Nginx [nginx-announce] unit-1.9.0
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, May 31, 2019.
    47,833
    10,907
    9:16 PM
    In this release, we continue improving routing capabilities for more advanced
    and precise request matching. Besides that, the control API was extended with
    POST operations to simplify array manipulation in configuration.
    Please check the documentation about new features:
    - Matching rules: https://unit.nginx.org/configuration/#condition-matching
    - API operations: https://unit.nginx.org/configuration/#configuration-management
    If you prefer to perceive information visually, here's a recording of
    NGINX Meetup that gives a good overview of dynamic application routing,
    although doesn't discuss new features from this release:
    - https://www.youtube.com/watch?v=5O4TjbbxTxw
    Also, a number of annoying bugs were fixed; thanks to your feedback,
    the Node.js module now works fine with more applications.
    Changes with Unit 1.9.0 30 May 2019
    *) Feature: request routing by arguments, headers, and cookies.
    *) Feature: route matching patterns allow a wildcard in the middle.
    *) Feature: POST operation for appending elements to arrays in
    configuration.
    *) Feature: support for changing credentials using CAP_SETUID and
    CAP_SETGID capabilities on Linux without running main process as
    privileged user.
    *) Bugfix: memory leak in the router process might have happened when a
    client prematurely closed the connection.
    *) Bugfix: applying a large configuration might have failed.
    *) Bugfix: PUT and DELETE operations on array elements in configuration
    did not work.
    *) Bugfix: request schema in applications did not reflect TLS
    connections.
    *) Bugfix: restored compatibility with Node.js applications that use
    ServerResponse._implicitHeader() function; the bug had appeared in
    1.7.
    *) Bugfix: various compatibility issues with Node.js applications.
    With this release, packages for Ubuntu 19.04 "disco" are also available.
    See the website for a full list of available repositories:
    - https://unit.nginx.org/installation/
    Meanwhile, we continue working on WebSocket support. It's almost ready and
    has great chances to be included in the next release for Node.js and Java
    modules.
    Work on proxying and static files serving is also in progress; this will
    take a bit more time.
    wbr, Valentin V. Bartenev
    nginx-announce mailing list
    nginx-announce@nginx.org
