Nginx Nginx Downloading problem on install
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Cr0w, Mar 30, 2015.
  1. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    hello guys , i have error on installing
    see the blew codes
    [1;32;40mDownloading all required software for install routines.
    (B[m*****************************************************
    [1;32;40m* Installing Development Tools
    please wait for yum download and installs to complete.
    yum installs in less verbose mode so final install status is only shown..
    Package yum-plugin-fastestmirror-1.1.30-30.el6.noarch already installed and latest version
    setting yum priorities for CentOS-Base.repo
    [base]
    name=CentOS-$releasever - Base
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/os/$basearch/
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-6
    [updates]
    name=CentOS-$releasever - Updates
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/updates/$basearch/
    gpgcheck=1
    [extras]
    name=CentOS-$releasever - Extras
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/extras/$basearch/
    gpgcheck=1
    [centosplus]
    name=CentOS-$releasever - Plus
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/centosplus/$basearch/
    gpgcheck=1
    enabled=0
    [contrib]
    name=CentOS-$releasever - Contrib
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=contrib&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/contrib/$basearch/
    gpgcheck=1
    enabled=0
    [1;32;40m*************************************************
    (B[m[1;32;40mFixing CentOS-Base.repo YUM Priorities
    (B[m[1;32;40m*************************************************
    (B[m# CentOS-Base.repo
    # The mirror system uses the connecting IP address of the client and the
    # update status of each mirror to pick mirrors that are updated to and
    # geographically close to the client.  You should use this for CentOS updates
    # unless you are manually picking other mirrors.
    # If the mirrorlist= does not work for you, as a fall back you can try the
    # remarked out baseurl= line instead.
    [base]
    gpgcheck=1
    priority=1
    #released updates
    [updates]
    gpgcheck=1
    priority=1
    priority=1
    #additional packages that may be useful
    [extras]
    gpgcheck=1
    priority=1
    #additional packages that extend functionality of existing packages
    [centosplus]
    gpgcheck=1
    enabled=0
    priority=2
    #contrib - packages by Centos Users
    [contrib]
    gpgcheck=1
    enabled=0
    priority=2
    Processing package: ca-certificates
    ca-certificates already installed
    Processing package: yum-plugin-security
    yum-plugin-security already installed
    Processing package: yum-utils
    yum-utils already installed
    Processing package: bash
    bash already installed
    Processing package: mlocate
    mlocate already installed
    Processing package: subversion
    [1;33;40mInstalling subversion
    (B[m----------------------------------------------------------------------------------
    Processing package: rsyslog
    rsyslog already installed
    Processing package: dos2unix
    [1;33;40mInstalling dos2unix
    Processing package: net-tools
    net-tools already installed
    Processing package: imake
    [1;33;40mInstalling imake
    Processing package: libvpx
    [1;33;40mInstalling libvpx
    Processing package: libvpx-devel
    [1;33;40mInstalling libvpx-devel
    Processing package: t1lib
    [1;33;40mInstalling t1lib
    Processing package: t1lib-devel
    [1;33;40mInstalling t1lib-devel
    Processing package: expect
    [1;33;40mInstalling expect
    Processing package: expect-devel
    [1;33;40mInstalling expect-devel
    Processing package: bind-utils
    bind-utils already installed
    Processing package: readline
    readline already installed
    Processing package: readline-devel
    [1;33;40mInstalling readline-devel
    Processing package: libedit
    libedit already installed
    Processing package: libedit-devel
    [1;33;40mInstalling libedit-devel
    Processing package: libatomic_ops-devel
    [1;33;40mInstalling libatomic_ops-devel
    Processing package: time
    time already installed
    Processing package: yum-downloadonly
    [1;33;40mInstalling yum-downloadonly
    Package yum-plugin-downloadonly-1.1.30-30.el6.noarch already installed and latest version
    Processing package: coreutils
    coreutils already installed
    Processing package: autoconf
    [1;33;40mInstalling autoconf
    Processing package: cronie
    cronie already installed
    Processing package: crontabs
    crontabs already installed
    Processing package: cronie-anacron
    cronie-anacron already installed
    Processing package: nc
    [1;33;40mInstalling nc
    Processing package: gcc
    [1;33;40mInstalling gcc
    Processing package: gcc-c++
    [1;33;40mInstalling gcc-c++
    Processing package: automake
    [1;33;40mInstalling automake
    Processing package: distcache
    [1;33;40mInstalling distcache
    Error: Nothing to do
    Processing package: openssl
    openssl already installed
    Processing package: openssl-devel
    [1;33;40mInstalling openssl-devel
    Processing package: curl
    curl already installed
    Processing package: curl-devel
    [1;33;40mInstalling curl-devel
    Processing package: openldap
    openldap already installed
    Processing package: openldap-devel
    [1;33;40mInstalling openldap-devel
    Processing package: libtool
    [1;33;40mInstalling libtool
    Processing package: make
    make already installed
    Processing package: libXext-devel
    [1;33;40mInstalling libXext-devel
    Processing package: unzip
    unzip already installed
    Processing package: patch
    patch already installed
    Processing package: sysstat
    sysstat already installed
    Processing package: zlib
    zlib already installed
    Processing package: zlib-devel
    zlib-devel already installed
    Processing package: libc-client-devel
    [1;33;40mInstalling libc-client-devel
    Processing package: openssh
    openssh already installed
    Processing package: gd
    [1;33;40mInstalling gd
    Processing package: gd-devel
    [1;33;40mInstalling gd-devel
    Processing package: pcre
    pcre already installed
    Processing package: pcre-devel
    [1;33;40mInstalling pcre-devel
    Processing package: flex
    [1;33;40mInstalling flex
    Processing package: bison
    [1;33;40mInstalling bison
    Processing package: file
    file already installed
    Processing package: libgcj
    [1;33;40mInstalling libgcj
    Processing package: gettext
    gettext already installed
    Processing package: gettext-devel
    [1;33;40mInstalling gettext-devel
    Processing package: e2fsprogs-devel
    [1;33;40mInstalling e2fsprogs-devel
    Processing package: libtool-libs
    [1;33;40mInstalling libtool-libs
    Processing package: libtool-ltdl-devel
    [1;33;40mInstalling libtool-ltdl-devel
    Processing package: libidn
    libidn already installed
    Processing package: libidn-devel
    libidn-devel already installed
    Processing package: krb5-devel
    krb5-devel already installed
    Processing package: libjpeg
    [1;33;40mInstalling libjpeg
    Package libjpeg-turbo-1.2.1-3.el6_5.x86_64 already installed and latest version
    Processing package: libjpeg-devel
    [1;33;40mInstalling libjpeg-devel
    Package libjpeg-turbo-devel-1.2.1-3.el6_5.x86_64 already installed and latest version
    Processing package: libpng
    libpng already installed
    Processing package: libpng-devel
    libpng-devel already installed
    Processing package: freetype
    freetype already installed
    Processing package: freetype-devel
    freetype-devel already installed
    Processing package: libxml2
    libxml2 already installed
    Processing package: libxml2-devel
    [1;33;40mInstalling libxml2-devel
    Processing package: libXpm-devel
    libXpm-devel already installed
    Processing package: glib2
    glib2 already installed
    Processing package: glib2-devel
    [1;33;40mInstalling glib2-devel
    Processing package: bzip2
    bzip2 already installed
    Processing package: bzip2-devel
    [1;33;40mInstalling bzip2-devel
    Processing package: nano
    nano already installed
    Processing package: ncurses
    ncurses already installed
    Processing package: ncurses-devel
    ncurses-devel already installed
    e2fsprogs already installed
    Processing package: gmp-devel
    [1;33;40mInstalling gmp-devel
    Processing package: pspell-devel
    [1;33;40mInstalling pspell-devel
    Processing package: aspell-devel
    [1;33;40mInstalling aspell-devel
    Processing package: numactl
    numactl already installed
    Processing package: lsof
    lsof already installed
    Processing package: pkgconfig
    pkgconfig already installed
    Processing package: gdbm-devel
    gdbm-devel already installed
    Processing package: tk-devel
    [1;33;40mInstalling tk-devel
    Processing package: bluez-libs-devel
    [1;33;40mInstalling bluez-libs-devel
    Processing package: iptables*
    iptables* already installed
    Processing package: rrdtool
    [1;33;40mInstalling rrdtool
    Processing package: diffutils
    diffutils already installed
    libc-client already installed
    libc-client-devel already installed
    Processing package: which
    which already installed
    Processing package: ImageMagick
    [1;33;40mInstalling ImageMagick
    Processing package: ImageMagick-devel
    [1;33;40mInstalling ImageMagick-devel
    Processing package: ImageMagick-c++
    [1;33;40mInstalling ImageMagick-c++
    Processing package: ImageMagick-c++-devel
    [1;33;40mInstalling ImageMagick-c++-devel
    Processing package: perl-Test-Simple
    perl-Test-Simple already installed
    Processing package: perl-ExtUtils-MakeMaker
    perl-ExtUtils-MakeMaker already installed
    Processing package: perl-Time-HiRes
    perl-Time-HiRes already installed
    Processing package: perl-libwww-perl
    perl-libwww-perl already installed
    Processing package: perl-Crypt-SSLeay
    perl-Crypt-SSLeay already installed
    Processing package: perl-Net-SSLeay
    [1;33;40mInstalling perl-Net-SSLeay
    Processing package: perl-LWP-Protocol-https
    [1;33;40mInstalling perl-LWP-Protocol-https
    Processing package: cyrus-sasl
    cyrus-sasl already installed
    Processing package: cyrus-sasl-devel
    cyrus-sasl-devel already installed
    Processing package: cyrus-imapd
    [1;33;40mInstalling cyrus-imapd
    Processing package: cyrus-sasl-md5
    [1;33;40mInstalling cyrus-sasl-md5
    Processing package: cyrus-sasl-plain
    cyrus-sasl-plain already installed
    Processing package: strace
    strace already installed
    Processing package: pam
    pam already installed
    Processing package: pam-devel
    [1;33;40mInstalling pam-devel
    Processing package: cmake
    [1;33;40mInstalling cmake
    Processing package: libaio
    libaio already installed
    Processing package: libaio-devel
    [1;33;40mInstalling libaio-devel
    Processing package: libevent
    libevent already installed
    Processing package: libevent-devel
    [1;33;40mInstalling libevent-devel
    Processing package: git
    [1;33;40mInstalling git
    Processing package: recode
    [1;33;40mInstalling recode
    Processing package: recode-devel
    [1;33;40mInstalling recode-devel
    Processing package: libtidy
    [1;33;40mInstalling libtidy
    Processing package: libtidy-devel
    [1;33;40mInstalling libtidy-devel
    Processing package: net-snmp
    [1;33;40mInstalling net-snmp
    Processing package: net-snmp-devel
    [1;33;40mInstalling net-snmp-devel
    Processing package: net-snmp-libs
    net-snmp-libs already installed
    Processing package: net-snmp-utils
    [1;33;40mInstalling net-snmp-utils
    Processing package: enchant
    [1;33;40mInstalling enchant
    Processing package: enchant-devel
    [1;33;40mInstalling enchant-devel
    Package iotop-0.3.2-7.el6.noarch already installed and latest version
    Loaded plugins: downloadonly, fastestmirror, priorities, security
    Setting up Install Process
    * base: less.cogeco.net
    * extras: less.cogeco.net
    * updates: less.cogeco.net
    Resolving Dependencies
    --> Running transaction check
    ---> Package ipset.x86_64 0:6.11-3.el6 will be installed
    --> Processing Dependency: libmnl.so.0(LIBMNL_1.0)(64bit) for package: ipset-6.11-3.el6.x86_64
    --> Processing Dependency: libmnl.so.0()(64bit) for package: ipset-6.11-3.el6.x86_64
    ---> Package ipset-devel.x86_64 0:6.11-3.el6 will be installed
    --> Processing Dependency: kernel-devel for package: ipset-devel-6.11-3.el6.x86_64
    ---> Package kernel-devel.x86_64 0:2.6.32-504.12.2.el6 will be installed
    ---> Package libmnl.x86_64 0:1.0.2-3.el6 will be installed
    Dependencies Resolved
    Package            Arch         Version                    Repository     Size
    Installing:
    ipset              x86_64       6.11-3.el6                 base           63 k
    ipset-devel        x86_64       6.11-3.el6                 base           20 k
    Installing for dependencies:
    kernel-devel       x86_64       2.6.32-504.12.2.el6        updates       9.4 M
    libmnl             x86_64       1.0.2-3.el6                base           21 k
    Transaction Summary
    Install       4 Package(s)
    Total download size: 9.5 M
    Installed size: 25 M
    Downloading Packages:
    Total                                            18 MB/s | 9.5 MB     00:00
    Running rpm_check_debug
    Running Transaction Test
    Transaction Test Succeeded
    Running Transaction
      Installing : libmnl-1.0.2-3.el6.x86_64                                    1/4
      Installing : ipset-6.11-3.el6.x86_64                                      2/4
      Installing : kernel-devel-2.6.32-504.12.2.el6.x86_64                      3/4
      Installing : ipset-devel-6.11-3.el6.x86_64                                4/4
      Verifying  : kernel-devel-2.6.32-504.12.2.el6.x86_64                      1/4
      Verifying  : ipset-6.11-3.el6.x86_64                                      2/4
      Verifying  : libmnl-1.0.2-3.el6.x86_64                                    3/4
      Verifying  : ipset-devel-6.11-3.el6.x86_64                                4/4
    Installed:
      ipset.x86_64 0:6.11-3.el6           ipset-devel.x86_64 0:6.11-3.el6
    Dependency Installed:
      kernel-devel.x86_64 0:2.6.32-504.12.2.el6     libmnl.x86_64 0:1.0.2-3.el6
    Complete!
    [1;32;40m* CentOS 6.x detected installing EPEL Repo
    Error: epel-release-6-8.noarch.rpm not found !!! Download now......
    2015-03-29 11:33:52 URL:http://epel.mirrors.ovh.net/epel/6/x86_64/epel-release-6-8.noarch.rpm [14540/14540] -> "epel-release-6-8.noarch.rpm" [1]
    [1;33;40mDownload done.
    (B[msetting yum priorities for epel.repo
    [epel]
    name=Extra Packages for Enterprise Linux 6 - $basearch
    #baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
    mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=$basearch
    failovermethod=priority
    enabled=1
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
    (B[m[1;32;40mFixing epel.repo YUM Priorities
    (B[m[epel]
    enabled=1
    gpgcheck=1
    priority=3
    exclude=varnish clamd clamav clamav-db
    [epel-debuginfo]
    name=Extra Packages for Enterprise Linux 6 - $basearch - Debug
    #baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch/debug
    mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-debug-6&arch=$basearch
    enabled=0
    gpgcheck=1
    [epel-source]
    name=Extra Packages for Enterprise Linux 6 - $basearch - Source
    #baseurl=http://download.fedoraproject.org/pub/epel/6/SRPMS
    mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-source-6&arch=$basearch
    enabled=0
    gpgcheck=1
    Error: rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm not found !!! Download now......
