pls refer to attached upgrade log Thanks in advance
how did you enable those modules ? it seems the download url for them was broken as the version number was missing in download url for unrelated ngx_cache_purge module Code (Text): Initializing download: http://labs.frickle.com/files/ngx_cache_purge-.tar.gz HTTP/1.1 404 Not Found tar (child): ngx_cache_purge-.tar.gz: Cannot open: No such file or directory tar (child): Error is not recoverable: exiting now tar: Child returned status 2 tar: Error is not recoverable: exiting now [1;32;40mNginx-accesskey 2.0.3 Archive found, skipping download... (B[mnginx-accesskey-2.0.3/ nginx-accesskey-2.0.3/config nginx-accesskey-2.0.3/ngx_http_accesskey_module.c grep: /svr-setup/nginx-1.11.7/auto/modules: No such file or directory
did you originally have older centmin mod 123.08stable and switch to 123.09beta01 afterwards ? either way fixed with 123.09beta01 update at Beta Branch - update ngx_cache_purge download link in 123.09beta01
update 123.09beta01 and use persistent config file set to /etc/centminmod/custom_config.inc set to below to enable Code (Text): NGINX_FLV=y NGINX_MP4=y then run centmin.sh menu option 4
