Nginx Nginx help info for Ddos attacks
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Apr 20, 2016.
    4,101
    428
    5:19 PM
    Nginx-1.26.x
    Hi
    Here we have some info about ddos protection using Nginx and some info also related to Wordpress latest attack:
    DDos Mitigation - Using NGINX to Prevent DDoS Attacks | NGINX
    https://javapipe.com/block-wordpress-xml-rpc-ddos-attacks-with-nginx
    1 Minute fix for WordPress XML-RPC Pingback Vulnerability to Quadratic Attack | 3PRIME Blog
    How To Protect WordPress from XML-RPC Attacks on Ubuntu 14.04 | DigitalOcean
    Survive DDOS attack with Nginx's and fail2ban
    Also another user recommends to use 444 instead of 403 user agent block:
    if ($http_user_agent ~* (wordpress) ) {
    return 444;
    if ($http_user_agent ~ (WordPress) ) {
    return 444;
    Also this one may help:
    reset_timedout_connection on;
    That will help disconnect clients that have not responded on a timely manner, which is typical from a ddos attack, some bots will simply make an http call and never send the ack which will make the tcp connection timeout on the webservers default timeout which is pretty long ( usually ).
    Another recommendation:
    Use power of LUA module and bash-fu to integrate with iptables, to block zombies on a system level to prevent concurrent UDP/SSH/whatever-flood (you may consider using ipset utility to handle large sets of zombie IPs which iptables will fail to process fast enough).
  2. Revenge
    Revenge Active Member
    469
    93
    Portugal
    3:19 PM
    1.9.x
    10.1.x
    This is becoming normal i think...
    One of my sites: running for 40 seconds, 79215 records processed: 1973.50 req/sec
    My page load time is slower by 0,6s lol... They need to make an attack a lot bigger.
  3. Revenge
    469
    93
    Portugal
    3:19 PM
    1.9.x
    10.1.x
    I created the fail2ban rule on this server, and i was still able to ban more than 4700 ip's. Then the attack stopped, probably because it was not taking any affect, so the guy have probably given up:
    # fail2ban-client status pingback
    Status for the jail: pingback
    |- Filter
    |  |- Currently failed: 0
    |  |- Total failed:     85358
    |  `- File list:        /var/log/nginx/domains/iosgods.com.log
    `- Actions
       |- Currently banned: 4707
       |- Total banned:     4707
  4. pamamolf
    4,101
    428
    5:19 PM
    Nginx-1.26.x
    That's great :)
    Can you provide more details about installation of fail to ban and how to set this rule?
  5. Revenge
    469
    93
    Portugal
    3:19 PM
    1.9.x
    10.1.x
    Fail2ban is still banning IP's, after the attack stopped. I guess it takes time to ban all of them lol
  6. Revenge
    469
    93
    Portugal
    3:19 PM
    1.9.x
    10.1.x
  7. Revenge
    469
    93
    Portugal
    3:19 PM
    1.9.x
    10.1.x
    If someone wants the list of the hacked wordpress server that attacked my server:
    |- Filter
    `- Actions
       `- Banned IP list:   200.129.69.110 162.13.189.194 31.22.4.211 23.104.140.164 107.170.41.66 104.131.45.213 162.250.144.155 45.33.13.13 210.209.86.19 84.21.108.19 104.197.9.169 159.203.74.3 52.17.124.92 104.155.32.153 92.51.145.127 153.122.4.236 54.158.134.54 5.63.155.196 116.197.130.200 77.222.150.67 104.155.10.168 66.135.42.91 216.172.178.248 96.91.156.181 210.122.36.241 188.165.238.24 50.198.19.50 64.34.218.35 132.247.83.250 192.162.100.196 162.13.90.85 37.120.189.186 108.171.180.141 84.52.159.178 45.55.148.230 92.243.3.217 195.228.45.61 187.0.207.60 50.116.14.143 54.68.116.246 119.9.92.123 78.29.26.50 54.236.86.20 50.171.121.157 153.127.240.233 195.96.241.182 87.230.95.177 50.63.182.67 162.218.89.49 54.67.120.170 212.235.189.238 164.132.224.111 144.76.8.75 194.145.208.88 54.245.100.108 209.126.99.68 205.147.110.201 40.113.119.142 217.73.170.10 162.209.127.79 54.214.4.246 50.63.154.7 54.79.115.83 111.65.227.132 79.136.125.24 202.64.32.68 77.86.229.248 213.241.41.50 192.241.235.133 52.68.142.175 104.130.61.85 72.69.28.204 221.140.99.210 199.167.148.73 95.174.28.156 178.18.124.36 54.171.243.44 104.200.25.88 1.223.132.234 45.55.76.130 36.83.1.51 195.12.114.136 92.51.146.108 104.131.134.150 52.49.172.141 40.127.132.240 54.84.61.125 74.92.198.105 186.202.165.78 176.28.121.91 178.79.171.12 174.142.90.216 203.66.130.206 80.82.117.192 85.10.246.199 23.88.82.55 50.63.177.9 109.233.99.215 94.177.33.158 131.206.43.10 204.9.205.184 204.9.205.185 188.40.84.150 40.76.17.50 104.238.185.35 193.40.5.152 162.221.206.226 216.198.164.57 13.92.184.26 95.173.185.77 213.223.170.170 192.30.33.56 52.50.248.33 5.9.81.72 83.222.214.125 115.146.95.196 210.177.214.57 159.203.99.41 54.247.93.18 23.226.236.10 87.230.11.106 216.165.135.10 149.202.73.110 128.146.194.10 5.9.11.215 173.255.213.18 62.75.241.100 186.154.200.99 54.83.33.102 133.130.107.232 194.102.58.22 54.149.129.169 104.154.71.57 188.121.50.41 52.38.75.180 144.76.61.180 139.162.4.17 209.90.136.53 52.28.49.132 91.250.115.232 149.56.108.235 45.118.135.68 136.243.3.77 88.82.180.33 54.172.240.145 62.233.106.99 52.29.188.141 176.28.102.47 162.243.238.55 144.76.201.5 202.55.191.89 78.47.92.46 75.98.171.16 45.55.65.127 108.59.83.170 141.138.141.189 192.155.87.90 174.51.5.222 124.108.39.45 23.97.138.197 193.183.99.122 212.227.106.68 104.236.211.80 190.197.87.116 115.159.184.68 192.80.133.44 192.249.61.130 207.166.138.50 5.56.63.226 94.103.46.11 209.54.61.99 45.55.137.51 200.111.160.50 38.94.160.116 38.94.160.117 52.86.43.43 72.3.215.245 195.154.163.32 54.165.244.96 151.80.151.66 194.132.113.73 200.130.15.92 212.179.42.34 178.32.211.109 148.251.136.118 107.150.16.220 144.76.97.53 162.209.99.219 178.254.38.242 59.188.7.69 65.202.62.212 130.193.86.130 151.248.0.175 192.26.129.146 50.63.137.74 104.236.6.230 52.21.93.168 162.219.6.164 192.64.72.185 58.250.192.205 198.61.196.112 54.173.175.77 162.243.35.160 162.243.166.234 69.160.58.11 213.192.76.50 199.223.233.140 178.254.22.27 45.55.40.174 52.74.143.6 192.210.203.27 121.78.112.136 104.236.241.88 70.186.146.133 168.63.218.68 108.61.11.27 168.235.69.251 5.189.177.74 65.52.73.204 13.90.215.84 5.101.113.97 172.86.148.47 194.150.114.145 162.213.113.59 166.78.191.165 125.209.194.85 204.44.73.217 45.55.198.121 198.11.178.5 173.13.255.162 112.169.178.194 52.17.98.103 192.227.236.168 149.56.108.4 210.89.48.106 208.109.238.84 52.3.244.107 128.199.86.239 52.4.64.49 52.26.67.189 37.140.238.76 41.203.11.76 62.138.0.138 207.198.119.107 62.76.184.171 52.31.195.118 168.235.64.119 187.191.99.53 45.78.22.152 85.214.25.116 212.79.163.50 185.20.243.199 45.56.113.144 52.35.40.134 91.221.26.18 52.5.92.48 91.109.11.124 54.164.204.174 115.68.17.113 207.238.164.140 194.170.131.25 88.198.67.216 104.237.136.49 188.166.39.43 104.236.171.89 104.155.13.96 54.228.100.167 91.223.235.199 82.211.8.96 84.22.103.219 5.150.225.46 52.30.131.135 5.189.130.92 193.232.254.248 50.62.41.184 169.55.113.213 31.27.101.80 52.89.146.179 104.197.96.151 23.97.141.53 66.228.42.83 180.179.206.13 27.101.100.77 45.55.153.218 217.16.184.217 51.254.209.25 50.56.182.44 129.21.160.24 45.55.209.97 85.214.222.11 176.223.127.55 208.88.120.100 193.254.4.72 128.199.241.174 50.57.227.117 195.154.14.37 37.186.127.124 64.88.186.99 198.58.100.216 202.127.97.122 133.242.182.234 133.242.137.228 203.124.120.60 185.56.84.229 85.214.23.227 71.163.17.12 198.27.69.84 23.104.140.224 107.182.16.72 129.114.128.104 23.239.23.110 41.76.215.105 104.131.45.202 80.249.167.236 166.62.38.129 178.62.100.76 157.26.64.134 162.242.219.24 72.26.98.37 52.23.194.86 107.170.114.178 178.79.180.172 79.172.249.48 104.131.162.129 131.159.56.4 78.138.98.223 173.230.128.223 45.55.197.230 54.200.158.39 78.46.22.93 104.236.91.177 168.63.67.38 54.154.122.123 89.137.225.224 104.131.242.72 104.236.83.180 181.143.79.203 62.4.8.196 72.52.81.76 104.46.52.111 200.54.103.74 5.9.73.166 137.82.84.193 54.171.176.2 209.35.10.58 46.101.9.209 162.242.221.6 79.125.3.32 23.253.158.230 192.249.76.209 187.188.88.6 52.32.228.140 199.21.115.134 85.214.225.85 176.9.116.8 52.27.211.25 185.2.155.246 40.76.30.254 104.236.166.57 50.116.60.30 45.79.146.19 141.85.254.250 200.6.103.219 204.107.27.210 139.196.107.58 216.55.183.73 184.172.9.202 86.123.88.70 54.148.28.207 54.82.1.233 192.81.211.110 45.56.75.132 192.237.188.71 88.150.188.42 54.191.84.150 128.199.94.218 58.64.167.71 88.208.208.186 124.158.4.88 74.207.252.162 41.231.53.73 87.118.112.188 93.104.203.161 50.63.137.12 45.63.17.236 139.162.147.92 129.232.172.10 66.150.124.82 52.18.109.148 139.196.17.165 192.249.76.115 74.123.31.45 158.69.195.254 203.209.147.9 193.35.56.136 85.214.44.212 45.55.175.170 31.133.18.229 54.246.153.83 183.181.170.46 40.117.230.253 84.249.217.2 94.126.106.201 