Install Nginx and php not installed on a fresh installation.
Discussion in 'Install & Upgrades or Pre-Install Questions' started by jellday, Jun 17, 2019.
  1. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    Fresh installation of using one line command:
    yum -y update; curl -O https://centmin.com/installer.sh && chmod 0700 installer.sh && bash installer.sh
    • CentOS Version: CentOS 6.8 64bit ?
    Check Nginx Version:
    inc/centminfinish.inc: line 49: nginx: command not found
    Check PHP-FPM Version:
    inc/centminfinish.inc: line 55: php: command not found
    Check mysqlreport version:
    inc/centminfinish.inc: line 102: /root/mysqlreport: No such file or directory
    Check NSD Bind Version:
    inc/centminfinish.inc: line 108: nsd: command not found
    Log file:
    Ubuntu Pastebin
    Please help. VPS is from Baidu
    41,646
    9,380
    8:25 AM
    123.09bet01 or 123.08stable you stated 123.09beta01 but log shows 123.08stable ?
    B[m[1;32;40m* Centmin Mod Nginx, MariaDB MySQL, PHP & DNS Install script for CentOS
    (B[m[1;32;40m* Version: 1.2.3-eva2000.08 - Date: 31/07/2015
    (B[m[1;32;40m* Copyright 2011-2015 CentminMod.com eva2000 (vbtechsupport.com)
    (B[m[1;33;40m**********************************************************************
    failed php download too due to corrupted php-5.5.38.tar.gz
    [1;33;40mDownload done.
    (B[m[1;33;40mecho-nginx-module_v0.60.tar.gz valid file.
    (B[m
    [1;33;40mDownload redis2-nginx-module_v0.13.tar.gz ...
    (B[m[1;32;40mredis2-nginx-module_v0.13.tar.gz Archive found, skipping download...
    (B[m[1;33;40mredis2-nginx-module_v0.13.tar.gz valid file.
    (B[m
    [1;33;40mDownload php-5.5.38.tar.gz ...
    (B[mwget -cnv --no-dns-cache -4 --progress=bar https://www.php.net/distributions/php-5.5.38.tar.gz -O php-5.5.38.tar.gz --tries=3
    2019-06-17 10:23:18 URL:https://www.php.net/distributions/php-5.5.38.tar.gz [2440956] -> "php-5.5.38.tar.gz" [1]
    (B[m
    gzip: stdin: unexpected end of file
    tar: Unexpected EOF in archive
    tar: Error is not recoverable: exiting now
    [1;32;40mError: php-5.5.38.tar.gz extraction failed.
    (B[mcheck Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    123.08stable installs libressl by default and that failed to download too which means nginx will fail to install
    net.ipv4.tcp_challenge_ack_limit = 999999999
    [1;32;40mInstalling nginx Modules / Prerequisites...
    (B[mCompiling LibreSSL...
    inc/openssl_install.inc: line 67: cd: libressl-2.8.3: No such file or directory
    Loaded plugins: priorities, security, versionlock
    Setting up Install Process
    any reason using 123.08stable instead of 123.09beta01 ?
    as per Centmin Mod LEMP Stack Install Nginx on CentOS
    123.09beta01 installer command
    and CentOS 7 recommended ;)
  3. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    Thank you for the reply. I used the wrong command so I thought I installed the beta version.
    Still the same problem with CentOS 7.5 installed and using the 123.09beta01 installer command.
    log file
    Ubuntu Pastebin
    41,646
    9,380
    8:25 AM
    is this exact same server or different server for latest run as i still see failed downloads which could be specific to your servers network connectivity
    failed php download
    [1;32;40mError: php-5.6.40.tar.gz download failed.
    (B[m
    failed or corrupted openssl 1.1.1c download
    Compiling OpenSSL...
    OPENSSL_CFZLIB_OPT =
    OPENSSL_CFZLIB_RPATH =
    tar (child): openssl-1.1.1c.tar.gz: Cannot open: No such file or directory
    tar (child): Error is not recoverable: exiting now
    tar: Child returned status 2
    inc/openssl_install.inc: line 892: cd: /svr-setup/openssl-1.1.1c: No such file or directory
    failed openssl 1.1.1c download will prevent nginx from compiling
    make -f objs/Makefile install
    make[1]: Entering directory `/svr-setup/nginx-1.17.0'
    cd ../ \
    && if [ -f Makefile ]; then make clean; fi \
    && ./config --prefix=/svr-setup/nginx-1.17.0/..//.openssl no-shared no-threads  \
    && make \
    && make install_sw LIBDIR=lib
    /bin/sh: line 2: ./config: No such file or directory
    make[1]: *** [..//.openssl/include/openssl/ssl.h] Error 127
    make[1]: Leaving directory `/svr-setup/nginx-1.17.0'
    make: *** [install] Error 2
    i noticed 123.09beta01's china geographic location check being triggered to download mariadb yum repo from chinese mirror for better speed, so this server is located in china ? it could be it has network connectivity issues outside of china for some of the downloads
    [1;32;40m* Installing MariaDB via CentOS Yum Repo
    (B[m*************************************************
    MariaDB 10.3 Repo setup...
