Nginx nginx not starting "unknown server_https variable"
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by neverminder, Dec 2, 2017.
  1. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    Solved the phpmyadmin install part. I removed /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf.bak. I'll get back with the rest of the issues in a few minutes.
  2. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    phpmyadmin installed without errors, but trying to access it generates ERR_TOO_MANY_REDIRECTS.
    59,738
    9:43 AM
    What do you get for output for curl header checks in SSH where domain.com is yourdomain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    curl -I https://domain.com
    • If the problematic version(s) you are trying to get has a 301 HTTP status then it's probably a browser cached 301 permanent redirect issue.
    • If you use chrome in private incognito browsing session you probably have working www domain access ? if so you need to clear you browser of the 301 permanent redirect. If that works you need to clear your browsers' cache as outlined at Refreshyourcache.com - The Guide to Clear your Browser Cache!
    • That is dangers of 301 permanent redirects as they are cached in web browsers forever until cleared. 302 temp redirects are not permanent.
    59,738
    9:43 AM
    if you have cloudflare https enabled you can set http to https redirect on cloudflare level but remove the http to https redirect on nginx level - otherwise = too many redirects
  5. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    The only 301 redirects are for http://www and https:/www
    Right now, my problem is that I can't access phpmyadmin page because of too many redirects. I didnt set up cloudflare to redirect http to https yet.
  6. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    On the other hand, trying the same on web.mszp.ro i'm getting this:
    # curl -I https://web.mszp.ro
    curl: (60) Peer's certificate issuer has been marked as not trusted by the user.
    More details here: http://curl.haxx.se/docs/sslcerts.html
    curl performs SSL certificate verification by default, using a "bundle"
     of Certificate Authority (CA) public keys (CA certs). If the default
     bundle file isn't adequate, you can specify an alternate file
     using the --cacert option.
    If this HTTPS server uses a certificate signed by a CA represented in
     the bundle, the certificate verification probably failed due to a
     problem with the certificate (it might be expired, or the name might
     not match the domain name in the URL).
    If you'd like to turn off curl's verification of the certificate, use
     the -k (or --insecure) option.
  7. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    Just saw that all the lines in the ssl.conf file are commented out. I really couldn't tell if I did this, in all that panic when my site went down, as I didn't log anything like that (and I log quite every move).
    59,738
    9:43 AM
    did you enable HSTS on Cloudflare or nginx ? that forces the entire domain and subdomains accessed to be forced over HTTPS as preemptive security measure
    Are the host.domain.com and HTTPS enabled site also on same top level domain.com ? did you enable HSTS with include subdomain too ? if you did then you're telling browsers to force HTTP to HTTPS redirected connections for domain.com and any *.domain.com subdomain as well
    see Enabling HSTS for SSL for specifics
    As accessing host.domain.com is usually reserved for stats and admin pages the Centmin Mod LEMP stack owner only needs to access, you can just clear your web browser's HSTS record for the domain.com and host.domain.com so the web browser no longer redirects from HTTP to HTTPS. I posted a thread at SSL - How to clear HSTS browser cache | Centmin Mod Community specifically for this :)
    is web.mszp.ro your main hostname ? if so, could be as above cloudflare HSTS is enabled
  9. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    I didnt enable HSTS. I cleared my web browser's HSTS record, I even turned off SSL in Cloudflare. phpmyadmin page still has too many redirections.
    Yes, web.mszp.ro is my main hostname, but, as I said, HSTS is out of the question.