104.236.23.165 54.191.124.146 50.62.133.182 103.248.248.2 137.116.240.141 107.170.118.241 184.95.52.206 52.4.216.230 58.185.88.194 134.159.116.135 81.12.153.90 104.131.186.120 213.251.187.155 178.62.186.194 185.26.49.176 54.254.193.231 52.48.126.86 212.50.211.99 54.229.105.115 37.120.166.96 54.198.23.246 77.48.80.29 193.137.203.19 141.71.207.33 54.84.80.93 159.203.9.153 185.117.153.241 107.170.80.108 54.153.155.79 188.117.28.43 31.192.209.55 125.54.124.72 1.255.51.127 153.120.167.144 40.114.11.117 159.203.84.16 91.250.117.22 162.220.216.100 131.159.46.60 23.21.129.124 134.213.13.166 54.186.225.111 85.130.111.122 95.170.152.164 5.249.154.101 217.31.57.65 103.1.210.42 151.248.0.151 139.162.128.74 78.142.140.45 5.35.243.148 109.123.78.82 185.47.61.34 162.13.155.237 91.250.98.73 200.129.142.95 5.35.243.141 209.56.110.170 88.208.204.106 72.249.145.43 52.25.249.13 46.101.24.115 64.62.180.213 62.210.122.191 193.72.216.178 192.162.103.244 52.37.35.247 91.185.236.113 208.50.229.3 183.181.170.130 52.24.191.232 1.233.37.135 46.101.139.54 46.4.19.87 155.207.26.80 147.95.38.241 88.208.221.117 109.108.143.204 50.19.90.140 128.199.195.155 193.194.87.52 37.139.47.199 83.222.235.127 46.163.73.165 168.235.70.31 52.64.173.52 91.192.103.202 54.186.216.77 94.101.38.92 54.86.1.128 202.8.20.6 115.159.76.126 204.12.84.163 216.87.168.114 45.55.220.92 54.197.188.247 202.78.202.150 213.180.93.228 92.63.110.57 45.55.246.197 104.130.230.201 193.104.37.105 5.249.153.223 134.213.48.240 52.21.121.145 74.221.210.143 104.131.52.239 192.44.77.69 109.169.43.175 66.90.227.5 52.21.37.169 104.131.198.197 40.114.43.55 98.129.29.232 202.58.182.54 46.101.202.164 47.88.15.221 162.243.221.79 128.199.182.164 12.182.237.140 203.189.96.222 178.62.90.15 107.170.175.47 24.204.41.18 134.213.177.53 115.112.230.184 84.21.18.96 31.200.243.170 207.210.241.204 220.134.72.214 54.68.120.170 95.138.173.25 38.108.92.85 168.144.196.69 107.170.254.99 173.254.231.112 54.243.128.143 182.50.155.97 209.54.53.148 203.143.89.118 85.25.201.40 52.88.131.45 104.236.72.99 110.74.130.194 24.72.47.153 69.10.231.90 104.130.226.133 198.211.99.48 133.18.4.69 162.242.241.217 122.117.185.24 176.31.107.105 115.146.126.89 92.255.189.173 104.236.245.157 89.248.103.140 188.138.48.90 150.254.121.50 98.115.128.7 78.46.16.200 158.193.151.32 45.114.116.72 91.106.195.246 149.156.2.248 104.197.107.94 31.13.228.164 40.127.171.166 62.75.166.83 104.131.19.90 149.5.34.30 184.168.31.241 136.243.104.42 158.69.219.70 209.34.246.124 23.253.228.210 52.7.162.172 104.236.120.42 104.223.107.184 54.221.216.192 91.240.86.105 195.228.152.150 203.94.160.114 202.90.34.140 38.88.22.6 107.161.20.205 179.190.57.253 85.113.69.58 54.191.118.53 193.183.95.196 52.34.157.172 41.185.29.39 58.205.208.241 66.150.174.240 54.191.83.42 82.223.29.71 104.210.34.222 185.96.5.165 201.238.226.13 195.42.153.21 178.62.112.232 104.131.111.78 159.253.3.200 96.237.180.171 81.169.204.1 162.243.116.166 45.78.39.169 173.201.180.22 81.95.155.27 162.243.115.109 198.2.60.13 148.163.27.110 186.67.80.14 24.144.26.196 206.223.192.95 109.195.226.202 52.62.0.111 62.210.105.27 77.47.135.249 173.236.26.18 185.21.100.51 5.9.19.248 213.136.79.69 85.214.69.129 220.135.141.243 52.90.79.29 46.101.56.158 168.63.141.11 148.251.80.15 104.43.202.15 77.111.217.147 109.74.0.126 79.172.213.88 1.234.178.64 54.178.151.115 54.68.21.233 12.42.226.165 162.243.1.226 75.141.72.174 52.26.184.107 153.122.30.112 121.200.245.90 117.79.227.35 185.9.7.75 207.46.224.107 167.114.174.173 112.33.0.122 65.216.217.68 82.146.38.113 104.236.35.162 88.131.87.56 86.34.150.131 80.248.227.75 94.231.249.106 58.180.28.7 136.243.60.133 88.208.3.197 52.28.81.203 173.203.132.160 23.91.64.200 185.87.51.43 161.202.132.254 208.85.242.85 94.247.28.190 52.6.200.193 86.56.207.170 203.190.113.119 212.34.236.214 75.127.15.136 50.18.129.191 192.34.67.37 187.61.51.82 37.187.48.29 23.253.68.125 190.90.8.142 54.175.138.167 46.101.57.165 80.234.106.192 130.211.133.99 72.34.233.50 52.91.238.155 54.235.156.176 209.61.160.203 54.248.127.88 217.78.6.98 133.242.188.35 49.212.30.146 52.19.118.82 88.150.228.149 52.27.249.179 89.163.146.199 91.250.99.145 72.4.146.66 146.148.65.224 185.5.251.224 173.230.134.198 209.213.32.24 209.54.56.197 104.236.132.122 88.198.39.75 204.62.151.111 104.237.140.192 95.138.188.129 5.9.70.210 210.116.112.53 83.254.69.133 23.253.79.168 188.226.252.209 52.8.81.141 173.163.154.131 216.218.133.34 91.202.26.43 128.76.136.138 103.23.20.200 169.45.151.183 54.228.203.117 77.75.122.130 106.185.36.100 158.136.4.201 72.11.45.39 66.45.240.204 54.149.11.230 91.194.90.156 85.118.13.43 108.61.247.239 40.127.170.236 92.243.127.150 173.68.150.43 199.195.250.10 107.170.83.63 45.55.61.43 52.26.91.54 74.208.250.1 160.16.91.119 173.201.183.205 89.47.228.52 104.223.1.145 159.203.142.209 69.54.55.214 46.37.168.6 46.37.168.7 198.236.100.11 144.76.93.229 45.55.171.36 153.120.41.108 186.147.130.18 130.211.251.56 54.184.100.75 208.78.103.123 104.156.251.149 85.214.53.203 52.17.64.77 193.183.102.67 213.171.205.177 45.32.249.146 142.4.6.54 72.45.241.247 46.38.234.167 52.18.90.135 91.217.181.50 162.13.110.86 50.63.137.80 168.235.65.95 52.32.209.18 209.212.140.93 200.107.7.116 5.196.69.186 69.64.37.44 50.116.53.52 104.155.63.229 46.101.0.88 217.160.183.30 167.114.219.157 52.3.185.20 23.23.80.145 104.130.58.215 176.9.228.172 23.97.163.194 197.221.59.82 194.58.96.81 52.29.55.110 111.69.42.46 192.248.32.211 199.193.246.196 77.110.2.90 5.196.77.198 83.87.254.213 37.120.173.53 153.127.244.97 69.254.130.181 167.114.253.165 203.86.206.250 194.9.51.137 74.82.200.71 162.243.138.237 160.80.1.220 52.193.220.155 108.166.77.231 198.100.145.124 119.9.30.146 104.197.44.238 60.191.231.235 192.241.237.76 107.23.242.37 52.25.206.83 104.254.98.207 40.121.56.249 89.248.162.213 46.102.233.70 198.245.63.157 84.22.6.68 88.80.190.173 96.126.115.70 58.177.213.154 212.71.255.246 136.145.180.3 153.122.112.135 148.163.83.182 54.149.81.222 195.206.34.236 46.105.244.76 141.19.140.35 184.172.5.234 198.199.103.38 183.179.78.137 83.166.201.98 94.199.243.84 162.13.140.13 173.230.141.159 206.251.244.80 45.55.253.186 80.28.139.215 184.170.64.210 75.126.94.178 104.154.85.131 182.54.218.126 183.181.20.101 188.120.247.210 69.61.187.98 178.62.254.137 178.62.53.237 104.236.204.111 46.226.104.156 193.32.68.10 62.210.127.188 211.21.61.13 192.81.132.76 80.248.227.35 193.2.44.62 147.27.16.58 80.82.215.243 104.44.137.50 178.62.159.236 162.243.157.146 67.171.229.126 52.74.7.30 199.223.235.100 206.192.244.165 198.56.238.115 46.101.50.89 212.71.252.115 62.210.127.168 69.164.219.35 52.10.68.131 202.68.186.20 50.63.137.13 151.248.0.150 12.171.178.34 133.130.89.128 50.168.118.38 54.218.66.246 72.34.248.214 200.116.2.120 23.97.211.38 54.186.128.168 212.83.161.232 64.251.19.188 210.119.95.12 141.85.254.147 128.199.247.177 95.110.231.178 5.9.158.232 104.155.72.218 45.32.35.17 185.50.72.4 54.86.6.216 194.199.90.59 54.175.193.7 69.41.12.12 45.78.46.2 153.127.244.222 162.242.254.52 207.166.137.90 52.10.130.2 24.208.129.81 23.253.81.107 198.61.200.238 83.220.168.20 182.163.74.32 54.172.147.17 195.226.105.84 173.255.229.194 148.251.13.103 107.155.85.171 212.20.227.22 198.199.77.144 54.77.82.210 45.55.211.126 176.62.193.108 62.76.176.46 23.92.217.18 162.13.121.15 207.21.228.211 62.109.14.192 72.44.82.84 184.73.105.208 191.233.85.189 46.18.226.200 40.122.206.25 139.80.32.30 133.130.48.217 130.235.135.248 81.30.80.82 52.26.52.174 12.227.46.38 5.1.86.151 54.194.149.110 86.34.204.52 185.20.227.150 159.203.1.248 205.201.158.3 23.253.110.176 64.151.118.124 85.214.204.158 91.210.204.4 183.181.170.93 175.103.49.53 5.196.127.143 54.169.178.177 133.18.16.25 111.161.39.245 203.195.236.112 85.17.225.31 104.236.45.220 162.243.109.169 104.196.137.128 32.212.201.76 208.109.234.35 203.109.37.26 95.163.17.124 106.184.0.178 82.223.20.81 46.107.224.219 77.120.104.176 212.12.60.50 58.229.6.114 193.198.75.85 49.212.49.161 77.79.65.83 54.229.85.41 188.93.208.198 54.83.63.166 176.31.175.77 72.167.176.38 185.21.17.28 104.130.105.108 62.109.23.134 50.57.101.108 80.216.184.162 87.106.246.136 31.216.224.52 176.28.12.54 104.215.197.121 203.201.220.221 162.243.239.112 52.74.117.237 213.188.153.44 54.193.0.230 37.187.9.58 54.236.196.7 54.235.90.225 37.34.63.159 52.91.249.153 104.131.150.129 180.131.136.236 54.167.159.253 137.43.99.36 37.120.174.74 94.126.69.50 149.56.135.4 184.71.41.226 54.69.115.54 23.94.228.164 54.228.192.201 103.30.88.18 69.65.41.156 52.6.46.75 80.248.227.68 66.228.50.230 76.177.62.36 23.251.139.179 106.75.198.164 64.88.12.109 104.236.151.101 54.193.49.212 213.229.73.244 72.252.209.117 104.209.176.29 104.197.59.190 27.87.62.109 200.114.118.150 70.35.198.235 8.39.228.47 203.197.156.43 209.148.91.233 104.155.28.126 