    rpm --import https://mirrors.tuna.tsinghua.edu.cn/mariadb/yum//RPM-GPG-KEY-MariaDB
    but because php and openssl 1.1.1c download failures, nginx and php-fpm didn't build properly
    can you post output for below commands from your problematic server and wrap output in CODE bbcode tags
    curl -Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    curl -4Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    curl -6Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    curl -Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    curl -Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    cd /svr-setup
    rm -f php-5.6.40.tar.gz openssl-1.1.1c.tar.gz
    axel -4v https://www.php.net/distributions/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    axel -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    wget -4v https://www.php.net/distributions/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    wget -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
    and see from my local mirrors to see if for china detected servers if using centminmod local mirrors is better than official mirror download links
    cd /svr-setup
    axel -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    axel -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    wget -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    wget -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
  5. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    Yes, it is in China, the same server.
    [11:16][[email protected] ~]# curl -Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    * About to connect() to www.openssl.org port 443 (#0)
    *   Trying 104.76.133.237...
    * Connection timed out
    *   Trying 2600:140e:6:39d::c1e...
    * Failed to connect to 2600:140e:6:39d::c1e: Network is unreachable
    *   Trying 2600:140e:6:3bc::c1e...
    * Failed to connect to 2600:140e:6:3bc::c1e: Network is unreachable
    * Failed connect to www.openssl.org:443; Network is unreachable
    * Closing connection 0
    curl: (7) Failed to connect to 2600:140e:6:39d::c1e: Network is unreachable
    [11:16][[email protected] ~]# curl -4Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    * Failed connect to www.openssl.org:443; Connection timed out
    curl: (7) Failed connect to www.openssl.org:443; Connection timed out
    [11:17][[email protected] ~]# curl -6Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    *   Trying 2600:1417:76:18c::c1e...
    * Failed to connect to 2600:1417:76:18c::c1e: Network is unreachable
    *   Trying 2600:1417:76:197::c1e...
    * Failed to connect to 2600:1417:76:197::c1e: Network is unreachable
    * couldn't connect to host at www.openssl.org:443
    curl: (7) Failed to connect to 2600:1417:76:18c::c1e: Network is unreachable
    [11:17][[email protected] ~]# curl -Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    * About to connect() to www.php.net port 443 (#0)
    *   Trying 119.81.61.41...
    * Connected to www.php.net (119.81.61.41) port 443 (#0)
    * Initializing NSS with certpath: sql:/etc/pki/nssdb
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    * Server certificate:
    *    subject: CN=*.php.net
    *    start date: May 24 00:00:00 2019 GMT
    *    expire date: May 23 12:00:00 2021 GMT
    *    common name: *.php.net
    *    issuer: CN=Thawte TLS RSA CA G1,OU=www.digicert.com,O=DigiCert Inc,C=US
    > HEAD /distributions/php-5.6.40.tar.xz HTTP/1.1
    > User-Agent: curl/7.29.0
    > Host: www.php.net
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Server: myracloud
    Server: myracloud
    < Date: Fri, 21 Jun 2019 11:27:15 GMT
    < Content-Type: application/x-xz
    < Connection: keep-alive
    < Last-Modified: Thu, 10 Jan 2019 08:00:10 GMT
    < ETag: "be4fac-57f15f7ae7680"
    < X-CDN: 1
    X-CDN: 1
    * Connection #0 to host www.php.net left intact
    [11:27][[email protected] ~]# curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.xz
      CApath: none
    > Host: www.php.net
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Server: myracloud
    Server: myracloud
    < Date: Fri, 21 Jun 2019 11:27:18 GMT
    < X-CDN: 1
    X-CDN: 1
    [11:27][[email protected] ~]# curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    *   Trying 2a02:cb40:200::1ad...
    * Failed to connect to 2a02:cb40:200::1ad: Network is unreachable
    * couldn't connect to host at www.php.net:443
    curl: (7) Failed to connect to 2a02:cb40:200::1ad: Network is unreachable
    [02:39][[email protected] ~]# cd /svr-setup
    [02:39][[email protected] svr-setup]# rm -f php-5.6.40.tar.gz openssl-1.1.1c.tar.gz
    [02:39][[email protected] svr-setup]# axel -4v https://www.php.net/distributions/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    Initializing download: https://www.php.net/distributions/php-5.6.40.tar.gz
    File size: unavailable
    Opening output file php-5.6.40.tar.gz
    Server unsupported, starting from scratch with one connection.
    Starting download
    [ N/A]  .......... .......... .......... .......... ..........  [  11.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  21.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  29.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  16.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  10.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   9.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   6.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   5.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   5.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   4.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   4.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   4.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   4.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   3.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [   2.2KB/s]
    [ N/A]  .......... .
