Nginx Nginx failing with xenforo rewrites
Discussion in 'Install & Upgrades or Pre-Install Questions' started by mikey, Sep 13, 2023.
  1. mikey
    mikey New Member
    2:03 AM
    • Centmin Mod Version Installed: 124.00 stable
    • Nginx Version Installed: 1.24.0
    • PHP Version Installed: 8.1.23
    • MariaDB MySQL Version Installed: 10.3.39
    • Persistent Config: LETSENCRYPT_DETECT='y'
      autoindex  off;
    restarting Nginx fails with this error.  I removed all the xenforo location things and nginx restarted again.  adding just the first location / {  caused it to error again.
    [code]
    [root@igor conf.d]# systemctl status nginx.service
    ● nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
       Loaded: loaded (/etc/rc.d/init.d/nginx; bad; vendor preset: disabled)
       Active: failed (Result: exit-code) since Tue 2023-09-12 23:39:29 UTC; 23s ago
      Process: 3436 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=1/FAILURE)
     Main PID: 726 (code=exited, status=0/SUCCESS)
    Sep 12 23:39:29 igor.xxxxx systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Sep 12 23:39:29 igor.xxxxx nginx[3436]: Starting nginx: nginx: [emerg] unknown directive " " in /usr/local/nginx/conf/conf.d/xxxxx.com.ssl.conf:68
    Sep 12 23:39:29 igor.xxxxx nginx[3436]: [FAILED]
    Sep 12 23:39:29 igor.xxxxx systemd[1]: nginx.service: control process exited, code=exited status=1
    Sep 12 23:39:29 igor.xxxxx systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
    Sep 12 23:39:29 igor.xxxxx systemd[1]: Unit nginx.service entered failed state.
    Sep 12 23:39:29 igor.xxxxx systemd[1]: nginx.service failed.
    Sep 12 23:39:29 igor.xxxx systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Sep 12 23:39:29 igor.xxxx nginx[3436]: Starting nginx: nginx: [emerg] unknown directive " " in /usr/local/nginx/conf/conf.d/xxxxxx.ssl.conf:68
    Sep 12 23:39:29 igor.xxxx nginx[3436]: [FAILED]
    Sep 12 23:39:29 igor.xxxx systemd[1]: nginx.service: control process exited, code=exited status=1
    Sep 12 23:39:29 igor.xxxx systemd[1]: Unit nginx.service entered failed state.
    Sep 12 23:39:29 igor.xxxx systemd[1]: nginx.service failed.
    55,896
    12,281
    5:03 PM
    When it fails to restart what does nginx config test command show when you type
    nginx -t
