126     0       htdocs/default/index.html
    22      0       htdocs/default/phpi.php
    45      0       htdocs/demodomain.com/index.html
    185     0       inc/apcinstall.inc
    89      0       inc/apcprotect.inc
    164     0       inc/apcreinstall.inc
    216     0       inc/axelsetup.inc
    27      0       inc/bookmark.inc
    210     0       inc/brotli.inc
    114     0       inc/ccache.inc
    320     0       inc/centminfinish.inc
    9       0       inc/centminlogs.inc
    16      0       inc/centos_seven.inc
    156     0       inc/centoscheck.inc
    188     0       inc/compress.inc
    1779    0       inc/cpcheck.inc
    228     0       inc/cpucount.inc
    226     0       inc/csfinstall.inc
    175     0       inc/csftweaks.inc
    121     0       inc/customrpms.inc
    6       0       inc/diskalert.inc
    459     0       inc/downloadlinks.inc
    3694    0       inc/downloads.inc
    167     0       inc/downloads_centosfive.inc
    421     0       inc/downloads_centosseven.inc
    420     0       inc/downloads_centossix.inc
    59      0       inc/entropy.inc
    30      0       inc/fastmirrors.conf
    51      0       inc/fastopen.inc
    202     0       inc/ffmpeginstall.inc
    161     0       inc/gcc.inc
    215     0       inc/geoip.inc
    1       0       inc/google_perftools.inc
    6       0       inc/htpasswdsh.inc
    148     0       inc/igbinary.inc
    209     0       inc/imagick_install.inc
    44      0       inc/jemalloc.inc
    169     0       inc/logrotate_mysql.inc
    98      0       inc/logrotate_nginx.inc
    88      0       inc/logrotate_phpfpm.inc
    28      0       inc/lowmem.inc
    61      0       inc/luajit.inc
    70      0       inc/mailparse.inc
    148     0       inc/mainmenu_cli.inc
    638     0       inc/mariadb_install.inc
    274     0       inc/mariadb_submenu.inc
    109     0       inc/mariadb_upgrade.inc
    403     0       inc/mariadb_upgrade10.inc
    653     0       inc/mariadb_upgrade101.inc
    639     0       inc/mariadb_upgrade102.inc
    65      0       inc/mariadb_upgrade53.inc
    305     0       inc/mariadb_upgrade55.inc
    87      0       inc/memcacheadmin.inc
    636     0       inc/memcached_install.inc
    56      0       inc/memcheck.inc
    65      0       inc/mongodb.inc
    66      0       inc/motd.inc
    37      0       inc/mysql_install.inc
    48      0       inc/mysql_legacy.inc
    40      0       inc/mysql_proclimit.inc
    125     0       inc/mysqladmin.inc
    28      0       inc/mysqlsecure.inc
    27      0       inc/mysqltmp.inc
    1045    0       inc/nginx_addvhost.inc
    29      0       inc/nginx_backup.inc
    2529    0       inc/nginx_configure.inc
    38      0       inc/nginx_configure_openresty.inc
    35      0       inc/nginx_errorpage.inc
    404     0       inc/nginx_install.inc
    13      0       inc/nginx_logformat.inc
    52      0       inc/nginx_mimetype.inc
    43      0       inc/nginx_modules.inc
    70      0       inc/nginx_modules_openresty.inc
    616     0       inc/nginx_pagespeed.inc
    399     0       inc/nginx_patch.inc
    1051    0       inc/nginx_upgrade.inc
    91      0       inc/nsd_install.inc
    176     0       inc/nsd_reinstall.inc
    49      0       inc/nsd_submenu.inc
    244     0       inc/nsdsetup.inc
    425     0       inc/openssl_install.inc
    122     0       inc/openvz_stack.inc
    27      0       inc/pcre.inc
    737     0       inc/php_configure.inc
    5       0       inc/php_extraopts.inc
    35      0       inc/php_mssql.inc
    897     0       inc/php_upgrade.inc
    7       0       inc/phpfpmdir.inc
    23      0       inc/phpinfo.inc
    103     0       inc/phpng_download.inc
    120     0       inc/phpsededit.inc
    310     0       inc/postfix.inc
    34      0       inc/postgresql.inc
    119     0       inc/pureftpd.inc
    124     0       inc/python_install.inc
    32      0       inc/questions.inc
    35      0       inc/ramdisk.inc
    165     0       inc/redis.inc
    52      0       inc/redis_submenu.inc
    24      0       inc/sendmail.inc
    57      0       inc/setmycnf.inc
    164     0       inc/shortcuts_install.inc
    67      0       inc/siegeinstall.inc
    207     0       inc/sshd.inc
    80      0       inc/suhosin_setup.inc
    217     0       inc/tcp.inc
    57      0       inc/undo.inc
    533     0       inc/updater_submenu.inc
    2575    0       inc/wpsetup.inc
    82      0       inc/xcache_install.inc
    179     0       inc/xcache_installask.inc
    173     0       inc/xcache_reinstall.inc
    308     0       inc/yuminstall.inc
    495     0       inc/yumpriorities.inc
    7       0       inc/yumskip.inc
    63      0       inc/zendopcache_55ini.inc
    204     0       inc/zendopcache_install.inc
    213     0       inc/zendopcache_reinstall.inc
    49      0       inc/zendopcache_submenu.inc
    64      0       inc/zendopcache_tweaks.inc
    264     0       inc/zendopcache_upgrade.inc
    40      0       inc/zlib.inc
    110     0       init/nginx
    106     0       init/nginx-centmin
    117     0       init/nsd
    167     0       init/php-fpm
    1122    0       installer-dnf-gitlab.sh
    1115    0       installer-dnf.sh
    1121    0       installer-gitlab.sh
    1155    0       installer-latest-gitlab.sh
    1147    0       installer-latest.sh
    1153    0       installer-minimal-gitlab.sh
    1147    0       installer-minimal.sh
    1121    0       installer-ngxpagespeed-gitlab.sh