202.171.41.180 150.86.231.1 54.187.214.163 133.65.176.15 202.46.156.3 193.105.32.6 178.213.240.11 178.254.8.201 95.87.255.118 159.203.99.141 85.214.220.231 38.110.119.26 72.51.41.57 92.62.40.67 212.110.172.235 144.16.140.127 66.180.203.216 82.77.189.22 45.56.72.205 182.50.129.250 54.229.113.185 88.208.204.222 139.196.4.159 66.35.78.172 198.199.102.24 95.138.168.96 86.107.179.226 162.226.127.121 77.72.149.162 212.158.174.164 66.201.40.52 198.211.122.199 157.7.168.11 218.38.28.169 207.30.12.183 85.214.75.55 128.199.88.222 23.100.90.175 104.130.170.196 5.135.189.88 38.96.49.29 83.136.248.58 107.170.209.53 208.109.162.155 82.196.5.230 104.193.41.139 50.62.76.76 91.250.85.107 184.175.52.213 52.8.79.174 68.178.128.74 50.59.99.166 46.105.241.232 52.88.117.23 52.64.156.71 162.13.121.5 54.147.231.115 208.163.53.211 173.255.250.109 216.200.17.66 213.64.130.236 52.32.173.179 91.197.174.35 23.253.90.131 133.242.176.175 217.12.209.109 162.243.142.65 202.162.207.137 5.133.177.7 5.35.244.31 67.207.201.98 13.7.8.24 152.8.57.78 85.214.116.136 31.193.6.176 87.50.4.160 191.233.99.31 23.107.27.206 52.90.96.117 54.254.221.189 213.106.253.232 79.129.4.43 103.17.9.216 77.245.129.194 109.72.224.25 104.239.136.71 27.54.130.86 46.38.99.52 69.20.93.212 97.74.229.132 116.250.255.38 40.76.64.77 107.170.47.136 52.25.177.194 95.142.165.12 162.243.71.43 178.79.139.167 112.196.2.41 178.62.120.146 104.197.119.48 54.148.147.161 202.43.164.77 23.239.30.175 203.39.204.136 54.148.61.130 5.189.141.252 192.0.131.147 195.31.154.218 52.33.208.161 198.199.116.214 178.79.188.115 104.236.106.40 54.154.101.139 52.10.247.106 54.209.155.45 72.14.190.24 162.243.5.133 176.9.35.136 65.175.173.124 151.236.29.69 138.91.39.205 45.78.52.4 181.224.134.248 66.155.1.211 66.155.1.210 185.26.49.131 104.236.102.9 136.243.219.58 208.112.117.148 104.41.146.214 216.137.102.202 108.61.28.4 172.245.137.179 50.19.214.8 120.138.8.36 91.203.194.70 130.242.7.14 37.25.77.162 144.76.225.140 31.27.101.118 45.55.54.179 200.42.93.195 46.249.216.97 162.220.10.125 54.183.220.163 80.93.233.95 54.83.203.11 108.198.133.165 162.243.245.96 104.131.199.63 46.36.218.4 27.54.42.27 198.57.190.177 52.20.128.232 216.69.181.231 159.203.117.113 52.21.246.57 38.91.128.235 54.153.9.156 5.2.19.166 5.35.242.50 194.79.56.189 54.232.202.9 81.2.225.109 193.138.213.71 62.210.82.128 212.1.213.132 104.197.55.200 130.0.145.66 104.131.144.43 138.91.249.188 207.178.195.170 206.191.128.175 104.154.38.180 162.242.223.176 128.199.237.43 185.30.238.231 31.31.78.136 47.19.51.73 45.79.211.106 46.137.97.25 166.62.82.29 103.20.104.95 82.116.198.115 104.154.86.103 104.236.1.196 45.55.43.106 146.148.86.248 103.19.62.34 77.81.245.161 50.62.214.243 52.17.224.108 24.141.181.103 165.180.148.204 203.142.16.34 184.106.134.50 107.170.13.101 207.232.11.34 104.131.36.126 136.243.151.87 5.148.165.171 202.55.176.15 65.99.230.27 50.62.214.39 85.214.231.69 104.236.221.37 153.127.247.164 52.27.231.2 52.7.202.242 107.161.191.130 50.56.207.20 50.63.129.251 168.63.232.234 46.101.243.227 50.17.39.234 37.48.83.179 198.23.211.109 162.243.194.58 104.233.83.27 54.159.212.216 104.154.88.176 212.129.21.205 104.131.93.243 52.0.144.62 45.79.131.175 103.253.113.253 157.7.122.26 54.173.80.59 187.109.19.74 151.248.0.236 136.243.155.92 173.255.158.67 95.110.205.144 179.96.211.230 173.246.56.33 110.4.188.241 45.55.35.224 46.20.236.237 209.15.236.15 62.76.178.229 41.86.98.151 162.242.213.199 217.149.179.101 178.79.128.177 54.254.213.77 199.223.254.132 67.230.85.248 40.112.138.3 188.72.189.7 92.51.134.162 93.84.116.143 88.198.62.115 211.120.239.230 92.63.109.247 52.36.153.47 173.14.72.43 67.66.218.60 54.215.139.72 85.214.248.16 192.241.162.172 204.197.244.70 54.149.243.108 139.162.222.124 183.181.16.76 175.45.119.118 54.211.238.237 152.74.221.96 220.132.61.12 204.210.198.188 45.33.108.238 173.255.206.252 45.55.80.182 185.112.156.198 54.209.211.138 217.75.128.16 104.131.250.178 137.135.75.119 162.222.180.253 104.131.1.54 176.126.243.73 64.150.186.135 52.35.161.51 174.37.22.242 96.81.213.225 54.252.111.106 149.210.165.3 85.214.84.27 192.81.210.183 50.57.114.79 46.101.22.145 153.120.166.232 222.255.41.164 114.207.112.236 202.93.166.40 130.153.209.3 13.80.66.59 130.211.93.207 45.55.164.59 95.96.247.3 173.255.231.188 97.65.10.125 68.169.63.222 58.229.183.116 82.223.31.115 195.202.86.91 134.213.195.184 190.115.28.165 159.253.209.98 89.234.7.19 106.187.51.76 177.39.17.36 64.93.72.90 104.236.3.159 50.62.73.193 149.24.137.165 88.208.192.244 37.187.71.7 77.59.185.152 62.141.44.177 31.193.7.86 162.13.89.84 52.4.7.166 176.9.72.90 195.230.2.134 176.28.9.156 217.78.0.153 23.253.50.241 104.236.39.52 192.3.111.70 104.236.251.226 104.154.80.7 162.210.250.92 192.145.234.90 104.236.112.221 62.149.174.239 81.169.244.71 106.184.7.84 54.85.112.78 118.139.178.79 75.149.81.17 208.126.36.12 52.1.148.143 41.71.77.35 54.221.214.133 138.23.71.31 12.219.49.26 186.202.117.252 212.159.21.174 74.63.169.156 165.161.11.35 54.164.66.0 31.135.92.20 54.165.47.190 23.95.102.76 45.56.110.20 73.11.98.6 93.174.0.121 63.255.134.23 178.62.26.17 184.154.145.74 186.47.101.195 91.121.86.82 68.169.61.219 198.46.157.41 193.33.151.7 54.210.62.48 192.198.87.226 178.62.152.134 91.240.85.112 213.108.135.31 94.245.88.87 188.40.49.28 107.21.144.74 52.34.199.108 117.121.13.216 45.55.181.145 118.98.235.222 54.215.242.89 190.14.198.200 162.13.13.21 54.83.32.109 83.212.123.243 204.44.87.169 81.169.217.254 37.235.58.13 54.87.54.105 52.24.155.125 104.41.155.52 185.47.61.76 137.118.139.52 40.69.40.113 180.153.55.97 85.214.84.119 160.16.104.247 45.55.2.49 207.223.251.184 169.45.95.30 23.238.16.51 69.161.222.142 122.248.209.90 180.169.22.133 182.73.163.116 166.62.46.143 104.236.165.116 134.213.51.136 66.170.45.35 46.137.112.51 208.94.233.29 69.89.37.78 54.93.84.110 71.194.220.158 5.45.121.106 104.236.141.177 173.255.112.216 37.187.240.112 154.0.165.141 136.243.32.88 66.18.194.246 213.168.248.204 54.166.60.197 148.251.75.21 96.45.186.185 64.120.77.218 107.170.33.244 83.69.74.190 72.26.207.210 37.79.208.2 85.214.64.79 192.210.212.194 162.243.242.146 54.209.107.44 130.237.126.252 176.28.23.42 136.243.55.40 23.99.19.185 137.135.83.38 103.253.145.93 141.100.10.18 193.35.56.145 139.59.240.40 168.235.90.214 130.211.58.181 133.242.203.217 103.226.185.7 204.246.143.76 176.28.102.194 192.241.167.218 198.50.227.2 23.92.210.66 104.154.92.246 23.21.88.31 54.66.169.137 198.58.96.40 210.152.247.69 104.206.222.124 104.236.34.15 86.58.174.73 133.242.142.123 45.33.3.157 83.169.43.78 52.11.94.45 80.179.141.26 163.225.10.106 52.87.204.152 85.214.21.215 54.151.59.130 212.36.69.104 190.106.0.178 195.154.169.97 5.45.124.110 185.18.196.93 159.203.90.200 23.96.108.243 199.231.121.202 91.121.138.164 199.89.55.130 216.68.72.73 208.167.252.44 199.80.254.73 195.154.121.54 72.28.176.83 46.243.98.18 81.10.136.135 31.27.101.71 52.16.9.157 188.166.83.213 85.214.142.232 193.231.136.5 173.230.132.198 137.135.135.162 211.125.90.162 50.116.59.209 166.78.100.42 149.202.79.122 111.221.102.235 219.94.250.162 173.201.191.26 104.197.55.6 54.175.0.146 211.144.126.168 173.201.191.21 204.112.140.205 54.184.64.133 168.235.149.214 114.35.204.81 52.88.43.142 162.217.70.193 178.62.23.65 141.211.6.90 96.39.79.99 120.126.83.179 54.172.113.66 118.163.20.12 199.4.150.172 151.248.0.131 162.243.232.75 173.203.64.225 62.210.73.57 23.104.140.47 178.140.241.24 160.16.99.112 162.13.94.206 91.184.11.194 207.189.130.207 198.100.149.220 92.222.125.141 78.46.109.148 133.242.1.180 109.108.144.102 80.88.90.111 23.101.186.32 192.163.225.76 178.62.17.73 198.61.225.74 52.11.207.187 45.55.62.73 185.8.253.184 209.140.29.170 200.68.74.65 81.169.206.6 151.236.53.102 173.0.51.126 54.244.89.226 104.236.148.50 45.55.163.4 78.111.69.41 52.0.196.246 46.101.190.26 70.60.38.15 162.243.216.147 104.131.208.54 178.62.39.197 72.1.218.86 139.162.203.223 23.94.47.236 31.186.86.38 104.224.136.44 54.255.182.239 212.118.198.217 149.165.228.91 45.55.227.249 168.77.41.44 104.155.45.223 52.16.39.206 213.246.38.41 213.147.99.228 106.186.17.87 118.71.224.167 52.32.58.194 192.249.76.41 176.28.12.46 185.5.99.68 45.33.122.8 173.227.253.179 169.45.65.233 54.86.181.2 190.181.26.131 178.62.78.113 14.49.30.133 81.196.51.163 106.187.52.244 148.251.128.118 52.18.230.118 95.154.216.34 54.66.129.154 54.92.41.102 118.140.201.36 104.236.12.13 104.197.107.61 103.228.103.103 176.31.244.18 95.78.255.227 46.101.232.209 104.47.136.249 104.236.250.70 52.17.170.241 14.141.39.158 216.152.138.203 93.175.140.39 192.34.92.202 162.243.243.80 199.48.128.110 51.254.11.184 79.125.23.163 88.198.111.20 54.245.235.99 168.63.219.16 23.107.27.181 159.226.67.79 190.9.132.29 107.167.76.210 5.189.146.18 82.211.56.214 104.239.174.125 210.48.155.116 157.7.198.113 