Upgrade Nginx Nginx recompile again twice aio on;
Discussion in 'Bug Reports' started by EckyBrazzz, Jan 4, 2020.
    189
    5:09 AM
    For some reason OVH had put the old kernel back into my server, so I put 5.4.x again back.
    I had nginx complied for 5.4, so there was an entry in my nginx.conf
    To prevent the same issue again, I removed all old kernels.
    After I reinstalled the kernel 5.4.x and recompiled nginx and found this
    nginx -t
    nginx: [emerg] "aio" directive is duplicate in /usr/local/nginx/conf/nginx.conf:110
    aio on;
    aio on;
    49,890
    11,489
    6:09 PM
    contents of your persistent config file at /etc/centminmod/custom_config.inc ?
  3. steph40
    steph40 Member
    81
    15
    4:09 AM
    1.1.5
    mariadb 10
    Same for me. Here is my custom_config:
    LETSENCRYPT_DETECT='y'
    NGINX_IOURING_PATCH='y'
    NGINX_HPACK='y'
    NGINX_DYNAMICTLS='y'
    PHP_PGO='y'
    49,890
    11,489
    6:09 PM
    what kernels version are you both using ? output for
    uname -r
    and
    uname -r | awk -F. '{ printf("%d%03d%03d%03d\n", $1,$2,$3,$4); }'
  5. steph40
    steph40 Member
    81
    15
    4:09 AM
    1.1.5
    mariadb 10
    5.4.7-1.el7.elrepo.x86_64
  6. EckyBrazzz
    189
    5:09 AM
    49,890
    11,489
    6:09 PM
    what's output for Nginx version
    nginx -V
    you can wrap Nginx version output in quote tags
    @EckyBrazzz you have NGINX_IOURING_PATCH='y' listed twice in your persistent config file, so if you only set 1st instance to = n, then it would of still been detected as y due to latter instance so would of inserted aio on directive setting
  8. EckyBrazzz
    189
    5:09 AM
    Again twice? lol Thanks. Remove one of them. Did it sleepwalking I think.....:banghead: Think I did it twice to be sure it worked...
    Here is the config of this server
  9. steph40
    steph40 Member
    81
    15
    4:09 AM
    1.1.5
    mariadb 10
  10. EckyBrazzz
    189
    5:09 AM
    @steph40 May I ask you why you use cast-function-type? One say yes, other no. Gnome, bug. I don't know.
  11. steph40
    steph40 Member
    81
    15
    4:09 AM
    1.1.5
    mariadb 10
    No clue, it just installed with centminmod install I guess.
    49,890
    11,489
    6:09 PM
    Centmin Mod determins that for Nginx build routines
    everything looks correct to me, remove the duplicate aio on entry and then try recompile nginx via centmin.sh menu option 4 again and see if it happens again
  13. Nik
    Nik Member
    73
    4:09 AM
    I can confirm this duplicate also. I did centmin install, add wp site, upgrade kernel, recompile nginx,php, found the dupe in nginx.conf. No biggie commented it out.
  14. EckyBrazzz
    189
    5:09 AM
    Again, the same, manually deleted from nginx.conf.
    If I did not have an online monitor, all my sites where offline until now because of this. And checked, no double NGINX_IOURING_PATCH='y' in the custom_config.inc
    Feb 20 12:42:10 <<SNIPPED>> systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Feb 20 12:42:10 <<SNIPPED>> nginx[26043]: Starting nginx: nginx: [emerg] "aio" directive is duplicate in /usr/local/nginx/conf/nginx.conf:117
    Feb 20 12:42:10 <<SNIPPED>> nginx[26043]: [FAILED]
    Feb 20 12:42:10 <<SNIPPED>> systemd[1]: nginx.service: control process exited, code=exited status=1
    Feb 20 12:42:10 <<SNIPPED>> systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
    Feb 20 12:42:10 <<SNIPPED>> systemd[1]: Unit nginx.service entered failed state.
    Feb 20 12:42:10 <<SNIPPED>> systemd[1]: nginx.service failed.
    [12:43][root@<<SNIPPED>> ~]# nano /usr/local/nginx/conf/nginx.conf
    [12:43][root@<<SNIPPED>> ~]# nprestart
    Restarting nginx (via systemctl):                          [  OK  ]
    Restarting php-fpm (via systemctl) [  OK  ]
    49,890
    11,489
    6:09 PM
    probably best to set NGINX_IOURING_PATCH='n' for now until I have time to investigate
  16. EckyBrazzz
    189
    5:09 AM
    Guess I stay with @Nik solution for now.
    Also, I had to kill -9 process# in another screen to finish the recompile.
  17. buik
    1,787
    485
    Flanders
    10:09 AM
    Had the same, but I thought of a personal error, so removed the double entry and kept no logs. @eva Thanks for looking after it.
    49,890
    11,489
    6:09 PM
    just tested and can't reproduce on my end, i only get a single aio on; instance
    when you get duplicate aio on; instances, post contents of your /usr/local/nginx/conf/nginx.conf
    cat -n /usr/local/nginx/conf/nginx.conf
    for posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags :)
