Nginx NGINX Dynamic Modules: How They Work
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Apr 8, 2017.
    50,852
    11,782
    6:10 AM
    Centmin Mod 123.09beta and newer branches support Nginx dynamic modules (FAQ item 39). Nginx posted a new article explaining how they work - NGINX Dynamic Modules: How We Implemented Them :)
    50,852
    11,782
    6:10 AM
    ah learnt something new I need to add to Centmin Mod 123.09beta01's Nginx builds
    technically this should allow Centmin Mod 123.09beta01's Nginx to just drop in Nginx dynamic modules + a load module line to use the Nginx module as intended rather than recompiling via centmin.sh menu option 4. Need to test this :D
    dynamic modules include file /usr/local/nginx/conf/dynamic-modules.conf
    load_module "modules/ngx_http_image_filter_module.so";
    load_module "modules/ngx_http_fancyindex_module.so";
    load_module "modules/ngx_stream_module.so";
    dynamic module directory at /usr/local/nginx/modules
    -rwxr-xr-x   1 root root  55K Apr  8 11:41 ngx_http_fancyindex_module.so
    -rwxr-xr-x   1 root root  55K Apr  8 11:31 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x   1 root root  58K Apr  8 11:41 ngx_http_image_filter_module.so
    -rwxr-xr-x   1 root root  58K Apr  8 11:31 ngx_http_image_filter_module.so.old
    -rwxr-xr-x   1 root root 471K Apr  8 11:41 ngx_stream_module.so
    -rwxr-xr-x   1 root root 470K Apr  8 11:31 ngx_stream_module.so.old
    now enable ngx_pagespeed as a dynamic module via persistent config file /etc/centminmod/custom_config.inc and recompile via centmin.sh menu option 4
    NGXDYNAMIC_NGXPAGESPEED='y'
    NGINX_PAGESPEED='y'
    dynamic modules include file /usr/local/nginx/conf/dynamic-modules.conf loading the newly enabled ngx_pagespeed dynamic module from /usr/local/nginx/modules/ngx_pagespeed.so
    load_module "modules/ngx_pagespeed.so";
    -rwxr-xr-x   1 root root  57K Apr  8 11:58 ngx_http_fancyindex_module.so
    -rwxr-xr-x   1 root root  55K Apr  8 11:41 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x   1 root root  56K Apr  8 11:58 ngx_http_image_filter_module.so
    -rwxr-xr-x   1 root root  58K Apr  8 11:41 ngx_http_image_filter_module.so.old
    -rwxr-xr-x   1 root root  16M Apr  8 11:58 ngx_pagespeed.so
    -rwxr-xr-x   1 root root 486K Apr  8 11:58 ngx_stream_module.so
    -rwxr-xr-x   1 root root 471K Apr  8 11:41 ngx_stream_module.so.old
    centmin.sh menu option 4 auto backs up nginx dynamic modules at /usr/local/nginx/modules to a separate directory at /usr/local/nginx/modules.copy so you can revert to previous version just dropping the nginx dynamic module from backup directory /usr/local/nginx/modules.copy to /usr/local/nginx/modules directory. I guess with --with-compat now added, you could drop the same nginx dynamic modules into other Centmin Mod 123.09beta01 Nginx instances without needing to recompile Nginx via centmin.sh menu option 4 now :)
    backup dynamic modules to /usr/local/nginx/modules.copy
    -rwxr-xr-x.  1 root root  55K Apr  8 11:41 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x.  1 root root  58K Apr  8 11:41 ngx_http_image_filter_module.so.old
    -rwxr-xr-x.  1 root root 471K Apr  8 11:41 ngx_stream_module.so.old
    Let's test this out by disabling Nginx pagespeed again by removing persistent config variables in /etc/centminmod/custom_config.inc and recompile via centmin.sh menu option 4
    set to 'n' or remove these 2 variables BEFORE recompile via centmin.sh menu option 4
    NGXDYNAMIC_NGXPAGESPEED='n'
    NGINX_PAGESPEED='n'
    end up without ngx_pagespeed.so in /usr/local/nginx/modules directory
    total 1.2M
    drwxr-xr-x.  2 root root 4.0K Apr  8 12:10 .
    drwxr-xr-x. 11 root root 4.0K Apr  8 11:31 ..
