Nginx ngx_stream_core_module & ngx_stream_ssl_module examples
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by eva2000, May 20, 2015.
    49,890
    11,489
    6:01 PM
    Nginx 1.9 adds TCP load balancing support if you compile Nginx with the following configure options below:
    --with-stream --with-stream_ssl_module
    Official documentation below still is vague as to what you can do:
    However, this thread's purpose is for me and you (if you want to contribute) is to compile a list of links or web sites with info explaining how to use Nginx stream support.
    Example links for Nginx stream usage:
    Centmin Mod Nginx 1.9 Stream Support
    Centmin Mod .08 beta 02 latest update has support for Nginx 1.9 stream modules.
  2. rdan
    1,354
    4:01 PM
    So basically you can serve Nginx request via Memcached with this?
    49,890
    11,489
    6:01 PM
    TCP load balancing means load balancing anything that listens to TCP port like memcached, mysql etc