    2015-03-29 11:34:02 URL:http://apt.sw.be/redhat/el6/en/x86_64/rpmforge/RPMS/rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm [12640/12640] -> "rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm" [1]
    (B[msetting yum priorities for rpmforge.repo
    [rpmforge]
    name = RHEL $releasever - RPMforge.net - dag
    baseurl = http://apt.sw.be/redhat/el6/en/$basearch/rpmforge
    mirrorlist = http://mirrorlist.repoforge.org/el6/mirrors-rpmforge
    #mirrorlist = file:///etc/yum.repos.d/mirrors-rpmforge
    enabled = 1
    protect = 0
    gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-rpmforge-dag
    gpgcheck = 1
    (B[m[1;32;40mFixing rpmforge.repo YUM Priorities
    (B[m### Name: RPMforge RPM Repository for RHEL 6 - dag
    ### URL: http://rpmforge.net/
    [rpmforge]
    enabled = 1
    protect = 0
    gpgcheck = 1
    priority=5
    [rpmforge-extras]
    name = RHEL $releasever - RPMforge.net - extras
    baseurl = http://apt.sw.be/redhat/el6/en/$basearch/extras
    mirrorlist = http://mirrorlist.repoforge.org/el6/mirrors-rpmforge-extras
    #mirrorlist = file:///etc/yum.repos.d/mirrors-rpmforge-extras
    enabled = 0
    protect = 0
    gpgcheck = 1
    [rpmforge-testing]
    name = RHEL $releasever - RPMforge.net - testing
    baseurl = http://apt.sw.be/redhat/el6/en/$basearch/testing
    mirrorlist = http://mirrorlist.repoforge.org/el6/mirrors-rpmforge-testing
    #mirrorlist = file:///etc/yum.repos.d/mirrors-rpmforge-testing
    enabled = 0
    protect = 0
    gpgcheck = 1
    Error: percona-release-0.1-3.noarch.rpm not found !!! Download now......
    2015-03-29 11:34:09 URL:http://www.percona.com/downloads/percona-release/redhat/latest/percona-release-0.1-3.noarch.rpm [6566/6566] -> "percona-release-0.1-3.noarch.rpm" [1]
    (B[msetting yum priorities for percona-release.repo
    [percona-release-$basearch]
    name = Percona-Release YUM repository - $basearch
    baseurl = http://repo.percona.com/release/$releasever/RPMS/$basearch
    enabled = 1
    gpgcheck = 1
    (B[m[1;32;40mFixing percona-release.repo YUM Priorities
    (B[m########################################
    # Percona releases and sources, stable #
    enabled = 0
    gpgcheck = 1
    priority=11
    exclude=Percona-SQL* Percona-Server* Percona-XtraDB-Cluster*
    gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-Percona
    [percona-release-noarch]
    name = Percona-Release YUM repository - noarch
    baseurl = http://repo.percona.com/release/$releasever/RPMS/noarch
    enabled = 0
    gpgcheck = 1
    [percona-release-source]
    name = Percona-Release YUM repository - Source packages
    baseurl = http://repo.percona.com/release/$releasever/SRPMS
    enabled = 0
    gpgcheck = 1
    # Testing & pre-release packages. You don't need it for production #
    [percona-testing-$basearch]
    name = Percona-Testing YUM repository - $basearch
    baseurl = http://repo.percona.com/testing/$releasever/RPMS/$basearch
    enabled = 0
    gpgcheck = 1
    [percona-testing-noarch]
    name = Percona-Testing YUM repository - noarch
    baseurl = http://repo.percona.com/testing/$releasever/RPMS/noarch
    enabled = 0
    gpgcheck = 1
    [percona-testing-source]
    name = Percona-Testing YUM repository - Source packages
    baseurl = http://repo.percona.com/testing/$releasever/SRPMS
    enabled = 0
    gpgcheck = 1
    # Experimental packages, use with caution! #
    [percona-experimental-$basearch]
    name = Percona-Experimental YUM repository - $basearch
    baseurl = http://repo.percona.com/experimental/$releasever/RPMS/$basearch
    enabled = 0
    gpgcheck = 1
    [percona-experimental-noarch]
    name = Percona-Experimental YUM repository - noarch
    baseurl = http://repo.percona.com/experimental/$releasever/RPMS/noarch
    enabled = 0
    gpgcheck = 1
    [percona-experimental-source]
    name = Percona-Experimental YUM repository - Source packages
    baseurl = http://repo.percona.com/experimental/$releasever/SRPMS
    enabled = 0
    gpgcheck = 1
    Error: varnish-release-3.0-1.el6.noarch.rpm not found !!! Download now......
    2015-03-29 11:34:09 URL:http://repo.varnish-cache.org/redhat/varnish-3.0/el6/noarch/varnish-release/varnish-release-3.0-1.el6.noarch.rpm [2780/2780] -> "varnish-release-3.0-1.el6.noarch.rpm" [1]
    (B[msetting yum priorities for varnish.repo
    (B[m[1;32;40mFixing varnish.repo YUM Priorities
    (B[m[varnish-3.0]
    name=Varnish 3.0 for Enterprise Linux el6 - $basearch
    baseurl=http://repo.varnish-cache.org/redhat/varnish-3.0/el6/$basearch
    enabled=0
    gpgcheck=0
    #gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-VARNISH
    priority=2
    Error: remi-release-6.rpm not found !!! Download now......
    2015-03-29 11:34:09 URL:http://rpms.famillecollet.com/enterprise/remi-release-6.rpm [5688/5688] -> "remi-release-6.rpm" [1]
    (B[mPreparing...                ##################################################
    remi-release                ##################################################
    setting yum priorities for remi.repo
    [remi]
    name=Les RPM de remi pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/remi/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/remi/mirror
    enabled=0
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-remi
    (B[m[1;32;40mFixing remi.repo YUM Priorities
    (B[m[remi]
    enabled=0
    gpgcheck=1
    priority=9
    exclude=php* mysql*
    [remi-php55]
    name=Les RPM de remi de PHP 5.5 pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/php55/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/php55/mirror
    # WARNING: If you enable this repository, you must also enable "remi"
    enabled=0
    gpgcheck=1
    [remi-php56]
    name=Les RPM de remi de PHP 5.6 pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/php56/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/php56/mirror
    enabled=0
    gpgcheck=1
    [remi-test]
    name=Les RPM de remi en test pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/test/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/test/mirror
    enabled=0
    gpgcheck=1
    [remi-debuginfo]
    name=Les RPM de remi pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-remi/$basearch/
    enabled=0
    gpgcheck=1
    [remi-php55-debuginfo]
    name=Les RPM de remi de PHP 5.5 pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-php55/$basearch/
    enabled=0
    gpgcheck=1
    [remi-php56-debuginfo]
    name=Les RPM de remi de PHP 5.6 pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-php56/$basearch/
    enabled=0
    gpgcheck=1
    [remi-test-debuginfo]
    name=Les RPM de remi en test pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-test/$basearch/
    enabled=0
    gpgcheck=1
    Processing package: pigz
    [1;33;40mInstalling pigz
    Warning: RPMDB altered outside of yum.
    Processing package: pbzip2
    [1;33;40mInstalling pbzip2
    Processing package: xz
    enchant-devel already installed
    Processing package: pxz
    [1;33;40mInstalling pxz
    Processing package: lz4
    [1;33;40mInstalling lz4
    Processing package: libJudy
    [1;33;40mInstalling libJudy
    Processing package: axel
    [1;33;40mInstalling axel
    Processing package: glances
    [1;33;40mInstalling glances
    Processing package: bash-completion
    [1;33;40mInstalling bash-completion
    Processing package: re2c
    [1;33;40mInstalling re2c
    Processing package: libmcrypt
    [1;33;40mInstalling libmcrypt
    Processing package: libmcrypt-devel
    [1;33;40mInstalling libmcrypt-devel
    Processing package: kernel-headers
    Processing package: kernel-devel
    Processing package: cmake28
    [1;33;40mInstalling cmake28
    [1;33;40mGeoIP database and library install...
    (B[m/usr/include/GeoIP.h
    /usr/include/GeoIPCity.h
    /usr/include/GeoIPUpdate.h
    /usr/lib64/libGeoIP.so
    /usr/lib64/libGeoIPUpdate.so
    /usr/lib64/pkgconfig/geoip.pc
    /etc/GeoIP.conf
    /etc/GeoIP.conf.default
    /usr/bin/geoiplookup
    /usr/bin/geoiplookup6
    /usr/bin/geoipupdate
    /usr/lib64/libGeoIP.so.1
    /usr/lib64/libGeoIP.so.1.5.1
    /usr/lib64/libGeoIPUpdate.so.0
    /usr/lib64/libGeoIPUpdate.so.0.0.0
    /usr/share/GeoIP
    /usr/share/GeoIP/GeoIP.dat
    /usr/share/GeoIP/GeoIPASNum.dat
    /usr/share/GeoIP/GeoIPASNumv6.dat
    /usr/share/GeoIP/GeoIPv6.dat
    /usr/share/GeoIP/GeoLiteASNum.dat
    /usr/share/GeoIP/GeoLiteASNumv6.dat
    /usr/share/GeoIP/GeoLiteCity.dat
    /usr/share/GeoIP/GeoLiteCityv6.dat
    /usr/share/GeoIP/GeoLiteCountry.dat
    /usr/share/doc/GeoIP-1.5.1
    /usr/share/doc/GeoIP-1.5.1/AUTHORS
    /usr/share/doc/GeoIP-1.5.1/COPYING
    /usr/share/doc/GeoIP-1.5.1/ChangeLog
    /usr/share/doc/GeoIP-1.5.1/README
    /usr/share/doc/GeoIP-1.5.1/TODO
    /usr/share/doc/GeoIP-1.5.1/fetch-geoipdata-city.pl
    /usr/share/doc/GeoIP-1.5.1/fetch-geoipdata.pl
    /usr/share/man/man1/geoiplookup.1.gz
    /usr/share/man/man1/geoiplookup6.1.gz
    /usr/share/man/man1/geoipupdate.1.gz
    [1;33;40mGeoLiteCity database download ...
    (B[m2015-03-29 11:35:33 URL:http://geolite.maxmind.com/download/geoip/database/GeoLiteCity.dat.gz [12263571/12263571] -> "/usr/share/GeoIP/GeoLiteCity.dat.gz" [1]
    [1;33;40mUsing Remi YUM repo ImageMagicK version
    * base: centos.bhs.mirrors.ovh.net
    * epel: mirrors.mit.edu
    * extras: centos.bhs.mirrors.ovh.net
    * remi: mirrors.mediatemple.net
    * rpmforge: repoforge.spinellicreations.com
    * updates: centos.bhs.mirrors.ovh.net
    1725 packages excluded due to repository priority protections
    Package mesa-libGL-10.1.2-2.el6.x86_64 already installed and latest version
    No package mesa- available.
    Package libXxf86vm-1.1.3-2.1.el6.x86_64 already installed and latest version
    ---> Package OpenEXR-devel.x86_64 0:1.6.1-8.1.el6 will be installed
    ---> Package ilmbase-devel.x86_64 0:1.0.1-6.1.el6 will be installed
    ---> Package lcms2-devel.x86_64 0:2.3-2.el6 will be installed
    --> Processing Dependency: lcms2 = 2.3-2.el6 for package: lcms2-devel-2.3-2.el6.x86_64
    --> Processing Dependency: liblcms2.so.2()(64bit) for package: lcms2-devel-2.3-2.el6.x86_64
    ---> Package libXxf86vm-devel.x86_64 0:1.1.3-2.1.el6 will be installed
    ---> Package libwebp.x86_64 0:0.3.1-2.el6.remi will be installed
    ---> Package libwebp-devel.x86_64 0:0.3.1-2.el6.remi will be installed
    ---> Package mesa-libGL-devel.x86_64 0:10.1.2-2.el6 will be installed
    --> Processing Dependency: pkgconfig(libdrm) >= 2.4.24 for package: mesa-libGL-devel-10.1.2-2.el6.x86_64
    --> Processing Dependency: pkgconfig(xfixes) for package: mesa-libGL-devel-10.1.2-2.el6.x86_64
    --> Processing Dependency: pkgconfig(xdamage) for package: mesa-libGL-devel-10.1.2-2.el6.x86_64
    ---> Package mesa-libGLU-devel.x86_64 0:10.1.2-2.el6 will be installed
    ---> Package lcms2.x86_64 0:2.3-2.el6 will be installed
    ---> Package libXdamage-devel.x86_64 0:1.1.3-4.el6 will be installed
    ---> Package libXfixes-devel.x86_64 0:5.0.1-2.1.el6 will be installed
    ---> Package libdrm-devel.x86_64 0:2.4.52-4.el6 will be installed
    Installing:
    OpenEXR-devel           x86_64       1.6.1-8.1.el6            base        54 k
    ilmbase-devel           x86_64       1.0.1-6.1.el6            base        71 k
    lcms2-devel             x86_64       2.3-2.el6                epel       2.1 M
    libXxf86vm-devel        x86_64       1.1.3-2.1.el6            base        18 k
    libwebp                 x86_64       0.3.1-2.el6.remi         remi       173 k
    libwebp-devel           x86_64       0.3.1-2.el6.remi         remi        24 k
    mesa-libGL-devel        x86_64       10.1.2-2.el6             base       483 k
    mesa-libGLU-devel       x86_64       10.1.2-2.el6             base        83 k
    lcms2                   x86_64       2.3-2.el6                epel       127 k
    libXdamage-devel        x86_64       1.1.3-4.el6              base       9.3 k
    libXfixes-devel         x86_64       5.0.1-2.1.el6            base        13 k
    libdrm-devel            x86_64       2.4.52-4.el6             base        86 k
    Transaction Summary
    Install      12 Package(s)
    Total download size: 3.2 M
    Installed size: 5.5 M
    Total                                           2.4 MB/s | 3.2 MB     00:01
    warning: rpmts_HdrFromFdno: Header V3 DSA/SHA1 Signature, key ID 00f97f56: NOKEY
    Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-remi
    Importing GPG key 0x00F97F56:
    Userid : Remi Collet <RPMS@FamilleCollet.com>
    Package: remi-release-6.5-1.el6.remi.noarch (installed)
    Running Transaction
      Installing : libXfixes-devel-5.0.1-2.1.el6.x86_64                        1/12
      Installing : libXdamage-devel-1.1.3-4.el6.x86_64                         2/12
      Installing : libXxf86vm-devel-1.1.3-2.1.el6.x86_64                       3/12
      Installing : libwebp-0.3.1-2.el6.remi.x86_64                             4/12
      Installing : libdrm-devel-2.4.52-4.el6.x86_64                            5/12
      Installing : mesa-libGL-devel-10.1.2-2.el6.x86_64                        6/12
      Installing : mesa-libGLU-devel-10.1.2-2.el6.x86_64                       7/12
      Installing : ilmbase-devel-1.0.1-6.1.el6.x86_64                          8/12
      Installing : lcms2-2.3-2.el6.x86_64                                      9/12
      Installing : lcms2-devel-2.3-2.el6.x86_64                               10/12
      Installing : OpenEXR-devel-1.6.1-8.1.el6.x86_64                         11/12
      Installing : libwebp-devel-0.3.1-2.el6.remi.x86_64                      12/12
      Verifying  : lcms2-2.3-2.el6.x86_64                                      1/12
      Verifying  : libXdamage-devel-1.1.3-4.el6.x86_64                         2/12
      Verifying  : lcms2-devel-2.3-2.el6.x86_64                                3/12
      Verifying  : libXfixes-devel-5.0.1-2.1.el6.x86_64                        4/12
      Verifying  : OpenEXR-devel-1.6.1-8.1.el6.x86_64                          5/12
      Verifying  : libdrm-devel-2.4.52-4.el6.x86_64                            6/12
      Verifying  : mesa-libGL-devel-10.1.2-2.el6.x86_64                        7/12
      Verifying  : libwebp-0.3.1-2.el6.remi.x86_64                             8/12
      Verifying  : ilmbase-devel-1.0.1-6.1.el6.x86_64                          9/12
      Verifying  : libXxf86vm-devel-1.1.3-2.1.el6.x86_64                      10/12
      Verifying  : libwebp-devel-0.3.1-2.el6.remi.x86_64                      11/12
      Verifying  : mesa-libGLU-devel-10.1.2-2.el6.x86_64                      12/12
    Installed:
      lcms2.x86_64 0:2.3-2.el6                libXdamage-devel.x86_64 0:1.1.3-4.el6
      libXfixes-devel.x86_64 0:5.0.1-2.1.el6  libdrm-devel.x86_64 0:2.4.52-4.el6
    Complete!