    Connection 0 finished
    Downloaded 911.8 Kilobyte in 6:50 minute(s). (2.24 KB/s)
    [02:46][[email protected] svr-setup]# axel -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    Initializing download: https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    File size: 8864262 bytes
    Opening output file openssl-1.1.1c.tar.gz
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  57.4KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [  98.3KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 129.7KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 149.6KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 188.1KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 196.8KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 221.9KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 256.0KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 284.5KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 283.1KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 309.4KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 344.9KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 367.2KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 391.3KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 417.3KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 443.6KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 408.0KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 435.1KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 456.1KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 478.7KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 509.2KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 531.8KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 552.8KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 575.4KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 595.5KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 564.6KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 581.7KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 605.0KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 629.0KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 647.9KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 651.6KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 669.9KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 698.0KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 712.6KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 687.2KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 702.8KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 724.0KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 746.2KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 763.3KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [ 764.6KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 789.0KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 798.4KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 815.0KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 832.8KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 850.9KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 868.4KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [ 867.6KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 883.7KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 908.4KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 924.5KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 941.9KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [ 934.8KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 937.8KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 907.7KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 923.4KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 936.8KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 954.9KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 973.9KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [ 988.5KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1004.3KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1025.6KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1041.4KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1047.1KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1009.3KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1024.4KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1038.9KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1006.8KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1020.0KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1034.1KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1053.2KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1067.4KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1080.5KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1094.7KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1109.0KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1127.9KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1139.9KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1156.2KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [1173.1KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1186.3KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1199.7KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1212.9KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1146.9KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1159.1KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1171.5KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [1177.3KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1192.3KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1208.0KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1210.7KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1212.2KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1229.5KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1207.3KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [1218.9KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1231.4KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1244.1KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1244.0KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1233.0KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [1244.3KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1237.5KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1248.5KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1260.4KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1271.4KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1283.2KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1299.2KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [1311.1KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1321.1KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1245.6KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1258.9KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1269.2KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1280.2KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1295.2KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [1306.3KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1316.6KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1327.6KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1338.9KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1349.8KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [1363.0KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1373.3KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1384.4KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1399.3KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1410.4KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1420.7KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1431.7KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [1443.0KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1457.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1467.1KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1479.9KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1493.2KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1493.7KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1497.2KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [1504.0KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1516.1KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1526.2KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1537.1KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1548.1KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1546.1KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1506.0KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [1515.6KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [1526.1KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [1540.1KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [1550.6KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [1560.2KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [1570.7KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [1581.2KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [1376.4KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [1384.0KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [1392.3KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [1405.2KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [1413.5KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [1422.5KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [1430.8KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [1439.8KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [1452.0KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [1461.0KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [1468.6KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [1479.0KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [1489.8KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [1498.1KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [1507.1KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [1519.3KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [1528.2KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [1536.6KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [1545.6KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [1554.7KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [1563.6KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [1574.3KB/s]
    [ 95%]  .......... .......... .......... .......... ........
    Connection 2 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,..  [1583.3KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [1592.6KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [1601.4KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [1613.4KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [1620.1KB/s]
    [ 98%]  .......... .
    Connection 3 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, .......... ..........  [1629.9KB/s]
    [ 98%]  .......... .......... .......... ...
    Connection 1 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,....... ..........  [1412.8KB/s]
    [ 99%]  .......... .......... .......... .......... ..........  [1374.4KB/s]
    [ 99%]  ......
    Downloaded 8.5 Megabyte in 6 seconds. (1374.84 KB/s)
    [02:46][[email protected] svr-setup]# wget -4v https://www.php.net/distributions/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    --2019-06-23 02:46:24--  https://www.php.net/distributions/php-5.6.40.tar.gz
    Resolving www.php.net... 119.81.61.41
    Connecting to www.php.net|119.81.61.41|:443... connected.
    Length: unspecified [application/x-gzip]
    Saving to: ‘php-5.6.40.tar.gz’
    php-5.6.40.tar.gz                                        [                                            <=>        ]  11.20M  39.0KB/s    in 8m 12s
    2019-06-23 02:54:39 (23.3 KB/s) - Read error at byte 11745281 (Connection reset by peer).Retrying.
    --2019-06-23 02:54:40--  (try: 2)  https://www.php.net/distributions/php-5.6.40.tar.gz
    php-5.6.40.tar.gz                                        [        <=>                                       ]   7.37M  13.5KB/s    in 5m 17s
    2019-06-23 02:59:59 (23.8 KB/s) - Read error at byte 11745281 (Connection reset by peer).Retrying.
    --2019-06-23 03:00:01--  (try: 3)  https://www.php.net/distributions/php-5.6.40.tar.gz
    php-5.6.40.tar.gz                                        [        <=>                                          ]   5.45M  6.36KB/s    in 5m 13s
    2019-06-23 03:05:17 (17.8 KB/s) - Read error at byte 11745281 (Connection reset by peer).Retrying.
    --2019-06-23 03:05:20--  (try: 4)  https://www.php.net/distributions/php-5.6.40.tar.gz
    php-5.6.40.tar.gz                                        [        <=>                                    ]   1.20M   364 B/s    in 17m 20s
    2019-06-23 03:22:54 (1.18 KB/s) - ‘php-5.6.40.tar.gz’ saved [11745281]
    [03:22][[email protected] svr-setup]# wget -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
    --2019-06-23 03:22:54--  https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    Resolving www.openssl.org... 23.76.86.50
    Connecting to www.openssl.org|23.76.86.50|:443... connected.
