Nginx / Railgun Ip issue
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by BamaStangGuy, Jan 30, 2017.
  1. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    9:51 AM
    We are having problems getting the real ip to pass through when using Railgun.
    We have proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; set and
    include /usr/local/nginx/conf/cloudflare.conf; uncommented.
    Yet XenForo is showing our servers IP address for all members. Not cloudflares ip address but our OVH servers ip address.
    55,233
    12,253
    12:51 AM
  3. BamaStangGuy
    668
    192
    9:51 AM
    I figured it out. Needed to add our servers ip to set_real_ip_from
  4. BamaStangGuy
    668
    192
    9:51 AM
    55,233
    12,253
    12:51 AM
    got links to documentation ? you may only need to use proxy_set_header and not need /usr/local/nginx/conf/cloudflare.conf include file
  6. BamaStangGuy
    668
    192
    9:51 AM
    This is what CloudFlare support said:
    Also: Installation — Railgun 5.3.0 documentation
    55,233
    12,253
    12:51 AM
    tried just proxy_set_header X-Forwarded-For $remote_addr; as well ?
  8. BamaStangGuy
    668
    192
    9:51 AM
    Yea just that shows cloudflare ip address in logs and in xf.
    55,233
    12,253
    12:51 AM
    with /usr/local/nginx/conf/cloudflare.conf include file enabled or disabled ? if disabled, try enabling the /usr/local/nginx/conf/cloudflare.conf include file
    55,233
    12,253
    12:51 AM
    also try
       proxy_set_header X-Real-IP $remote_addr;
    55,233
    12,253
    12:51 AM
    or
       proxy_set_header CF-Connecting-IP $http_CF_Connecting_IP;
    or
  12. BamaStangGuy
    668
    192
    9:51 AM
    Just an FYI, none of those worked. The only thing that works is adding the servers ip address to the cloudflare.conf.
    55,233
    12,253
    12:51 AM
    55,233
    12,253
    12:51 AM
    FYI, just about to updated 123.09beta01's tools/csfcf.sh auto routine to add an include file into cloudflare.conf called cloudflare_customips.conf so you can still run tools/csfcf.sh via cronjob and not overwrite your custom added ips in cloudflare_customips.conf
    cat /usr/local/nginx/conf/cloudflare.conf
    include /usr/local/nginx/conf/cloudflare_customips.conf;
    set_real_ip_from 103.21.244.0/22;
    set_real_ip_from 103.22.200.0/22;
    set_real_ip_from 103.31.4.0/22;
    set_real_ip_from 104.16.0.0/12;
    set_real_ip_from 108.162.192.0/18;
    set_real_ip_from 131.0.72.0/22;
    set_real_ip_from 141.101.64.0/18;
    set_real_ip_from 162.158.0.0/15;
    set_real_ip_from 172.64.0.0/13;
    set_real_ip_from 173.245.48.0/20;
    set_real_ip_from 188.114.96.0/20;
    set_real_ip_from 190.93.240.0/20;
    set_real_ip_from 197.234.240.0/22;
    set_real_ip_from 198.41.128.0/17;
    set_real_ip_from 199.27.128.0/21;
    set_real_ip_from 2400:cb00::/32;
    set_real_ip_from 2405:8100::/32;
    set_real_ip_from 2405:b500::/32;
    set_real_ip_from 2606:4700::/32;
    set_real_ip_from 2803:f800::/32;
    set_real_ip_from 2c0f:f248::/32;
    set_real_ip_from 2a06:98c0::/29;
    real_ip_header CF-Connecting-IP;
    so stick your custom ips etc into /usr/local/nginx/conf/cloudflare_customips.conf
    set_real_ip_from YOURCUSTOM_IPADDRESS;
