Wordpress Nginx broke and won't start. Please help.
Discussion in 'Blogs & CMS usage' started by fiftycent, Jun 17, 2022.
  1. fiftycent
    fiftycent New Member
    6
    Florida, USA
    6:45 PM
    Nginx 1.21.6
    MariaDB 10.3.35
    • CentOS Version: centOS 7 64bit (DigitalOcean)
    • Centmin Mod Version Installed: 124.00 stable
    • Nginx Version Installed: 1.21.6
    • PHP Version Installed: 8.0.19
    • MariaDB MySQL Version Installed: 10.3.35
    • When was last time updated Centmin Mod code base ? : Few days ago
    • Persistent Config:
      MARCH_TARGETNATIVE='n'
      LETSENCRYPT_DETECT='y'
      DUALCERTS='y'
      Hello, I'll try to keep this short. I've been building a Wordpress site. Yesterday, nginx was failing to start and kept throwing errors about config files (which I haven't touched). It started randomly so I took down the post. Now it won't start again. I've attached the errors below. Do I have to do a clean install and migrate the data over? I appreciate any help you can provide.
      Starting Nginx:
      Starting nginx (via systemctl):  Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
        [FAILED]
      journalctl -xe:
      -- Unit nginx.service has begun starting up.
      Jun 17 12:52:42 mew nginx[2006]: Starting nginx: nginx: [emerg] duplicate location "/" in /usr/local/nginx/conf/conf.d/mew.com.conf:46
      Jun 17 12:52:42 mew systemd[1]: nginx.service: control process exited, code=exited status=1
      Jun 17 12:52:42 mew nginx[2006]: [FAILED]
      Jun 17 12:52:42 mew systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
      -- Subject: Unit nginx.service has failed
      -- Defined-By: systemd
      -- Unit nginx.service has failed.
      -- The result is failed.
      Jun 17 12:52:42 mew systemd[1]: Unit nginx.service entered failed state.
      Jun 17 12:52:42 mew systemd[1]: nginx.service failed.
      Jun 17 12:52:42 mew polkitd[559]: Unregistered Authentication Agent for unix-process:2000:12221 (system bus name :1.22, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
      Jun 17 12:52:42 mew polkitd[559]: Registered Authentication Agent for unix-process:2019:12237 (system bus name :1.23 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale
      Jun 17 12:52:42 mew systemd[1]: Stopping PHP FastCGI Process Manager...
      -- Subject: Unit php-fpm.service has begun shutting down
      -- Unit php-fpm.service has begun shutting down.
      Jun 17 12:52:42 mew systemd[1]: Stopped PHP FastCGI Process Manager.
      -- Subject: Unit php-fpm.service has finished shutting down
      -- Unit php-fpm.service has finished shutting down.
      Jun 17 12:52:42 mew systemd[1]: Starting PHP FastCGI Process Manager...
      -- Subject: Unit php-fpm.service has begun start-up
      -- Unit php-fpm.service has begun starting up.
      Jun 17 12:52:42 mew systemd[1]: Started PHP FastCGI Process Manager.
      -- Subject: Unit php-fpm.service has finished start-up
      -- Unit php-fpm.service has finished starting up.
      -- The start-up result is done.
