Nginx nginx: [emerg] unknown "maintenance" variable
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Nov 23, 2017.
    3,693
    356
    3:56 AM
    Nginx-1.17.x
    • CentOS Version: CentOS 6 64bit
    • Nginx Version Installed: 1.13.7
    • PHP Version Installed:7.0.15
    • When was last time updated Centmin Mod code base ? : just now
    On Centos 6 (don't know if that issue exists also on Centos 7) after adding a new domain using menu option 2 with self signed certificate after the creation of the vhost i try to restart Nginx 1.13.7 and i got:
    and fails to restart :(
    But maintenance line is disabled at:
    /usr/local/nginx/conf/nginx.conf
    After trying a few edits i found that the issue is related to this:
    If i comment the include it works:
    503include-only.conf content:
    43,012
    9,758
    11:56 AM
    that's why you're getting the error as that include file is disabled while it should be enabled. You broke Centmin Mod's sitestatus maintenance mode feature by commenting out the include file /usr/local/nginx/conf/maintenance.conf in nginx.conf https://community.centminmod.com/threads/sitestatus-maintenance-mode.5599/
    recursive grep for word maintenance in /usr/local/nginx/conf shows 1st entry reporting include file for /usr/local/nginx/conf/maintenance.conf is enabled (uncommented) on line 56 of /usr/local/nginx/conf/nginx.conf
    grep -rn 'maintenance' /usr/local/nginx/conf
    /usr/local/nginx/conf/nginx.conf:56:include /usr/local/nginx/conf/maintenance.conf;
    /usr/local/nginx/conf/maintenance.conf:1:     # IPs you can whitelist from maintenance mode
    /usr/local/nginx/conf/maintenance.conf:14:     map $maint_whitelist$exclude_url $maintenance {
    /usr/local/nginx/conf/503include-main.conf:4:     error_page 503 @maintenance;
    /usr/local/nginx/conf/503include-main.conf:5:     location @maintenance {
    /usr/local/nginx/conf/503include-main.conf:6:          #if ($maintenance = 1) {
    /usr/local/nginx/conf/503include-main.conf:7:          rewrite ^ /maintenance.html break;
    /usr/local/nginx/conf/503include-main.conf:8:          #try_files /maintenance.html =503;
    /usr/local/nginx/conf/503include-only.conf:1:if ($maintenance = 1) { return 503; }
  3. pamamolf
    3,693
    356
    3:56 AM
    Nginx-1.17.x
    So if i have it enabled on main nginx config and disabled on domain vhost config it will not function?
    Or is it disabled by default anyway ?
    43,012
    9,758
    11:56 AM
    yes leave maintenance.conf include enabled in nginx.conf and just disable in vhost if you want to disable sitestatus maintenance mode
