Nginx Nginx ssl cipher suite
Discussion in 'Centmin Mod Insights' started by rdan, Jul 7, 2014.
    7:10 AM
    I'm using Comodo before, they have 2 intermediate that needs to concatenate with the domain resulting 3 cert on unified file.
    Resulting 8KB file just for unified.crt
    That's why I transfer to Rapidssl, Only 2 cert having 3-4 kb file.
    60,082
    12,584
    9:10 AM
    i think depending on cert some roots would be required if the browser doesn't contain a copy https://www.namecheap.com/support/k...x/886/38/chained-and-single-root-certificates and i don't think older browser problem was cert type related but your chosen ciphers ;)
    but for @BamaStangGuy your root is already in trust store so not needed AFAIK
    Yeah Comodo EssentialSSL has 5 files. While Comodo Positive SSL as well as Comodo SSL/Wildcard SSL all have 3 total
    » ComodoSSL / ComodoSSL Wildcard / ComodoSSL UCC
    » Root: AddTrustExternalCARoot.crt
    » Intermediate: ComodoSSLCA.crt
    » End-Entity/Domain Certificate
    » EssentialSSL / Free Certificate
    » Intermediate 1: UTNAddTrustSGCCA.crt
    » Intermediate 2: ComodoUTNSGCCA.crt
    » Intermediate 3: EssentialSSLCA_2.crt
    » PositiveSSL
    » Intermediate: PositiveSSLCA2.crt
  3. rdan
    7:10 AM
    That's bad!
    5 cert to load on first time visitor, wooh!
    60,082
    12,584
    9:10 AM
    Yeah quite a few.. I just stick with Wildcard certs myself - if you need to protect >5 subdomains, then wildcard SSL work out cheaper than individual SSL for each subdomain :D
    60,082
    12,584
    9:10 AM
    This forum's Nginx and OpenSSL configuration has been updated to Nginx 1.7.3 and Centmin Mod Nginx's static compiled OpenSSL 1.0.1h has been patched with Cloudflare RC4 Kill patched OpenSSL version outlined at https://community.centminmod.com/threads/nginx-ssl-cipher-suite.714/#post-3341
    Nginx 1.7.3 updated
    nginx -V
    nginx version: nginx/1.7.3
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC)
    TLS SNI support enabled
    configure arguments: --with-cc-opt='-I/svr-setup/staticlibssl/include -I/usr/include' --with-ld-opt='-L/svr-setup/staticlibssl/lib -Wl,-rpath -lssl -lcrypto -ldl -lz' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --with-openssl=../openssl-1.0.1h --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.8.31.4-beta
    You can see the patch working on IE8 as it skips all RC4 preferred and prioritised SSL ciphers in it's profile at https://www.ssllabs.com/ssltest/viewClient.html?name=IE&version=8&platform=XP and opts for TLS_RSA_WITH_3DES_EDE_CBC_SHA
    Handshake Simulation
  6. rdan
    7:10 AM
    I think it's better to include Cloudflare patch as Default on Centmin Mod ;)
    60,082
    12,584
    9:10 AM
    Added as an option in .08 beta but disabled by default as it's unknown when the next openssl 1.01.x build will break and not be compatible with the patch - committed to .08 beta on Github https://github.com/centminmod/centminmod/commits/123.08beta01 ;) This time no alternate zips it's easier to manage if work from Github for .08 beta01 and .08 centos 7 beta 01 branches :)
  8. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    6:10 PM
    I have fixed this now. Thanks.
    60,082
    12,584
    9:10 AM
    looking better :)
  10. rdan
    7:10 AM
    Please also include this on the stable release zip?
    60,082
    12,584
    9:10 AM
    .07 stable only gets bug fix updates now. Newer features such as this go into .08 beta+ for now :)
  12. Andy
    Andy Active Member
    546
    90
    6:10 PM
    I just order rapidssl and they only emailed me the server cert as well as intermediate.crt
    I saw that you need the root.pem to generate trusted.crt, where did you get that root.pem?
    60,082
    12,584
    9:10 AM
    Google led me to RapidSSL - Knowledge Center - SSL Certificates Support - but asking RapidSSL support probably better
  14. Andy
    Andy Active Member
    546
    90
    6:10 PM
    Got the cert installed correctly according to
    and SSLLabs give me a A+ score but OSCP is not working
    Qualys SSL Labs - Projects / SSL Server Test / quantnet.com
    I basically followed your guide on ssl
            listen 443 ssl spdy;
             server_name quantnet.com;
            ssl_certificate      /usr/local/nginx/conf/ssl/quantnet.com/ssl-unified.crt;
            ssl_certificate_key  /usr/local/nginx/conf/ssl/quantnet.com/ssl.key;
            ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
            ssl_session_cache      shared:SSL:10m;
            ssl_session_timeout  10m;
            ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GC$
            add_header Strict-Transport-Security "max-age=31536000;";
            resolver 8.8.8.8;
            ssl_stapling on;
            ssl_stapling_verify on;
            ssl_trusted_certificate /usr/local/nginx/conf/ssl/quantnet.com/ssl-trusted.crt;
    The ssl-trusted.crt is the part I'm not sure.
    Here is the ssl instruction for nginx RapidSSL - Knowledge Center - SSL Certificates Support
    What missing from this and your instruction to create trusted.crt is the root.pem. Is this something called differently with rapidssl?
  15. Andy
    Andy Active Member
    546
    90
    6:10 PM
    Solved.
    According to this thread nginx - OCSP validation - unable to get local issuer certificate - Server Fault
    I need to get the GeoTrust_Global_CA.crt and rapidsslG3.crt
    I got the GeoTrust directly from geotrust website. The rapidsslg3 is the intermediate cert that included in the email.
    Then we can just do cat Intermediate.crt GeoTrust_Global_CA.crt > ssl-trusted.crt
    Now, OSCD is working
  16. rdan
    7:10 AM
  17. rdan
    7:10 AM
    60,082
    12,584
    9:10 AM
  19. rdan
    7:10 AM
    60,082
    12,584
    9:10 AM