    -rwxr-xr-x   1 root root  55K Apr  8 12:10 ngx_http_fancyindex_module.so
    -rwxr-xr-x   1 root root  57K Apr  8 11:58 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x   1 root root  58K Apr  8 12:10 ngx_http_image_filter_module.so
    -rwxr-xr-x   1 root root  56K Apr  8 11:58 ngx_http_image_filter_module.so.old
    -rwxr-xr-x   1 root root 471K Apr  8 12:10 ngx_stream_module.so
    -rwxr-xr-x   1 root root 486K Apr  8 11:58 ngx_stream_module.so.old
    then in existing Nginx vhost enable ngx_pagespeed include files i.e. in /usr/local/nginx/conf/conf.d/newdomain2.com.conf uncomment 3 include files
    from
    to
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
    try enable ngx_pagespeed now via Centmin Mod custom pscontrol command
    pscontrol on
    nginx failed to restart
    pscontrol on
    systemctl restart nginx.service
    Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
    because ngx_pagespeed module wasn't installed so doesn't recognise pagespeed variable in include file /usr/local/nginx/conf/pagespeed.conf
    nginx -t
    nginx: [emerg] unknown directive "pagespeed" in /usr/local/nginx/conf/pagespeed.conf:1
    Now let's drop the ngx_pagespeed.so dynamic module in from backup directory. Just copying the backup directory /usr/local/nginx/modules.copy/ngx_pagespeed.so module into /usr/local/nginx/modules and adding a load line to /usr/local/nginx/conf/dynamic-modules.conf for
    so it becomes
    copy backup ngx_pagespeed.so module from /usr/local/nginx/modules.copy/ngx_pagespeed.so to /usr/local/nginx/modules/ngx_pagespeed.so
    cp -a /usr/local/nginx/modules.copy/ngx_pagespeed.so /usr/local/nginx/modules/ngx_pagespeed.so
    restart nginx
    ngxrestart
    seems Nginx still failed to restart
    ngxrestart
    Restarting nginx (via systemctl):  Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
                                                               [FAILED]
    but not due to unrecognised ngx_pagespeed pagespeed variable.
    nginx -t
    nginx: [emerg] "gzip_types" directive FileCachePath must be set in /usr/local/nginx/conf/nginx.conf:148
    reason is /usr/local/nginx/conf/nginx.conf has an include file for ngx_pagespeed that is only auto enabled when NGINX_PAGESPEED='y' variable is set. Otherwise the include file is commented out
    so manually uncomment
    test Nginx config
    nginx -t
    now enable ngx_pagespeed via pscontrol
    pscontrol on
    working ! So I enabled ngx_pagespeed without recompiling Centmin Mod 123.09beta01 Nginx just by dropping in ngx_pagespeed.so dynamic module into /usr/local/nginx/modules and adding a load line to /usr/local/nginx/conf/dynamic-modules.conf :D
    Other Nginx Dynamic Modules
    Centmin Mod 123.09beta01's Nginx has other nginx dynamic modules supported via persistent config file set up /etc/centminmod/custom_config.inc and these include the below listing - some are enabled by default for dynamic compilation some are not.
    NGXDYNAMIC_NJS='n'
    NGXDYNAMIC_XSLT='n'
    NGXDYNAMIC_PERL='n'
    NGXDYNAMIC_IMAGEFILTER='y'
    NGXDYNAMIC_GEOIP='n'
    NGXDYNAMIC_STREAM='y'
    NGXDYNAMIC_STREAMGEOIP='n'  # nginx 1.11.3+ option http://hg.nginx.org/nginx/rev/558db057adaa
    NGXDYNAMIC_STREAMREALIP='n' # nginx 1.11.4+ option http://hg.nginx.org/nginx/rev/9cac11efb205
    NGXDYNAMIC_HEADERSMORE='n'
    NGXDYNAMIC_SETMISC='n'
    NGXDYNAMIC_ECHO='n'
    NGXDYNAMIC_LUA='n'          #
    NGXDYNAMIC_SRCCACHE='n'
    NGXDYNAMIC_DEVELKIT='n'     #
    NGXDYNAMIC_MEMC='n'
    NGXDYNAMIC_REDISTWO='n'
    NGXDYNAMIC_BROTLI='y'
    NGXDYNAMIC_FANCYINDEX='y'
    NGXDYNAMIC_HIDELENGTH='y'
    50,852
    11,782
    6:10 AM
    Updated 123.09beta01 routine to now add support to a custom include file /usr/local/nginx/conf/dynamic-modules-includes.conf that is included in /usr/local/nginx/conf/dynamic-modules.conf so you can place custom load_module nginx dynamic modules in /usr/local/nginx/conf/dynamic-modules-includes.conf to persist and survive.
    # place custom load_module lines in this dynamic-modules-includes.conf
    # file so that they persistent i.e. for manually dropped in dynamic modules
    include /usr/local/nginx/conf/dynamic-modules-includes.conf;
    Just need to figure out how to make manually dropped in nginx dynamic modules placed in /usr/local/nginx/modules survive and persist on subsequent nginx compiles as currently Centmin Mod wipes the /usr/local/nginx/modules it detects as not enabled via persistent /etc/centminmod/custom_config.inc set variables i.e. if NGINX_PAGESPEED='n' and NGXDYNAMIC_NGXPAGESPEED='n' is set.