    Setting up Remove Process
    ---> Package ImageMagick.x86_64 0:6.5.4.7-7.el6_5 will be erased
    --> Processing Dependency: libMagickCore.so.2()(64bit) for package: ImageMagick-c++-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: libMagickCore.so.2()(64bit) for package: ImageMagick-devel-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: libMagickWand.so.2()(64bit) for package: ImageMagick-c++-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: libMagickWand.so.2()(64bit) for package: ImageMagick-devel-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: ImageMagick = 6.5.4.7-7.el6_5 for package: ImageMagick-c++-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: ImageMagick = 6.5.4.7-7.el6_5 for package: ImageMagick-devel-6.5.4.7-7.el6_5.x86_64
    ---> Package ImageMagick-c++.x86_64 0:6.5.4.7-7.el6_5 will be erased
    --> Processing Dependency: libMagick++.so.2()(64bit) for package: ImageMagick-c++-devel-6.5.4.7-7.el6_5.x86_64
    --> Processing Dependency: ImageMagick-c++ = 6.5.4.7-7.el6_5 for package: ImageMagick-c++-devel-6.5.4.7-7.el6_5.x86_64
    ---> Package ImageMagick-devel.x86_64 0:6.5.4.7-7.el6_5 will be erased
    ---> Package ImageMagick-c++-devel.x86_64 0:6.5.4.7-7.el6_5 will be erased
    Removing:
    ImageMagick                x86_64      6.5.4.7-7.el6_5        @base      6.4 M
    Removing for dependencies:
    ImageMagick-c++            x86_64      6.5.4.7-7.el6_5        @base      510 k
    ImageMagick-c++-devel      x86_64      6.5.4.7-7.el6_5        @base      346 k
    ImageMagick-devel          x86_64      6.5.4.7-7.el6_5        @base      378 k
    Transaction Summary
    Remove        4 Package(s)
    Installed size: 7.6 M
    Running Transaction
      Erasing    : ImageMagick-c++-devel-6.5.4.7-7.el6_5.x86_64                 1/4
      Erasing    : ImageMagick-devel-6.5.4.7-7.el6_5.x86_64                     2/4
      Erasing    : ImageMagick-c++-6.5.4.7-7.el6_5.x86_64                       3/4
      Erasing    : ImageMagick-6.5.4.7-7.el6_5.x86_64                           4/4
      Verifying  : ImageMagick-6.5.4.7-7.el6_5.x86_64                           1/4
      Verifying  : ImageMagick-devel-6.5.4.7-7.el6_5.x86_64                     2/4
      Verifying  : ImageMagick-c++-6.5.4.7-7.el6_5.x86_64                       3/4
      Verifying  : ImageMagick-c++-devel-6.5.4.7-7.el6_5.x86_64                 4/4
    Removed:
    Dependency Removed:
    Complete!
    Loaded plugins: downloadonly, fastestmirror, security
    * rpmforge: mirror.team-cymru.org
    ---> Package ImageMagick-last.x86_64 0:6.9.0.4-1.el6.remi will be installed
    --> Processing Dependency: ImageMagick-last-libs(x86-64) = 6.9.0.4-1.el6.remi for package: ImageMagick-last-6.9.0.4-1.el6.remi.x86_64
    --> Processing Dependency: libfftw3.so.3()(64bit) for package: ImageMagick-last-6.9.0.4-1.el6.remi.x86_64
    --> Processing Dependency: libMagickWand-6.Q16.so.2()(64bit) for package: ImageMagick-last-6.9.0.4-1.el6.remi.x86_64
    --> Processing Dependency: libMagickCore-6.Q16.so.2()(64bit) for package: ImageMagick-last-6.9.0.4-1.el6.remi.x86_64
    ---> Package ImageMagick-last-c++.x86_64 0:6.9.0.4-1.el6.remi will be installed
    ---> Package ImageMagick-last-c++-devel.x86_64 0:6.9.0.4-1.el6.remi will be installed
    ---> Package ImageMagick-last-devel.x86_64 0:6.9.0.4-1.el6.remi will be installed
    ---> Package ImageMagick-last-libs.x86_64 0:6.9.0.4-1.el6.remi will be installed
    ---> Package fftw.x86_64 0:3.2.1-3.1.el6 will be installed
        Size
    Installing:
    ImageMagick-last              x86_64    6.9.0.4-1.el6.remi       remi     58 k
    ImageMagick-last-c++          x86_64    6.9.0.4-1.el6.remi       remi    158 k
    ImageMagick-last-c++-devel    x86_64    6.9.0.4-1.el6.remi       remi    101 k
    ImageMagick-last-devel        x86_64    6.9.0.4-1.el6.remi       remi    102 k
    ImageMagick-last-libs         x86_64    6.9.0.4-1.el6.remi       remi    2.1 M
    fftw                          x86_64    3.2.1-3.1.el6            base    1.2 M
    Transaction Summary
    Install       6 Package(s)
    Total download size: 3.7 M
    Installed size: 13 M
    Total                                           1.4 MB/s | 3.7 MB     00:02
    Running Transaction
      Installing : fftw-3.2.1-3.1.el6.x86_64                                    1/6
      Installing : ImageMagick-last-libs-6.9.0.4-1.el6.remi.x86_64              2/6
      Installing : ImageMagick-last-c++-6.9.0.4-1.el6.remi.x86_64               3/6
      Installing : ImageMagick-last-6.9.0.4-1.el6.remi.x86_64                   4/6
      Installing : ImageMagick-last-devel-6.9.0.4-1.el6.remi.x86_64             5/6
      Installing : ImageMagick-last-c++-devel-6.9.0.4-1.el6.remi.x86_64         6/6
      Verifying  : ImageMagick-last-c++-devel-6.9.0.4-1.el6.remi.x86_64         1/6
      Verifying  : ImageMagick-last-c++-6.9.0.4-1.el6.remi.x86_64               2/6
      Verifying  : ImageMagick-last-6.9.0.4-1.el6.remi.x86_64                   3/6
      Verifying  : ImageMagick-last-devel-6.9.0.4-1.el6.remi.x86_64             4/6
      Verifying  : fftw-3.2.1-3.1.el6.x86_64                                    5/6
      Verifying  : ImageMagick-last-libs-6.9.0.4-1.el6.remi.x86_64              6/6
    Installed:
      ImageMagick-last-libs.x86_64 0:6.9.0.4-1.el6.remi fftw.x86_64 0:3.2.1-3.1.el6
    Complete!
    Setting up Update Process
    No Packages marked for Update
    1619 packages excluded due to repository priority protections
    -rw-r--r-- 1 root root 71K Mar 29 11:36 /root/centminlogs/centminmod_yumtimes_290315-112939.log
    Set cache size limit to 2.0 Gbytes
    [1;33;40mDownload csf.tgz ...
    (B[mInitializing download: http://download.configserver.com/csf.tgz
    File size: 643226 bytes
    Opening output file csf.tgz
    Starting download
    [  2%] [0            1           2            3           ] [  33.3KB/s] [00:18]
    [  3%] [0            1           2            3           ] [  66.5KB/s] [00:08]
    [  4%] [0            1           .2           3           ] [  91.8KB/s] [00:06]
    [  5%] [0            1           .2           3           ] [  91.5KB/s] [00:06]
    [  7%] [0            .1          .2           3           ] [ 119.6KB/s] [00:04]
    [  8%] [0            .1          .2           3           ] [ 139.9KB/s] [00:03]
    [  9%] [0            .1          .2           3           ] [ 150.6KB/s] [00:03]
    [  9%] [0            .1          .2           3           ] [ 164.5KB/s] [00:03]
    [  9%] [0            .1          .2           3           ] [ 165.0KB/s] [00:03]
    [ 10%] [0            .1          .2           3           ] [ 152.2KB/s] [00:03]
    [ 11%] [0            .1          .2           3           ] [ 177.4KB/s] [00:03]
    [ 13%] [0            .1          ..2          3           ] [ 202.7KB/s] [00:02]
    [ 14%] [.0           .1          ..2          3           ] [ 225.0KB/s] [00:02]
    [ 14%] [.0           .1          ..2          3           ] [ 226.4KB/s] [00:02]
    [ 14%] [.0           .1          ..2          3           ] [ 208.3KB/s] [00:02]
    [ 15%] [.0           .1          ..2          .3          ] [ 219.7KB/s] [00:02]
    [ 16%] [.0           .1          ..2          .3          ] [ 231.1KB/s] [00:02]
    [ 17%] [.0           .1          ..2          .3          ] [ 242.6KB/s] [00:02]
    [ 17%] [.0           .1          ..2          ..3         ] [ 247.1KB/s] [00:02]
    [ 18%] [.0           ..1         ..2          ..3         ] [ 251.5KB/s] [00:01]
    [ 19%] [.0           ..1         ..2          ..3         ] [ 262.6KB/s] [00:01]
    [ 19%] [.0           ...1        ..2          ..3         ] [ 271.8KB/s] [00:01]
    [ 20%] [.0           ...1        ..2          ..3         ] [ 282.9KB/s] [00:01]
    [ 20%] [.0           ...1        ..2          ..3         ] [ 284.3KB/s] [00:01]
    [ 21%] [.0           ...1        ..2          ..3         ] [ 295.4KB/s] [00:01]
    [ 21%] [.0           ....1       ..2          ..3         ] [ 300.0KB/s] [00:01]
    [ 22%] [.0           ....1       ..2          ..3         ] [ 300.5KB/s] [00:01]
    [ 23%] [.0           ....1       ..2          ..3         ] [ 304.9KB/s] [00:01]
    [ 23%] [..0          ....1       ..2          ..3         ] [ 315.5KB/s] [00:01]
    [ 24%] [..0          ....1       ..2          ..3         ] [ 326.2KB/s] [00:01]
    [ 24%] [..0          ....1       ..2          ..3         ] [ 329.0KB/s] [00:01]
    [ 25%] [..0          ....1       ..2          ..3         ] [ 318.0KB/s] [00:01]
    [ 26%] [..0          ....1       ...2         ..3         ] [ 326.5KB/s] [00:01]
    [ 26%] [..0          ....1       ...2         ..3         ] [ 336.5KB/s] [00:01]
    [ 27%] [..0          ....1       ...2         ..3         ] [ 346.6KB/s] [00:01]
    [ 28%] [..0          ....1       ....2        ..3         ] [ 355.0KB/s] [00:01]
    [ 28%] [..0          ....1       ....2        ..3         ] [ 333.0KB/s] [00:00]
    [ 29%] [..0          ....1       ....2        ..3         ] [ 342.2KB/s] [00:00]
    [ 30%] [..0          ....1       ....2        ...3        ] [ 351.5KB/s] [00:00]
    [ 31%] [..0          ....1       ....2        ...3        ] [ 360.9KB/s] [00:00]
    [ 31%] [..0          ....1       ....2        ...3        ] [ 369.9KB/s] [00:00]
    [ 32%] [..0          ....1       ....2        ...3        ] [ 372.4KB/s] [00:00]
    [ 33%] [..0          ....1       ....2        ...3        ] [ 381.6KB/s] [00:00]
    [ 34%] [..0          .....1      ....2        ...3        ] [ 390.8KB/s] [00:00]
    [ 35%] [..0          .....1      ....2        ...3        ] [ 400.0KB/s] [00:00]
    [ 35%] [..0          ......1     ....2        ...3        ] [ 409.2KB/s] [00:00]
    [ 36%] [..0          ......1     ....2        ...3        ] [ 418.3KB/s] [00:00]
    [ 37%] [..0          ......1     ....2        ...3        ] [ 422.4KB/s] [00:00]
    [ 37%] [..0          ......1     ....2        ...3        ] [ 418.9KB/s] [00:00]
    [ 38%] [...0         ......1     ....2        ...3        ] [ 427.8KB/s] [00:00]
    [ 38%] [...0         ......1     ....2        ...3        ] [ 430.1KB/s] [00:00]
    [ 39%] [...0         ......1     ....2        ...3        ] [ 438.9KB/s] [00:00]
    [ 40%] [....0        ......1     ....2        ...3        ] [ 447.8KB/s] [00:00]
    [ 41%] [....0        ......1     ....2        ...3        ] [ 455.1KB/s] [00:00]
    [ 41%] [....0        ......1     ....2        ...3        ] [ 441.7KB/s] [00:00]
    [ 42%] [....0        ......1     ....2        ...3        ] [ 450.1KB/s] [00:00]
    [ 42%] [....0        ......1     .....2       ...3        ] [ 453.6KB/s] [00:00]
    [ 43%] [....0        ......1     .....2       ...3        ] [ 462.1KB/s] [00:00]
    [ 44%] [....0        ......1     .....2       ...3        ] [ 470.6KB/s] [00:00]
    [ 45%] [....0        ......1     ......2      ...3        ] [ 477.6KB/s] [00:00]
    [ 45%] [....0        ......1     ......2      ...3        ] [ 482.4KB/s] [00:00]
    [ 46%] [....0        ......1     ......2      ....3       ] [ 458.7KB/s] [00:00]
    [ 46%] [....0        ......1     ......2      ....3       ] [ 459.7KB/s] [00:00]
    [ 47%] [....0        ......1     ......2      ....3       ] [ 467.3KB/s] [00:00]
    [ 48%] [....0        ......1     ......2      .....3      ] [ 475.1KB/s] [00:00]
    [ 48%] [....0        ......1     ......2      .....3      ] [ 483.1KB/s] [00:00]
    [ 49%] [....0        ......1     ......2      .....3      ] [ 491.0KB/s] [00:00]
    [ 50%] [....0        ......1     ......2      ......3     ] [ 497.4KB/s] [00:00]
    [ 51%] [....0        .......1    ......2      ......3     ] [ 499.8KB/s] [00:00]
    [ 51%] [....0        .......1    ......2      ......3     ] [ 507.5KB/s] [00:00]
    [ 52%] [....0        .......1    ......2      ......3     ] [ 515.3KB/s] [00:00]
    [ 53%] [....0        ........1   ......2      ......3     ] [ 523.1KB/s] [00:00]
    [ 54%] [....0        ........1   ......2      ......3     ] [ 530.9KB/s] [00:00]
    [ 55%] [....0        .........1  ......2      ......3     ] [ 538.7KB/s] [00:00]
    [ 55%] [....0        .........1  ......2      ......3     ] [ 546.5KB/s] [00:00]
    [ 56%] [....0        .........1  ......2      ......3     ] [ 553.6KB/s] [00:00]
    [ 57%] [....0        .........1  ......2      ......3     ] [ 547.0KB/s] [00:00]
    [ 58%] [.....0       .........1  ......2      ......3     ] [ 554.5KB/s] [00:00]
