Nginx PageSpeed Nginx Pagespeed Troubleshooting issues and errors
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by BamaStangGuy, May 25, 2014.
    59,592
    12,540
    2:39 AM
  2. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    11:39 AM
    Does that page spit out errors to any log file that I can check?
    59,592
    12,540
    2:39 AM
    unfortunately not, all logging is done in memory
    59,592
    12,540
    2:39 AM
  5. BamaStangGuy
    669
    192
    11:39 AM
    I am not sure what else to try. Something just seems off with how its configured but I don't see errors anywhere. :confused:
  6. BamaStangGuy
    669
    192
    11:39 AM
    I assume you have this working on a server running SSL and SPDY with the latest pagespeed? I am going to fire up a fresh droplet and give it a go.
    59,592
    12,540
    2:39 AM
  8. BamaStangGuy
    669
    192
    11:39 AM
    59,592
    12,540
    2:39 AM
    yeah my Wordpress blog is running Nginx 1.7.1 + ngx_pagespeed 1.8.31-2 beta and Google SPDY/3.1 https://blog.centminmod.com with everything fine besides lazy loading image filter being semi broken since 1.8.31-2 beta update
    will do :)
  10. BamaStangGuy
    669
    192
    11:39 AM
    Ok so I made something happen... nothing works when you go to /pagespeed_console but looking at the pagespeedadmin.conf settings I tried
    ngx_pagespeed_statistics and it spit out this: Screen Shot 2014-05-29 at 6.36.28 AM.png
  11. BamaStangGuy
    669
    192
    11:39 AM
    and the messages one works to. You just have to call them individually. pagespeed_console is broken.
    Any idea on what this means:
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/media_lightbox.js?_v=3bc78865': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xenforo/bb_code_edit.js?_v=ed9fc917': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/media_user_tag.js?_v=3bc78865': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/gallery_bb_code.js?_v=3bc78865': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/media_view_navigation.js?_v=3bc78865': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/media_view.js?_v=3bc78865': as https is not supported
    [Thu, 29 May 2014 11:36:39 GMT] [Info] [3296] Cannot fetch url 'https://www.aspiescentral.com/js/xengallery/min/media_share.js?_v=3bc78865': as https is not supported
    59,592
    12,540
    2:39 AM
    yup it's working now.. pagespeed_console was blank for me at first after a while it shows the stats - i think it takes time to gather to produce the charts
    59,592
    12,540
    2:39 AM
    ah if you're using https/SSL need additional settings which are not found in my forum's posted pagespeed.conf https://developers.google.com/speed/pagespeed/module/https_support
    For example if I had https/SSL enabled on the forums I need to add to pagespeed.conf this line. Changing your paths appropriately for your domain of course.
    pagespeed LoadFromFile "https://community.centminmod.com" "/home/nginx/domains/community.centminmod.com/public";
    updated pagespeed.conf thread at http://community.centminmod.com/threads/this-forums-pagespeed-conf.62/ with same info for others :)
  14. BamaStangGuy
    669
    192
    11:39 AM
    Wow that changes everything. Thanks! So much more is being rewritten now that wasn't touched before.
    59,592
    12,540
    2:39 AM
    59,592
    12,540
    2:39 AM
    A before and after gtmetrix.com scan would be interesting to see :)
  17. BamaStangGuy
    669
    192
    11:39 AM
    I will do that as soon as I ensure everything is setup perfectly with pagespeed. My Google Font rewrite still isn't working:
    [Thu, 29 May 2014 12:21:17 GMT] [Info] [3521] No permission to rewrite 'https://fonts.googleapis.com/css?family=Roboto:400,700'
    Setting:
    59,592
    12,540
    2:39 AM
    that's correct pagespeed only rewrites google font css elements not the actual font itself as it's hosted on a 3rd party url. So that entry is correct
  19. BamaStangGuy
    669
    192
    11:39 AM
    No before yet but this is current
    Screen Shot 2014-05-29 at 8.03.20 AM.png Screen Shot 2014-05-29 at 8.03.26 AM.png Screen Shot 2014-05-29 at 8.04.30 AM.png
    59,592
    12,540
    2:39 AM
    Nice, definitely higher scoring than default Xenforo theme at least :D