      Jun 17 12:52:42 mew polkitd[559]: Unregistered Authentication Agent for unix-process:2019:12237 (system bus name :1.23, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
      Jun 17 13:38:15 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=42768 PROTO=TCP SPT=40028 DPT=9884 WINDOW=1
      Jun 17 13:38:20 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=45.61.187.156 DST=147.182.253.158 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=44999 DPT=5555 WINDOW=65
      Jun 17 13:38:39 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=34739 PROTO=TCP SPT=40028 DPT=8796 WINDOW=1
      Jun 17 13:39:33 mew kernel: Firewall: *UDP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=171.103.125.46 DST=147.182.253.158 LEN=46 TOS=0x00 PREC=0x00 TTL=48 ID=0 DF PROTO=UDP SPT=41689 DPT=8083 LEN=26
      Jun 17 13:39:39 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=79.124.62.82 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=55058 PROTO=TCP SPT=43343 DPT=4005 WINDOW=102
      Jun 17 13:39:46 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=185.196.220.27 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=54321 PROTO=TCP SPT=49668 DPT=8443 WINDOW=6
      Jun 17 13:39:46 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=124.220.182.242 DST=147.182.253.158 LEN=60 TOS=0x00 PREC=0x00 TTL=49 ID=57003 DF PROTO=TCP SPT=56660 DPT=8081 WINDO
      Jun 17 13:39:59 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=5.188.206.18 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=9471 PROTO=TCP SPT=51476 DPT=3538 WINDOW=1024
      Jun 17 13:40:01 mew systemd[1]: Started Session 15 of user root.
      -- Subject: Unit session-15.scope has finished start-up
      -- Unit session-15.scope has finished starting up.
      Jun 17 13:40:01 mew CROND[23237]: (root) CMD (/usr/lib64/sa/sa1 1 1)
      Jun 17 13:40:02 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=35674 PROTO=TCP SPT=40028 DPT=7197 WINDOW=1
      Jun 17 13:40:13 mew polkitd[559]: Registered Authentication Agent for unix-process:23268:297281 (system bus name :1.101 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, loca
      Jun 17 13:40:13 mew systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
      -- Subject: Unit nginx.service has begun start-up
      Jun 17 13:40:13 mew nginx[23274]: Starting nginx: nginx: [emerg] duplicate location "/" in /usr/local/nginx/conf/conf.d/mew.com.conf:46
      Jun 17 13:40:13 mew nginx[23274]: [FAILED]
      Jun 17 13:40:13 mew systemd[1]: nginx.service: control process exited, code=exited status=1
      Jun 17 13:40:13 mew systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
      Jun 17 13:40:13 mew systemd[1]: Unit nginx.service entered failed state.
      Jun 17 13:40:13 mew systemd[1]: nginx.service failed.
      Jun 17 13:40:13 mew polkitd[559]: Unregistered Authentication Agent for unix-process:23268:297281 (system bus name :1.101, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
      Jun 17 13:40:18 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=34663 PROTO=TCP SPT=40028 DPT=3213 WINDOW=1
      Jun 17 13:40:31 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=138.201.62.183 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=33145 PROTO=TCP SPT=55589 DPT=6443 WINDOW=1
      Jun 17 13:40:41 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=193.201.9.235 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=21357 PROTO=TCP SPT=43588 DPT=5545 WINDOW=10
      Jun 17 13:40:54 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=33700 PROTO=TCP SPT=40028 DPT=9995 WINDOW=1
      Jun 17 13:41:13 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=193.201.9.238 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=9838 PROTO=TCP SPT=43680 DPT=5938 WINDOW=102
      Jun 17 13:41:15 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=45.143.203.95 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=31367 PROTO=TCP SPT=40406 DPT=7890 WINDOW=10
      Jun 17 13:42:07 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=79.124.62.130 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=20727 PROTO=TCP SPT=43345 DPT=17012 WINDOW=1
      Jun 17 13:42:09 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=89.248.165.109 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=32307 PROTO=TCP SPT=40028 DPT=988 WINDOW=10
      Jun 17 13:42:09 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=79.124.62.82 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=19213 PROTO=TCP SPT=43343 DPT=55553 WINDOW=10
      Jun 17 13:42:14 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=79.124.62.82 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=52646 PROTO=TCP SPT=43343 DPT=24000 WINDOW=10
      Jun 17 13:42:14 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=193.201.9.237 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=28277 PROTO=TCP SPT=43637 DPT=5734 WINDOW=10