    [ 58%] [.....0       .........1  ......2      ......3     ] [ 562.1KB/s] [00:00]
    [ 59%] [......0      .........1  ......2      ......3     ] [ 567.9KB/s] [00:00]
    [ 60%] [......0      .........1  ......2      ......3     ] [ 575.2KB/s] [00:00]
    [ 61%] [......0      .........1  ......2      ......3     ] [ 582.8KB/s] [00:00]
    [ 61%] [.......0     .........1  ......2      ......3     ] [ 589.1KB/s] [00:00]
    [ 62%] [.......0     .........1  ......2      ......3     ] [ 572.4KB/s] [00:00]
    [ 63%] [.......0     .........1  .......2     ......3     ] [ 579.7KB/s] [00:00]
    [ 64%] [.......0     .........1  .......2     ......3     ] [ 587.0KB/s] [00:00]
    [ 64%] [.......0     .........1  .......2     ......3     ] [ 589.8KB/s] [00:00]
    [ 65%] [.......0     .........1  ........2    ......3     ] [ 597.0KB/s] [00:00]
    [ 66%] [.......0     .........1  ........2    ......3     ] [ 604.3KB/s] [00:00]
    [ 66%] [.......0     .........1  ........2    ......3     ] [ 611.5KB/s] [00:00]
    [ 67%] [.......0     .........1  .........2   ......3     ] [ 616.5KB/s] [00:00]
    [ 68%] [.......0     .........1  .........2   ......3     ] [ 588.4KB/s] [00:00]
    [ 68%] [.......0     .........1  .........2   ......3     ] [ 589.1KB/s] [00:00]
    [ 68%] [.......0     .........1  .........2   ......3     ] [ 591.0KB/s] [00:00]
    [ 69%] [.......0     .........1  .........2   .......3    ] [ 597.8KB/s] [00:00]
    [ 69%] [.......0     .........1  .........2   .......3    ] [ 602.6KB/s] [00:00]
    [ 70%] [.......0     .........1  .........2   .......3    ] [ 609.4KB/s] [00:00]
    [ 71%] [.......0     .........1  .........2   ........3   ] [ 614.2KB/s] [00:00]
    [ 71%] [.......0     .........1  .........2   ........3   ] [ 618.0KB/s] [00:00]
    [ 72%] [.......0     .........1  .........2   ........3   ] [ 624.8KB/s] [00:00]
    [ 73%] [.......0     .........1  .........2   .........3  ] [ 629.5KB/s] [00:00]
    [ 73%] [.......0     ..........1 .........2   .........3  ] [ 632.4KB/s] [00:00]
    [ 74%] [.......0     ..........1 .........2   .........3  ] [ 637.1KB/s] [00:00]
    [ 75%] [.......0     ..........1 .........2   .........3  ] [ 643.8KB/s] [00:00]
    [ 76%] [.......0     ...........1.........2   .........3  ] [ 650.6KB/s] [00:00]
    [ 76%] [.......0     ...........1.........2   .........3  ] [ 654.3KB/s] [00:00]
    [ 77%] [.......0     ...........1.........2   .........3  ] [ 661.0KB/s] [00:00]
    [ 77%] [.......0     .....................2   .........3  ] [ 662.3KB/s] [00:00]
    Connection 1 finished
    [ 77%] [.......0     .....................2   .........3  ] [ 662.2KB/s] [00:00]
    [ 78%] [.......0     .....................2   .........3  ] [ 653.2KB/s] [00:00]
    [ 79%] [........0    .....................2   .........3  ] [ 659.6KB/s] [00:00]
    [ 79%] [........0    .....................2   .........3  ] [ 666.3KB/s] [00:00]
    [ 80%] [........0    .....................2   .........3  ] [ 672.9KB/s] [00:00]
    [ 81%] [.........0   .....................2   .........3  ] [ 679.5KB/s] [00:00]
    [ 82%] [.........0   .....................2   .........3  ] [ 686.1KB/s] [00:00]
    [ 82%] [.........0   .....................2   .........3  ] [ 691.4KB/s] [00:00]
    [ 83%] [..........0  .....................2   .........3  ] [ 697.9KB/s] [00:00]
    [ 84%] [..........0  .....................2   .........3  ] [ 704.4KB/s] [00:00]
    [ 85%] [..........0  .....................2   .........3  ] [ 684.2KB/s] [00:00]
    [ 85%] [..........0  .....................2   .........3  ] [ 690.6KB/s] [00:00]
    [ 86%] [..........0  ......................2  .........3  ] [ 697.0KB/s] [00:00]
    [ 87%] [..........0  ......................2  .........3  ] [ 703.4KB/s] [00:00]
    [ 88%] [..........0  .......................2 .........3  ] [ 709.8KB/s] [00:00]
    [ 89%] [..........0  .......................2 .........3  ] [ 716.2KB/s] [00:00]
    [ 89%] [..........0  .......................2 .........3  ] [ 722.5KB/s] [00:00]
    [ 90%] [..........0  ........................2.........3  ] [ 728.9KB/s] [00:00]
    [ 90%] [..........0  ..................................3  ] [ 730.7KB/s] [00:00]
    Connection 2 finished
    [ 91%] [..........0  ..................................3  ] [ 697.7KB/s] [00:00]
    [ 92%] [..........0  ..................................3  ] [ 703.7KB/s] [00:00]
    [ 92%] [..........0  ..................................3  ] [ 706.2KB/s] [00:00]
    [ 93%] [..........0  ...................................3 ] [ 711.2KB/s] [00:00]
    [ 94%] [..........0  ...................................3 ] [ 717.2KB/s] [00:00]
    [ 94%] [..........0  ...................................3 ] [ 723.2KB/s] [00:00]
    [ 95%] [..........0  ....................................3] [ 724.8KB/s] [00:00]
    [ 95%] [..........0  ....................................3] [ 730.8KB/s] [00:00]
    [ 96%] [..........0  ....................................3] [ 736.8KB/s] [00:00]
    [ 96%] [..........0  .....................................] [ 738.9KB/s] [00:00]
    Connection 3 finished
    [ 96%] [..........0  .....................................] [ 738.8KB/s] [00:00]
    [ 97%] [...........0 .....................................] [ 725.9KB/s] [00:00]
    [ 98%] [...........0 .....................................] [ 731.6KB/s] [00:00]
    [ 99%] [...........0 .....................................] [ 737.5KB/s] [00:00]
    [100%] [............0.....................................] [ 743.4KB/s] [00:00]
    Connection 0 finished
    Downloaded 628.2 kilobytes in 0 seconds. (746.27 KB/s)
    [1;33;40mDownload csf.tgz done.
    (B[m[1;33;40mcsf.tgz valid file.
    (B[m
    [1;33;40mDownload siege-3.0.9.tar.gz ...
    (B[mInitializing download: http://centminmod.com/centminmodparts/siege/siege-3.0.9.tar.gz
    File size: 524125 bytes
    Opening output file siege-3.0.9.tar.gz
    Starting download
    [  3%] [0            1           2            3           ] [  37.4KB/s] [00:12]
    [  6%] [0            1           2            3           ] [  74.8KB/s] [00:05]
    [  8%] [.0           1           .2           3           ] [ 105.7KB/s] [00:03]
    [  9%] [.0           1           .2           3           ] [ 118.1KB/s] [00:02]
    [ 10%] [..0          1           .2           3           ] [ 130.6KB/s] [00:02]
    [ 11%] [..0          1           .2           3           ] [ 143.1KB/s] [00:02]
    [ 12%] [...0         1           .2           3           ] [ 155.5KB/s] [00:01]
    [ 13%] [...0         1           .2           3           ] [ 165.9KB/s] [00:01]
    [ 13%] [...0         1           .2           3           ] [ 169.3KB/s] [00:01]
    [ 14%] [...0         1           .2           3           ] [ 176.3KB/s] [00:01]
    [ 14%] [...0         1           .2           3           ] [ 179.6KB/s] [00:01]
    [ 15%] [...0         1           ..2          3           ] [ 183.8KB/s] [00:01]
    [ 15%] [...0         1           ..2          3           ] [ 190.4KB/s] [00:01]
    [ 16%] [...0         1           ..2          3           ] [ 198.5KB/s] [00:01]
    [ 17%] [...0         1           ...2         3           ] [ 205.4KB/s] [00:01]
    [ 17%] [...0         1           ...2         3           ] [ 208.7KB/s] [00:01]
    [ 18%] [...0         1           ...2         3           ] [ 220.6KB/s] [00:00]
    [ 18%] [...0         1           ...2         3           ] [ 222.2KB/s] [00:00]
    [ 19%] [...0         1           ...2         .3          ] [ 221.9KB/s] [00:00]
    [ 20%] [...0         1           ...2         .3          ] [ 233.3KB/s] [00:00]
    [ 20%] [...0         1           ...2         ..3         ] [ 239.6KB/s] [00:00]
    [ 21%] [...0         1           ...2         ..3         ] [ 244.2KB/s] [00:00]
    [ 21%] [...0         1           ...2         ..3         ] [ 247.3KB/s] [00:00]
    [ 22%] [...0         1           ...2         ..3         ] [ 250.4KB/s] [00:00]
    [ 22%] [...0         1           ...2         ..3         ] [ 253.5KB/s] [00:00]
    [ 22%] [...0         1           ...2         ..3         ] [ 256.7KB/s] [00:00]
    [ 22%] [...0         1           ...2         ...3        ] [ 259.8KB/s] [00:00]
    [ 23%] [....0        1           ...2         ...3        ] [ 257.3KB/s] [00:00]
    [ 24%] [....0        1           ...2         ...3        ] [ 266.4KB/s] [00:00]
    [ 24%] [....0        1           ...2         ...3        ] [ 269.3KB/s] [00:00]
    [ 25%] [.....0       1           ...2         ...3        ] [ 278.3KB/s] [00:00]
    [ 25%] [.....0       1           ...2         ...3        ] [ 281.3KB/s] [00:00]
    [ 26%] [.....0       1           ...2         ...3        ] [ 290.3KB/s] [00:00]
    [ 26%] [.....0       1           ...2         ...3        ] [ 281.5KB/s] [00:00]
    [ 27%] [.....0       1           ...2         ...3        ] [ 291.9KB/s] [00:00]
    [ 28%] [.....0       1           ...2         ...3        ] [ 302.4KB/s] [00:00]
    [ 29%] [.....0       1           ...2         ...3        ] [ 310.1KB/s] [00:00]
    [ 29%] [.....0       1           ...2         ...3        ] [ 312.7KB/s] [00:00]
    [ 29%] [.....0       1           ....2        ...3        ] [ 315.6KB/s] [00:00]
    [ 30%] [.....0       1           ....2        ...3        ] [ 324.3KB/s] [00:00]
    [ 31%] [.....0       1           ....2        ...3        ] [ 327.2KB/s] [00:00]
    [ 31%] [.....0       1           ....2        ...3        ] [ 333.0KB/s] [00:00]
    [ 32%] [.....0       1           .....2       ...3        ] [ 337.1KB/s] [00:00]
    [ 32%] [.....0       1           .....2       ...3        ] [ 340.0KB/s] [00:00]
    [ 33%] [.....0       1           .....2       ...3        ] [ 348.5KB/s] [00:00]
    [ 33%] [.....0       1           ......2      ...3        ] [ 348.3KB/s] [00:00]
    [ 34%] [.....0       1           ......2      ...3        ] [ 351.1KB/s] [00:00]
    [ 34%] [.....0       1           ......2      ...3        ] [ 353.7KB/s] [00:00]
    [ 34%] [.....0       1           ......2      ...3        ] [ 356.5KB/s] [00:00]
    [ 35%] [.....0       1           ......2      ...3        ] [ 362.0KB/s] [00:00]
    [ 35%] [.....0       1           .......2     ...3        ] [ 367.7KB/s] [00:00]
    [ 36%] [.....0       1           .......2     ...3        ] [ 376.1KB/s] [00:00]
    [ 36%] [.....0       1           .......2     ...3        ] [ 378.9KB/s] [00:00]
    [ 37%] [.....0       1           .......2     ...3        ] [ 371.3KB/s] [00:00]
    [ 38%] [.....0       1           .......2     ...3        ] [ 373.6KB/s] [00:00]
    [ 38%] [.....0       1           .......2     ...3        ] [ 376.7KB/s] [00:00]
    [ 38%] [.....0       1           .......2     ....3       ] [ 379.3KB/s] [00:00]
    [ 39%] [.....0       1           .......2     ....3       ] [ 381.9KB/s] [00:00]
    [ 39%] [.....0       1           .......2     ....3       ] [ 389.7KB/s] [00:00]
    [ 40%] [.....0       1           .......2     ....3       ] [ 386.2KB/s] [00:00]
    [ 40%] [.....0       1           .......2     ....3       ] [ 386.7KB/s] [00:00]
    [ 41%] [......0      1           .......2     ....3       ] [ 389.2KB/s] [00:00]
    [ 41%] [......0      1           .......2     ....3       ] [ 391.7KB/s] [00:00]
    [ 41%] [......0      1           .......2     ....3       ] [ 389.7KB/s] [00:00]
    [ 41%] [......0      1           .......2     ....3       ] [ 392.3KB/s] [00:00]
    [ 42%] [......0      1           .......2     ....3       ] [ 396.3KB/s] [00:00]
    [ 43%] [.......0     1           .......2     ....3       ] [ 405.3KB/s] [00:00]
    [ 44%] [.......0     1           .......2     ....3       ] [ 414.5KB/s] [00:00]
    [ 45%] [........0    1           .......2     ....3       ] [ 423.7KB/s] [00:00]
    [ 45%] [........0    1           .......2     ....3       ] [ 427.3KB/s] [00:00]
    [ 46%] [........0    1           .......2     ....3       ] [ 436.3KB/s] [00:00]
    [ 47%] [.........0   1           .......2     ....3       ] [ 442.7KB/s] [00:00]
    [ 47%] [.........0   1           .......2     ....3       ] [ 439.3KB/s] [00:00]
    [ 47%] [.........0   .1          .......2     ....3       ] [ 441.5KB/s] [00:00]
    [ 48%] [.........0   .1          .......2     ....3       ] [ 444.0KB/s] [00:00]
    [ 48%] [.........0   .1          .......2     ....3       ] [ 450.8KB/s] [00:00]
