Nginx [nginx-announce] unit-1.25.0
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Aug 20, 2021.
    55,400
    12,255
    2:55 AM
    This one is much awaited not only because the last one occurred quite some
    time ago, but also because it contains some sought-after features that were
    requested quite often.
    :: Obtaining The Originating Client IP Address ::
    When Unit operates behind a reverse proxy, it receives all incoming connections
    from a proxy machine address. As a result, the originating IP address of
    a client cannot be determined from the IP protocol. To overcome this, a
    special HTTP request header field can be used to carry the client IP address
    information over one to several proxies. Such header fields are usually called
    "X-Forwarded-For", but variations exist as well ("X-Real-IP", "X-Remote-Addr",
    etc..).
    Before, Unit could not use information from such header fields otherwise than
    just pass them on "as is." With this release, functionality similar to the
    real-ip nginx module became available. Now, in any listener object, you can
    specify a "client_ip" option, configuring trusted proxy addresses and the
    header field name, to obtain the client IP address:
    "listeners": {
    "*:80": {
    "client_ip": {
    "header": "X-Forwarded-For",
    "recursive": true,
    "source": [
    "10.0.0.0/8",
    "150.172.238.0/24"
    Unit will use the address obtained from this header to the same effect as if a
    direct connection was made from the client. For instance, it will be reflected
    in any logs, used for source address matching in routing, and provided to the
    application via a relevant request environment (e. g. $_SERVER['REMOTE_ADDR']
    in PHP).
    See more details in the documentation:
    - https://unit.nginx.org/configuration/#originating-ip-identification
    :: Control API to Restart Application Processes ::
    Unit dynamic configuration is pretty smart and granular. If it detects
    no changes to an application during reconfiguration, it won't touch the
    application's processes. However, sometimes our users need to restart a
    specific application, and the only good way to do that was to intentionally
    introduce a change to the application's configuration. Usually, a dummy
    "environment" option was used for this:
    curl -X PUT -d '"$RANDOM"' --unix-socket /var/run/control.unit.sock \
    /config/applications/<name>/environment/gen
    While it worked well, the solution can't be called elegant; it was more like a
    workaround. But now, Unit has a special section in the control API that allows
    restarting any configured application with a basic GET request:
    curl --unix-socket /var/run/control.unit.sock \
    /control/applications/<name>/restart
    See here for the details of app process management in Unit:
    - https://unit.nginx.org/configuration/#process-management
    :: TLS Sessions Cache and Tickets ::
    A full TLS handshake can be quite expensive; to save server resources and
    reduce latency in subsequent client connections, two ways are commonly used:
    TLS sessions cache and TLS session tickets. The main difference between the
    two is who stores the session information: the server (cache) or the client
    (tickets). Now, Unit allows you to configure either or both:
    "tls": {
    "certificate": "bundle",
    "session": {
    "cache_size": 10000,
    "timeout": 600,
    "tickets": true
    For tickets, it doesn't only allow enabling or disabling them; you can specify
    shared ticket keys between multiple servers and rotate them.
    See more sophisticated configurations in the docs:
    - https://unit.nginx.org/configuration/#ssl-tls-configuration
    We will proceed to improve the client-side protocol support to be on par with
    nginx in this regard or even go further. To be specific, HTTP/2 and HTTP/3
    are definitely on our shortlist.
    :: Ruby Process and Thread Start/Stop Hooks ::
    Earlier this year, one of our users opened a feature request on Unit's GitHub:
    https://github.com/nginx/unit/issues/535; we were asked to support hooks to be
    triggered on process or thread start/stop, as does another popular Ruby web
    server, Puma. These are usually used to instantiate a database connection or
    to perform some other initialization or cleanup work.
    A few months later, we've fulfilled the request. Here we go:
    - https://unit.nginx.org/configuration/#ruby
    That's why I always ask you not to hesitate and instead open a feature request
    for any crazy idea you may have on our GitHub issue tracker:
    - https://github.com/nginx/unit/issues
    We'd like to hear from you, we'd like to know your cases, your issues, anything
    you're struggling with or are missing and would want to see in Unit.
    Sure, not all requests are handled fast. There's plenty of them pending for
    years already. It's different case by case; sometimes, we're just busy with
    other important tasks, sometimes the feature depends on other missing parts,
    which also depend on other ones, and so on. Sometimes, it just takes a while
    to find a good solution, to design a good architecture, or to find a proper
    method of configuring something. Anyway, all your requests are collected and
    carefully examined; perhaps, it's your idea that will be implemented next.
    Please go and open a ticket if in doubt.
    The full changelog for the release:
    Changes with Unit 1.25.0 19 Aug 2021
    *) Feature: client IP address replacement from a specified HTTP header
    field.
    *) Feature: TLS sessions cache.
    *) Feature: TLS session tickets.
    *) Feature: application restart control.
    *) Feature: process and thread lifecycle hooks in Ruby.
    *) Bugfix: the router process could crash on TLS connection open when
    multiple listeners with TLS certificates were configured; the bug had
    appeared in 1.23.0.
    *) Bugfix: TLS connections were rejected for configurations with
    multiple certificate bundles in a listener if the client did not use
    SNI.
    *) Bugfix: the router process could crash with frequent multithreaded
    application reconfiguration.
    *) Bugfix: compatibility issues with some Python ASGI apps, notably
    based on the Starlette framework.
    *) Bugfix: a descriptor and memory leak occurred in the router process
    when an app process stopped or crashed.
    *) Bugfix: the controller or router process could crash if the
    configuration contained a full-form IPv6 in a listener address.
    *) Bugfix: the router process crashed when a request was passed to an
    empty "routes" or "upstreams" using a variable "pass" option.
    *) Bugfix: the router process crashed while matching a request to an
    empty array of source or destination address patterns.
    In the meantime, there are several other features currently at different stages
    of development and implementation:
    - Variable support in the static file serving options
    - Custom variables from regexp captures in the "match" object
    - Simple request rewrites using variables
    - More variables to access request and connection information
    - A statistics API
    - Unit CLI utility tool
    - App prototype processes to reduce memory usage, share the PHP opcache,
    and improve the handling of apps isolation
    - njs integration (https://nginx.org/en/docs/njs/index.html)
    - .NET Core language module prototype
    Some of them bound to appear in the next release. Stay tuned!
    wbr, Valentin V. Bartenev
    nginx-announce mailing list
    nginx-announce@nginx.org