52.2.109.127 85.202.30.158 66.155.75.222 5.101.99.17 113.21.229.4 192.241.235.210 50.63.60.190 188.166.18.49 104.155.211.191 23.253.68.99 148.251.247.221 213.42.29.198 148.251.234.47 54.242.220.41 85.171.88.89 54.164.158.147 212.47.226.108 54.83.58.88 81.4.107.5 210.213.57.128 193.224.99.35 199.96.175.30 109.237.220.137 5.79.21.98 146.185.175.22 151.80.25.197 54.206.112.225 54.152.59.102 54.92.59.135 82.221.133.171 185.5.96.101 173.255.220.100 45.55.0.49 52.87.16.219 50.197.102.198 4.35.202.213 74.120.236.13 219.142.106.153 107.182.131.105 69.194.133.172 192.99.166.58 199.88.59.185 173.193.20.238 92.51.146.146 136.243.18.148 143.93.113.3 62.210.253.85 166.78.9.188 168.144.251.76 137.117.173.142 41.76.213.71 178.62.24.24 50.56.69.240 5.39.76.223 104.41.15.72 144.76.13.46 153.127.250.237 52.34.56.12 103.25.172.142 146.185.187.244 209.141.36.74 45.58.35.100 95.85.44.118 139.162.11.242 52.20.187.187 150.254.190.249 198.199.114.171 61.219.11.126 52.36.187.85 58.72.188.78 104.197.93.224 64.64.23.98 52.31.135.13 71.122.219.28 169.54.204.44 23.244.26.52 52.8.34.248 104.130.23.50 83.99.168.2 104.155.230.50 1.160.81.205 54.201.201.78 81.211.103.106 85.214.102.161 159.122.206.189 51.255.38.246 172.245.32.40 157.88.213.79 195.81.194.35 50.3.30.252 65.52.154.114 37.139.5.51 52.90.200.159 137.135.102.251 69.64.67.97 107.170.113.147 173.212.57.25 104.131.38.145 52.88.90.70 99.198.124.212 178.23.244.77 54.254.120.178 37.128.187.193 23.253.204.52 142.109.1.55 50.116.42.126 14.139.159.35 212.120.120.31 104.197.139.137 104.47.139.34 64.140.158.150 185.37.227.81 162.243.141.160 64.80.169.42 52.28.11.40 45.55.185.149 109.169.57.13 178.248.109.11 108.60.136.162 37.187.70.126 186.202.139.33 157.7.53.161 45.37.44.223 63.223.64.132 209.95.48.197 104.217.248.176 139.196.10.209 104.197.88.6 178.238.227.99 198.199.95.36 94.136.55.205 183.61.83.206 51.254.96.42 50.63.137.175 192.96.207.165 23.226.133.5 192.81.217.59 181.198.91.75 200.57.14.163 212.71.253.240 176.126.246.8 142.4.16.30 134.213.104.236 142.46.193.10 108.9.164.92 144.76.8.28 50.233.122.8 50.17.249.224 104.131.129.188 78.142.19.12 80.229.41.40 192.241.213.104 54.176.85.175 188.166.15.133 193.2.146.122 212.18.228.118 81.4.107.34 132.252.238.111 107.189.147.181 212.7.208.187 112.196.35.196 188.165.212.148 192.107.168.86 68.98.212.60 52.30.72.242 153.122.141.185 188.40.255.52 210.29.144.53 50.17.226.101 174.136.37.174 186.195.177.2 193.147.16.75 14.139.185.93 50.249.29.146 52.86.165.112 52.27.68.182 86.89.182.13 203.151.84.7 54.65.99.154 162.243.74.34 74.214.25.85 54.187.5.136 121.127.12.54 50.247.143.194 93.186.197.146 24.118.230.9 162.249.6.97 104.236.154.156 184.72.61.37 37.252.124.32 146.148.87.101 109.86.199.53 67.219.149.130 178.33.143.248 184.168.147.84 69.70.130.78 24.39.93.38 104.131.146.68 188.166.99.80 52.23.209.10 185.93.245.67 185.47.61.232 61.7.236.194 54.251.62.171 162.243.70.49 162.243.219.238 104.238.124.87 104.236.237.134 144.76.120.207 80.71.4.243 85.143.221.109 213.94.214.244 209.54.52.18 155.212.3.222 213.136.81.229 83.136.86.23 199.223.235.156 50.28.63.136 162.243.149.156 78.46.42.130 185.47.14.130 77.68.236.247 84.246.94.107 52.11.14.84 206.188.208.247 52.74.68.169 50.63.84.170 148.251.54.57 178.32.218.6 195.154.165.112 45.55.153.24 46.163.71.83 54.200.37.92 54.166.110.218 66.85.77.251 178.62.35.39 153.120.34.206 94.23.163.168 216.14.115.89 104.236.28.47 54.196.171.92 184.168.20.61 63.146.121.244 208.109.52.242 149.56.15.136 54.187.204.43 24.21.164.214 192.198.84.194 183.181.50.227 71.127.152.199 81.130.210.18 99.198.186.199 40.68.219.187 54.214.232.166 151.97.48.31 203.66.65.184 103.246.60.3 54.195.29.164 79.135.129.223 78.137.98.170 5.56.56.75 164.177.149.36 50.63.24.3 148.163.114.250 95.211.153.183 103.2.197.15 154.5.195.7 61.219.70.221 167.114.254.44 66.241.100.235 66.35.78.176 52.23.74.250 52.27.248.110 151.248.0.215 79.133.210.122 50.63.130.85 51.255.44.24 166.78.241.183 62.210.247.104 138.192.246.21 82.223.10.158 80.175.36.62 121.96.25.162 168.235.90.16 208.79.106.67 36.71.132.164 87.117.194.56 198.57.162.87 85.94.200.190 164.132.45.81 70.38.64.167 212.124.197.186 62.210.60.125 107.21.113.194 213.246.61.104 87.118.11.134 162.220.241.145 212.112.245.156 83.169.37.19 62.210.214.249 166.78.169.47 212.174.24.198 180.222.184.220 54.93.70.141 54.241.2.55 78.109.168.32 139.196.52.232 190.120.14.37 212.83.128.68 208.88.130.150 137.44.2.11 134.213.48.214 192.241.129.63 93.127.247.113 167.160.164.129 45.55.79.31 66.135.33.245 129.252.169.8 73.211.56.84 133.242.170.115 72.14.186.215 106.186.127.69 167.114.34.75 213.184.255.68 80.33.112.172 200.132.84.50 69.65.47.34 92.51.163.185 54.153.81.88 75.149.159.205 54.253.254.31 188.138.48.156 162.243.217.228 116.93.124.59 65.122.251.21 45.78.31.205 5.175.26.169 106.185.24.161 84.19.41.124 52.11.94.231 208.167.252.27 46.4.89.59 80.14.20.22 162.211.226.156 153.122.136.184 52.74.159.135 93.175.140.36 93.150.32.206 104.154.51.220 185.62.138.10 94.23.234.71 45.115.36.141 195.154.235.32 23.21.226.84 176.31.125.58 95.211.190.34 108.166.70.171 45.79.217.75 81.18.21.155 199.233.247.2 150.165.237.6 52.26.38.32 70.183.45.107 209.222.8.211 104.131.124.59 54.191.26.64 40.114.44.126 98.143.148.43 195.134.66.241 46.101.2.246 159.148.215.219 109.169.18.119 192.241.197.138 82.98.131.142 177.36.7.123 178.62.110.217 23.96.201.195 178.22.232.33 54.218.18.209 97.74.121.19 176.62.48.243 164.177.144.12 209.129.47.40 136.243.107.27 163.53.192.28 123.202.129.155 104.236.30.197 162.243.49.28 151.236.22.249 23.253.176.58 130.211.64.101 208.100.24.112 41.79.241.195 54.149.17.149 213.50.111.19 192.187.114.242 40.114.13.129 52.8.216.255 104.197.98.0 91.109.10.163 82.220.34.66 139.162.195.169 104.131.85.165 54.85.122.243 195.251.63.61 54.152.72.232 66.228.32.152 66.11.12.183 198.58.124.83 82.224.191.187 153.121.56.164 54.241.252.73 104.46.62.201 162.243.110.242 104.41.2.74 149.210.178.194 128.119.148.120 195.154.15.138 104.200.65.60 72.167.36.178 104.130.30.135 54.225.203.119 94.208.75.218 23.23.215.159 45.55.213.39 62.90.96.235 85.14.85.30 192.249.77.91 106.187.46.190 5.153.252.12 95.173.177.122 188.166.26.202 128.199.85.89 93.186.200.67 199.195.252.242 85.214.222.82 78.218.112.112 151.236.217.11 49.212.53.225 198.211.124.164 162.144.43.201 89.108.71.104 188.226.253.244 188.138.99.16 54.249.123.105 162.243.36.244 103.25.74.218 146.255.33.72 216.55.187.190 185.47.14.137 66.240.205.236 52.19.151.67 199.89.54.82 62.210.178.135 89.111.40.247 52.10.61.195 162.243.155.129 52.71.96.212 50.57.122.193 46.4.77.116 178.79.131.201 92.51.165.26 54.158.129.10 92.222.18.224 159.203.47.146 66.103.147.124 217.14.201.83 198.46.142.133 106.187.94.213 62.100.65.123 71.81.19.10 190.102.97.100 69.16.226.61 62.209.166.16 5.56.58.234 151.236.62.93 212.200.151.98 207.195.92.203 192.241.229.144 208.38.132.148 193.226.163.50 89.253.229.202 91.142.210.209 71.13.74.201 69.64.95.60 23.226.79.55 52.71.231.71 153.122.74.197 109.104.93.146 209.94.250.43 82.116.198.63 93.184.242.165 185.101.35.27 52.74.78.69 69.164.204.244 94.231.110.29 23.226.137.69 88.208.250.194 217.112.179.32 12.107.80.93 52.27.180.40 85.134.54.164 8.14.136.55 23.96.124.238 46.32.250.50 54.80.97.34 83.212.120.166 52.2.19.33 52.26.41.107 213.186.202.190 200.23.149.25 104.236.110.198 130.211.85.162 192.34.67.20 104.236.31.54 212.72.155.109 104.236.134.87 176.126.242.12 31.31.75.191 62.109.2.129 23.29.16.170 217.215.101.177 178.62.93.32 71.180.143.189 104.236.76.241 209.135.157.124 37.120.165.140 68.145.201.68 123.30.130.1 52.53.210.47 178.20.224.114 104.210.2.93 180.222.182.58 64.186.192.173 62.210.247.244 109.238.224.182 178.62.161.34 50.63.56.135 52.35.85.115 220.241.118.97 153.150.54.10 144.76.241.205 153.127.248.209 91.198.35.8 192.38.91.29 54.183.34.56 108.171.178.212 104.197.136.87 82.146.53.65 166.78.237.128 209.133.197.186 54.204.35.192 45.78.7.113 52.2.34.112 162.247.142.82 213.208.132.135 208.65.114.139 210.211.101.83 83.167.254.50 52.23.151.220 109.163.226.210 62.4.8.197 220.134.96.160 52.2.249.104 188.166.15.64 62.4.8.194 198.199.79.34 52.4.209.54 45.55.29.179 45.55.193.204 104.154.78.148 85.124.252.130 80.65.165.4 52.0.22.44 162.253.64.84 217.16.187.132 207.249.90.185 104.236.224.44 45.79.99.89 54.193.34.29 24.229.6.29 89.208.49.84 188.44.42.110 212.47.237.148 37.59.242.146 166.62.32.190 54.183.188.141 202.182.53.222 212.89.28.245 52.62.111.202 146.148.35.16 68.170.70.165 52.26.114.96 45.33.122.167 151.248.0.209 77.86.251.221 64.77.72.74 46.101.49.10 176.9.63.231 52.28.67.253 52.24.9.158 151.248.0.201 189.50.84.73 52.91.224.169 54.225.108.17 23.94.101.170 31.216.38.151 172.245.103.121 146.148.113.172 139.162.202.161 138.192.246.32 80.70.184.49 52.3.251.221 192.99.6.25 104.236.188.129 104.131.215.14 52.19.37.133 128.199.90.200 