    [ 49%] [.........0   ..1         .......2     ....3       ] [ 459.7KB/s] [00:00]
    [ 50%] [.........0   ..1         .......2     ....3       ] [ 468.7KB/s] [00:00]
    [ 51%] [.........0   ..1         .......2     ....3       ] [ 471.1KB/s] [00:00]
    [ 51%] [.........0   ..1         .......2     ....3       ] [ 470.7KB/s] [00:00]
    [ 51%] [.........0   ..1         .......2     ....3       ] [ 473.1KB/s] [00:00]
    [ 52%] [.........0   ..1         ........2    ....3       ] [ 477.8KB/s] [00:00]
    [ 52%] [.........0   ..1         ........2    ....3       ] [ 480.3KB/s] [00:00]
    [ 53%] [.........0   ..1         ........2    ....3       ] [ 487.7KB/s] [00:00]
    [ 53%] [.........0   ..1         ........2    ....3       ] [ 490.2KB/s] [00:00]
    [ 53%] [.........0   ..1         ........2    ....3       ] [ 492.6KB/s] [00:00]
    [ 54%] [.........0   ..1         .........2   ....3       ] [ 497.6KB/s] [00:00]
    [ 55%] [.........0   ..1         .........2   ....3       ] [ 499.1KB/s] [00:00]
    [ 55%] [.........0   ..1         .........2   ....3       ] [ 504.1KB/s] [00:00]
    [ 56%] [.........0   ..1         ..........2  ....3       ] [ 505.8KB/s] [00:00]
    [ 57%] [.........0   ..1         ..........2  ....3       ] [ 514.5KB/s] [00:00]
    [ 57%] [.........0   ..1         ..........2  ....3       ] [ 515.6KB/s] [00:00]
    [ 57%] [.........0   ..1         ..........2  ....3       ] [ 515.0KB/s] [00:00]
    [ 58%] [.........0   ..1         ...........2 ....3       ] [ 519.9KB/s] [00:00]
    [ 58%] [.........0   ..1         ...........2 ....3       ] [ 522.0KB/s] [00:00]
    [ 58%] [.........0   ..1         ...........2 ....3       ] [ 526.9KB/s] [00:00]
    [ 59%] [.........0   ..1         ...........2 ....3       ] [ 531.7KB/s] [00:00]
    [ 59%] [.........0   ..1         ...........2 ....3       ] [ 534.0KB/s] [00:00]
    [ 60%] [.........0   ..1         ............2....3       ] [ 542.6KB/s] [00:00]
    [ 61%] [.........0   ..1         .................3       ] [ 545.8KB/s] [00:00]
    [ 61%] [.........0   ..1         .................3       ] [ 545.7KB/s] [00:00]
    [ 61%] [.........0   ..1         .................3       ] [ 532.7KB/s] [00:00]
    [ 62%] [.........0   ..1         ..................3      ] [ 537.4KB/s] [00:00]
    [ 62%] [.........0   ..1         ..................3      ] [ 539.0KB/s] [00:00]
    [ 63%] [.........0   ..1         ..................3      ] [ 541.2KB/s] [00:00]
    [ 63%] [.........0   ..1         ..................3      ] [ 546.8KB/s] [00:00]
    [ 64%] [.........0   ..1         ...................3     ] [ 548.8KB/s] [00:00]
    [ 64%] [.........0   ..1         ...................3     ] [ 554.6KB/s] [00:00]
    [ 65%] [.........0   ..1         ...................3     ] [ 557.0KB/s] [00:00]
    [ 65%] [.........0   ..1         ...................3     ] [ 558.9KB/s] [00:00]
    [ 65%] [.........0   ..1         ...................3     ] [ 561.0KB/s] [00:00]
    [ 66%] [.........0   ..1         ....................3    ] [ 563.2KB/s] [00:00]
    [ 66%] [.........0   ..1         ....................3    ] [ 565.4KB/s] [00:00]
    [ 66%] [.........0   ..1         ....................3    ] [ 567.5KB/s] [00:00]
    [ 67%] [.........0   ..1         ....................3    ] [ 571.7KB/s] [00:00]
    [ 67%] [.........0   ..1         ....................3    ] [ 564.2KB/s] [00:00]
    [ 68%] [..........0  ..1         ....................3    ] [ 568.7KB/s] [00:00]
    [ 68%] [..........0  ..1         ....................3    ] [ 573.1KB/s] [00:00]
    [ 69%] [..........0  ..1         ....................3    ] [ 571.7KB/s] [00:00]
    [ 69%] [..........0  ..1         ....................3    ] [ 576.2KB/s] [00:00]
    [ 70%] [...........0 ..1         ....................3    ] [ 579.7KB/s] [00:00]
    [ 71%] [...........0 ..1         ....................3    ] [ 584.0KB/s] [00:00]
    [ 71%] [...........0 ..1         ....................3    ] [ 585.9KB/s] [00:00]
    [ 72%] [............0..1         ....................3    ] [ 593.7KB/s] [00:00]
    [ 73%] [...............1         ....................3    ] [ 600.9KB/s] [00:00]
    [ 73%] [...............1         ....................3    ] [ 596.7KB/s] [00:00]
    [ 73%] [................1        ....................3    ] [ 598.8KB/s] [00:00]
    [ 74%] [................1        ....................3    ] [ 606.3KB/s] [00:00]
    [ 74%] [................1        ....................3    ] [ 607.3KB/s] [00:00]
    [ 75%] [................1        ....................3    ] [ 613.8KB/s] [00:00]
    [ 75%] [.................1       ....................3    ] [ 614.8KB/s] [00:00]
    [ 76%] [.................1       ....................3    ] [ 619.0KB/s] [00:00]
    [ 77%] [.................1       ....................3    ] [ 623.2KB/s] [00:00]
    [ 77%] [.................1       ....................3    ] [ 627.1KB/s] [00:00]
    [ 77%] [..................1      ....................3    ] [ 629.1KB/s] [00:00]
    [ 78%] [..................1      ....................3    ] [ 631.1KB/s] [00:00]
    [ 78%] [..................1      ....................3    ] [ 633.1KB/s] [00:00]
    [ 78%] [..................1      ....................3    ] [ 635.1KB/s] [00:00]
    [ 79%] [..................1      .....................3   ] [ 607.0KB/s] [00:00]
    [ 80%] [..................1      .....................3   ] [ 614.3KB/s] [00:00]
    [ 80%] [..................1      .....................3   ] [ 615.4KB/s] [00:00]
    [ 81%] [..................1      ......................3  ] [ 621.5KB/s] [00:00]
    [ 82%] [..................1      ......................3  ] [ 628.5KB/s] [00:00]
    [ 82%] [..................1      ......................3  ] [ 629.4KB/s] [00:00]
    [ 83%] [..................1      ......................3  ] [ 631.3KB/s] [00:00]
    [ 83%] [..................1      ......................3  ] [ 633.3KB/s] [00:00]
    [ 84%] [..................1      .......................3 ] [ 638.5KB/s] [00:00]
    [ 85%] [..................1      .......................3 ] [ 645.6KB/s] [00:00]
    [ 85%] [..................1      .......................3 ] [ 646.5KB/s] [00:00]
    [ 85%] [..................1      ........................3] [ 648.5KB/s] [00:00]
    [ 86%] [..................1      ........................3] [ 654.4KB/s] [00:00]
    [ 87%] [..................1      ........................3] [ 661.4KB/s] [00:00]
    [ 87%] [..................1      .........................] [ 661.9KB/s] [00:00]
    [ 87%] [..................1      .........................] [ 661.8KB/s] [00:00]
    [ 88%] [..................1      .........................] [ 638.1KB/s] [00:00]
    [ 88%] [...................1     .........................] [ 642.0KB/s] [00:00]
    [ 88%] [...................1     .........................] [ 643.6KB/s] [00:00]
    [ 89%] [...................1     .........................] [ 647.6KB/s] [00:00]
    [ 89%] [...................1     .........................] [ 651.5KB/s] [00:00]
    [ 90%] [....................1    .........................] [ 657.3KB/s] [00:00]
    [ 91%] [....................1    .........................] [ 659.2KB/s] [00:00]
    [ 91%] [....................1    .........................] [ 660.4KB/s] [00:00]
    [ 91%] [....................1    .........................] [ 664.0KB/s] [00:00]
    [ 92%] [.....................1   .........................] [ 669.9KB/s] [00:00]
    [ 93%] [.....................1   .........................] [ 671.7KB/s] [00:00]
    [ 93%] [.....................1   .........................] [ 675.5KB/s] [00:00]
    [ 94%] [.....................1   .........................] [ 681.1KB/s] [00:00]
    [ 94%] [......................1  .........................] [ 682.8KB/s] [00:00]
    [ 95%] [......................1  .........................] [ 686.6KB/s] [00:00]
    [ 96%] [......................1  .........................] [ 692.2KB/s] [00:00]
    [ 96%] [......................1  .........................] [ 629.9KB/s] [00:00]
    [ 97%] [.......................1 .........................] [ 636.2KB/s] [00:00]
    [ 97%] [.......................1 .........................] [ 637.0KB/s] [00:00]
    [ 97%] [.......................1 .........................] [ 638.7KB/s] [00:00]
    [ 98%] [........................1.........................] [ 644.7KB/s] [00:00]
    [ 99%] [........................1.........................] [ 651.1KB/s] [00:00]
    [ 99%] [........................1.........................] [ 652.7KB/s] [00:00]
    [100%] [........................1.........................] [ 654.5KB/s] [00:00]
    [100%] [..................................................] [ 656.3KB/s]
    Downloaded 511.8 kilobytes in 0 seconds. (656.33 KB/s)
    (B[m[1;33;40msiege-3.0.9.tar.gz valid file.
    (B[m
    [1;33;40mDownload sproxy-latest.tar.gz ...
    (B[mInitializing download: http://centminmod.com/centminmodparts/siege/sproxy-latest.tar.gz
    File size: 543610 bytes
    Opening output file sproxy-latest.tar.gz
    Starting download
    [  2%] [0            1           2            3           ] [  33.3KB/s] [00:15]
    [  4%] [0            1           2            3           ] [  66.5KB/s] [00:07]
    [  5%] [0            1           .2           3           ] [  95.4KB/s] [00:05]
    [  6%] [0            1           .2           3           ] [ 112.0KB/s] [00:04]
    [  7%] [0            1           ..2          3           ] [ 128.6KB/s] [00:03]
    [  8%] [0            1           ..2          3           ] [ 145.2KB/s] [00:03]
    [  9%] [0            1           ...2         3           ] [ 161.8KB/s] [00:02]
    [ 10%] [0            1           ...2         3           ] [ 171.0KB/s] [00:02]
    [ 10%] [0            1           ...2         3           ] [ 146.2KB/s] [00:03]
    [ 11%] [0            1           ...2         3           ] [ 160.0KB/s] [00:02]
    [ 12%] [0            1           ...2         3           ] [ 173.9KB/s] [00:02]
    [ 13%] [0            1           ...2         3           ] [ 184.1KB/s] [00:02]
    [ 13%] [0            1           ....2        3           ] [ 197.8KB/s] [00:02]
    [ 14%] [0            1           ....2        3           ] [ 199.6KB/s] [00:02]
    [ 14%] [0            1           ....2        3           ] [ 211.0KB/s] [00:02]
    [ 15%] [0            1           ....2        3           ] [ 218.7KB/s] [00:02]
    [ 15%] [0            1           .....2       3           ] [ 226.4KB/s] [00:01]
    [ 16%] [0            1           .....2       3           ] [ 234.1KB/s] [00:01]
    [ 16%] [0            1           .....2       3           ] [ 238.0KB/s] [00:01]
    [ 17%] [0            1           .....2       3           ] [ 245.6KB/s] [00:01]
    [ 17%] [0            .1          .....2       3           ] [ 253.2KB/s] [00:01]
    [ 18%] [0            .1          .....2       3           ] [ 260.8KB/s] [00:01]
    [ 19%] [0            .1          .....2       3           ] [ 271.0KB/s] [00:01]
    [ 20%] [0            ..1         .....2       3           ] [ 284.5KB/s] [00:01]
    [ 20%] [0            ..1         .....2       3           ] [ 286.3KB/s] [00:01]
    [ 20%] [0            ..1         .....2       3           ] [ 293.7KB/s] [00:01]
    [ 21%] [0            ..1         .....2       3           ] [ 300.5KB/s] [00:01]
    [ 21%] [0            ...1        .....2       3           ] [ 307.6KB/s] [00:01]
    [ 22%] [0            ...1        .....2       3           ] [ 302.9KB/s] [00:00]
    [ 22%] [0            ...1        ......2      3           ] [ 310.2KB/s] [00:00]
    [ 23%] [0            ...1        ......2      3           ] [ 323.4KB/s] [00:00]
    [ 23%] [0            ...1        ......2      3           ] [ 325.1KB/s] [00:00]
    [ 23%] [0            ...1        ......2      3           ] [ 311.0KB/s] [00:00]
    [ 24%] [0            ...1        ......2      .3          ] [ 317.7KB/s] [00:00]
    [ 24%] [0            ...1        ......2      .3          ] [ 324.6KB/s] [00:00]
    [ 25%] [0            ...1        ......2      .3          ] [ 327.9KB/s] [00:00]
    [ 25%] [0            ...1        ......2      .3          ] [ 331.2KB/s] [00:00]
    [ 25%] [0            ...1        ......2      .3          ] [ 338.0KB/s] [00:00]
    [ 26%] [0            ...1        ......2      ..3         ] [ 341.5KB/s] [00:00]
    [ 26%] [0            ...1        ......2      ..3         ] [ 344.8KB/s] [00:00]