    Length: 8864262 (8.5M) [application/x-gzip]
    Saving to: ‘openssl-1.1.1c.tar.gz’
    openssl-1.1.1c.tar.gz                                100%[===================================================================================================================>]   8.45M   905KB/s    in 11s
    [04:36][[email protected] svr-setup]# rm -f php-5.6.40.tar.gz openssl-1.1.1c.tar.gz
    wget -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz[04:36][[email protected] svr-setup]# axel -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    Initializing download: https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz
    File size: 19305795 bytes
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  61.1KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 115.6KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 124.2KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 161.9KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 189.9KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 223.9KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 253.4KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 278.6KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 300.2KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 330.8KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 357.9KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 384.1KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 412.6KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 436.8KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 463.2KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 433.9KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 457.0KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 481.4KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 461.5KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 479.8KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 500.2KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 512.9KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 528.4KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 468.9KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 489.9KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 507.2KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 528.3KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 544.1KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 568.4KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 582.5KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 600.6KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 620.1KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 638.8KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 656.8KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 673.8KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 655.5KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 672.0KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 684.3KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 698.8KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 711.6KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 724.7KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 739.7KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 752.3KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 761.7KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 769.4KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 788.2KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 791.2KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 804.9KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 814.7KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 824.0KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 838.4KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 850.1KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 864.9KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 810.9KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 762.9KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 776.1KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 788.4KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 801.1KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 814.3KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 827.5KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 841.8KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 859.4KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 871.5KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 884.7KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 897.9KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 911.6KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 924.2KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 937.4KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 955.0KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 964.9KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 981.9KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 995.1KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1008.3KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1020.4KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1035.2KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1047.3KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1064.8KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1078.0KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1091.2KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1104.9KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1118.7KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1130.7KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1148.3KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1158.2KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1171.4KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1188.9KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1180.4KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1192.2KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1207.3KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1220.3KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1232.1KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1249.9KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1258.6KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1275.8KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1288.8KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1301.2KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1313.6KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1327.6KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1340.0KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1352.9KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1370.2KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1382.6KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1396.6KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1409.0KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1421.9KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1434.3KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1394.5KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1406.1KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1417.3KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1432.6KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1443.9KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1456.7KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1466.6KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1477.6KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1490.0KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1502.0KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1516.3KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1526.8KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1537.6KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1549.9KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1561.7KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1571.8KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1582.5KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1597.6KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1605.8KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1621.0KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1630.9KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1641.2KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1652.9KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1665.4KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1674.7KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1685.5KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1700.1KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1709.3KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1723.5KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1732.9KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1743.7KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1754.8KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1766.8KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1776.1KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1790.2KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1800.3KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1812.3KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1824.0KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1832.9KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1843.2KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1855.3KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1827.6KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1841.4KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1850.3KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1861.2KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1870.3KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1879.9KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1890.6KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1901.2KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1910.4KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1919.0KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1932.8KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1943.5KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1953.9KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1962.9KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1972.4KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1984.0KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1993.9KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2007.2KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2015.7KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2024.6KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2035.6KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2045.6KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2054.9KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2063.8KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2077.2KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2084.9KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2097.6KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2106.0KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2116.4KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2127.5KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2137.0KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2146.9KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2155.7KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2046.3KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2054.3KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2068.7KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2078.6KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2086.6KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2096.9KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2108.5KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2118.9KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2133.2KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2144.0KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2154.7KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2157.2KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2167.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2173.6KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2184.2KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2195.8KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2210.1KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2219.9KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2230.6KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2241.3KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2242.5KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2253.5KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2261.6KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2275.7KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2282.8KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2297.0KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2307.6KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2318.2KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2327.9KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2339.4KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2350.0KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2360.7KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2374.8KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2384.6KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2396.1KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2316.2KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2326.3KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2336.6KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2347.2KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2357.4KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2367.6KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2381.2KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2390.6KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2402.0KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2411.4KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2421.6KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2431.8KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2442.9KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2456.5KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2465.8KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2476.4KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2485.8KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2496.8KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2507.1KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2517.2KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2530.9KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2537.7KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2551.3KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2561.5KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2571.7KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2581.1KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2591.6KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2601.8KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2612.8KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2626.4KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2635.8KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2646.0KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2656.2KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2667.2KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2676.2KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2686.8KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2697.0KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2707.6KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2721.2KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2730.5KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2741.1KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2750.9KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2761.1KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2771.3KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2782.8KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2796.4KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2805.7KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2815.8KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2825.2KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2837.1KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2846.8KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2856.2KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [2869.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [2877.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [2888.0KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [2901.6KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [2910.5KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [2920.8KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [2932.6KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [2941.9KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [2955.5KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [2964.8KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [2973.3KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [2986.5KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [2995.8KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [3006.0KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [3015.7KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [2997.7KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3007.3KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3020.8KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3031.3KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3041.0KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3051.0KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3061.1KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3071.6KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3081.2KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3091.7KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3105.1KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3114.7KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3124.8KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3134.0KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3145.8KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3155.4KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3165.5KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3178.5KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3186.1KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3199.1KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3209.6KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3218.4KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3228.1KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3239.4KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3249.1KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3262.5KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3272.5KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3282.2KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3288.9KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3298.4KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3307.2KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3315.2KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3326.5KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3337.0KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3350.0KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3359.6KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3369.2KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,.... .......... ..........  [3379.7KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3389.7KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3399.4KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3410.3KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3419.5KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3432.7KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3442.7KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3452.8KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3462.8KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3472.9KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3483.4KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3493.4KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3505.7KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3515.8KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3525.8KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3535.9KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3546.0KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3556.0KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3566.5KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3576.5KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3588.4KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3598.4KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3608.5KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3618.6KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3630.5KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3640.5KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3650.6KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3661.0KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3671.1KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3681.1KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,........ .......... ..........  [3692.1KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3702.2KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3713.5KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3724.4KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3733.5KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3744.4KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3755.7KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3765.7KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3775.7KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [3785.8KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [3797.9KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [3807.1KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3817.9KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3731.1KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3739.3KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,.........  [3749.2KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3760.2KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3769.5KB/s]
    [ 97%]  .