212.48.74.75 134.213.53.173 163.17.29.115 162.13.162.197 64.41.83.100 173.230.153.62 144.76.176.173 54.84.105.150 46.101.38.46 69.16.242.170 188.226.144.222 104.197.35.133 168.63.203.174 54.254.126.213 81.169.142.92 82.225.105.38 191.236.57.241 104.41.41.213 52.18.13.243 52.11.215.218 52.26.50.197 73.26.250.226 153.122.54.117 168.63.234.75 75.73.138.115 92.222.26.118 5.179.31.10 130.191.226.146 45.55.212.106 52.24.183.205 45.35.35.102 45.124.66.73 52.91.164.222 202.177.23.94 46.101.246.43 173.255.217.228 202.114.123.29 185.28.22.61 106.185.45.167 78.46.160.67 106.187.99.151 198.58.103.216 212.47.244.160 104.236.68.161 162.13.85.79 64.74.115.38 54.147.20.202 106.185.45.208 54.85.7.173 54.172.204.136 69.64.70.157 185.107.172.66 136.243.84.152 50.57.58.217 188.226.250.119 119.27.32.164 162.243.14.135 137.99.139.46 71.198.3.230 31.15.52.175 210.152.244.100 103.25.202.205 212.129.56.54 54.164.117.126 212.34.44.126 93.115.250.113 59.188.87.96 204.12.125.216 70.169.139.108 188.165.131.173 81.169.141.206 84.31.132.23 52.27.91.175 106.187.93.83 54.84.235.42 169.55.202.181 143.93.113.84 178.62.60.94 91.142.91.212 216.55.187.26 148.163.5.174 104.209.45.212 188.226.143.38 75.148.103.196 104.239.157.150 5.189.138.79 195.154.102.148 199.103.6.238 192.241.198.37 85.25.93.146 54.76.252.98 72.32.153.58 81.170.162.31 88.150.232.122 5.35.241.64 54.68.211.170 51.255.152.130 95.154.236.133 52.7.181.212 148.251.180.165 195.204.110.200 148.251.153.55 188.165.223.107 45.79.1.169 195.154.8.32 133.242.139.45 199.175.48.158 193.16.217.16 173.239.120.236 62.210.115.176 192.232.197.225 37.34.50.206 104.131.114.215 92.62.138.77 210.122.10.126 23.253.53.232 107.161.157.121 46.101.47.48 64.79.68.122 128.199.141.219 85.25.64.226 203.223.41.23 37.187.148.191 50.23.131.92 50.23.131.93 193.136.58.170 192.210.139.242 125.22.83.72 45.56.90.228 198.46.157.3 52.89.236.144 184.107.145.58 201.94.149.226 216.38.134.138 80.219.155.7 212.235.181.5 52.35.233.184 92.63.104.81 216.194.172.56 190.84.233.207 54.86.208.54 104.155.224.189 198.46.193.40 52.11.153.182 104.131.248.110 104.131.48.66 198.49.75.150 50.242.36.173 173.230.135.73 192.99.204.59 162.13.82.52 50.116.14.226 62.210.76.35 81.169.252.241 217.73.131.16 50.63.172.17 104.131.103.93 63.143.50.54 24.249.101.197 194.102.32.2 104.131.114.100 52.11.147.186 103.231.212.106 153.92.44.187 95.67.78.222 54.85.44.169 151.248.0.243 104.131.107.194 210.5.178.202 52.74.143.227 212.71.244.75 62.218.29.50 128.199.180.239 66.206.192.162 109.239.49.19 162.242.227.132 138.16.174.14 128.199.36.69 45.55.140.143 78.8.34.222 45.33.10.174 81.169.157.59 77.73.7.200 178.62.57.223 168.77.213.57 54.215.239.68 195.34.159.139 46.101.25.135 116.58.181.183 69.164.198.239 66.228.43.114 200.58.100.226 40.113.17.112 73.143.212.175 164.77.209.203 66.155.209.113 166.62.118.217 50.57.123.85 209.123.213.148 121.201.14.152 198.74.50.204 54.210.225.7 106.185.33.58 185.49.13.53 142.54.178.34 192.237.146.160 45.79.2.31 173.164.126.210 54.169.186.134 208.65.139.20 200.98.151.23 94.230.210.247 207.171.3.138 184.73.171.53 68.232.185.19 213.154.176.208 74.95.197.236 153.120.33.128 4.71.144.182 162.242.218.46 91.150.189.133 192.169.218.239 185.26.51.70 153.127.243.60 223.255.138.42 49.128.39.117 144.76.93.22 52.26.219.97 149.56.14.197 64.127.84.4 207.192.227.9 209.59.182.225 178.239.177.208 107.160.42.71 46.105.3.227 185.27.132.194 178.62.39.17 52.10.224.202 31.193.165.118 54.172.17.165 50.63.129.57 176.28.126.139 216.69.170.44 148.251.139.205 212.3.96.114 202.212.82.249 95.0.39.20 52.21.187.10 67.227.206.9 67.207.134.75 173.214.191.202 186.215.84.186 216.155.145.222 54.245.114.67 217.174.240.253 52.3.164.97 128.199.40.250 88.198.51.13 117.52.89.215 82.223.31.148 104.130.2.175 23.239.18.28 194.63.143.222 181.211.99.242 160.16.125.145 54.254.243.32 137.135.167.189 52.33.199.91 52.6.115.242 128.199.120.176 54.246.89.171 87.230.14.55 98.129.206.10 23.102.40.58 109.173.98.8 79.99.200.161 210.211.97.180 54.245.81.71 84.32.80.25 54.94.160.50 23.101.127.161 185.3.152.211 138.91.185.107 185.56.86.45 50.17.228.247 5.9.190.35 108.179.51.200 52.26.224.100 41.33.230.227 191.235.135.65 52.7.118.53 54.72.34.86 50.56.189.251 148.251.149.91 199.59.2.35 118.140.113.10 72.251.234.53 200.130.15.30 52.20.105.34 52.24.168.138 23.102.52.32 54.241.3.147 195.154.232.153 104.236.253.190 72.251.248.20 62.210.122.119 144.76.31.212 40.69.36.5 136.243.245.131 217.22.159.123 188.226.210.124 95.175.42.94 92.51.164.134 104.131.255.248 52.69.98.39 23.27.160.254 188.93.210.137 89.185.97.130 112.72.98.105 52.87.221.86 188.40.107.76 107.170.122.217 213.221.250.31 139.179.56.28 178.21.175.163 218.66.104.137 52.88.228.246 148.234.138.61 178.79.164.250 104.245.109.52 5.79.70.218 54.68.149.224 68.189.80.58 62.210.72.176 97.74.234.137 66.209.94.107 107.170.14.168 98.171.208.135 45.79.188.197 54.191.36.254 91.109.25.195 104.238.103.165 216.74.51.68 52.24.12.226 109.107.127.2 198.23.251.230 46.102.173.11 95.0.40.9 107.170.105.36 212.71.253.171 54.157.216.80 179.49.8.28 109.74.196.102 193.183.98.209 82.147.150.158 54.160.152.73 91.109.10.211 72.249.104.30 104.196.9.19 89.22.96.95 54.186.49.238 49.236.192.141 54.153.133.149 194.146.198.94 213.136.70.10 72.45.241.246 54.251.122.4 51.255.40.106 75.126.89.10 192.241.167.164 50.63.61.146 104.40.220.49 192.241.252.182 221.121.148.138 185.101.156.201 184.105.162.183 69.16.210.190 69.16.210.193 209.15.249.235 178.62.116.154 182.171.250.218 91.189.38.89 212.0.160.19 46.4.92.188 52.90.160.232 13.80.70.91 50.116.41.32 50.116.41.31 210.115.46.22 74.208.227.169 54.186.163.234 54.164.248.19 52.88.197.150 14.161.5.224 109.238.54.49 171.25.155.36 216.191.199.82 23.253.108.102 169.54.188.249 103.233.193.89 94.177.33.146 104.236.118.80 178.62.55.40 213.180.92.179 208.78.139.76 97.79.158.80 50.17.123.132 62.210.182.150 107.170.23.45 52.86.193.32 54.242.36.164 52.16.177.20 213.169.148.100 162.209.106.56 130.211.255.68 104.236.199.150 104.131.169.100 188.226.139.152 54.65.35.10 194.50.126.210 46.252.27.24 52.11.47.218 67.23.96.34 23.108.254.234 117.169.4.9 54.193.121.116 160.16.211.118 107.20.248.9 178.62.48.171 97.107.128.226 64.76.23.62 162.243.130.56 109.166.217.190 64.79.69.154 50.254.128.20 37.49.228.128 79.99.1.150 199.217.118.84 54.94.253.79 54.67.33.157 104.131.234.197 104.236.249.136 206.221.179.19 104.199.139.96 82.223.15.192 212.18.254.130 72.78.64.60 46.32.231.137 149.210.159.46 166.78.255.111 64.34.173.116 183.81.153.219 209.163.165.167 159.182.30.197 188.226.131.191 69.42.100.246 81.10.185.122 45.55.138.16 5.249.151.156 130.211.181.91 52.5.214.29 104.45.19.62 5.9.41.125 31.192.227.66 176.9.43.37 193.140.83.106 5.199.138.26 92.222.161.64 50.62.8.164 118.88.18.91 188.226.132.122 45.79.166.32 88.198.39.233 157.7.108.48 192.249.78.210 91.108.68.237 203.122.251.203 85.214.204.27 58.137.222.186 213.246.63.61 143.107.91.243 85.71.224.11 185.83.217.167 45.55.149.64 121.58.238.22 104.130.139.146 212.36.84.132 52.16.10.19 198.144.186.153 198.71.88.184 82.204.7.73 178.62.27.245 65.98.110.50 200.27.59.62 195.177.214.108 191.101.152.75 45.79.6.141 46.21.104.121 128.199.139.56 23.96.4.101 41.168.131.72 82.220.39.100 118.139.161.167 54.245.88.110 45.78.37.197 81.95.208.90 46.101.175.91 165.132.197.194 94.199.178.62 188.21.96.20 94.23.54.38 213.52.130.162 45.55.145.157 172.245.126.246 167.128.56.12 192.243.109.149 64.128.254.37 199.185.120.64 193.183.252.198 69.16.211.241 23.253.231.146 40.127.175.39 212.59.170.147 54.171.58.242 45.56.127.129 91.121.108.219 166.62.39.250 153.121.77.56 54.75.248.103 104.155.87.55 87.230.87.166 54.172.185.33 69.71.55.95 76.10.177.106 107.181.166.158 104.130.225.83 52.53.253.51 85.90.245.43 52.27.201.167 54.243.233.163 83.169.21.151 58.80.17.142 162.248.8.198 174.129.36.212 162.242.182.90 104.153.45.106 13.67.61.8 216.75.196.228 107.191.111.152 162.242.173.179 5.189.181.39 104.131.90.237 107.189.147.171 192.241.198.59 178.239.176.241 65.74.108.130 52.8.25.241 212.13.64.104 115.159.44.75 148.163.81.177 66.119.7.120 198.11.179.187 168.77.213.214 31.222.140.31 54.83.55.153 153.122.53.189 198.56.176.249 54.213.207.230 210.45.66.88 52.2.208.79 82.149.245.105 51.255.197.149 104.131.28.74 137.116.133.96 136.243.44.94 180.179.57.128 52.88.144.49 52.6.34.35 52.5.187.74 159.203.100.140 104.236.201.71 188.138.91.122 75.148.25.163 52.0.186.213 202.166.195.102 161.53.40.216 193.239.136.198 104.155.27.249 50.62.214.217 54.64.44.156 188.173.187.236 159.203.97.37 79.143.75.17 37.187.70.111 62.210.211.116 94.102.67.233 133.242.182.83 173.201.185.157 104.155.83.50 204.12.49.159 52.89.239.172 119.81.153.122 5.45.75.18 207.192.70.59 5.150.243.122 85.214.29.131 166.78.109.190 70.33.224.222 188.166.100.216 178.62.36.72 198.23.161.249 69.175.77.27 219.92.247.86 89.31.150.242 