SSL Nginx SSL issue
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Itworx4me, Feb 17, 2019.
  1. Itworx4me
    196
    21
    3:53 AM
    Nginx 1.17.X
    MariaDB 10.3.X
    I setup a new ngnix vhost today. I added a letsencrypt ssl manually. Everything seems good. I uploaded the new xF 2.1.0 software. When I go to install the software it takes me to this addy with a 404 error.
    https://domain.com/install/install/index.php
    The software is installed in the public directory of the domain. My ngnix configuration seems to think its installed in a subdirectory I think. Where did I go wrong?
    Thanks,
    Itworx4me
  2. Itworx4me
    196
    21
    3:53 AM
    Nginx 1.17.X
    MariaDB 10.3.X
    Here is my domain.com.ssl.conf file
    # For HTTP/2 SSL Setup
        return 302 https://domain.com$request_uri;
      listen 443 ssl http2;
      ssl_dhparam /usr/local/nginx/conf/ssl/domain.com/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/domain.com/domain.com-acme.cer;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/domain.com/domain.com-acme.key;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # dual cert supported ssl ciphers
      ssl_ciphers TLS13-AES-128-GCM-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-CCM-8-SHA256:TLS13-AES-128-CCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/domain.com/domain.com-acme.cer;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=5m;
    #location /admin.php {
        #auth_basic "Private";
        #auth_basic_user_file /usr/local/nginx/conf/htpasswd_admin_php;
            #allow 127.0.0.1;
            #deny all;
    location /install/data/ {
         internal;
    location /install/templates/ {
         internal;
    location /internal_data/ {
         internal;
    # xenforo 2 uncomment / remove hash from next 3 lines
    location /src/ {
         internal;
      #include /usr/local/nginx/conf/drop.conf;
  3. Itworx4me
    196
    21
    3:53 AM
    Nginx 1.17.X
    MariaDB 10.3.X
    Disregard this thread. It was a permissions issue :cry:
    • Funny Funny x 1
