Nginx Nginx permission issues
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Robert, Sep 7, 2014.
  1. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    I am trying to install Nginx from last couple of days but not able to get around it as I want.
    So I used Centmin Mod on Linode 1GB plan VPS. Although server is running but have coupld of issues and cuncerns.
    1. I added a host with centmin.sh and it gave permissions to nginx:nginx which does not allow me (as user) to read write in folder. How can I change it to user:user and to all future domains added from centmin too.
    EDIT: I have a user account. I do not use root for daily operations.
    2. If I change any config files, will I be able to update my server via centmin without worrying about overwriting my changes.
  2. dorobo
    dorobo Active Member
    420
    104
    7:03 AM
    latest
    latest
    nginx:nginx is the right permission. Aren't you running as root?
  3. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    Sorry I forgot to mention. Just edited original post.
    I have a user account. I do not use root for daily operations. Uploading website files, editing etc.
    55,380
    12,255
    9:03 AM
    only root user can chown user/group changes from root:root ;)
  5. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    What?
    I know how to change ownership with root and I can easily change /home/nginx/ folder ownership to my user but then nginx will not have permissions to read and write in domain. What I want is to run nginx as my user. How to do that.
    If I edit nginx.conf file and chnage user from nginx to my user, will that make nginx to run as user? I did that and it does not work. Nginx is not able to write or read.
    55,380
    12,255
    9:03 AM
    The way Centmin Mod sets up Nginx right now, you can only run domain site files as user/group = nginx/nginx as it's legacy structure from original Centmin. Only when proper jailed/chroot user features roll out will you have per user/group per domains - see preview and explanation at Previews - Jailed / chrooted SFTP & SSH user Nginx vhost menu | Centmin Mod Community
    Getting started guide step 2 has info Getting Started with Centmin Mod
    Location you upload files is listed when you created your new Nginx vhost:
    upload files to /home/nginx/domains/newdomain.com/public
    Whenever you completed uploading new files, you'd need to give them correct user and group permissions within SSH window as root user type:
    chown -R nginx:nginx /home/nginx/domains/newdomain.com/public
    You do not need to do this will files created via PHP-FPM or Nginx, i.e. if you use Wordpress and used Wordpress admin to add a new Wordpress plugin, the plugin will automatically have nginx user and group permissions as it was processed by PHP-FPM.
    To verify the files and directories are with nginx user and group permissions, use command
    ls -lah directorypath
    i.e.
    ls -lah /home/nginx/domains/newdomain.com/public
    total 36K
    drwxr-sr-x 2 nginx nginx 151 Aug 11 05:24 .
    drwxr-sr-x 6 nginx nginx 56 Aug 11 05:24 ..
    -rw-r--r-- 1 nginx nginx 1.6K Aug 11 05:24 403.html
    -rw-r--r-- 1 nginx nginx 1.6K Aug 11 05:24 404.html
    -rw-r--r-- 1 nginx nginx 2.1K Aug 11 05:24 500.html
    -rw-r--r-- 1 nginx nginx 2.1K Aug 11 05:24 502.html
    -rw-r--r-- 1 nginx nginx 2.2K Aug 11 05:24 503.html
    -rw-r--r-- 1 nginx nginx 2.1K Aug 11 05:24 504.html
    -rw-r--r-- 1 nginx nginx 2.2K Aug 11 05:24 50x.html
    -rw-r--r-- 1 nginx nginx 1.2K Aug 11 05:24 index.html
    -rw-r--r-- 1 nginx nginx 2.2K Aug 11 05:24 maintenance.html
  7. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    You are right. Centmin is installed in a way, we can not change nginx user or it will break server. I know because I tried it alrady and I had to setup server again. lol
    But I think there should be an option to change user in centmin before start installing. Because it's too much hassel to just update one single file on server.
    Since most people turn off direct root login via SSH or SFTP (for security reasons). To upload a file, these are the steps
    1. Upload file via user
    2. SSH with user and then login to root.
    3. Move file to /home/nginx/domains/newdomain.com/public with root user
    4. Run chown
    And if you are making chnages on your website theme then you will probably have to repeat these steps 100 times a day.
    I think that defeats the whole purpose of this mod. It is suppose to make life easier and save time by installing all these components in one shot. infact, it does save time in installing server but it also increases post installation work.
    For now I am trying to setup server manually. Will come back later if I find centmin suitable for a website/server.
    Thank you and keep up good work.
    55,380
    12,255
    9:03 AM
    Yeah understand your point. You can always setup a cronjob to change the user/group on /home/nginx/domains/newdomain.com/public
    For me, i rarely upload files via SFTP and if I do its as root user direct into /home/nginx/domains/newdomain.com/public. Then I do it all via SSH window if I need to update files i.e. upgrade Xenforo just upload zip file then SSH in and unzip, chown -R nginx:nginx and cp files over.
  9. dorobo
    420
    104
    7:03 AM
    latest
    latest
    I don't think anyone running Centminmod is not logging directly as root. Anyone?
    Use PubkeyAuthentication if you're concerned with security.
    55,380
    12,255
    9:03 AM
    Yeah most folks using Centmin Mod will be using root user.
    Another method some folks use is setup SFTP user at /home/username/public and upload to that folder and set a cronjob or write a script that auto moves files from /home/username/public to /home/nginx/domains/newdomain.com/public with nginx:nginx user/group.
  11. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    I am already doing that. Of course for my user account since I never allow direct root login with or without password. In fact you will never need to be root unless you update server or change configuration.
    Don't you think that's because they don't have any other better option.
  12. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    Yes, it's an option but cron job is never a good idea for this purpose because unless you are running it every 60 sec (or similar), it will not update website imedieately and also this might break website because you uploaded a file with errors (of course by mistake and we make fair share of em) and you will have to wait for next cron to run and update correct file or follow my steps in previous posts.
    Anyway the way I undrstand I have two options.
    1. Either I only use root logiin.
    2. or I use cron job.
    55,380
    12,255
    9:03 AM
    Yeah for now there is no better way as you understand it due to legacy Nginx vhost path structure used.
    Just to put things in perspective, no Nginx YUM or APT package install from official distros include any jailed/chroot user options from out of the box installs as well unless you specifically configure for it and modify the default setups that those packages initially install. It's the same for Centmin Mod Nginx right now until jailed/chroot features come.
  14. Robert
    Robert New Member
    4:33 AM
    Nginx 1.7.4
    MariaDB 5.5
    :) Thank you for addressing my concerns.
    Really appreciate it.
    55,380
    12,255
    9:03 AM
    Yeah I understand, it's why I planned for jailed/chroot users to plug that missing aspect of Centmin Mod Nginx left over from original Centmin structure :)