    Updated 123.09beta01 with a solution for persistent nginx dynamic modules manually dropped into /usr/local/nginx/modules directory. Add NGXDYNAMIC_MANUALOVERRIDE='n' variable to optional override nginx dynamic module purge
    When set in centmin mod persistent config file /etc/centminmod/custom_config.inc to NGXDYNAMIC_MANUALOVERRIDE='y' you can override centmin mod default behavior to purge manually dropped in nginx dynamic modules from /usr/local/nginx/modules so they survive and persistent on nginx recompiles
    50,852
    11,782
    6:10 AM
    Nginx Dynamic Module Support Updates
    Should have working nginx dynamic module manual drop in of modules working with these 4 committed updates in 123.09beta01+ and newer versions
    So for manually dropped in nginx dynamic modules placed in /usr/local/nginx/modules, you can set in centmin mod persistent config file /etc/centminmod/custom_config.inc to NGXDYNAMIC_MANUALOVERRIDE='y' you can override centmin mod default behavior to purge manually dropped in nginx dynamic modules from /usr/local/nginx/modules and then add to /usr/local/nginx/conf/dynamic-modules-includes.conf the load_module line i.e.
    Then the Nginx dynamic module will persist even if it's control variable is set to = 'n' i.e. if NGINX_PAGESPEED='n' and NGXDYNAMIC_NGXPAGESPEED='n' is set.
    Example
    So I have in persistent config file /etc/centminmod/custom_config.inc set variables
    NGINX_PAGESPEED='n'
    so Nginx doesn't have ngx_pagespeed configure like in Nginx -V output
    include file /usr/local/nginx/conf/dynamic-modules.conf in nginx.conf has contents below notice no ngx_pagespeed.so module load_module line it's removed
    but in include file /usr/local/nginx/conf/dynamic-modules-includes.conf i manually added it to survive
    cat /usr/local/nginx/conf/dynamic-modules-includes.conf
    now check /usr/local/nginx/modules directory which i manually dropped a backed up copy of ngx_pagespeed.so into and it survived due to centmin mod persistent config file /etc/centminmod/custom_config.inc set variable for NGXDYNAMIC_MANUALOVERRIDE='y'
    -rwxr-xr-x   1 root root  55K Apr  8 14:18 ngx_http_fancyindex_module.so
    -rwxr-xr-x   1 root root  57K Apr  8 14:06 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x   1 root root  58K Apr  8 14:18 ngx_http_image_filter_module.so
    -rwxr-xr-x   1 root root  56K Apr  8 14:06 ngx_http_image_filter_module.so.old
    -rwxr-xr-x   1 root root  16M Apr  8 14:06 ngx_pagespeed.so
    -rwxr-xr-x   1 root root 471K Apr  8 14:18 ngx_stream_module.so
    -rwxr-xr-x   1 root root 486K Apr  8 14:06 ngx_stream_module.so.old
    Enabling All Nginx Dynamic modules
    So to do it one time and enable all Nginx dynamic modules once off to get a backup copy of all nginx dynamic modules saved in /usr/local/nginx/modules.copy first set in persistent config file /etc/centminmod/custom_config.inc the following variables and recompile nginx via centmin.sh menu option 4
    NGINX_PAGESPEED='y'
    NGINX_LIBBROTLI='y'
    NGXDYNAMIC_MANUALOVERRIDE='y' # set to 'y' if you want to manually drop in nginx dynamic modules into /usr/local/nginx/modules
    NGXDYNAMIC_NJS='y'
    NGXDYNAMIC_XSLT='y'
    NGXDYNAMIC_PERL='y'
    NGXDYNAMIC_GEOIP='y'
    NGXDYNAMIC_STREAMGEOIP='y'  # nginx 1.11.3+ option http://hg.nginx.org/nginx/rev/558db057adaa
    NGXDYNAMIC_STREAMREALIP='y' # nginx 1.11.4+ option http://hg.nginx.org/nginx/rev/9cac11efb205
    NGXDYNAMIC_HEADERSMORE='y'
    NGXDYNAMIC_SETMISC='y'
    NGXDYNAMIC_ECHO='y'
    NGXDYNAMIC_LUA='y'          #
    NGXDYNAMIC_SRCCACHE='y'
    NGXDYNAMIC_DEVELKIT='y'     #