    59,738
    9:43 AM
    http://web.mszp.ro works for header check at https://tools.keycdn.com/curl
    HTTP/1.1 200 OK
    Date: Sun, 10 Dec 2017 00:12:26 GMT
    Connection: keep-alive
    Set-Cookie: __cfduid=d12d120263dee09efb5ca374effc40e361512864746; expires=Mon, 10-Dec-18 00:12:26 GMT; path=/; domain=.mszp.ro; HttpOnly
    Last-Modified: Sat, 09 Dec 2017 21:29:12 GMT
    Vary: Accept-Encoding
    Expires: Mon, 11 Dec 2017 00:12:26 GMT
    Cache-Control: max-age=86400
    Cache-Control: public, must-revalidate, proxy-revalidate
    Server: cloudflare-nginx
    CF-RAY: 3cabfe16e55599ec-EWR
    so the redirect is your web browser 301 cache probably (separate from HSTS cache)
  11. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    Yes, but for the phpmyadmin page it doesn't work:
    Date: Sun, 10 Dec 2017 00:16:57 GMT
    Set-Cookie: __cfduid=dd0abcf77a045f420a2f30835ade2121a1512865016; expires=Mon, 10-Dec-18 00:16:56 GMT; path=/; domain=.mszp.ro; HttpOnly
    CF-RAY: 3cac04b4061c218c-EWR
  12. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    In fact, I think this shows the problem:
    Same query, but for https://web.mszp.ro/XXXXX_mysqladminXXXXX/
    HTTP/2 301
    date: Sun, 10 Dec 2017 00:34:30 GMT
    content-type: text/html
    set-cookie: __cfduid=d5e826a1e71daadecc840d92a346034a71512866070; expires=Mon, 10-Dec-18 00:34:30 GMT; path=/; domain=.mszp.ro; HttpOnly
    server: cloudflare-nginx
    cf-ray: 3cac1e6dca1791a6-EWR
    59,738
    9:43 AM
    you have cloudflare orange cloud enabled on the hostname web.mszp.ro that's why
  14. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    OK, I'm going to access it through the server's IP. That way is working. Back to the original problem, I'll keep the fastcgi_param HTTPS $server_https; line commented out in php-wpsc.conf for now. Hopefully, it won't be the source of more problems. Still don't know when and what happened. Are you sure it had nothing to do with me removing /etc/centminmod/php.d/mongodb.ini and /etc/centminmod/php.d/redis.ini? This is the only thing I did besides installing phpmyadmin.
    Thanks for all your help so far!
  15. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    Well, if I try to activate full SSL on Cloudflare, accessing http://mszp[dot]ro (vhost) redirects me to https://web.mszp[dot]ro (mainhost).
    If I change my wp and site URLs to https in wp admin, trying to access the site ends up in too many redirects.
    I'm perfectly stuck. I don't understand anything anymore :(
    59,738
    9:43 AM
    yup sure nothing to do with those ini settings files
    FYI, if you want to post unparsed hyper links you can wrap the address or text in [PLAIN][/PLAIN] tags BB Codes | Centmin Mod Community.
    output for
    curl -Iv http://mszp.ro
    curl -Iv https://mszp.ro
    curl -Iv http://web.mszp.ro
    curl -Iv https://web.mszp.ro
    grep -rn 'mszp.ro' /usr/local/nginx/conf/conf.d | grep server_name
    also if you're using cloudflare full ssl, make sure to uninstall official cloudflare wordpress plugin as that is only used for cloudflare flexible ssl users
  17. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    # curl -Iv http://mszp.ro
    * About to connect() to mszp.ro port 80 (#0)
    *   Trying 104.27.153.136...
    * Connected to mszp.ro (104.27.153.136) port 80 (#0)
    > HEAD / HTTP/1.1
    > User-Agent: curl/7.29.0
    > Host: mszp.ro
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Date: Mon, 11 Dec 2017 06:10:13 GMT
    < Content-Type: text/html; charset=utf-8
    < Connection: keep-alive
    < Set-Cookie: __cfduid=d506f9b8045c7d7c1865ef7be06d90d391512972613; expires=Tue, 11-Dec-18 06:10:13 GMT; path=/; domain=.mszp.ro; HttpOnly
    < Last-Modified: Mon, 11 Dec 2017 03:49:32 GMT
    < Vary: Accept-Encoding
    < Server: cloudflare-nginx
    < CF-RAY: 3cb64795329f9c05-AMS
    * Connection #0 to host mszp.ro left intact
    # curl -Iv https://mszp.ro
    * About to connect() to mszp.ro port 443 (#0)
    * Connected to mszp.ro (104.27.153.136) port 443 (#0)
    * Initializing NSS with certpath: sql:/etc/pki/nssdb
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSL connection using TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
    * Server certificate:
    *     subject: CN=sni45979.cloudflaressl.com,OU=PositiveSSL Multi-Domain,OU=Domain Control Validated
    *     start date: Dec 09 00:00:00 2017 GMT
    *     expire date: Jun 17 23:59:59 2018 GMT
    *     common name: sni45979.cloudflaressl.com
    *     issuer: CN=COMODO ECC Domain Validation Secure Server CA 2,O=COMODO CA Limited,L=Salford,ST=Greater Manchester,C=GB
    > HEAD / HTTP/1.1
    > Host: mszp.ro
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Date: Mon, 11 Dec 2017 06:14:37 GMT
    < Set-Cookie: __cfduid=d24238a0a7c4a57f0d6ac3231c184a8661512972877; expires=Tue, 11-Dec-18 06:14:37 GMT; path=/; domain=.mszp.ro; HttpOnly
    < CF-RAY: 3cb64e05ea909bff-AMS
    # curl -Iv http://web.mszp.ro
    * About to connect() to web.mszp.ro port 80 (#0)
    *   Trying 62.xxx.xxx.xx...
