cmupdate .... There should be something new in the addons
Discussion in 'Install & Upgrades or Pre-Install Questions' started by EckyBrazzz, Dec 26, 2019.
    190
    12:28 AM
    Hi Folks,
    Some days ago I logged in and noticed cmupdate, did that and saw that there "should be some extra addons".
    I checked the directory, but I could not find them, nav, I believe something about Cloudflare and so
    My current content is only
    Snisp;;;;paste won't work with manjaro
    But these extra items are missing.
    Should we download them from github or so?
    60,088
    12,584
    1:28 PM
    ??? what output do you get when you run cmupdate command ?
  3. EckyBrazzz
    190
    12:28 AM
    @eva2000 I don't remember it anymore. But it were some add-ons that I can't find in the folder.
    17+++++++++++++++++++++++ on one and the other I don't know
    60,088
    12,584
    1:28 PM
    well if you want to make sure you have everything just do a fresh reload of local centmin mod files by wiping /usr/local/src/centminmod as outlined similar to update guide here for older than .07 releases.
    replace branchname with branch you want either 123.08stable or 123.09beta01
    first verify that github repo link is working and you don't have connectivity issues to github.com via curl header inspection - look for HTTP 200 status code = ok
    curl -I https://github.com/centminmod/centminmod
    example
    HTTP/1.1 200 OK
    Server: GitHub.com
    Date: Fri, 03 May 2019 09:37:50 GMT
    Status: 200 OK
    Then do clean Centmin Mod code replacement using below SSH commands
    branchname=123.09beta01
    cd /usr/local/src
    rm -rf centminmod*
    cd centminmod
    ./centmin.sh
  5. EckyBrazzz
    190
    12:28 AM
    rm -rf centminmod*
    Nice way to remove it..... Made a stupid typo and could not get it back, corrected it, but still missing these addons.
    60,088
    12,584
    1:28 PM
    ??? what's output of latest cmupdate command ?
    and output for
    ls -lah /usr/local/src/centminmod/addons
    example output
    total 576K
    drwxr-xr-x  2 root root 4.0K Dec 23 07:39 .
    drwxr-xr-x 19 root root 4.0K Dec 25 18:51 ..
    -rwxrwxr-x  1 root root 236K Dec 23 07:39 acmetool.sh
    -rwxr-xr-x  1 root root 4.4K Jan  2  2019 avginstall.sh
    -rwxrwxr-x  1 root root 8.4K Sep 25 11:08 customcurl.sh
    -rwxrwxr-x  1 root root 7.5K Sep 25 11:08 devtoolset-4.sh
    -rwxrwxr-x  1 root root 7.4K Sep 25 11:08 devtoolset-6.sh
    -rwxr-xr-x  1 root root  27K Aug 11 06:10 ffmpeg.sh
    -rwxr-xr-x  1 root root  15K Apr 19  2019 geoip.sh
    -rwxrwxr-x  1 root root 4.9K Sep 25 11:08 git2_install.sh
    -rwxrwxr-x  1 root root 6.4K Dec  9 07:31 golang.sh
    -rwxr-xr-x  1 root root 5.2K Jan  2  2019 ioncube.sh
    -rwxrwxr-x  1 root root 5.2K Sep 25 11:08 ius-repo.sh
    -rwxr-xr-x  1 root root 6.1K Apr 30  2019 linfo.sh
    -rwxrwxr-x  1 root root  11K Sep 25 11:08 maldet.sh
    -rwxrwxr-x  1 root root  18K Feb  2  2019 mysqladmin_shell.sh
    -rwxrwxr-x  1 root root  15K Oct  3 04:46 nodejs.sh
    -rwxr-xr-x  1 root root 8.8K Jan  2  2019 opendkim.sh
    -rwxrwxr-x  1 root root  17K Dec  9 07:31 passenger.sh
    -rwxrwxr-x  1 root root 7.0K Feb 25  2019 php72-mcrypt.sh
    -rwxrwxr-x  1 root root 7.0K Feb 25  2019 php73-mcrypt.sh
    -rwxrwxr-x  1 root root 7.0K Sep  7 15:57 php74-mcrypt.sh
    -rwxrwxr-x  1 root root 6.4K Sep 25 11:08 python27_install.sh
    -rwxrwxr-x  1 root root 5.7K Sep 25 11:08 python34_install.sh
    -rwxrwxr-x  1 root root 5.1K Sep 25 11:08 python35_install.sh
    -rwxrwxr-x  1 root root 8.8K Sep 25 11:08 python36_install.sh
    -rwxrwxr-x  1 root root  17K Sep 25 11:08 rclone.sh
    -rwxrwxr-x  1 root root  11K Dec  9 07:31 ruby.sh
    -rwxrwxr-x  1 root root  26K Dec  9 07:31 wget.sh
    -rwxrwxr-x  1 root root 8.4K Dec  9 07:31 wpcli.sh
  7. EckyBrazzz
    190
    12:28 AM
    @eva2000 I still have to ask vandyke how to get secureCRT to work on ARCH, I can't copy / paste but it looks the same.
    But some days ago cmupdate showed nav or so and something about that new issue on cloudflare as addon.
    Logged in before the cron did his job
    cmupdate is cron
    But vandyke..... Installing SecureCRT 8.3.2 on Debian 9.3 - VanDyke Software Forums
    The part copy / paste I just fixed in the poor man's edition "Putty"
    The flowing around secureCRT with Unity in VMware was too slow
  8. EckyBrazzz
    190
    12:28 AM
    @eva2000 Sorry again.....
    It was on the TOOLS, not add-ons
    update tools/setio.sh in 123.09beta01 ยท centminmod/centminmod@aa46ea4
    setio, I had some trouble with it. Before the fix, I recompiled nginx and it was twice in the nginx.conf
    Do we need to something with it? I did not check if the cron every Friday was created.
    You work too hard/much George, these days are for Family and so. (hmm. I have the same problem, can't leave my things behind. Guess we are a kind of Brothers or so):)
    60,088
    12,584
    1:28 PM
    ??? what you mean in nginx.conf ?
  10. EckyBrazzz
    190
    12:28 AM
    Yes, with kernel 5.4.x But now it's gone, I had it twice in nginx.conf.
    It looked like below, added one to make it clear to you. So, again, It was me, a little :confused:confused.:whistle:
    sendfile on;
    sendfile on;
    Guess I need some more sleep.......Zzzz:sleep: 20/7 is too much:banghead:
    I only noticed now that some files in the tools need a chmod +x, like the imagemacki-fix.sh & nvwp.sh
    60,088
    12,584
    1:28 PM
    that's sendfile not setio :)
    but yeah fixed the duplicates in previous update and just updated fix for permissions for tools directory scripts
