Nginx PageSpeed Nginx Pagespeed Troubleshooting issues and errors
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by BamaStangGuy, May 25, 2014.
  1. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    11:40 AM
    Somethings I can't help, such as adsense and other ad networks we use.
    59,592
    12,540
    2:40 AM
    Yeah that will drag down your scores :)
  3. BamaStangGuy
    669
    192
    11:40 AM
    VIP members should have a very good experience though :D
    59,592
    12,540
    2:40 AM
    Ah something I plan to setup on this forum too using the User Upgrades feature eventually :D
  5. Matt
    Matt Well-Known Member
    933
    415
    Rotherham, UK
    5:40 PM
    1.5.15
    MariaDB 10.2
    That's what I do on my site. They don't get ANY ads, so page load is bloody quick for them.
  6. BamaStangGuy
    669
    192
    11:40 AM
    The only ad javascript I serve to VIP members is skimlinks as it is invisible to them.
  7. Matt
    933
    415
    Rotherham, UK
    5:40 PM
    1.5.15
    MariaDB 10.2
    I remove skimlinks as well for premium members.
  8. BamaStangGuy
    669
    192
    11:40 AM
    So for those of you running Google Adsense what are you doing to be able to use defer js?
    59,592
    12,540
    2:40 AM
    I believe @RoldanLT also has the similar problem with Adsense. I haven't tried on ngx_pagespeed enabled site - might try later on the forums just to see what can be done with ngx_pagespeed and Adsense
  10. BamaStangGuy
    669
    192
    11:40 AM
  11. rdan
    12:40 AM
    I'm using the addon.
    I disable ngx_pagespeed defer js.
    From my experience, when defer js of pagespeed is enabled, sometimes adsense doesn't load fine for 1st time visitor, reason to cut off your revenue.
  12. rdan
    12:40 AM
  13. BamaStangGuy
    669
    192
    11:40 AM
    I have it disabled for admin to. The only site it does it on is the one with pagespeed enabled. All my other sites don't have the constant loading.
  14. rdan
    12:40 AM
    I'm using pagespeed too, both of us I think are on https also and I don't have that problem :confused:
  15. BamaStangGuy
    669
    192
    11:40 AM
    It only happens on the page_container template with this:
  16. rdan
    12:40 AM
    Happens for me too :D
  17. BamaStangGuy
    669
    192
    11:40 AM
    Seems to be an add-on. Doesn't happen on default install. What template does that go to?
    59,592
    12,540
    2:40 AM
  19. rdan
    12:40 AM
    Happens to my default theme also.
  20. BamaStangGuy
    669
    192
    11:40 AM
    Then its an add-on. My completely default forum doesn't do it.