    [ 26%] [0            ...1        ......2      ..3         ] [ 348.2KB/s] [00:00]
    [ 27%] [0            ...1        ......2      ..3         ] [ 354.6KB/s] [00:00]
    [ 28%] [0            ...1        ......2      ..3         ] [ 367.0KB/s] [00:00]
    [ 28%] [0            ...1        ......2      ..3         ] [ 367.6KB/s] [00:00]
    [ 28%] [0            ...1        ......2      ..3         ] [ 371.0KB/s] [00:00]
    [ 28%] [0            ...1        ......2      ..3         ] [ 374.5KB/s] [00:00]
    [ 29%] [0            ...1        ......2      ..3         ] [ 377.7KB/s] [00:00]
    [ 29%] [.0           ...1        ......2      ..3         ] [ 381.2KB/s] [00:00]
    [ 29%] [.0           ...1        ......2      ..3         ] [ 384.6KB/s] [00:00]
    [ 29%] [.0           ...1        ......2      ..3         ] [ 387.8KB/s] [00:00]
    [ 30%] [.0           ...1        .......2     ..3         ] [ 368.1KB/s] [00:00]
    [ 31%] [.0           ...1        .......2     ..3         ] [ 372.8KB/s] [00:00]
    [ 31%] [.0           ...1        .......2     ..3         ] [ 375.9KB/s] [00:00]
    [ 32%] [.0           ...1        .......2     ..3         ] [ 382.3KB/s] [00:00]
    [ 32%] [.0           ...1        .......2     ..3         ] [ 388.5KB/s] [00:00]
    [ 33%] [.0           ...1        ........2    ..3         ] [ 394.7KB/s] [00:00]
    [ 33%] [.0           ...1        ........2    ..3         ] [ 404.2KB/s] [00:00]
    [ 34%] [.0           ...1        .........2   ..3         ] [ 415.2KB/s] [00:00]
    [ 35%] [.0           ...1        .........2   ..3         ] [ 419.9KB/s] [00:00]
    [ 36%] [.0           ...1        .........2   ..3         ] [ 431.2KB/s] [00:00]
    [ 36%] [.0           ...1        .........2   ..3         ] [ 432.6KB/s] [00:00][ 37%] [.0           ...1        ..........2  ..3         ] [ 445.0KB/s] [00:00]
    [ 38%] [.0           ...1        ..........2  ..3         ] [ 454.4KB/s] [00:00]
    [ 38%] [.0           ...1        ..........2  ..3         ] [ 457.6KB/s] [00:00]
    [ 39%] [.0           ....1       ..........2  ..3         ] [ 468.5KB/s] [00:00]
    [ 40%] [.0           ....1       ..........2  ..3         ] [ 476.4KB/s] [00:00]
    [ 40%] [.0           .....1      ..........2  ..3         ] [ 482.6KB/s] [00:00]
    [ 40%] [.0           .....1      ..........2  ..3         ] [ 485.5KB/s] [00:00]
    [ 41%] [.0           .....1      ..........2  ..3         ] [ 496.7KB/s] [00:00]
    [ 42%] [.0           .....1      ..........2  ..3         ] [ 501.3KB/s] [00:00]
    [ 42%] [.0           ......1     ..........2  ..3         ] [ 506.4KB/s] [00:00]
    [ 42%] [.0           ......1     ..........2  ..3         ] [ 509.4KB/s] [00:00]
    [ 43%] [.0           ......1     ..........2  ..3         ] [ 519.9KB/s] [00:00]
    [ 43%] [.0           ......1     ..........2  ..3         ] [ 521.3KB/s] [00:00]
    [ 44%] [.0           ......1     ..........2  ..3         ] [ 523.7KB/s] [00:00]
    [ 45%] [.0           .......1    ..........2  ..3         ] [ 533.2KB/s] [00:00]
    [ 45%] [.0           .......1    ..........2  ..3         ] [ 530.5KB/s] [00:00]
    [ 46%] [.0           .......1    ..........2  ..3         ] [ 539.5KB/s] [00:00]
    [ 47%] [.0           .......1    ...........2 ..3         ] [ 550.3KB/s] [00:00]
    [ 47%] [.0           .......1    ...........2 ..3         ] [ 551.7KB/s] [00:00]
    [ 47%] [.0           .......1    ...........2 ..3         ] [ 554.6KB/s] [00:00]
    [ 48%] [.0           .......1    ...........2 ..3         ] [ 533.0KB/s] [00:00]
    [ 48%] [.0           .......1    ...........2 ..3         ] [ 535.8KB/s] [00:00]
    [ 48%] [.0           .......1    ...........2 ...3        ] [ 538.3KB/s] [00:00]
    [ 49%] [.0           .......1    ...........2 ...3        ] [ 548.5KB/s] [00:00]
    [ 49%] [.0           .......1    ...........2 ...3        ] [ 549.8KB/s] [00:00]
    [ 50%] [.0           .......1    ...........2 ...3        ] [ 555.6KB/s] [00:00]
    [ 50%] [.0           .......1    ...........2 ....3       ] [ 560.2KB/s] [00:00]
    [ 51%] [.0           .......1    ...........2 ....3       ] [ 563.0KB/s] [00:00]
    [ 51%] [.0           .......1    ...........2 ....3       ] [ 565.9KB/s] [00:00]
    [ 52%] [.0           .......1    ...........2 ....3       ] [ 574.6KB/s] [00:00]
    [ 53%] [.0           .......1    ...........2 .....3      ] [ 584.8KB/s] [00:00]
    [ 53%] [.0           .......1    ...........2 .....3      ] [ 592.1KB/s] [00:00]
    [ 54%] [.0           .......1    ...........2 .....3      ] [ 595.0KB/s] [00:00]
    [ 55%] [.0           .......1    ...........2 .....3      ] [ 609.2KB/s] [00:00]
    [ 56%] [..0          .......1    ...........2 .....3      ] [ 617.7KB/s] [00:00]
    [ 56%] [..0          .......1    ...........2 .....3      ] [ 623.1KB/s] [00:00]
    [ 57%] [..0          .......1    ...........2 .....3      ] [ 633.2KB/s] [00:00]
    [ 58%] [...0         .......1    ...........2 .....3      ] [ 637.5KB/s] [00:00]
    [ 58%] [...0         .......1    ...........2 .....3      ] [ 637.2KB/s] [00:00]
    [ 58%] [...0         .......1    ...........2 .....3      ] [ 640.0KB/s] [00:00]
    [ 58%] [...0         .......1    ...........2 .....3      ] [ 642.7KB/s] [00:00]
    [ 59%] [...0         .......1    ...........2 .....3      ] [ 647.8KB/s] [00:00]
    [ 60%] [...0         .......1    ...........2 .....3      ] [ 616.0KB/s] [00:00]
    [ 60%] [...0         .......1    ............2.....3      ] [ 624.1KB/s] [00:00]
    [ 61%] [...0         .......1    ..................3      ] [ 626.5KB/s] [00:00]
    [ 61%] [...0         .......1    ..................3      ] [ 626.4KB/s] [00:00]
    [ 61%] [...0         .......1    ..................3      ] [ 630.4KB/s] [00:00]
    [ 62%] [...0         .......1    ..................3      ] [ 633.1KB/s] [00:00]
    [ 62%] [...0         .......1    ..................3      ] [ 638.2KB/s] [00:00]
    [ 63%] [...0         ........1   ..................3      ] [ 643.5KB/s] [00:00]
    [ 64%] [...0         ........1   ..................3      ] [ 652.7KB/s] [00:00]
    [ 64%] [...0         ........1   ..................3      ] [ 656.6KB/s] [00:00]
    [ 65%] [...0         .........1  ..................3      ] [ 662.0KB/s] [00:00]
    [ 65%] [...0         .........1  ..................3      ] [ 664.5KB/s] [00:00]
    [ 65%] [...0         .........1  ..................3      ] [ 666.7KB/s] [00:00]
    [ 65%] [...0         .........1  ..................3      ] [ 669.3KB/s] [00:00]
    [ 66%] [...0         .........1  ..................3      ] [ 678.7KB/s] [00:00]
    [ 67%] [...0         ..........1 ..................3      ] [ 686.2KB/s] [00:00]
    [ 68%] [...0         ..........1 ..................3      ] [ 695.7KB/s] [00:00]
    [ 68%] [...0         ..........1 ..................3      ] [ 696.9KB/s] [00:00]
    [ 69%] [...0         ...........1..................3      ] [ 704.9KB/s] [00:00]
    [ 69%] [...0         ...........1..................3      ] [ 709.9KB/s] [00:00]
    [ 70%] [...0         ...........1..................3      ] [ 719.3KB/s] [00:00]
    [ 70%] [...0         ..............................3      ] [ 719.4KB/s] [00:00]
    [ 70%] [...0         ..............................3      ] [ 719.3KB/s] [00:00]
    [ 71%] [...0         ...............................3     ] [ 682.3KB/s] [00:00]
    [ 71%] [...0         ...............................3     ] [ 686.9KB/s] [00:00]
    [ 72%] [...0         ...............................3     ] [ 688.6KB/s] [00:00]
    [ 72%] [...0         ...............................3     ] [ 691.0KB/s] [00:00]
    [ 73%] [...0         ................................3    ] [ 698.2KB/s] [00:00]
    [ 74%] [...0         ................................3    ] [ 705.7KB/s] [00:00]
    [ 74%] [...0         ................................3    ] [ 708.1KB/s] [00:00]
    [ 74%] [...0         ................................3    ] [ 713.0KB/s] [00:00]
    [ 75%] [...0         ................................3    ] [ 714.7KB/s] [00:00]
    [ 75%] [...0         .................................3   ] [ 721.3KB/s] [00:00]
    [ 76%] [....0        .................................3   ] [ 728.7KB/s] [00:00]
    [ 76%] [....0        .................................3   ] [ 731.0KB/s] [00:00]
    [ 77%] [....0        .................................3   ] [ 727.2KB/s] [00:00]
    [ 77%] [....0        .................................3   ] [ 729.6KB/s] [00:00]
    [ 78%] [....0        ..................................3  ] [ 736.8KB/s] [00:00]
    [ 78%] [....0        ..................................3  ] [ 743.3KB/s] [00:00]
    [ 79%] [....0        ..................................3  ] [ 745.7KB/s] [00:00]
    [ 79%] [....0        ..................................3  ] [ 748.1KB/s] [00:00]
    [ 80%] [....0        ...................................3 ] [ 755.4KB/s] [00:00]
    [ 81%] [....0        ...................................3 ] [ 762.6KB/s] [00:00]
    [ 81%] [....0        ...................................3 ] [ 771.4KB/s] [00:00]
    [ 82%] [.....0       ...................................3 ] [ 780.0KB/s] [00:00]
    [ 83%] [.....0       ...................................3 ] [ 784.9KB/s] [00:00]
    [ 83%] [.....0       ...................................3 ] [ 789.7KB/s] [00:00]
    [ 84%] [......0      ...................................3 ] [ 794.5KB/s] [00:00]
    [ 85%] [......0      ...................................3 ] [ 799.3KB/s] [00:00]
    [ 85%] [......0      ...................................3 ] [ 804.2KB/s] [00:00]
    [ 85%] [......0      ...................................3 ] [ 806.4KB/s] [00:00]
    [ 86%] [.......0     ...................................3 ] [ 815.0KB/s] [00:00]
    [ 86%] [.......0     ...................................3 ] [ 816.1KB/s] [00:00]
    [ 87%] [.......0     ...................................3 ] [ 818.5KB/s] [00:00]
    [ 87%] [.......0     ...................................3 ] [ 823.1KB/s] [00:00]
    [ 87%] [.......0     ...................................3 ] [ 739.8KB/s] [00:00]
    [ 88%] [.......0     ...................................3 ] [ 744.1KB/s] [00:00]
    [ 88%] [.......0     ...................................3 ] [ 745.9KB/s] [00:00]
    [ 89%] [.......0     ....................................3] [ 750.1KB/s] [00:00]
    [ 89%] [.......0     ....................................3] [ 751.8KB/s] [00:00]
    [ 90%] [.......0     ....................................3] [ 756.0KB/s] [00:00]
    [ 90%] [.......0     ....................................3] [ 760.1KB/s] [00:00]
    [ 90%] [.......0     .....................................] [ 761.9KB/s] [00:00]
    [ 90%] [.......0     .....................................] [ 761.7KB/s] [00:00]
    [ 91%] [.......0     .....................................] [ 762.5KB/s] [00:00]
    [ 91%] [........0    .....................................] [ 768.8KB/s] [00:00]
    [ 92%] [........0    .....................................] [ 766.8KB/s] [00:00]
    [ 92%] [........0    .....................................] [ 768.9KB/s] [00:00]
    [ 93%] [........0    .....................................] [ 770.1KB/s] [00:00]
    [ 93%] [.........0   .....................................] [ 776.5KB/s] [00:00]
    [ 94%] [.........0   .....................................] [ 782.9KB/s] [00:00]
    [ 94%] [.........0   .....................................] [ 785.1KB/s] [00:00]
    [ 95%] [.........0   .....................................] [ 789.4KB/s] [00:00]
    [ 95%] [..........0  .....................................] [ 791.5KB/s] [00:00]
    [ 96%] [..........0  .....................................] [ 797.9KB/s] [00:00]
    [ 97%] [..........0  .....................................] [ 804.6KB/s] [00:00]
    [ 97%] [...........0 .....................................] [ 807.7KB/s] [00:00]
    [ 98%] [...........0 .....................................] [ 814.9KB/s] [00:00]
    [ 99%] [...........0 .....................................] [ 819.0KB/s] [00:00]
    [ 99%] [............0.....................................] [ 823.3KB/s] [00:00]
    [100%] [............0.....................................] [ 825.4KB/s] [00:00]
    Downloaded 530.9 kilobytes in 0 seconds. (829.07 KB/s)
    (B[m[1;33;40msproxy-latest.tar.gz valid file.
    (B[m
    [1;33;40mDownload nginx-1.7.11.tar.gz ...