107.170.106.221 31.14.134.200 78.47.162.175 54.94.252.114 153.122.54.140 138.128.196.137 104.131.157.208 107.20.49.81 119.9.92.89 149.210.219.189 23.227.187.61 95.211.156.87 46.252.16.52 45.56.77.190 62.210.222.154 62.109.18.232 54.175.56.141 192.237.250.108 176.58.96.19 66.195.117.3 5.9.25.202 5.196.4.138 54.186.76.11 76.77.208.21 64.79.234.246 192.81.135.119 5.196.187.109 52.5.38.126 50.62.72.194 82.194.72.211 97.107.134.215 173.203.83.175 98.102.95.51 77.72.147.209 52.8.51.28 192.184.91.151 192.241.220.247 50.56.19.134 148.163.6.188 104.131.110.134 216.51.174.173 49.212.218.25 132.216.12.109 104.131.64.221 140.112.148.131 108.166.180.4 153.120.40.60 157.7.214.145 54.213.67.189 54.67.35.224 23.227.167.13 5.2.143.192 178.254.2.79 134.213.74.208 213.180.93.77 104.131.118.92 23.254.115.164 40.114.42.82 98.158.190.196 159.203.129.46 81.128.173.165 77.240.14.73 217.12.194.168 132.206.251.142 192.241.194.86 205.178.186.38 176.58.118.157 54.167.29.25 104.236.104.123 72.191.65.101 46.183.9.141 109.171.40.191 188.226.254.239 134.213.60.44 54.191.81.39 198.199.90.33 107.178.217.100 128.130.178.154 50.161.253.100 190.96.85.141 103.6.212.116 176.28.14.214 5.45.109.99 31.220.108.13 149.210.175.179 42.112.17.192 50.59.80.80 46.236.34.202 104.131.184.238 123.30.239.217 178.239.182.240 167.160.162.134 178.62.78.23 54.219.149.9 154.119.226.12 89.135.140.112 104.236.19.236 46.163.116.204 123.30.242.30 195.148.91.88 45.55.153.12 202.166.25.103 83.166.162.188 209.61.142.121 46.4.121.221 54.246.137.219 80.120.162.14 206.223.156.45 134.213.49.149 204.225.103.25 54.194.13.132 68.169.140.69 71.19.190.141 198.211.123.43 192.169.226.130 160.16.98.88 5.135.164.166 45.55.165.230 137.117.102.43 104.236.162.162 50.250.165.25 54.205.88.50 88.80.186.186 188.226.133.26 91.109.10.154 162.213.252.92 52.64.15.112 52.64.154.243 52.76.52.148 130.211.172.63 176.31.125.25 198.58.111.242 136.243.9.136 50.57.170.16 192.187.118.242 62.138.0.82 180.210.53.105 67.221.217.120 188.165.249.189 201.203.104.65 104.197.64.19 94.23.6.183 54.215.134.22 186.183.182.163 199.223.116.79 173.201.187.150 195.210.28.238 193.77.101.143 46.163.113.139 202.88.239.67 54.235.109.232 162.209.50.73 194.68.37.200 37.252.235.216 217.12.207.134 109.238.54.167 54.200.18.49 66.175.217.9 23.254.164.150 54.217.221.74 166.62.86.27 5.2.247.240 162.252.107.108 45.55.205.178 139.162.196.102 104.197.132.30 192.241.218.160 107.21.232.123 168.144.5.63 104.131.213.147 162.242.223.39 212.251.156.44 153.122.136.132 185.24.74.22 54.223.148.142 96.126.97.162 195.189.95.152 23.94.134.171 178.62.9.120 219.141.135.114 54.200.217.60 193.204.255.197 188.226.194.195 52.4.215.153 104.154.64.85 88.206.209.4 68.168.105.212 185.49.14.92 178.62.111.122 209.124.35.165 58.225.57.239 188.20.241.45 128.199.187.162 104.238.97.122 173.83.250.132 23.102.26.205 185.28.22.43 155.247.167.252 45.33.58.51 169.244.138.12 45.79.2.239 195.29.61.108 178.62.116.219 2.228.223.212 31.220.109.223 212.35.193.178 169.45.65.228 49.212.190.239 217.21.61.138 84.246.225.122 217.170.72.138 85.222.229.121 62.210.249.53 54.173.103.229 130.211.158.77 162.248.54.35 50.116.31.62 136.145.62.70 104.44.137.247 52.0.112.112 82.221.104.231 74.50.57.163 144.76.13.228 192.254.69.230 173.44.54.142 89.253.230.249 104.46.53.152 46.101.25.115 23.239.9.222 188.166.2.169 104.154.37.231 185.45.253.22 54.215.180.134 83.169.8.168 139.196.183.175 184.184.203.172 66.55.135.155 45.55.166.95 41.189.74.37 198.51.169.108 153.120.125.175 108.59.252.206 69.8.238.170 107.155.108.169 115.146.123.233 216.168.201.123 46.101.37.38 216.168.201.124 194.162.122.79 107.20.202.152 45.79.100.208 209.181.248.189 139.162.32.221 94.23.51.198 200.151.25.139 144.76.201.104 104.236.53.211 52.74.3.214 141.192.254.170 46.4.90.232 76.74.153.101 198.61.170.9 5.101.123.17 67.183.30.106 190.9.132.11 153.122.10.149 54.94.225.96 167.246.44.193 173.255.212.44 95.172.17.154 52.3.154.196 23.95.39.190 210.51.174.219 5.35.248.221 82.146.40.188 192.249.76.174 65.49.9.75 178.62.28.140 37.75.251.12 23.253.23.26 92.51.240.149 193.35.56.154 96.126.126.5 94.23.51.159 31.168.132.171 193.1.75.50 178.208.35.37 96.56.247.138 46.235.224.240 54.172.0.125 52.20.26.52 209.128.91.28 23.101.194.159 104.196.58.8 202.134.0.217 153.126.210.161 178.62.67.108 93.104.213.158 134.213.48.241 185.83.216.90 106.186.17.29 54.254.233.55 52.28.2.139 5.35.250.50 176.28.102.140 71.174.52.14 54.207.62.206 188.166.67.104 45.79.68.135 155.4.12.225 185.53.129.239 45.55.130.164 178.254.24.36 5.196.100.82 23.91.68.35 162.211.248.221 45.79.215.242 151.236.221.223 94.199.48.188 104.236.89.203 104.236.213.203 178.254.43.235 66.175.213.151 195.154.227.90 45.56.76.163 146.185.142.148 193.219.179.2 54.69.169.24 199.195.248.98 184.73.219.133 222.235.64.206 173.13.8.17 193.136.11.85 164.132.101.163 82.148.227.237 5.189.145.178 23.253.47.248 134.100.14.62 69.66.105.121 37.143.12.163 54.183.253.38 50.57.149.211 162.13.47.135 180.222.182.127 84.40.31.179 210.14.155.119 52.7.206.7 104.154.66.135 199.193.252.227 209.90.238.3 202.112.126.144 108.166.85.147 65.101.157.107 165.100.238.183 195.85.215.36 80.90.48.200 200.123.179.17 81.169.166.192 199.231.241.78 212.118.198.249 198.50.212.232 204.244.51.41 12.154.57.241 133.130.75.55 23.226.237.2 166.63.127.144 216.75.12.168 31.192.224.15 61.219.17.223 67.204.164.31 133.242.147.81 163.172.10.194 140.136.167.25 104.155.70.119 50.62.134.38 107.191.98.127 107.170.40.170 148.163.83.245 49.212.218.54 68.233.45.150 128.199.247.200 104.128.228.4 192.241.224.203 162.243.37.235 219.239.91.74 136.243.103.216 132.177.240.85 208.78.106.113 104.236.37.40 192.155.89.153 107.170.141.140 104.245.34.93 50.57.126.127 104.131.36.234 104.131.36.235 67.184.180.72 62.80.224.150 174.140.167.209 184.73.249.88 185.25.148.14 151.248.0.68 86.58.128.153 94.199.242.51 151.248.0.67 52.36.252.155 92.51.134.219 128.199.140.209 162.243.109.197 207.111.253.12 64.120.28.86 54.195.246.39 54.254.55.122 76.169.135.9 217.20.180.66 64.183.19.67 80.88.126.72 46.4.40.130 202.244.241.54 133.242.203.123 52.37.152.224 213.246.42.4 85.214.220.79 23.239.8.46 218.91.205.203 79.78.176.21 206.223.156.102 208.94.165.169 119.46.77.171 199.89.55.36 52.26.133.133 91.250.252.229 66.70.101.22 213.9.95.214 67.219.60.120 148.251.190.100 166.78.190.54 134.213.159.139 162.220.241.181 213.131.118.6 193.40.194.202 50.116.12.38 74.207.251.134 45.58.36.142 136.243.111.8 153.122.152.196 109.205.54.69 212.129.55.29 52.30.162.202 130.75.109.19 136.159.87.32 195.88.174.33 31.192.231.58 54.221.239.178 54.65.117.185 209.8.127.190 13.70.201.65 200.27.203.5 144.76.56.251 62.210.69.6 69.20.200.217 107.191.48.203 62.210.106.57 162.242.222.104 173.61.145.75 198.58.127.144 194.105.29.134 188.166.117.213 91.184.11.137 50.63.138.88 45.55.63.216 130.185.109.48 178.79.181.192 75.127.3.154 54.165.77.143 54.221.234.124 5.189.147.225 84.50.108.235 213.46.37.203 50.56.194.145 23.97.219.85 69.63.112.19 83.255.195.158 104.131.37.28 72.52.166.4 192.71.3.133 65.98.76.98 112.216.136.186 74.217.43.85 92.51.131.41 45.55.138.71 54.84.134.14 185.26.144.112 104.197.1.208 159.203.9.59 104.197.50.153 198.58.107.156 220.128.132.113 202.241.168.53 71.93.125.134 213.165.94.180 95.110.236.165 54.186.27.35 162.243.22.92 23.229.4.195 157.7.72.43 51.255.33.42 46.38.240.211 159.8.85.44 50.56.186.113 207.210.128.22 162.13.15.198 209.78.110.99 104.239.228.171 64.79.108.219 209.20.64.207 54.225.76.33 173.203.220.5 52.91.141.124 159.203.113.194 45.55.20.86 49.212.152.24 176.58.124.231 14.0.17.15 103.26.192.156 119.81.214.21 91.194.60.90 169.45.65.232 54.163.230.138 182.163.56.12 107.170.186.5 169.45.65.236 158.69.207.161 62.4.0.46 169.45.65.238 104.197.65.85 82.166.80.231 178.254.30.114 95.213.182.91 45.33.3.234 104.236.167.8 185.15.76.218 104.131.194.226 50.56.191.105 104.155.222.34 69.60.118.129 122.227.59.131 178.77.97.5 54.241.191.56 37.59.66.190 54.215.238.0 104.155.63.137 52.35.38.97 64.6.243.251 87.237.205.145 104.131.99.212 85.206.150.11 187.163.97.88 153.122.58.6 137.117.45.68 130.149.22.104 114.160.88.116 195.62.77.49 74.85.242.213 45.79.172.13 181.113.62.173 207.54.97.60 45.79.136.35 52.17.173.75 72.90.84.227 66.175.215.254 205.185.118.81 23.19.43.42 217.116.191.47 213.136.87.135 213.136.40.57 134.213.62.89 198.71.86.233 23.99.216.175 54.85.206.106 45.79.177.199 198.101.157.45 61.239.221.51 104.224.133.138 54.193.54.41 212.71.255.228 188.121.50.86 66.175.214.164 95.85.26.53 192.241.192.232 202.182.174.70 54.77.136.254 80.86.107.177 174.120.70.157 176.112.195.196 146.185.180.203 50.63.128.159 107.155.75.33 63.86.121.33 104.239.228.203 209.66.198.146 162.13.184.177 27.120.106.132 193.35.56.142 23.94.38.113 82.100.197.184 82.199.134.148 104.197.72.136 45.55.48.68 62.210.110.38 142.4.30.81 207.178.170.91 94.73.238.61 