Featured Nginx ngxtop real time metrics for Nginx
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by eva2000, Jun 5, 2014.
  1. negative
    negative Active Member
    415
    50
    1:54 PM
    1.9.10
    10.1.11
    Yes it is, bingo:)
    I don't wan to use multiple access logs so i prefer amplify now :) Thanks.
    12,579
    8:54 PM
    12,579
    8:54 PM
    hmm looks like ngxtop hasn't been updated since Feb 2015 lebinh/ngxtop !
  4. negative
    415
    50
    1:54 PM
    1.9.10
    10.1.11
    I've no issue about logging
    66.249.65.89 - - [25/Oct/2018:17:14:09 +0300] "GET /forum/thread/thread-title.245979/ HTTP/1.1" 200 46293 "-" "Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)" "66.249.65.89" rt=0.100 ua="127.0.0.1:9000" us="200" ut="0.100" ul="46333" cs=MISS
  5. negative
    415
    50
    1:54 PM
    1.9.10
    10.1.11
    end of life for ngxtop so :)
    12,579
    8:54 PM
    problem isn't logging it's ngxtop can't read non-standard log formats which nginx amplify suggested format you switched to
    12,579
    8:54 PM
    probably, author of ngxtop works for cloudflare probably busy man · GitHub
  8. negative
    415
    50
    1:54 PM
    1.9.10
    10.1.11
    Access.log is okay and i'm checking something with awk command without problem.
    For example, i can show top user agents with this command
    awk -F"\"" '{print $6}' access.log | sort | uniq -dc | sort -nr | head -20
    But ngxtop no result. Because ngxtop EOL
    So what is the awk command for like most called url, top referrer ip