    (B[mInitializing download: http://nginx.org/download/nginx-1.7.11.tar.gz
    File size: 831490 bytes
    Opening output file nginx-1.7.11.tar.gz
    Starting download
    [  1%] [0            1           2            3           ] [  24.9KB/s] [00:32]
    [  1%] [0            1           2            3           ] [  49.9KB/s] [00:15]
    [  2%] [0            1           2            3           ] [  69.3KB/s] [00:11]
    [  2%] [.0           1           2            3           ] [  72.1KB/s] [00:10]
    [  3%] [.0           1           2            3           ] [  91.2KB/s] [00:08]
    [  4%] [.0           1           2            3           ] [ 110.3KB/s] [00:06]
    [  4%] [.0           1           2            3           ] [ 117.8KB/s] [00:06]
    [  4%] [..0          1           2            3           ] [ 107.0KB/s] [00:07]
    [  6%] [..0          1           2            3           ] [ 151.7KB/s] [00:04]
    [  8%] [..0          1           2            3           ] [ 196.4KB/s] [00:03]
    [ 10%] [...0         1           2            3           ] [ 234.4KB/s] [00:02]
    [ 10%] [...0         1           2            3           ] [ 249.3KB/s] [00:02]
    [ 11%] [...0         1           2            3           ] [ 259.0KB/s] [00:02]
    [ 11%] [...0         1           2            3           ] [ 273.1KB/s] [00:02]
    [ 11%] [...0         1           2            3           ] [ 275.0KB/s] [00:02]
    [ 12%] [...0         .1          2            3           ] [ 289.6KB/s] [00:02]
    [ 13%] [...0         .1          2            3           ] [ 304.4KB/s] [00:02]
    [ 13%] [...0         .1          2            3           ] [ 319.3KB/s] [00:02]
    [ 13%] [...0         .1          2            3           ] [ 325.1KB/s] [00:01]
    [ 14%] [...0         .1          2            3           ] [ 299.9KB/s] [00:02]
    [ 15%] [...0         .1          2            3           ] [ 313.1KB/s] [00:02]
    [ 15%] [...0         .1          2            3           ] [ 326.2KB/s] [00:01]
    [ 16%] [...0         .1          2            3           ] [ 336.4KB/s] [00:01]
    [ 16%] [...0         .1          2            3           ] [ 349.5KB/s] [00:01]
    [ 17%] [...0         .1          2            .3          ] [ 362.7KB/s] [00:01]
    [ 17%] [...0         .1          2            .3          ] [ 369.8KB/s] [00:01]
    [ 18%] [...0         .1          2            .3          ] [ 355.7KB/s] [00:01]
    [ 19%] [....0        .1          2            .3          ] [ 367.8KB/s] [00:01]
    [ 19%] [....0        .1          2            .3          ] [ 380.0KB/s] [00:01]
    [ 20%] [....0        .1          2            .3          ] [ 392.2KB/s] [00:01]
    [ 20%] [.....0       .1          2            .3          ] [ 404.4KB/s] [00:01]
    [ 21%] [.....0       .1          2            .3          ] [ 416.6KB/s] [00:01]
    [ 22%] [.....0       .1          2            .3          ] [ 428.8KB/s] [00:01]
    [ 22%] [......0      .1          2            .3          ] [ 441.0KB/s] [00:01]
    [ 22%] [......0      .1          2            .3          ] [ 442.2KB/s] [00:01]
    [ 23%] [......0      .1          2            .3          ] [ 450.3KB/s] [00:01]
    [ 23%] [......0      ..1         2            .3          ] [ 462.2KB/s] [00:01]
    [ 24%] [......0      ..1         2            .3          ] [ 474.3KB/s] [00:01]
    [ 25%] [......0      ..1         2            .3          ] [ 486.5KB/s] [00:01]
    [ 25%] [......0      ...1        2            .3          ] [ 494.6KB/s] [00:01]
    [ 26%] [......0      ...1        2            .3          ] [ 506.7KB/s] [00:01]
    [ 26%] [......0      ...1        2            .3          ] [ 516.4KB/s] [00:01]
    [ 26%] [......0      ...1        2            .3          ] [ 517.7KB/s] [00:01]
    [ 27%] [......0      ...1        .2           .3          ] [ 529.6KB/s] [00:01]
    [ 28%] [......0      ...1        .2           .3          ] [ 541.7KB/s] [00:00]
    [ 28%] [......0      ...1        .2           .3          ] [ 553.8KB/s] [00:00]
    [ 28%] [......0      ...1        .2           .3          ] [ 555.1KB/s] [00:00]
    [ 29%] [......0      ...1        .2           .3          ] [ 516.7KB/s] [00:01]
    [ 29%] [......0      ...1        .2           ..3         ] [ 527.7KB/s] [00:01]
    [ 30%] [......0      ...1        .2           ..3         ] [ 538.6KB/s] [00:00]
    [ 31%] [......0      ...1        .2           ..3         ] [ 549.6KB/s] [00:00]
    [ 31%] [......0      ...1        .2           ..3         ] [ 560.5KB/s] [00:00]
    [ 32%] [......0      ...1        .2           ..3         ] [ 537.2KB/s] [00:00]
    [ 32%] [......0      ...1        .2           ..3         ] [ 547.5KB/s] [00:00]
    [ 33%] [.......0     ...1        .2           ..3         ] [ 557.8KB/s] [00:00]
    [ 34%] [.......0     ...1        .2           ..3         ] [ 568.0KB/s] [00:00]
    [ 34%] [.......0     ...1        .2           ..3         ] [ 578.3KB/s] [00:00]
    [ 35%] [.......0     ...1        .2           ..3         ] [ 588.6KB/s] [00:00]
    [ 36%] [........0    ...1        .2           ..3         ] [ 599.0KB/s] [00:00]
    [ 36%] [........0    ...1        .2           ..3         ] [ 601.8KB/s] [00:00]
    [ 36%] [........0    ...1        .2           ..3         ] [ 604.6KB/s] [00:00]
    [ 37%] [........0    ....1       .2           ..3         ] [ 614.6KB/s] [00:00]
    [ 37%] [........0    ....1       .2           ..3         ] [ 621.8KB/s] [00:00]
    [ 38%] [........0    ....1       .2           ..3         ] [ 631.9KB/s] [00:00]
    [ 38%] [........0    ....1       .2           ..3         ] [ 642.1KB/s] [00:00]
    [ 39%] [........0    .....1      .2           ..3         ] [ 652.4KB/s] [00:00]
    [ 39%] [........0    .....1      .2           ..3         ] [ 662.7KB/s] [00:00]
    [ 40%] [........0    .....1      .2           ..3         ] [ 665.1KB/s] [00:00]
    [ 40%] [........0    .....1      ..2          ..3         ] [ 672.8KB/s] [00:00]
    [ 41%] [........0    .....1      ..2          ..3         ] [ 682.8KB/s] [00:00]
    [ 41%] [........0    .....1      ..2          ..3         ] [ 693.1KB/s] [00:00]
    [ 42%] [........0    .....1      ...2         ..3         ] [ 703.3KB/s] [00:00]
    [ 42%] [........0    .....1      ...2         ..3         ] [ 708.6KB/s] [00:00]
    [ 43%] [........0    .....1      ...2         ...3        ] [ 663.0KB/s] [00:00]
    [ 44%] [........0    .....1      ...2         ...3        ] [ 672.2KB/s] [00:00]
    [ 44%] [........0    .....1      ...2         ...3        ] [ 681.7KB/s] [00:00]
    [ 45%] [........0    .....1      ...2         ....3       ] [ 691.1KB/s] [00:00]
    [ 45%] [........0    .....1      ...2         ....3       ] [ 700.6KB/s] [00:00]
    [ 46%] [........0    .....1      ...2         ....3       ] [ 710.1KB/s] [00:00]
    [ 47%] [........0    .....1      ...2         .....3      ] [ 719.5KB/s] [00:00]
    [ 47%] [........0    .....1      ...2         .....3      ] [ 724.3KB/s] [00:00]
    [ 48%] [........0    .....1      ...2         .....3      ] [ 695.5KB/s] [00:00]
    [ 48%] [........0    .....1      ...2         .....3      ] [ 704.3KB/s] [00:00]
    [ 49%] [.........0   .....1      ...2         .....3      ] [ 713.1KB/s] [00:00]
    [ 49%] [.........0   .....1      ...2         .....3      ] [ 722.0KB/s] [00:00]
    [ 50%] [.........0   .....1      ...2         .....3      ] [ 731.0KB/s] [00:00]
    [ 51%] [..........0  .....1      ...2         .....3      ] [ 739.9KB/s] [00:00]
    [ 51%] [..........0  .....1      ...2         .....3      ] [ 745.8KB/s] [00:00]
    [ 52%] [..........0  .....1      ...2         .....3      ] [ 753.6KB/s] [00:00]
    [ 52%] [..........0  ......1     ...2         .....3      ] [ 762.5KB/s] [00:00]
    [ 53%] [..........0  ......1     ...2         .....3      ] [ 767.4KB/s] [00:00]
    [ 53%] [..........0  ......1     ...2         .....3      ] [ 776.1KB/s] [00:00]
    [ 54%] [..........0  .......1    ...2         .....3      ] [ 784.9KB/s] [00:00]
    [ 54%] [..........0  .......1    ...2         .....3      ] [ 793.7KB/s] [00:00]
    [ 55%] [..........0  .......1    ...2         .....3      ] [ 802.4KB/s] [00:00]
    [ 56%] [..........0  .......1    ...2         .....3      ] [ 811.3KB/s] [00:00]
    [ 56%] [..........0  ........1   ...2         .....3      ] [ 820.2KB/s] [00:00]
    [ 57%] [..........0  ........1   ...2         .....3      ] [ 829.1KB/s] [00:00]
    [ 57%] [..........0  ........1   ...2         .....3      ] [ 829.3KB/s] [00:00]
    [ 57%] [..........0  ........1   ...2         .....3      ] [ 834.1KB/s] [00:00]
    [ 58%] [..........0  ........1   ...2         .....3      ] [ 842.7KB/s] [00:00]
    [ 59%] [..........0  ........1   ....2        .....3      ] [ 851.6KB/s] [00:00]
    [ 59%] [..........0  ........1   ....2        .....3      ] [ 860.5KB/s] [00:00]
    [ 60%] [..........0  ........1   ....2        .....3      ] [ 869.4KB/s] [00:00]
    [ 60%] [..........0  ........1   ....2        .....3      ] [ 871.5KB/s] [00:00]
    [ 60%] [..........0  ........1   ....2        .....3      ] [ 818.2KB/s] [00:00]
    [ 61%] [..........0  ........1   ....2        .....3      ] [ 826.1KB/s] [00:00]
    [ 62%] [..........0  ........1   ....2        .....3      ] [ 834.3KB/s] [00:00]
    [ 62%] [..........0  ........1   ....2        ......3     ] [ 842.5KB/s] [00:00]
    [ 63%] [..........0  ........1   ....2        ......3     ] [ 850.8KB/s] [00:00]
    [ 63%] [..........0  ........1   ....2        ......3     ] [ 859.1KB/s] [00:00]
    [ 64%] [..........0  ........1   ....2        .......3    ] [ 867.4KB/s] [00:00]
    [ 65%] [..........0  ........1   ....2        .......3    ] [ 875.7KB/s] [00:00]
    [ 65%] [..........0  ........1   ....2        .......3    ] [ 877.2KB/s] [00:00]
    [ 65%] [..........0  ........1   ....2        .......3    ] [ 845.1KB/s] [00:00]
    [ 66%] [...........0 ........1   ....2        .......3    ] [ 852.8KB/s] [00:00]
    [ 67%] [...........0 ........1   ....2        .......3    ] [ 860.6KB/s] [00:00]
    [ 67%] [...........0 ........1   ....2        .......3    ] [ 868.5KB/s] [00:00]
    [ 68%] [...........0 ........1   ....2        .......3    ] [ 876.3KB/s] [00:00]
    [ 68%] [............0........1   ....2        .......3    ] [ 884.2KB/s] [00:00]
    [ 69%] [.....................1   ....2        .......3    ] [ 890.1KB/s] [00:00]
    [ 70%] [.....................1   ....2        .......3    ] [ 896.9KB/s] [00:00]
    [ 70%] [......................1  ....2        .......3    ] [ 903.3KB/s] [00:00]
    [ 70%] [......................1  ....2        .......3    ] [ 905.2KB/s] [00:00]
    [ 71%] [......................1  ....2        .......3    ] [ 913.0KB/s] [00:00]
    [ 71%] [......................1  ....2        .......3    ] [ 916.3KB/s] [00:00]
    [ 72%] [......................1  ....2        .......3    ] [ 923.9KB/s] [00:00]
    [ 72%] [.......................1 ....2        .......3    ] [ 931.7KB/s] [00:00]
    [ 73%] [.......................1 ....2        .......3    ] [ 939.5KB/s] [00:00]
    [ 74%] [.......................1 ....2        .......3    ] [ 947.3KB/s] [00:00]
    [ 74%] [........................1....2        .......3    ] [ 955.2KB/s] [00:00]
    [ 75%] [........................1....2        .......3    ] [ 963.1KB/s] [00:00]
    [ 75%] [........................1....2        .......3    ] [ 963.9KB/s] [00:00]
    [ 75%] [........................1.....2       .......3    ] [ 969.7KB/s] [00:00]
    [ 76%] [........................1.....2       .......3    ] [ 977.5KB/s] [00:00]
    [ 77%] [........................1.....2       .......3    ] [ 985.4KB/s] [00:00]
    [ 77%] [........................1.....2       .......3    ] [ 990.7KB/s] [00:00]
    [ 78%] [........................1......2      .......3    ] [ 998.2KB/s] [00:00]
    [ 78%] [........................1......2      .......3    ] [1006.1KB/s] [00:00]
    [ 79%] [........................1......2      .......3    ] [1013.3KB/s] [00:00]
    [ 79%] [........................1......2      .......3    ] [ 955.3KB/s] [00:00]
    [ 80%] [........................1......2      .......3    ] [ 962.5KB/s] [00:00]
    [ 80%] [........................1......2      ........3   ] [ 969.9KB/s] [00:00]
    [ 81%] [........................1......2      ........3   ] [ 977.1KB/s] [00:00]
    [ 82%] [........................1......2      ........3   ] [ 984.4KB/s] [00:00]
    [ 82%] [........................1......2      .........3  ] [ 991.7KB/s] [00:00]
    [ 83%] [........................1......2      .........3  ] [ 999.0KB/s] [00:00]
    [ 83%] [........................1......2      .........3  ] [1006.3KB/s] [00:00]
    [ 84%] [........................1......2      ..........3 ] [1013.7KB/s] [00:00]
    [ 85%] [........................1......2      ..........3 ] [1021.0KB/s] [00:00]
    [ 85%] [........................1......2      ..........3 ] [   1.0MB/s] [00:00]
    [ 85%] [........................1......2      ..........3 ] [ 986.7KB/s] [00:00]
    [ 86%] [...............................2      ..........3 ] [ 992.0KB/s] [00:00]
    [ 86%] [...............................2      ..........3 ] [ 991.9KB/s] [00:00]
    [ 86%] [...............................2      ..........3 ] [ 991.4KB/s] [00:00]
    [ 87%] [................................2     ..........3 ] [ 998.3KB/s] [00:00]
    [ 87%] [................................2     ..........3 ] [1005.4KB/s] [00:00]
    [ 88%] [................................2     ..........3 ] [1009.2KB/s] [00:00]
    [ 88%] [.................................2    ..........3 ] [1016.0KB/s] [00:00]
    [ 89%] [.................................2    ..........3 ] [1023.1KB/s] [00:00]
    [ 89%] [.................................2    ..........3 ] [   1.0MB/s] [00:00]
    [ 90%] [.................................2    ..........3 ] [ 977.9KB/s] [00:00]
    [ 90%] [.................................2    ...........3] [ 984.5KB/s] [00:00]
    [ 91%] [.................................2    ...........3] [ 991.1KB/s] [00:00]
    [ 92%] [.................................2    ...........3] [ 997.8KB/s] [00:00]
    [ 92%] [.................................2    ............] [1000.9KB/s] [00:00]
    [ 92%] [.................................2    ............] [1000.8KB/s] [00:00]
    [ 93%] [.................................2    ............] [ 964.8KB/s] [00:00]
    [ 93%] [..................................2   ............] [ 971.1KB/s] [00:00]
    [ 94%] [..................................2   ............] [ 977.5KB/s] [00:00]
    [ 94%] [..................................2   ............] [ 983.9KB/s] [00:00]
    [ 95%] [...................................2  ............] [ 990.2KB/s] [00:00]
    [ 96%] [...................................2  ............] [ 996.5KB/s] [00:00]
    [ 96%] [...................................2  ............] [1002.9KB/s] [00:00]
    [ 97%] [...................................2  ............] [1009.3KB/s] [00:00]
    [ 98%] [....................................2 ............] [1015.7KB/s] [00:00]
    [ 98%] [....................................2 ............] [1020.7KB/s] [00:00]
    [ 99%] [....................................2 ............] [ 939.4KB/s] [00:00]
    [ 99%] [.....................................2............] [ 945.1KB/s] [00:00]
    [100%] [.....................................2............] [ 951.0KB/s] [00:00]
    [100%] [..................................................] [ 952.4KB/s]
    Downloaded 812.0 kilobytes in 0 seconds. (952.40 KB/s)
    [1;33;40mDownload done.
    (B[m[1;33;40mnginx-1.7.11.tar.gz valid file.
    (B[m
    [1;33;40mDownload ngx-fancyindex-0.3.1.tar.gz ...
