Nginx [nginx-announce] nginx-1.9.11
Discussion in 'Nginx and PHP-FPM news & discussions' started by eva2000, Feb 10, 2016.
    4,128
    1:51 AM
    Wondering with latest Centminmod code for how long about the site is going down for upgrade Nginx and how long for php?
    60,063
    12,574
    8:51 AM
    what do you mean down ? you mean how long nginx and php upgrade times ? depends on your server speed for length of update time
    it's own down for moment your restart nginx and php after update
  3. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    12:51 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    It is disabled like it was before last recompiling.
    Should I enable it (uncomment) and restart nginx to see what will be?
    limit_req_zone $binary_remote_addr zone=xwplogin:16m rate=40r/m;
    #limit_conn_zone $binary_remote_addr zone=xwpconlimit:16m;
    more_set_headers "Server: nginx centminmod";
    more_set_headers "X-Powered-By: centminmod";
    include /usr/local/nginx/conf/vts_http.conf;
    #include /usr/local/nginx/conf/maintenance.conf;
    include /usr/local/nginx/conf/fastcgi_param_https_map.conf
    60,063
    12,574
    8:51 AM
    yes please
  5. pamamolf
    4,128
    1:51 AM
    For how long the website will not work during the upgrade until it ends...(on a high end server about)
    60,063
    12,574
    8:51 AM
    normal it's just down for the service restart command.
    i just added 503 maintenance mode support optionally to php, nginx upgrades too https://community.centminmod.com/posts/26485/ so 503 maintenance mode will be as long as entire nginx or php upgrade duration if you enable those 3 variables
  7. BobbyWibowo
    BobbyWibowo Active Member
    197
    42
    Indonesia
    5:51 AM
    1.17.x
    10.3.x
    Although I suppose it's not really necessary since the site will only be down during the restart, right? As far as my experience goes, restarting nginx and php only takes like 1 to 3 seconds.
    On a side note, any update about 1.9.11 with PageSpeed enabled?
    60,063
    12,574
    8:51 AM
    yeah no necessary
    still same ngx_pagespeed 1.10.33.5 isn't coming until next Tuesday AFAIK
    added openresty headers more nginx module dynamic module support optionally via pulling headers more github master code https://community.centminmod.com/posts/26505/
    also did same for openresty echo nginx module https://community.centminmod.com/posts/26509/ and set-misc module https://community.centminmod.com/posts/26514/
  9. rdan
    6:51 AM
    What if I don't want this maintenance mode Eva?
    How can disable it always?
    Thanks!
  10. BobbyWibowo
    197
    42
    Indonesia
    5:51 AM
    1.17.x
    10.3.x
    @RoldanLT AFAIK it's disabled by default.
  11. Sunka
    1,150
    325
    Pula, Croatia
    12:51 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    same error.
    Will update centmin now to include last 12 hours updates, recompile nginx again and try then to uncomment that line
    60,063
    12,574
    8:51 AM
    yeah it's disabled by default, doesn't enable unless you type
    sitestatus off
    yup
  13. Sunka
    1,150
    325
    Pula, Croatia
    12:51 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Now nginx restarted OK with uncommented line for maintenance.conf (y)