            ,......... .......... .......... .......... ..........  [3290.0KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3283.4KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3269.4KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3210.7KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,....... .......... ..........  [3151.0KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3143.0KB/s]
    [ 99%]  .......... .......... .......... .......... ..........  [3132.8KB/s]
    [ 99%]  .......... .......... .......... .......... ..........  [3138.3KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,.......  [2722.2KB/s]
    [100%]  .......... .......... .......... .......... ..........  [2636.6KB/s]
    [100%]  ...
    Downloaded 18.4 Megabyte in 7 seconds. (2636.76 KB/s)
    [04:36][[email protected] svr-setup]# axel -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    Initializing download: https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  57.5KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [  91.9KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 131.8KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 153.5KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 188.5KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 216.9KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 251.7KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 280.0KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 303.0KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 289.7KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 320.9KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 339.4KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 363.0KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 388.9KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 409.6KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 433.0KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 461.9KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 489.7KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 509.2KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 531.6KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 557.0KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 580.2KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 597.2KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 595.6KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 607.8KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 632.1KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 650.3KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 669.4KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 689.8KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 707.1KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 725.6KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 663.8KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 691.2KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 709.4KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 725.3KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 738.0KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 756.6KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 773.7KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 788.3KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [ 807.3KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 809.7KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 834.8KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 852.1KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 863.6KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 881.6KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 901.1KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [ 919.0KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 938.5KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 957.9KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 982.1KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 956.3KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [ 966.0KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 983.4KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1001.1KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1016.6KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1038.2KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1052.4KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1068.4KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1085.2KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1102.2KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1117.7KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1132.4KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1149.8KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1166.5KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1186.5KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1200.4KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1202.8KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1219.9KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1217.8KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1226.7KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1243.0KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1262.9KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1274.0KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1292.9KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1307.1KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1323.0KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1338.2KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [1351.7KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1365.5KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1380.5KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1396.9KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1415.9KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1430.4KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1442.5KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [1457.3KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1473.6KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1488.1KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1504.7KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1517.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1531.1KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1549.9KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [1563.4KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1476.5KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1492.0KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1507.1KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1521.6KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [1535.8KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1547.2KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1566.6KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1580.4KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1590.1KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1605.0KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1621.3KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [1635.0KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1649.3KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1664.2KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1679.2KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1691.1KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1703.6KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1717.8KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [1732.2KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1743.3KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1755.7KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1770.5KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1777.8KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [1791.3KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1807.9KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1723.0KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1735.7KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1754.3KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1764.2KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1778.7KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [1797.2KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1809.9KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1822.7KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1838.4KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1852.9KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1865.7KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1884.2KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [1894.7KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1912.6KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1926.6KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1939.9KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1952.6KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1968.3KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1982.2KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [1996.1KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [2014.6KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [2027.4KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [2042.5KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [2056.4KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [2070.3KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [2083.1KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [2098.1KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [2112.0KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [2130.5KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [2144.4KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [2157.1KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [2172.2KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [2186.1KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [2200.0KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [2218.5KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [2227.8KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [2242.3KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [2260.2KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [2274.1KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [2286.8KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [2301.9KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [2315.8KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [2331.4KB/s]
    [ 92%]  .......... .
            ,,,,,,,,,, ,......... .......... .......... ..........  [2342.2KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [2350.8KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [2359.2KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,........ ..........  [2370.6KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [2386.1KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [2401.7KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [2413.7KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ..........  [2006.3KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [1936.0KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [1849.1KB/s]
            ,,,,,,,,,, ,,,,,,.... .......... .......... ..........  [1859.3KB/s]
            ,,,,,,,,,, ,,,,,,,,,. .......... .......... ..........  [1683.8KB/s]
    [ 99%]  .......... .......... .......... .......... ..........  [1562.1KB/s]
    [ 99%]  ......
    Downloaded 8.5 Megabyte in 5 seconds. (1549.06 KB/s)
    [04:36][[email protected] svr-setup]# wget -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    --2019-06-23 04:36:29--  https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz
    Resolving centminmod.com... 104.20.230.85, 104.20.231.85
    Connecting to centminmod.com|104.20.230.85|:443... connected.