    (B[m--2015-03-29 11:36:15--  http://centminmod.com/centminmodparts/nginx/modules/ngx-fancyindex-0.3.1.tar.gz
    Resolving centminmod.com... 205.185.121.179
    Connecting to centminmod.com|205.185.121.179|:80... connected.
    Length: 13148 (13K) [application/octet-stream]
    Saving to: “ngx-fancyindex-0.3.1.tar.gz”
         0K .......... ..                                         100% 2.78M=0.005s
    2015-03-29 11:36:15 (2.78 MB/s) - “ngx-fancyindex-0.3.1.tar.gz” saved [13148/13148]
    (B[m[1;33;40mngx-fancyindex-0.3.1.tar.gz valid file.
    (B[m
    (B[m
    [1;33;40mDownload ngx_cache_purge-2.3.tar.gz ...
    (B[mInitializing download: http://centminmod.com/centminmodparts/nginx/modules/ngx_cache_purge-2.3.tar.gz
    File size: 12248 bytes
    Opening output file ngx_cache_purge-2.3.tar.gz
    Starting download
    [ 25%] [.............1           2            3           ] [  14.9KB/s] [00:00]
    [ 50%] [..........................2           3           ] [  19.9KB/s] [00:00]
    [100%] [..................................................] [  29.8KB/s]
    Downloaded 12.0 kilobytes in 0 seconds. (29.82 KB/s)
    (B[m[1;33;40mngx_cache_purge-2.3.tar.gz valid file.
    (B[m
    [1;33;40mDownload Nginx-accesskey-2.0.3.tar.gz ...
    (B[m--2015-03-29 11:36:16--  http://wiki.nginx.org/images/5/51/Nginx-accesskey-2.0.3.tar.gz
    Resolving wiki.nginx.org... 206.251.255.64
    Connecting to wiki.nginx.org|206.251.255.64|:80... connected.
    Length: 2632 (2.6K) [application/octet-stream]
    Saving to: “Nginx-accesskey-2.0.3.tar.gz”
         0K ..                                                    100%  232M=0s
    2015-03-29 11:36:16 (232 MB/s) - “Nginx-accesskey-2.0.3.tar.gz” saved [2632/2632]
    (B[m[1;33;40mNginx-accesskey-2.0.3.tar.gz valid file.
    (B[m
    [1;33;40mDownload nginx-http-concat-master.tar.gz ...
    (B[m--2015-03-29 11:36:16--  https://github.com/alibaba/nginx-http-concat/archive/master.tar.gz
    Resolving github.com... 192.30.252.130
    Connecting to github.com|192.30.252.130|:443... connected.
    HTTP request sent, awaiting response... 302 Found
    Location: https://codeload.github.com/alibaba/nginx-http-concat/tar.gz/master [following]
    --2015-03-29 11:36:16--  https://codeload.github.com/alibaba/nginx-http-concat/tar.gz/master
    Resolving codeload.github.com... 192.30.252.147
    Connecting to codeload.github.com|192.30.252.147|:443... connected.
    Length: unspecified [application/x-gzip]
    Saving to: “nginx-http-concat-master.tar.gz”
         0K ......                                                 39.3M=0s
    2015-03-29 11:36:16 (39.3 MB/s) - “nginx-http-concat-master.tar.gz” saved [6980]
    (B[m[1;33;40mnginx-http-concat-master.tar.gz valid file.
    (B[m
    [1;33;40mDownload headers-more-v0.25.tar.gz ...
    (B[m--2015-03-29 11:36:16--  https://github.com/agentzh/headers-more-nginx-module/archive/v0.25.tar.gz
    Resolving github.com... 192.30.252.131
    Connecting to github.com|192.30.252.131|:443... connected.
    HTTP request sent, awaiting response... 301 Moved Permanently
    Location: https://github.com/openresty/headers-more-nginx-module/archive/v0.25.tar.gz [following]
    --2015-03-29 11:36:17--  https://github.com/openresty/headers-more-nginx-module/archive/v0.25.tar.gz
    Location: https://codeload.github.com/openresty/headers-more-nginx-module/tar.gz/v0.25 [following]
    --2015-03-29 11:36:17--  https://codeload.github.com/openresty/headers-more-nginx-module/tar.gz/v0.25
    Length: 27973 (27K) [application/x-gzip]
    Saving to: “headers-more-v0.25.tar.gz”
         0K .......... .......... .......                         100% 1.13M=0.02s
    2015-03-29 11:36:17 (1.13 MB/s) - “headers-more-v0.25.tar.gz” saved [27973/27973]
    (B[m[1;33;40mheaders-more-v0.25.tar.gz valid file.
    (B[m
    [1;33;40mDownload nginx-sticky-1.2.5.tar.gz ...
    (B[m--2015-03-29 11:36:17--  https://bitbucket.org/nginx-goodies/nginx-sticky-module-ng/get/1.2.5.tar.gz
    Resolving bitbucket.org... 131.103.20.168, 131.103.20.167
    Connecting to bitbucket.org|131.103.20.168|:443... connected.
    Length: 120567 (118K) [application/x-tar-gz]
    Saving to: “nginx-sticky-1.2.5.tar.gz”
         0K .......... .......... .......... .......... .......... 42%  857K 0s
        50K .......... .......... .......... .......... .......... 84%  856K 0s
       100K .......... .......                                    100% 51.4M=0.1s
    2015-03-29 11:36:17 (1005 KB/s) - “nginx-sticky-1.2.5.tar.gz” saved [120567/120567]
    (B[m[1;33;40mnginx-sticky-1.2.5.tar.gz valid file.
    (B[m
    [1;33;40mDownload nginx-upstream-check-0.3.0.tar.gz ...
    (B[m--2015-03-29 11:36:17--  https://github.com/yaoweibin/nginx_upstream_check_module/archive/v0.3.0.tar.gz
    Location: https://codeload.github.com/yaoweibin/nginx_upstream_check_module/tar.gz/v0.3.0 [following]
    --2015-03-29 11:36:17--  https://codeload.github.com/yaoweibin/nginx_upstream_check_module/tar.gz/v0.3.0
    Resolving codeload.github.com... 192.30.252.145
    Connecting to codeload.github.com|192.30.252.145|:443... connected.
    Saving to: “nginx-upstream-check-0.3.0.tar.gz”
         0K .......... .......... .......... .......... .......... 1.03M
        50K .......... .......... .......... .......... .......... 2.05M
       100K .......... .......... .......... ...                   23.3M=0.07s
    2015-03-29 11:36:18 (1.79 MB/s) - “nginx-upstream-check-0.3.0.tar.gz” saved [136542]
    (B[m[1;33;40mnginx-upstream-check-0.3.0.tar.gz valid file.
    (B[m
    [1;33;40mDownload pcre-8.36.tar.gz ...
    (B[m--2015-03-29 11:36:18--  ftp://ftp.csx.cam.ac.uk/pub/software/programming/pcre/pcre-8.36.tar.gz
               => “pcre-8.36.tar.gz”
    Resolving ftp.csx.cam.ac.uk... 131.111.8.115
    Connecting to ftp.csx.cam.ac.uk|131.111.8.115|:21... connected.
    Logging in as anonymous ... Logged in!
    ==> SYST ... done.    ==> PWD ... done.
    ==> TYPE I ... done.  ==> CWD (1) /pub/software/programming/pcre ... done.
    ==> SIZE pcre-8.36.tar.gz ... 2009464
    ==> PASV ... done.    ==> RETR pcre-8.36.tar.gz ... done.
    Length: 2009464 (1.9M) (unauthoritative)
         0K .......... .......... .......... .......... ..........  2%  300K 6s
        50K .......... .......... .......... .......... ..........  5%  299K 6s
       100K .......... .......... .......... .......... ..........  7%  301K 6s
       150K .......... .......... .......... .......... .......... 10%  601K 5s
       200K .......... .......... .......... .......... .......... 12% 36.5M 4s
       250K .......... .......... .......... .......... .......... 15%  598K 4s
       300K .......... .......... .......... .......... .......... 17%  605K 3s
       350K .......... .......... .......... .......... .......... 20% 54.4M 3s
       400K .......... .......... .......... .......... .......... 22%  605K 3s
       450K .......... .......... .......... .......... .......... 25%  602K 3s
       500K .......... .......... .......... .......... .......... 28%  111M 2s
       550K .......... .......... .......... .......... .......... 30% 77.5M 2s
       600K .......... .......... .......... .......... .......... 33%  604K 2s
       650K .......... .......... .......... .......... .......... 35% 61.1M 2s
       700K .......... .......... .......... .......... .......... 38%  607K 2s
       750K .......... .......... .......... .......... .......... 40% 62.4M 2s
       800K .......... .......... .......... .......... .......... 43% 51.8M 1s
       850K .......... .......... .......... .......... .......... 45%  606K 1s
       900K .......... .......... .......... .......... .......... 48% 65.2M 1s
       950K .......... .......... .......... .......... .......... 50% 98.1M 1s
      1000K .......... .......... .......... .......... .......... 53%  608K 1s
      1050K .......... .......... .......... .......... .......... 56% 70.5M 1s
      1100K .......... .......... .......... .......... .......... 58%  611K 1s
      1150K .......... .......... .......... .......... .......... 61% 35.6M 1s
      1200K .......... .......... .......... .......... .......... 63% 90.0M 1s
      1250K .......... .......... .......... .......... .......... 66% 75.0M 1s
      1300K .......... .......... .......... .......... .......... 68%  616K 1s
      1350K .......... .......... .......... .......... .......... 71% 34.0M 1s
      1400K .......... .......... .......... .......... .......... 73% 47.4M 1s
      1450K .......... .......... .......... .......... .......... 76%  140M 0s
      1500K .......... .......... .......... .......... .......... 78%  622K 0s
      1550K .......... .......... .......... .......... .......... 81% 35.2M 0s
      1600K .......... .......... .......... .......... .......... 84% 50.4M 0s
      1650K .......... .......... .......... .......... .......... 86% 93.8M 0s
      1700K .......... .......... .......... .......... .......... 89%  114M 0s
      1750K .......... .......... .......... .......... .......... 91%  617K 0s
      1800K .......... .......... .......... .......... .......... 94% 97.9M 0s
      1850K .......... .......... .......... .......... .......... 96% 43.8M 0s
      1900K .......... .......... .......... .......... .......... 99% 52.0M 0s
      1950K .......... ..                                         100% 42.2M=1.6s
    2015-03-29 11:36:21 (1.21 MB/s) - “pcre-8.36.tar.gz” saved [2009464]
    (B[m[1;33;40mpcre-8.36.tar.gz valid file.
    (B[m
    [1;33;40mDownload nginx-dav-ext-module-0.0.3.tar.gz ...
    (B[m--2015-03-29 11:36:21--  https://github.com/arut/nginx-dav-ext-module/archive/v0.0.3.tar.gz
    Location: https://codeload.github.com/arut/nginx-dav-ext-module/tar.gz/v0.0.3 [following]
    --2015-03-29 11:36:21--  https://codeload.github.com/arut/nginx-dav-ext-module/tar.gz/v0.0.3
    Unable to establish SSL connection.
    [1;32;40mError: nginx-dav-ext-module-0.0.3.tar.gz download failed.
    (B[mcheck Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    ccache stats:
    cache hit (direct)                     0
    cache hit (preprocessed)               0
    cache miss                             0
    files in cache                         0
    cache size                             0 Kbytes
    max cache size                       2.0 Gbytes
    Total Centmin Mod Install Time: 864.392214911 seconds
  2. rdan
    1,412
    7:42 PM
    This is surely github issue/problem.
    Try to re run Nginx Upgrade menu again.
    55,801
    12,271
    9:42 PM
    yeah there's a problem with github.com over https/SSL at their end it seems for that particular repository
    you're unlucky to hit it, so only thing to do is try again later and see or manually download it to /svr-setup on your server and then re-run menu option #1 to try installing again
    cd /srv-setup
    wget https://github.com/arut/nginx-dav-ext-module/archive/v0.0.3.tar.gz
    Aborting script...
    but wow i think your server might be a bit slow, as the download phase took 800+ seconds and I see further up in output downloads only doing 700KB/s ! That is very slow to download from !
    55,801
    12,271
    9:42 PM
    looks like Github might have problems or under another DDOS attack as github.com is down for me right now !
  5. rdan
    1,412
    7:42 PM
    Yeah down sometimes.
  6. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    so what i must do :| .
    55,801
    12,271
    9:42 PM
    unfortunately wait until Github.com is working again .. we all all have to wait :(
  8. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    so why you uploading your script resources on github :| its real bad for this big project "Centminmod"
    maybe you can transfer resources to your self-hosted server ;) its better idea 100% uptime and no fuc.... ddos :D
    55,801
    12,271
    9:42 PM
    everyone uses github.com there's milltions of projects all on github so really this is something github should be able to solve with better DDOS protection
    but yeah it has me thinking about backup plans. but even if i hosted my Centmin Mod myself, the downloads from 3rd parties will still be on github. I have plans for Centmin Mod Premium User Membership to have their own fully dedicated 100% self hosted code eventually though.
    But for now, all we can do is wait it out :)
    55,801
    12,271
    9:42 PM
  11. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    Error: APC-3.1.13.tgz download failed.
    Aborting script...
    there are many redirects
    so what the hell is this ? :D
  12. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    55,801
    12,271
    9:42 PM
    need more of the actually errors leading up to and including that part
    most common error would be pecl.php.net download link was having problems it's defined in line 230 of inc/downloadlinks.inc
    You're one unlucky person to be hit with multiple download issues from 3rd parties. But from 3rd post as i noticed your server has very slow download speed ~700KB/s so that could be the problem too
  14. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    after restarting the network service the problem was fixed
    i finally completed the Install :D
    55,801
    12,271
    9:42 PM
    ah so network issues :)
    Guess it's finally welcome to the world of Centmin Mod ! Next stop Getting Started with Centmin Mod ;)
  16. Cr0w
    Cr0w Member
    165
    9
    Iran
    3:12 PM
    1.9.x
    5.5
    Done / You Can Close the topic the problems was solved !
  17. AlekseY
    AlekseY Member
    47
    2:42 PM
    What do I do?
    centos 6.6. x 32 -> centmin mod 0.8 beta 2
    Aborting script...
  18. AlekseY
    AlekseY Member
    47
    2:42 PM
    not install :(
    55,801
    12,271
    9:42 PM
    looks like you ran into similar issue as Nginx Downloading problem on install | Centmin Mod Community could be temporarily APC pecl.php.net downtime.
    You can either wait till later to try again, or if you want try manually downloading the APC-3.1.13.tgz to /svr-setup via my local mirror at
    wget -O  /svr-setup/APC-3.1.13.tgz http://centminmod.com/centminmodparts/apc/php550/APC-3.1.13.tgz
    then re-run centmin.sh menu option 1 again and see if it passes that point. If pecl.php.net is indeed having issues, you may have further download issues down the track too
    If you already have another Centmin Mod server successfully installed, you can use centminmod_packager.sh script at Install - centminmod_packager.sh | Centmin Mod Community to bundle up that successfully installed server's /svr-setup directory downloaded files and copy them to your Centmin Mod server you want to run initial install on and place downloads into /svr-setup and then run centmin.sh menu option 1
    55,801
    12,271
    9:42 PM