    1115    0       installer-ngxpagespeed.sh
    1114    0       installer.sh
    1120    0       installer55-gitlab.sh
    1114    0       installer55.sh
    1120    0       installer56-gitlab.sh
    1114    0       installer56.sh
    1120    0       installer7-gitlab.sh
    1114    0       installer7.sh
    674     0       license.txt
    19      0       logrotate/nginx
    271     0       patches/cloudflare/nginx__dynamic_tls_records_1011004.patch
    249     0       patches/cloudflare/nginx__dynamic_tls_records_1011005.patch
    19      0       patches/luanginx/luanginx-0107.patch
    20      0       patches/luanginx/luanginx-0108.patch
    17      0       patches/memc-nginx/memc-nginx-1116.patch
    70      0       patches/nginx-http2push/nginx_1.11.12_http2_server_push.patch
    25      0       patches/nginx/openssl-110pre6.patch
    11      0       patches/nginx/openssl-110ticket.patch
    13      0       patches/ngx-cache-purge/ngx-cache-purge-1116.patch
    60      0       patches/openssl/chacha20-smarter.patch
    19      0       patches/redis2-nginx/redis2-nginx-1116.patch
    76      0       readme.txt
    30      0       sysconfig/nsd
    57      0       tools/addsudousers.sh
    458     0       tools/auditd.sh
    192     0       tools/autoprotect.sh
    111     0       tools/backup-perm.sh
    60      0       tools/centminmod_packager.sh
    354     0       tools/cminfo.sh
    126     0       tools/csf-advancetweaks.sh
    381     0       tools/csf-reinstall.sh
    228     0       tools/csfcf.sh
    168     0       tools/csfincapsula.sh
    103     0       tools/email.sh
    70      0       tools/geoipdb-update.sh
    83      0       tools/gitsetup.sh
    129     0       tools/hptweaks.sh
    125     0       tools/imagemagick-fix.sh
    356     0       tools/imagemagick-update.sh
    192     0       tools/kernelcheck.sh
    6       0       tools/mytimes.sh
    101     0       tools/nano-syntax.sh
    1199    0       tools/nginxupdate.sh
    73      0       tools/ntpd.sh
    1340    0       tools/nv.sh
    1666    0       tools/nvwp.sh
    625     0       tools/regen_wpsecure.sh
    628     0       tools/setio.sh
    131     0       tools/sitestatus.sh
     329 files changed, 83997 insertions(+)
    @[email protected] Nginx Upgrade Time: 30.344923442 seconds
  5. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    38,019
    8,348
    10:34 AM
    on centmin.sh menu option 4 run, on yum check prompt can you answer yes to yum check just to see if missing some packages that 123.09beta01 requires and see
  7. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    same error result.
    i did test this incident in centos6 and centos7 at Linode.
    1. using centos6 fresh install using stable scripts then upgrade via #23 everything goes smooth.
    2. using centos7 fresh install using stable scripts then upgrade via #23 then upgrade nginx got the error.
    Let me try again fresh install using centos7 in two ways:
    a. fresh install = stable scripts then upgrade to beta
    b. fresh install = direct install using beta
    regards,
    BusyBee
    38,019
    8,348
    10:34 AM
    if that doesn't help try removing /svr-setup/libressl-2.5.4 before running centmin.sh menu option 4
    rm -rf /svr-setup/libressl-2.5.4
  9. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    same error.
    i'm creating two new VPS in linode now, fresh install with beta and stable.
    very curious want to know the problem :)
    regards,
    busybee
    38,019
    8,348
    10:34 AM
  11. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    38,019
    8,348
    10:34 AM
    should work then.. weird
  13. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    yep, i'm retest now using two new linodes... the question only because there is no "modules" directory on my fresh installation... :(
    38,019
    8,348
    10:34 AM
    on fresh install of centos are you doing anything before you install centminmod itself ? i.e. setting server timezone etc ?
    38,019
    8,348
    10:34 AM
    might have ran into same problem @Matt did at nginx upgrade failing but that was nginx upgrade not fresh installs
    which geographic region is your linode at ?
    38,019
    8,348
    10:34 AM
    also what is output for this command - wrap output in CODE tags
    grep -rn 'server detected' /root/centminlogs/
  17. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    dont do anything except create new host with wordpress.
    linode singapore
    ok, finish fresh install, here what i got: the difference at /usr/local/nginx/ on both VPS are:
    1. left side is using stable scripts - no modules directory
    2. right side is using beta scripts - have modules directory
    is this normal? this will answer my problem so
    i need to do fresh installation using beta scripts on centos7 if i want to get "modules" directory. :)
    38,019
    8,348
    10:34 AM
  19. BusyBee
    BusyBee Member
    40
    9
    7:34 AM
    [01:09][[email protected] centminmod]# grep -rn 'server detected' /root/centminlogs/
    /root/centminlogs/centminmod_1.2.3-eva2000.09.005_020717-204806_php_upgrade.log:800:SG server detected
    /root/centminlogs/centminmod_1.2.3-eva2000.09.005_020717-202425_php_upgrade.log:61:SG server detected
    /root/centminlogs/centminmod_1.2.3-eva2000.09.005_020717-213236_php_upgrade.log:54:SG server detected
    38,019
    8,348
    10:34 AM
    k just checking to see which locale detected in script = SG = singapore