52.18.224.95 23.253.46.235 198.27.103.248 104.197.190.61 194.28.132.215 195.57.5.51 209.126.109.95 62.209.162.249 128.199.239.250 91.121.175.63 37.218.249.206 208.45.201.49 52.8.105.95 178.132.203.232 91.225.188.35 54.249.56.223 62.210.208.38 45.79.152.177 45.79.109.250 162.243.49.200 192.237.187.51 91.108.81.187 54.175.63.27 43.252.89.111 54.88.173.140 178.16.220.163 54.225.237.147 52.17.203.174 188.226.241.159 159.203.225.77 104.239.231.76 1.9.118.115 54.72.64.253 168.63.241.31 199.19.111.135 62.210.222.210 1.34.224.179 69.160.36.147 49.247.226.45 108.174.49.214 54.215.239.205 212.83.5.103 207.162.185.24 216.183.86.52 50.63.188.48 134.213.59.79 147.156.204.254 104.155.15.41 192.252.214.243 40.127.130.243 121.78.144.232 213.179.193.33 85.94.217.162 160.97.10.133 198.71.78.97 158.69.210.69 195.154.106.66 52.2.198.206 92.38.231.42 71.240.188.210 37.157.179.184 77.97.186.154 208.52.150.12 153.122.35.104 85.31.147.180 198.17.96.185 149.56.46.233 151.236.48.204 5.189.172.39 162.13.114.83 200.14.84.158 207.171.1.34 104.154.43.223 139.162.15.26 23.239.18.59 92.51.166.211 54.171.130.222 27.254.66.222 185.93.52.122 195.154.104.192 50.247.186.198 82.223.18.28 104.197.111.130 74.80.197.18 213.188.154.61 83.220.138.121 45.55.87.105 212.23.150.121 198.16.5.144 54.165.147.89 27.251.172.34 64.237.25.84 173.201.180.145 23.101.136.212 80.85.84.244 104.197.134.130 191.233.99.210 168.63.8.126 185.21.103.200 5.249.157.119 218.211.179.100 149.56.13.180 62.167.235.147 5.189.137.100 54.214.32.1 45.55.136.8 54.201.35.156 54.164.69.237 213.239.194.136 178.254.31.97 54.152.91.215 104.45.150.207 193.34.92.71 162.13.154.9 50.252.231.163 52.21.198.114 91.196.49.121 75.147.189.169 166.62.93.102 52.17.147.124 51.255.80.8 153.122.112.66 185.26.48.33 143.121.196.9 80.94.32.142 90.149.158.75 68.178.129.29 103.242.65.8 192.81.221.190 129.16.155.31 37.59.11.142 173.25.91.120 210.197.109.45 210.210.21.12 5.9.107.146 176.74.192.148 37.187.117.24 206.72.205.66 54.191.12.63 129.144.27.65 162.243.112.132 65.100.209.218 91.121.36.11 37.153.96.57 188.134.31.222 162.221.182.13 64.50.160.243 52.4.205.99 54.153.79.124 72.52.130.76 62.75.180.114 23.21.67.118 166.78.188.16 193.34.144.201 108.61.95.143 133.242.138.44 162.243.251.121 54.148.252.26 79.125.25.35 178.254.44.35 54.144.137.4 45.55.200.6 148.88.67.179 89.141.7.195 184.168.30.101 82.194.72.91 104.13.197.146 66.226.75.245 70.36.31.166 104.193.9.61 128.199.90.46 78.109.168.205 130.15.96.239 52.26.12.243 96.255.5.45 208.112.102.42 107.170.17.68 104.131.69.29 95.138.185.28 212.227.108.129 128.199.50.130 144.202.252.58 107.161.148.219 144.76.86.70 166.78.147.132 162.243.68.16 40.127.185.145 37.187.0.37 184.173.219.68 52.8.66.65 173.203.243.73 209.148.94.140 151.1.80.83 50.23.35.252 190.216.148.68 193.4.242.15 213.245.254.131 23.92.20.185 72.32.121.144 133.130.115.121 104.161.50.107 82.221.22.79 60.251.11.147 175.45.187.196 91.213.203.207 178.62.17.178 23.239.2.252 93.189.28.142 46.30.246.5 217.148.43.245 81.218.230.66 188.116.4.187 96.46.250.108 144.76.132.124 176.28.9.64 107.21.205.52 176.74.192.131 92.51.131.52 70.15.255.150 23.92.54.169 52.27.11.2 54.197.240.92 69.43.178.108 178.254.6.230 162.220.241.99 91.121.7.130 94.97.65.255 54.169.42.100 216.27.51.166 131.188.160.177 62.210.192.91 54.183.250.191 209.160.24.14 64.15.186.61 23.226.225.144 89.230.215.122 5.39.86.93 163.172.133.210 217.170.197.118 43.225.54.191 40.113.124.157 153.122.65.199 148.251.198.13 213.206.235.25 113.161.71.189 144.76.3.107 51.254.242.223 104.207.130.247 66.111.111.75 200.11.242.83 213.115.101.235 104.130.16.209 128.118.2.116 23.99.205.45 66.228.57.183 80.241.223.172 40.115.6.61 91.216.152.158 200.7.175.200 85.25.136.25 74.221.214.112 199.96.46.156 107.21.190.85 128.199.85.7 46.101.149.65 69.61.33.34 91.121.251.163 54.153.161.203 95.163.78.52 192.81.130.197 186.113.29.123 96.89.124.226 45.78.45.57 107.155.191.131 198.74.60.230 54.201.91.3 199.233.242.2 46.101.155.197 87.230.23.6 69.26.7.145 54.212.74.200 81.91.1.67 195.154.162.102 95.85.52.243 204.12.123.151 62.48.35.80 59.44.102.254 52.27.66.233 198.61.165.44 79.133.160.234 169.54.255.25 198.56.176.34 162.211.248.55 45.58.60.218 80.244.185.179 52.30.108.211 37.59.52.204 52.28.128.168 148.251.57.123 153.126.208.95 198.56.176.182 41.206.193.84 193.1.30.90 192.249.79.157 75.99.84.98 173.162.49.244 52.26.168.196 103.254.208.140 212.129.33.209 54.83.2.213 104.236.29.59 52.8.113.144 23.253.78.152 54.172.126.17 198.101.157.75 54.186.45.10 85.214.86.87 184.169.150.73 198.12.67.229 45.79.187.165 50.63.138.61 85.214.55.201 107.150.41.138 162.13.134.28 168.61.43.210 85.234.141.164 104.236.157.48 178.62.68.29 46.101.17.104 213.74.76.138 176.28.102.126 182.163.76.33 93.189.46.97 205.234.20.209 168.235.86.231 96.225.177.21 108.27.36.228 86.57.136.174 192.241.183.190 64.64.212.151 173.230.149.225 50.186.239.31 120.138.27.176 63.131.159.242 157.7.136.102 193.46.205.22 23.226.132.129 83.239.183.162 38.110.28.222 54.225.238.88 212.227.141.242 219.99.164.87 85.31.144.149 188.190.159.15 134.213.132.8 106.250.162.154 75.147.195.66 23.246.220.228 46.163.112.252 81.209.165.126 122.201.85.112 162.242.172.19 104.155.78.204 62.233.106.186 190.153.231.155 104.236.108.111 82.200.45.174 104.236.225.159 208.93.67.130 54.213.115.227 198.200.117.70 46.105.41.83 24.229.6.134 176.28.121.4 162.220.47.45 67.225.176.34 45.55.70.223 135.23.192.125 202.38.172.235 104.197.210.76 128.199.251.106 216.223.138.130 82.196.15.121 69.28.92.108 95.131.254.187 198.12.152.179 72.249.85.201 54.225.136.222 212.188.61.58 49.212.167.155 54.78.132.87 91.207.159.51 91.198.129.240 50.63.141.39 140.119.55.53 190.242.126.16 166.78.147.51 62.109.61.208 85.157.164.196 52.18.28.153 87.230.92.251 161.202.182.174 91.207.159.17 107.170.120.201 81.136.227.7 104.236.158.207 49.212.161.59 64.94.124.17 71.100.86.2 198.55.30.210 62.210.137.112 89.45.201.134 108.174.27.107 188.226.128.215 52.53.222.210 52.72.115.118 106.185.48.114 182.93.93.156 54.76.33.10 54.234.140.248 200.159.128.19 85.214.44.214 40.85.94.216 189.204.11.218 50.21.187.7 69.164.209.153 176.28.13.163 176.28.110.194 24.246.14.186 199.255.137.240 146.148.54.211 54.163.104.94 5.199.169.246 119.17.214.87 149.62.173.107 27.120.91.250 62.210.74.107 201.159.19.138 206.221.186.106 82.222.172.99 193.192.58.181 104.236.138.134 74.208.109.130 52.1.122.155 69.164.201.39 115.159.50.118 47.88.11.141 62.75.137.11 85.214.24.32 194.165.70.13 1.255.57.142 193.200.173.18 162.243.26.68 85.214.60.177 5.9.80.247 52.18.13.210 203.19.66.90 52.1.62.234 65.111.166.246 31.14.136.134 81.2.246.9 148.137.145.118 188.226.246.32 115.125.248.248 78.132.137.208 83.170.84.92 89.236.16.183 80.240.133.124 50.17.215.154 134.213.133.162 23.102.168.107 146.148.63.90 104.131.36.140 213.81.213.183 146.185.148.36 111.13.112.5 52.5.229.15 188.165.252.67 118.69.241.99 93.93.155.142 207.34.111.162 162.242.219.190 24.11.59.134 158.69.198.246 104.131.64.107 162.242.212.94 104.236.232.217 222.237.78.160 191.237.213.174 104.131.147.118 213.85.31.149 159.203.121.141 91.192.172.94 54.169.166.73 51.255.200.23 162.243.69.63 23.102.42.111 64.62.233.51 66.175.221.234 217.12.197.12 84.45.33.219 37.120.177.145 192.3.150.191 192.12.222.234 200.14.71.100 153.122.151.36 72.14.189.254 139.196.28.249 162.248.167.164 45.64.60.157 138.91.93.132 23.244.26.204 118.163.59.207 23.253.73.85 164.132.197.182 52.19.43.150 217.70.144.44 59.148.240.67 92.51.132.45 89.44.200.179 94.76.217.239 162.13.116.39 216.250.135.24 89.221.247.123 216.119.142.138 4.49.120.126 79.133.47.198 54.77.95.240 50.31.76.9 107.150.39.234 92.243.27.23 52.30.182.228 52.2.131.1 72.15.192.10 87.230.93.59 148.163.6.154 27.120.88.112 54.164.153.143 54.237.135.57 37.221.194.193 104.236.80.67 176.126.247.16 5.79.106.56 37.59.121.209 52.58.82.240 54.82.212.58 192.241.230.233 85.25.69.137 160.36.67.88 54.66.172.169 63.138.74.253 52.3.4.204 200.124.6.211 172.245.108.115 5.196.13.240 91.250.112.253 5.49.78.217 87.230.87.132 144.76.128.125 23.107.27.138 37.194.208.108 80.246.59.187 133.242.203.190 54.201.175.141 107.170.236.134 209.105.235.17 149.202.37.129 130.226.142.215 205.185.115.41 46.101.87.45 213.188.152.145 64.71.160.135 72.174.159.137 144.76.109.236 82.196.12.115 93.76.48.18 85.25.201.86 178.62.54.250 23.253.102.21 37.187.25.177 61.127.191.78 173.255.220.40 165.225.130.10 92.243.92.41 52.27.186.84 23.97.58.45 173.167.106.161 188.166.12.221 176.58.105.156 62.75.242.6 103.28.37.33 54.164.8.252 198.177.118.56 54.88.149.3 113.52.130.34 206.221.185.218 178.21.175.15 8.34.218.93 107.20.153.33 188.226.166.141 190.81.51.50 91.121.123.86 83.161.127.135 130.225.239.71 188.226.221.214 195.199.225.155 159.203.27.205 52.10.244.211 104.131.214.75 54.86.225.214 190.144.15.90 213.203.234.231 118.67.200.39 69.2.32.245 