    NGXDYNAMIC_MEMC='y'
    NGXDYNAMIC_REDISTWO='y'
    Resulting nginx config would be
    Your /usr/local/nginx/conf/dynamic-modules.conf include will end up with load_module lines as follows. Not all modules are listed as the above NGXDYNAMIC_* variables only control if Nginx module is statically or dynamically compiled. There is a corresponding variable to control whether the Nginx module is installed at all which may default to disabled unless you specify in persistent config file the enabled version i.e. NGINX_PAGESPEED='y' and NGINX_LIBBROTLI='y'
    load_module "modules/ngx_http_headers_more_filter_module.so";
    load_module "modules/ndk_http_module.so";
    load_module "modules/ngx_http_memc_module.so";
    load_module "modules/ngx_http_srcache_filter_module.so";
    load_module "modules/ngx_http_set_misc_module.so";
    load_module "modules/ngx_http_echo_module.so";
    load_module "modules/ngx_http_redis2_module.so";
    load_module "modules/ngx_http_brotli_filter_module.so";
    load_module "modules/ngx_http_brotli_static_module.so";
    load_module "modules/ngx_stream_geoip_module.so";
    load_module "modules/ngx_http_geoip_module.so";
    and your /usr/local/nginx/modules directory
    -rwxr-xr-x   1 root root  48K Apr  8 15:55 ndk_http_module.so
    -rwxr-xr-x   1 root root  43K Apr  8 15:38 ndk_http_module.so.old
    -rwxr-xr-x   1 root root 1.3M Apr  8 15:55 ngx_http_brotli_filter_module.so
    -rwxr-xr-x   1 root root  34K Apr  8 15:55 ngx_http_brotli_static_module.so
    -rwxr-xr-x   1 root root 210K Apr  8 15:55 ngx_http_echo_module.so
    -rwxr-xr-x   1 root root 195K Apr  8 15:38 ngx_http_echo_module.so.old
    -rwxr-xr-x   1 root root  57K Apr  8 15:55 ngx_http_fancyindex_module.so
    -rwxr-xr-x   1 root root  55K Apr  8 15:38 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x   1 root root  51K Apr  8 15:55 ngx_http_geoip_module.so
    -rwxr-xr-x   1 root root  48K Apr  8 15:38 ngx_http_geoip_module.so.old
    -rwxr-xr-x   1 root root  97K Apr  8 15:55 ngx_http_headers_more_filter_module.so
    -rwxr-xr-x   1 root root  96K Apr  8 15:38 ngx_http_headers_more_filter_module.so.old
    -rwxr-xr-x   1 root root  56K Apr  8 15:55 ngx_http_image_filter_module.so
    -rwxr-xr-x   1 root root  58K Apr  8 15:38 ngx_http_image_filter_module.so.old
    -rwxr-xr-x   1 root root 148K Apr  8 15:55 ngx_http_memc_module.so
    -rwxr-xr-x   1 root root 131K Apr  8 15:38 ngx_http_memc_module.so.old
    -rwxr-xr-x   1 root root  98K Apr  8 15:55 ngx_http_redis2_module.so
    -rwxr-xr-x   1 root root  95K Apr  8 15:38 ngx_http_redis2_module.so.old
    -rwxr-xr-x   1 root root 217K Apr  8 15:55 ngx_http_set_misc_module.so
    -rwxr-xr-x   1 root root 205K Apr  8 15:38 ngx_http_set_misc_module.so.old
    -rwxr-xr-x   1 root root 137K Apr  8 15:55 ngx_http_srcache_filter_module.so
    -rwxr-xr-x   1 root root 131K Apr  8 15:38 ngx_http_srcache_filter_module.so.old
    -rwxr-xr-x   1 root root  16M Apr  8 15:55 ngx_pagespeed.so
    -rwxr-xr-x   1 root root  16M Apr  8 14:06 ngx_pagespeed.so.old
    -rwxr-xr-x   1 root root  43K Apr  8 15:55 ngx_stream_geoip_module.so
    -rwxr-xr-x   1 root root  39K Apr  8 15:38 ngx_stream_geoip_module.so.old
    -rwxr-xr-x   1 root root 458K Apr  8 15:55 ngx_stream_module.so
    -rwxr-xr-x   1 root root 451K Apr  8 15:38 ngx_stream_module.so.old
    and your backup /usr/local/nginx/modules.copy directory which
    -rwxr-xr-x.  1 root root  55K Apr  8 15:38 ngx_http_fancyindex_module.so.old
    -rwxr-xr-x.  1 root root  58K Apr  8 15:38 ngx_http_image_filter_module.so.old
    -rwxr-xr-x.  1 root root 451K Apr  8 15:38 ngx_stream_module.so.old
