Nginx [nginx-announce] unit-1.23.0
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Mar 26, 2021.
    55,952
    6:20 PM
    Nowadays, TLS is everywhere, while plain HTTP is almost nonexistent in the
    global network. We are fully aware of this trend and strive to simplify TLS
    configuration in Unit as much as possible. Frankly, there's still much to do,
    but the introduction of smart SNI certificate selection marks yet another step
    in this direction.
    Perhaps, you already know about Unit's certificate storage API that uploads
    certificate bundles to a running instance. Otherwise, if you're not yet fully
    informed but still curious, here's a decent overview:
    - https://unit.nginx.org/configuration/#certificate-management
    Basically, you just upload a certificate chain and a key under some name; after
    that, you can specify the name ("mycert" in the example below) with any
    listening socket to configure it for HTTPS:
    "listeners": {
    "*:443": {
    "tls": {
    "certificate": "mycert"
    "pass": "routes"
    Unit's API also enables informative introspection of uploaded certificate
    bundles so you can monitor their validity and benefit from service discovery.
    You can also upload any number of certificate bundles to switch between them on
    the fly without restarting the server (yes, Unit's dynamic nature is exactly
    like that). Still, with this release, there are even more options, as you can
    supply any number of certificate bundle names with a listener socket:
    "certificate": [ "mycertA", "mycertB", ... ]
    For each client, Unit automatically selects a suitable certificate from the
    list depending on the domain name the client connects to (and therefore supplies
    via the "Server Name Indication" TLS extension). Thus, you don't even need to
    care about matching certificates to server names; Unit handles that for you.
    As a result, there's almost no room for a mistake, which spares more time for
    stuff that matters.
    As one can reasonably expect, you can always add more certs, delete them, or
    edit the cert list on the fly without compromising performance.
    That's the Unit way!
    In case you're wondering whom to thank for this shiny new feature: give a
    warm welcome to Andrey Suvorov, a new developer on our team. He will continue
    working on TLS improvements in Unit, and his TODO list is already stacked.
    Still, if you'd like to suggest a concept or have a particular interest in
    some feature, just start a ticket on GitHub; we are open to your ideas:
    - https://github.com/nginx/unit/issues
    Also, plenty of solid bug fixing work was done by the whole team. See the full
    change log below:
    Changes with Unit 1.23.0 25 Mar 2021
    *) Feature: support for multiple certificate bundles on a listener via
    the Server Name Indication (SNI) TLS extension.
    *) Feature: "--mandir" ./configure option to specify the directory for
    man page installation.
    *) Bugfix: the router process could crash on premature TLS connection
    close; the bug had appeared in 1.17.0.
    *) Bugfix: a connection leak occurred on premature TLS connection close;
    the bug had appeared in 1.6.
    *) Bugfix: a descriptor and memory leak occurred in the router process
    when processing small WebSocket frames from a client; the bug had
    appeared in 1.19.0.
    *) Bugfix: a descriptor leak occurred in the router process when
    removing or reconfiguring an application; the bug had appeared in
    1.19.0.
    *) Bugfix: persistent storage of certificates might've not worked with
    some filesystems in Linux, and all uploaded certificate bundles were
    forgotten after restart.
    *) Bugfix: the controller process could crash while requesting
    information about a certificate with a non-DNS SAN entry.
    *) Bugfix: the controller process could crash on manipulations with a
    certificate containing a SAN and no standard name attributes in
    subject or issuer.
    *) Bugfix: the Ruby module didn't respect the user locale for defaults
    in the Encoding class.
    *) Bugfix: the PHP 5 module failed to build with thread safety enabled;
    the bug had appeared in 1.22.0.
    Other notable features we are working on include:
    - statistics API
    - process control API
    - chrooting on a per-request basis during static file serving
    - MIME types filtering for static files
    - configuring ciphers and other OpenSSL settings
    So much more to come!
    Also, if you'd like to know more about Unit and prefer watching fun videos
    instead of reading tedious documentation, I'm happy to recommend Timo Stark,
    our own PM Engineer. Recently, he started regularly streaming on Twitch and
    YouTube:
    - https://www.twitch.tv/h30ne
    - https://www.youtube.com/Tippexs91
    Tomorrow (March 26), at 10 p.m. CET (or 2 p.m. PDT), he is going on air to
    livestream his using Unit's brand-new SNI feature to automate the certbot
    setup:
    - https://youtu.be/absaan-8y1Q
    Everyone is welcome!
    wbr, Valentin V. Bartenev
    nginx-announce mailing list
    nginx-announce@nginx.org