      Jun 17 13:42:57 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=79.124.62.34 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=20370 PROTO=TCP SPT=53879 DPT=2144 WINDOW=102
      Jun 17 13:43:07 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=192.241.213.164 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=251 ID=54321 PROTO=TCP SPT=60518 DPT=2000 WINDOW=
      Jun 17 13:43:28 mew kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=96:74:d4:e9:84:b4:fe:00:00:00:01:01:08:00 SRC=193.201.9.236 DST=147.182.253.158 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=22796 PROTO=TCP SPT=43605 DPT=5625 WINDOW=10
      systemctl status nginx.service:
      [12:54][root@mew ~]# systemctl status nginx.service
      ● nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
         Loaded: loaded (/etc/rc.d/init.d/nginx; bad; vendor preset: disabled)
         Active: failed (Result: exit-code) since Fri 2022-06-17 12:52:42 UTC; 2min 19s ago
        Process: 2006 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=1/FAILURE)
      Jun 17 12:52:42 mew systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
      nginx -t :
      I can't figure out what the issue is. For example, the duplicate location error. I would comment out the code and try again. Then it throws another error, and another one after I fix that. It threw errors about lines in the wpsecure conf file and php-wpsc. I've never touched these files so I don't know how something broke. The only thing I have done that I think could have possibly contributed to this was installing a WP Security plugin. I know that it modified my htaccess file, which I reverted back to the original with no success. Again I appreciate any help you can provide, this is very frustrating.
    48,899
    11,189
    8:45 AM
    clue is this your nginx vhost /usr/local/nginx/conf/conf.d/mew.com.conf has duplicate location / {} context configurations.
    You should ensure you only have one location / {} context. Centmin Mod nginx vhost created already have one configured so whatever rules you want to add should be added to the existing location / {} context rather than creating a 2nd copy of the location / {} context.
    48,899
    11,189
    8:45 AM
    Now one possible reason for duplication location / {} context that isn't your fault is if on Centmin Mod 123.09beta01 or newer i.e. 124.00stable or 130.00beta01, you may have ran into the new tools/autoprotect.sh cronjob feature outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community Your uploaded scripts may have .htaccess deny from all type files in their directories which may need bypassing autoprotect. In this case you may have a .htaccess in web root of your site i.e. at /home/nginx/domains/yourdomain.com/public/.htaccess. And autoprotect picks that up automatically to add an entry. In that case removing the /home/nginx/domains/yourdomain.com/public/.htaccess file and re-running tools/autoprotect.sh script manually should update that.
    It's a security feature that no other nginx based stack has as far as I know :)
    Check if your nginx vhost at either or both /usr/local/nginx/conf/conf.d/domain.com.conf and/or /usr/local/nginx/conf/conf.d/domain.com.ssl.conf has include file for autoprotect example
    include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
    see if your directory for the script which has issues is caught in an autoprotect include entry in /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf which has a deny all entry
    cat /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
    i.e.
    # /home/nginx/domains/domain.com/public/subdirectory/js
    location ~* ^/subdirectory/js/ { allow 127.0.0.1; deny all; }
    If caught you can whitelist it by autoprotect bypass .autoprotect-bypass file - details below here. So if problem js file is at domain.com/subdirectory/js/file.js then it is likely /subdirectory/js has a .htaccess with deny all in it - make sure that directory is meant to be publicly accessible by contacting author of script and if so, you can whitelist it and re-run autoprotect script to regenerate your /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf include file
    cd /home/nginx/domains/domain.com/public/subdirectory/js
    touch .autoprotect-bypass
    /usr/local/src/centminmod/tools/autoprotect.sh
    nprestart
    it maybe you need to also whitelist /subdirectory then it would be as follows creating bypass files at /home/nginx/domains/domain.com/public/subdirectory/.autoprotect-bypass and /home/nginx/domains/domain.com/public/subdirectory/js/.autoprotect-bypass
    nprestart
    then double check to see if updated /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf include file now doesn't show an entry for /subdirectory/js
