Nginx [nginx-announce] unit-1.6
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Nov 16, 2018.
    50,906
    11,799
    11:59 AM
    Hello,
    This release primarily focuses on improvements in Node.js module compatibility;
    thanks to our vibrant community, we made great progress here.
    Please don't hesitate to report any problems to:
    - Github: https://github.com/nginx/unit/issues
    - Mailing list: https://mailman.nginx.org/mailman/listinfo/unit
    If you have installed the "unit-http" module from npm, then don't forget to
    update it besides Unit itself.
    Detailed instructions for Node.js installation can be found here:
    - http://unit.nginx.org/installation/#node-js-package
    Changes with Unit 1.6 15 Nov 2018
    *) Change: "make install" now installs Node.js module as well if it was
    configured.
    *) Feature: "--local" ./configure option to install Node.js module
    locally.
    *) Bugfix: Node.js module might have crashed due to broken reference
    counting.
    *) Bugfix: asynchronous operations in Node.js might not have worked.
    *) Bugfix: various compatibility issues with Node.js applications.
    *) Bugfix: "freed pointer is out of pool" alerts might have appeared in
    log.
    *) Bugfix: module discovery didn't work on 64-bit big-endian systems
    like IBM/S390x.
    wbr, Valentin V. Bartenev
    nginx-announce mailing list
    nginx-announce@nginx.org