198.206.134.67 52.17.226.44 209.87.228.116 203.213.67.94 52.4.245.180 82.194.6.45 104.131.190.235 178.132.1.208 199.38.223.156 174.128.36.125 209.190.28.138 128.199.216.18 136.243.72.108 192.241.237.92 78.24.216.3 216.13.213.3 192.217.124.212 23.94.249.202 207.171.3.153 54.79.42.180 62.109.7.17 104.161.52.122 62.149.171.65 91.135.235.15 5.35.245.192 103.15.74.102 45.33.22.181 54.84.200.98 178.238.230.94 84.215.229.193 54.219.168.7 148.251.9.44 104.131.185.238 206.123.115.11 81.169.196.245 62.210.206.230 52.3.60.253 178.62.111.118 176.28.22.213 204.185.56.20 182.162.83.179 130.211.125.175 162.243.209.42 69.197.179.42 91.121.192.236 204.44.75.4 54.84.181.142 54.68.190.109 178.79.140.47 81.2.225.246 169.54.131.57 23.239.24.193 217.111.69.56 52.20.16.241 153.127.243.37 45.79.9.169 153.122.6.38 85.214.79.23 195.251.54.94 216.243.141.229 54.204.1.11 52.23.132.154 50.18.157.103 129.252.169.2 49.212.199.219 54.75.252.239 67.207.157.57 104.197.37.202 203.162.37.11 52.1.175.223 52.31.107.102 159.203.93.250 37.247.16.86 194.102.194.205 91.90.95.16 23.253.244.44 46.235.224.78 136.243.15.156 188.165.225.9 89.16.176.140 217.160.111.56 217.127.240.195 52.16.118.145 185.83.217.222 60.251.56.165 50.63.26.101 104.154.53.181 192.237.170.105 72.52.116.26 157.7.203.240 213.188.154.168 37.187.29.145 40.114.201.206 77.238.26.88 173.255.223.144 148.251.137.52 69.194.129.67 162.242.246.141 162.243.228.156 23.239.22.173 179.188.20.120 162.242.237.169 220.128.140.202 83.212.118.158 216.150.133.126 5.39.93.102 178.63.97.130 166.78.237.114 188.226.90.89 52.20.160.232 216.151.212.204 216.151.212.205 89.160.45.81 98.158.182.144 192.227.145.168 45.55.159.118 77.68.40.40 107.23.79.98 62.76.103.15 104.236.22.228 168.61.55.28 213.212.63.72 107.181.178.174 104.199.192.64 70.33.178.202 199.89.55.216 220.149.85.223 188.40.72.210 216.39.105.67 178.62.198.203 45.55.64.195 109.123.111.22 192.241.235.78 162.144.106.28 23.97.52.94 196.45.48.135 54.201.186.97 173.201.191.186 217.72.220.155 212.38.167.106 80.82.120.232 52.19.76.150 51.254.90.92 180.179.206.221 210.26.24.52 8.36.81.54 65.182.103.196 108.15.33.111 104.167.105.202 104.238.98.119 177.87.83.53 198.32.236.242 23.105.64.20 62.233.113.13 49.212.209.22 148.163.79.97 45.55.134.72 104.224.172.104 202.9.69.34 192.163.228.70 104.239.139.80 104.155.54.205 104.208.244.182 139.162.199.48 210.233.80.12 94.23.66.89 86.0.215.8 72.167.246.109 210.140.161.234 54.225.114.2 54.72.19.21 185.12.92.243 192.248.24.6 173.201.21.153 78.47.30.212 91.185.193.176 78.31.104.133 212.1.206.198 90.130.78.20 151.236.217.194 175.126.62.72 52.6.106.124 83.137.49.121 199.19.85.58 162.243.21.193 217.126.98.77 52.91.161.181 54.215.163.225 5.45.97.52 188.211.237.136 132.147.82.189 45.55.86.237 107.155.107.199 162.212.56.149 186.250.240.157 54.232.201.46 52.25.200.28 198.58.105.235 106.186.119.181 46.232.136.139 104.236.168.40 107.170.225.33 67.23.7.94 217.108.236.239 201.28.20.226 216.55.168.168 37.46.179.204 52.16.65.21 216.87.168.238 185.26.51.203 199.180.252.13 178.62.111.243 54.209.130.63 162.144.220.149 45.33.83.210 131.203.252.166 62.210.223.23 46.101.7.129 40.76.42.45 45.55.77.93 111.89.179.204 134.102.231.112 46.252.26.187 24.227.217.215 212.2.17.198 178.164.8.90 88.119.248.167 54.255.181.235 45.33.77.70 95.85.38.9 134.213.214.149 213.154.229.44 92.51.151.240 54.144.193.140 54.178.192.55 40.77.111.124 92.51.166.198 198.211.125.243 46.32.254.201 178.213.242.83 74.120.12.10 134.213.31.201 178.79.132.228 166.78.125.191 162.247.143.213 45.79.171.130 60.236.203.70 104.236.11.171 133.18.16.68 198.58.118.5 83.169.2.24 66.18.62.89 37.247.116.173 186.47.79.70 104.131.130.221 124.81.81.46 37.48.73.214 52.64.210.136 133.242.143.200 98.110.70.214 138.201.32.188 37.188.100.163 139.196.4.2 45.55.186.68 50.249.99.237 62.210.189.175 74.101.194.250 89.35.33.18 40.122.44.61 185.58.193.131 23.23.187.31 195.208.167.19 112.169.131.14 52.27.148.223 193.169.7.199 87.229.24.83 52.17.41.82 82.164.106.162 54.229.184.38 13.71.144.222 54.227.57.108 80.78.168.42 150.217.82.95 159.203.23.29 67.59.136.20 78.46.72.170 54.165.175.61 52.10.238.42 208.78.97.111 216.136.121.108 68.65.120.48 109.204.232.20 46.183.12.253 213.229.90.156 54.83.22.249 184.58.225.113 109.234.211.66 54.169.3.54 95.130.11.193 136.243.36.226 96.255.221.69 195.154.126.242 151.248.112.204 51.254.139.164 45.79.128.192 185.21.152.99 46.137.91.227 5.196.173.55 83.239.94.50 85.214.215.14 106.187.49.31 157.7.209.194 91.228.53.246 54.229.204.142 52.22.6.255 54.68.34.234 107.170.37.208 193.104.101.140 192.249.72.177 192.3.160.192 69.174.243.65 213.222.211.193 72.32.143.53 23.96.25.149 31.147.204.147 173.208.136.226 185.10.50.40 75.55.253.139 104.154.65.99 192.3.117.84 46.163.75.5 72.4.146.170 104.130.171.250 46.101.15.162 85.214.92.157 72.249.12.85 176.58.105.237 178.62.68.212 159.203.89.174 64.15.152.68 62.210.109.33 83.166.204.15 198.199.112.167 51.254.208.24 50.16.21.61 185.82.20.31 23.253.229.50 206.164.71.225 184.106.115.203 206.164.71.227 85.214.114.193 192.1.122.24 199.27.232.211 78.46.108.3 114.34.48.177 203.250.51.103 54.153.184.217 85.214.72.90 158.69.54.218 62.210.99.222 80.82.118.158 107.170.121.20 104.131.200.6 149.202.47.227 78.46.44.186 176.23.88.233 54.241.16.131 198.136.42.154 45.55.140.122 162.243.35.131 104.200.16.134 198.96.117.151 212.129.34.50 103.246.204.171 176.31.187.145 172.99.112.17 66.228.40.82 157.205.226.50 64.94.157.85 54.241.6.158 52.27.165.14 85.214.37.59 85.214.27.199 202.171.131.66 23.107.27.244 104.196.13.75 65.118.138.159 85.25.204.119 52.30.135.10 46.108.63.235 198.147.21.123 128.199.181.149 195.208.147.149 192.169.227.73 202.61.105.216 206.180.182.78 62.210.169.160 64.184.158.133 93.162.68.106 95.85.32.202 23.97.233.197 71.237.129.206 104.45.2.164 71.164.139.149 192.241.181.193 198.58.109.249 203.151.118.68 82.99.69.28 52.0.64.101 50.116.7.113 213.73.90.49 41.89.31.4 52.3.192.37 162.211.248.30 101.76.160.244 50.63.181.157 130.211.251.188 52.0.143.19 23.253.203.39 101.98.78.59 54.176.74.114 69.70.21.212 46.16.140.158 13.90.255.132 216.224.184.33 52.72.124.204 203.175.170.38 37.139.25.237 70.182.219.20 217.148.160.166 69.25.137.122 130.65.255.49 162.144.151.185 45.55.59.113 178.62.46.193 23.251.130.63 62.210.239.113 208.94.161.109 103.229.73.20 52.73.138.130 81.7.13.195 213.171.222.104 213.223.171.211 200.189.221.163 23.107.27.27 65.99.196.181 83.98.168.126 104.197.101.166 37.188.115.113 192.155.94.139 185.100.64.197 104.236.185.207 41.70.16.60 40.76.213.158 199.73.109.205 194.244.18.77 114.179.95.172 185.18.148.50 106.187.90.166 178.141.251.53 89.234.61.92 108.170.101.226 192.241.182.117 52.33.141.19 223.203.225.194 198.12.148.186 178.62.74.136 40.76.56.88 52.2.193.30 40.127.194.253 104.130.8.43 104.161.51.86 188.166.22.165 82.223.22.115 86.109.127.14 178.79.152.8 87.241.33.58 195.138.163.99 208.176.47.172 23.88.82.75 194.75.76.132 193.1.12.154 158.69.209.163 91.121.171.14 166.62.93.23 153.92.43.83 189.204.35.28 211.75.79.18 80.92.232.61 74.94.213.106 144.76.237.40 134.213.156.62 178.62.18.211 43.252.91.6 176.126.243.137 148.163.32.97 23.254.161.216 87.128.106.217 194.44.128.164 149.62.168.41 177.39.17.2 195.159.169.156 54.83.1.60 139.196.17.148 213.180.93.157 184.70.103.94 93.189.30.250 54.215.224.186 178.63.83.130 216.122.144.6 139.59.248.192 198.11.183.80 158.69.3.253 64.62.138.67 149.202.236.236 82.194.72.116 178.79.157.27 183.129.178.8 195.154.162.66 104.197.85.60 173.255.229.7 74.120.15.102 45.55.62.160 151.248.0.86 54.86.103.31 66.228.55.24 173.192.57.67 159.203.97.169 46.101.196.32 81.28.97.148 107.191.108.89 52.11.37.34 54.189.15.176 104.131.11.60 69.64.43.104 195.154.165.91 91.156.56.196 151.236.45.42 190.215.76.198 104.131.18.209 76.27.4.224 95.85.23.233 59.106.208.49 50.116.9.123 104.131.57.82 178.254.28.240 95.175.99.240 213.126.129.25 50.57.179.107 88.208.238.77 143.93.113.16 192.249.79.181 83.241.232.83 139.196.180.135 85.159.179.85 192.241.249.114 182.48.116.224 110.78.164.101 52.32.114.223 45.79.9.112 172.245.220.87 59.152.234.141 212.36.84.224 50.63.152.89 85.255.206.193 84.200.33.50 54.68.59.117 64.73.117.102 85.25.200.68 64.38.234.51 85.113.69.34 104.131.131.149 176.28.14.11 178.33.71.250 50.169.149.73 192.111.148.84 97.107.133.94 198.41.31.34 104.196.57.239 151.80.35.168 159.203.112.228 64.34.163.105 5.189.148.6 84.104.236.123 104.131.51.230 185.47.15.101 45.33.31.101 107.21.117.242 199.47.211.186 52.2.239.155 50.16.218.27 46.37.189.122 107.170.117.101 104.197.14.114 136.243.94.2 167.114.114.240 52.7.39.251 162.221.176.58 80.88.17.54 88.208.217.22 160.16.196.36 50.18.193.179 37.187.112.21 198.98.49.188 162.223.55.34 80.82.119.81 222.255.29.19 54.165.222.228 46.101.237.74 168.235.93.217 64.22.109.20 23.96.245.203 144.76.114.213 192.249.78.225 178.254.25.96