    Length: 19305795 (18M) [application/octet-stream]
    php-5.6.40.tar.gz                                    100%[===================================================================================================================>]  18.41M  5.81MB/s    in 3.2s
    2019-06-23 04:36:33 (5.81 MB/s) - ‘php-5.6.40.tar.gz’ saved [19305795/19305795]
    [04:36][[email protected] svr-setup]# wget -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
    --2019-06-23 04:37:08--  https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz
    Resolving centminmod.com... 104.20.231.85, 104.20.230.85
    Connecting to centminmod.com|104.20.231.85|:443... connected.
    Length: 8864262 (8.5M) [application/octet-stream]
    openssl-1.1.1c.tar.gz                                100%[===================================================================================================================>]   8.45M   765KB/s    in 14s
    2019-06-23 04:37:24 (598 KB/s) - ‘openssl-1.1.1c.tar.gz’ saved [8864262/8864262]
    41,646
    9,380
    8:25 AM
    definitely your china based server's network connectivity to openssl.org being a problem for nginx compiles
    [11:16][[email protected] ~]# curl -Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    * About to connect() to www.openssl.org port 443 (#0)
    *   Trying 104.76.133.237...
    * Connection timed out
    *   Trying 2600:140e:6:39d::c1e...
    * Failed to connect to 2600:140e:6:39d::c1e: Network is unreachable
    *   Trying 2600:140e:6:3bc::c1e...
    * Failed to connect to 2600:140e:6:3bc::c1e: Network is unreachable
    * Failed connect to www.openssl.org:443; Network is unreachable
    * Closing connection 0
    curl: (7) Failed to connect to 2600:140e:6:39d::c1e: Network is unreachable
    [11:16][[email protected] ~]# curl -4Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    * Failed connect to www.openssl.org:443; Connection timed out
    curl: (7) Failed connect to www.openssl.org:443; Connection timed out
    [11:17][[email protected] ~]# curl -6Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    *   Trying 2600:1417:76:18c::c1e...
    * Failed to connect to 2600:1417:76:18c::c1e: Network is unreachable
    *   Trying 2600:1417:76:197::c1e...
    * Failed to connect to 2600:1417:76:197::c1e: Network is unreachable
    * couldn't connect to host at www.openssl.org:443
    curl: (7) Failed to connect to 2600:1417:76:18c::c1e: Network is unreachable
    doing DNS A record lookups for me show akami cdn for openssl.org so probably connectivity issues with your china vps server
    dig +short A www.openssl.org
    www-ds.openssl.org.edgekey.net.
    e3102.dscx.akamaiedge.net.
    118.215.32.216
    dig +short AAAA www.openssl.org
    2600:1415:10:483::c1e
    2600:1415:10:4b5::c1e
    for php.net, your server has IPv6 connectivity issues
    curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    * About to connect() to www.php.net port 443 (#0)
    *   Trying 2a02:cb40:200::1ad...
    * Failed to connect to 2a02:cb40:200::1ad: Network is unreachable
    * couldn't connect to host at www.php.net:443
    curl: (7) Failed to connect to 2a02:cb40:200::1ad: Network is unreachable
    and IPv4 for php.net seems to getting connection resets during download
    you aren't getting any problems from my local mirror centminmod.com download url versions which are using Cloudflare though.
    what is your server's DNS resolvers ? contents of /etc/resolv.conf ?
    you can try re-testing curl and wget/axel commands but with /etc/resolv.conf set to
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    or
    nameserver 1.1.1.1
    nameserver 1.0.0.1
  7. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
     cat /etc/resolv.conf
    # Generated by NetworkManager
    nameserver 172.16.0.3
    nameserver 172.16.0.2
    After I reset resolv.conf, I do need to restart network service, right?
    I have confirmed that the provider does not support user's setting nameserver. So as long as I restart network service, the nameserver will be the same as "172.16.0.3" 172.16.0.2".
    Do I have any other alternative?
    41,646
    9,380
    8:25 AM
    no need to restart
    edit /etc/resolv.conf
    then write protect the file or other methods i.e. Linux Make Sure /etc/resolv.conf Never Get Updated By DHCP Client - nixCraft
    chattr +i /etc/resolv.conf
  9. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    I have tested, and the results are the same as I posted using the default DNS.
    So I assume I need to manually replace the download sources of "php and openssl" in the 123.09beta01 script? If so, please show me how. Thank you very much.
    41,646
    9,380
    8:25 AM
    Unfortunately not that simple as my centminmod.com mirrors aren't automated they're manually downlaod for nginx, openssl and php versions as they're released so it would break when the next version upgrade comes out and if i have yet to manually update local centminmod.com mirrors. Really, problem is php.net and openssl.org's side so really need to report the issue to them or find a proper mirror for their downloads that works well for China based servers.
    openssl.org has mirrors at /source/mirror.html
    and for php.net PHP: Getting Help
    41,646
    9,380
    8:25 AM
    also what's latest result for the following commands output
    post output for below commands from your problematic server and wrap output in CODE bbcode tags
    curl -Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    curl -Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.gz
    cd /svr-setup
    axel -4v https://www.php.net/distributions/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    axel -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    and see from my local mirrors to see if for china detected servers if using centminmod local mirrors is better than official mirror download links
    cd /svr-setup
  12. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    *   Trying 23.76.86.50...