    * Connected to web.mszp.ro (62.xxx.xxx.xx) port 80 (#0)
    > HEAD / HTTP/1.1
    > Host: web.mszp.ro
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Date: Mon, 11 Dec 2017 06:16:08 GMT
    < Content-Length: 1493
    < Last-Modified: Sat, 09 Dec 2017 21:29:12 GMT
    < ETag: "5a2c55a8-5d5"
    < Server: nginx centminmod
    < Expires: Tue, 12 Dec 2017 06:16:08 GMT
    < Cache-Control: max-age=86400
    < Cache-Control: public, must-revalidate, proxy-revalidate
    < Accept-Ranges: bytes
    * Connection #0 to host web.mszp.ro left intact
    # curl -Iv https://web.mszp.ro
    * About to connect() to web.mszp.ro port 443 (#0)
    * Connected to web.mszp.ro (62.xxx.xxx.xx) port 443 (#0)
      CApath: none
    *     subject: CN=web.mszp.ro,OU=IT,O=web.mszp.ro,L=Los Angeles,ST=California,C=US
    *     start date: Dec 09 21:36:23 2017 GMT
    *     expire date: Nov 15 21:36:23 2117 GMT
    *     common name: web.mszp.ro
    *     issuer: CN=web.mszp.ro,OU=IT,O=web.mszp.ro,L=Los Angeles,ST=California,C=US
    * NSS error -8172 (SEC_ERROR_UNTRUSTED_ISSUER)
    * Peer's certificate issuer has been marked as not trusted by the user.
    * Closing connection 0
    # grep -rn 'mszp.ro' /usr/local/nginx/conf/conf.d | grep server_name
    /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf:4:            server_name web.mszp.ro;
    /usr/local/nginx/conf/conf.d/mszp.ro.conf:9:#            server_name mszp.ro;
    /usr/local/nginx/conf/conf.d/mszp.ro.conf:14:  server_name mszp.ro www.mszp.ro;
    /usr/local/nginx/conf/conf.d/mszp.ro.ssl.conf:10:#  server_name mszp.ro www.mszp.ro;
    /usr/local/nginx/conf/conf.d/mszp.ro.ssl.conf:16:#  server_name mszp.ro www.mszp.ro;
    /usr/local/nginx/conf/conf.d/virtual.conf:4:            server_name web.mszp.ro;
    I don't have any cloudflare wp plugin installed.
    59,738
    9:43 AM
    grep output looks good as does curl header for
    it reports that https/ssl isn't setup
    and curl header check for https version works too
    so means too many redirects is happening at browser caching level it seems
    tried a different browser/incognito session + clear browser cache + HSTS cache as well + reboot your local pc ?
  19. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    You can see for yourself right now. I enabled full SSL on Cloudflare. http://mszp.ro working as expected, https://mszp.ro is redirecting to http://web.mszp.ro (mainhost).
    LE: wp and server URLs in wp admin are http
  20. neverminder
    neverminder Member
    44
    2:43 AM
    1.13.6
    10.0.33
    I uncommented the following lines in mszp.ro.ssl.conf:
       return 302 https://mszp.ro$request_uri;
    Testing nginx now warns me:
    # nginx -t
    nginx: [warn] conflicting server name "mszp.ro" on 0.0.0.0:80, ignored
    nginx: [warn] conflicting server name "www.mszp.ro" on 0.0.0.0:80, ignored
