Nginx [nginx-announce] unit-1.18.0
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, May 29, 2020.
    54,931
    12,240
    5:38 AM
    This release includes a few internal routing improvements that simplify some
    configurations and a new isolation option for chrooting application processes
    called "rootfs".
    Changes with Unit 1.18.0 28 May 2020
    *) Feature: the "rootfs" isolation option for changing root filesystem
    for an application.
    *) Feature: multiple "targets" in PHP applications.
    *) Feature: support for percent encoding in the "uri" and "arguments"
    matching options and in the "pass" option.
    Also, our official packages for the recently released Ubuntu 20.04 (Focal Fossa)
    are available now:
    - https://unit.nginx.org/installation/#ubuntu
    At least two of the features in this release deserve special attention.
    Changing The Root Filesystem
    Security is our top priority, so let's look closer at the "rootfs"
    option first.
    The coolest thing about it is that it's not just a simple chroot() system
    call as some may expect. It's not a secret that chroot() is not intended
    for security purposes, and there's plenty of ways for an attacker to get out
    of the chrooted directory (just check "man 2 chroot"). That's why on modern
    systems Unit can use pivot_root() with the "mount" namespace isolation
    enabled, which is way more secure and pretty similar to putting your
    application in an individual container.
    Also, our goal is to make any security option as easy to use as possible.
    In this case, Unit automatically tries to mount all the necessary
    language-specific dependencies inside a new root, so you won't need
    to care about them. Currently, this capability works for selected languages
    only, but the support will be extended in the next releases.
    For more information and examples of "rootfs" usage, check the documentation:
    - https://unit.nginx.org/configuration/#process-isolation
    Now to the second feature...
    Multiple PHP application "targets"
    The other major update in this release is called "targets", aiming to simplify
    configuration for many PHP applications. Perhaps, it is best illustrated by an
    example: WordPress. This is one of many applications that use two different
    addressing schemes:
    1. Most user requests are handled by index.php regardless of the actual
    request URI.
    2. Administration interface and some components rely on direct requests
    to specific .php scripts named in the URI.
    Earlier, users had to configure two Unit applications to handle this disparity:
    "wp_index": {
    "type": "php",
    "user": "wp_user",
    "group": "wp_user",
    "root": "/path/to/wordpress/",
    "script": "index.php"
    "wp_direct": {
    "type": "php",
    "user": "wp_user",
    "group": "wp_user",
    The first app directly executes the .php scripts named by the URI, whereas the
    second one passes all requests to index.php.
    Now, you can use "targets" instead:
    "wp": {
    "type": "php",
    "user": "wp_user",
    "group": "wp_user",
    "targets": {
    "index": {
    "direct": {
    The complete example is available in our WordPress howto:
    - https://unit.nginx.org/howto/wordpress/
    You can configure as many "targets" in one PHP application as you want, routing
    requests between them using various sophisticated request matching rules.
    Check our website to know more about the new option:
    - https://unit.nginx.org/configuration/#targets
    To learn more about request matching rules:
    - https://unit.nginx.org/configuration/#condition-matching
    Finally, see here for more howtos:
    We have plenty of them, covering many popular web applications and frameworks,
    but if your favorite one is still missing, let us know by opening a ticket here:
    - https://github.com/nginx/unit-docs/issues
    To keep the finger on the pulse, refer to our further plans in the roadmap here:
    - https://github.com/orgs/nginx/projects/1
    Stay tuned!
    wbr, Valentin V. Bartenev
    nginx-announce mailing list
    nginx-announce@nginx.org