    * Connected to www.openssl.org (23.76.86.50) port 443 (#0)
    * Initializing NSS with certpath: sql:/etc/pki/nssdb
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
    * Server certificate:
    *     subject: CN=www.openssl.org
    *     start date: Apr 20 01:05:28 2019 GMT
    *     expire date: Jul 19 01:05:28 2019 GMT
    *     common name: www.openssl.org
    *     issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US
    > HEAD /source/openssl-1.1.1c.tar.gz HTTP/1.1
    > User-Agent: curl/7.29.0
    > Host: www.openssl.org
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Server: Apache/2.4.18 (Ubuntu)
    < Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
    < Last-Modified: Tue, 28 May 2019 13:26:28 GMT
    < ETag: "874206-589f29cc304f6"
    < Accept-Ranges: bytes
    < Content-Length: 8864262
    < Content-Type: application/x-gzip
    < Cache-Control: max-age=67055
    < Expires: Wed, 26 Jun 2019 01:15:13 GMT
    < Date: Tue, 25 Jun 2019 06:37:38 GMT
    < Connection: keep-alive
    * Connection #0 to host www.openssl.org left intact
    [06:37][[email protected] ~]# curl -4Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
      CApath: none
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Cache-Control: max-age=67054
    < Date: Tue, 25 Jun 2019 06:37:39 GMT
    [06:37][[email protected] ~]# curl -6Iv https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    *   Trying 2600:1417:76:181::c1e...
    * Failed to connect to 2600:1417:76:181::c1e: Network is unreachable
    curl: (7) Failed to connect to 2600:1417:76:181::c1e: Network is unreachable
    [06:37][[email protected] ~]# curl -Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    *   Trying 185.85.0.29...
    * Connected to www.php.net (185.85.0.29) port 443 (#0)
      CApath: none
    * SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    *     subject: CN=*.php.net
    *     start date: May 24 00:00:00 2019 GMT
    *     expire date: May 23 12:00:00 2021 GMT
    *     common name: *.php.net
    *     issuer: CN=Thawte TLS RSA CA G1,OU=www.digicert.com,O=DigiCert Inc,C=US
    > HEAD /distributions/php-5.6.40.tar.xz HTTP/1.1
    > Host: www.php.net
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Server: myracloud
    Server: myracloud
    < Date: Tue, 25 Jun 2019 06:37:52 GMT
    < Content-Type: application/x-xz
    < Last-Modified: Thu, 10 Jan 2019 08:00:10 GMT
    < ETag: "be4fac-57f15f7ae7680"
    < X-CDN: 1
    X-CDN: 1
    * Connection #0 to host www.php.net left intact
    [06:37][[email protected] ~]# curl -4Iv https://www.php.net/distributions/php-5.6.40.tar.xz
      CApath: none
    > Host: www.php.net
    > Accept: */*
    < HTTP/1.1 200 OK
    HTTP/1.1 200 OK
    < Server: myracloud
    Server: myracloud
    < Date: Tue, 25 Jun 2019 06:37:53 GMT
    < X-CDN: 1
    X-CDN: 1
    [06:37][[email protected] ~]# curl -6Iv https://www.php.net/distributions/php-5.6.40.tar.xz
    # cd /svr-setup
    [06:38][[email protected] svr-setup]# rm -f php-5.6.40.tar.gz openssl-1.1.1c.tar.gz
    wget -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz[06:38][[email protected] svr-setup]# axel -4v https://www.php.net/distributions/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    Initializing download: https://www.php.net/distributions/php-5.6.40.tar.gz
    File size: unavailable
    Opening output file php-5.6.40.tar.gz
    Server unsupported, starting from scratch with one connection.
    Starting download
    [ N/A]  .......... .......... .......... .......... ..........  [  25.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  34.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  41.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  41.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  44.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  46.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  47.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  50.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  52.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  54.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  56.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  57.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  60.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  63.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  71.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  71.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  72.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  73.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  74.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  74.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  75.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  76.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  75.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  74.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  74.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  75.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  76.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  74.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  72.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  72.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  70.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  69.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  68.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  67.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  66.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  65.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  64.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  63.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  63.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  63.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  62.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  61.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  60.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  60.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  60.2KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  60.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.8KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.6KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.5KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.3KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.4KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  59.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.1KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.0KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  57.9KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  57.7KB/s]
    [ N/A]  .......... .......... .......... .......... ..........  [  58.2KB/s]
    [ N/A]  .....You have new mail in /var/spool/mail/root
    [06:44][ro[email protected] svr-setup]# axel -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    Initializing download: https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    File size: 8864262 bytes
    Opening output file openssl-1.1.1c.tar.gz
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  33.0KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [  60.1KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [  70.1KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [  85.0KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [  97.3KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 104.0KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 118.7KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 132.5KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 143.8KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 139.6KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 155.7KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 170.6KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 184.0KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 196.9KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 202.2KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 214.4KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 229.2KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 241.2KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 253.3KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 263.2KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 272.8KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 285.1KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 276.7KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 288.4KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 265.7KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 249.6KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 257.4KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 248.8KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 247.0KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 252.6KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 247.7KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 251.6KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 248.8KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 251.1KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 249.4KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 248.3KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 246.2KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 223.3KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 228.7KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [ 214.8KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 212.9KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 212.4KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 206.7KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 191.0KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 182.1KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 179.9KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [ 173.0KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 176.4KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 176.0KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 176.1KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 175.9KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [ 175.0KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 174.1KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 172.3KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 169.8KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 150.4KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 152.8KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 150.9KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [ 153.3KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [ 152.1KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [ 151.0KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [ 150.7KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [ 146.3KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [ 145.4KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [ 142.6KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [ 141.7KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [ 143.6KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [ 145.7KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [ 147.7KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [ 149.6KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [ 151.8KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [ 153.3KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [ 153.7KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [ 152.0KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [ 151.8KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [ 152.2KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [ 149.7KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [ 148.5KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [ 148.9KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [ 148.0KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [ 147.9KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [ 146.7KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [ 146.1KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [ 145.8KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [ 143.1KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [ 142.4KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [ 143.5KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [ 143.7KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [ 143.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [ 143.6KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [ 143.1KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [ 141.6KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [ 142.4KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [ 140.6KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [ 140.4KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [ 141.7KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [ 142.0KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [ 142.2KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [ 142.1KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [ 142.0KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [ 141.4KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [ 140.2KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [ 139.8KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [ 140.0KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [ 139.8KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [ 140.5KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [ 141.9KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [ 141.4KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [ 141.9KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [ 141.1KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [ 140.9KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [ 136.2KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [ 137.3KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [ 133.1KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [ 134.2KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [ 134.0KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [ 133.9KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [ 132.8KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [ 130.7KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [ 129.3KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [ 129.4KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [ 130.0KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [ 129.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [ 130.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [ 131.5KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [ 131.6KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [ 130.3KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [ 129.9KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [ 130.0KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [ 130.1KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [ 129.9KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [ 129.7KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [ 128.8KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [ 127.1KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [ 126.7KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [ 127.4KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [ 127.6KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [ 127.1KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [ 127.3KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [ 125.9KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [ 125.3KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [ 125.1KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [ 125.1KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [ 124.9KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [ 125.7KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [ 125.8KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [ 125.5KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [ 125.9KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [ 126.3KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [ 126.7KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [ 127.2KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [ 127.4KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [ 127.5KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [ 127.9KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [ 128.4KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [ 128.3KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [ 128.7KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [ 128.8KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [ 128.9KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [ 128.3KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [ 127.9KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [ 127.8KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [ 128.4KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [ 128.3KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [ 129.0KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [ 129.4KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [ 129.1KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [ 128.2KB/s]
    [ 97%]  ..
    Connection 0 finished
            ,,........ .......... .......... .......... ..........  [ 126.5KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [ 125.9KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [ 125.6KB/s]
    Connection 2 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, .......... ..........  [ 125.7KB/s]
    Connection 1 finished
    Connection 3 finished
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,.. ..........  [ 125.8KB/s]
    [ 99%]  ......
    Downloaded 8.5 Megabyte in 1:08 minute(s). (125.85 KB/s)
    [06:45][[email protected] svr-setup]# wget -4v https://www.php.net/distributions/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    --2019-06-25 06:45:12--  https://www.php.net/distributions/php-5.6.40.tar.gz
    Resolving www.php.net... 185.85.0.29
    Connecting to www.php.net|185.85.0.29|:443... connected.
    Length: unspecified [application/x-gzip]
    Saving to: ‘php-5.6.40.tar.gz’
    php-5.6.40.tar.gz                                        [        <=>                                     ]  18.41M  40.7KB/s    in 5m 49s
    2019-06-25 06:51:02 (53.9 KB/s) - ‘php-5.6.40.tar.gz’ saved [19305795]
    [06:51][[email protected] svr-setup]# wget -4v https://www.openssl.org/source/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
    --2019-06-25 06:58:26--  https://www.openssl.org/source/openssl-1.1.1c.tar.gz
    Resolving www.openssl.org... 23.76.86.50
    Connecting to www.openssl.org|23.76.86.50|:443... connected.
    Length: 8864262 (8.5M) [application/x-gzip]
    Saving to: ‘openssl-1.1.1c.tar.gz’
    openssl-1.1.1c.tar.gz                                100%[===================================================================================================================>]   8.45M   789KB/s    in 11s
    2019-06-25 06:58:39 (792 KB/s) - ‘openssl-1.1.1c.tar.gz’ saved [8864262/8864262]
    # axel -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -o php-5.6.40.tar.gz
    wget -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gzInitializing download: https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz
    File size: 19305795 bytes
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  61.4KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 117.5KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 154.4KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [ 200.4KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 247.2KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 270.2KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 307.2KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 343.2KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 349.7KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 350.2KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 344.8KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 373.0KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 407.7KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 435.4KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 445.0KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 478.1KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 504.5KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 536.6KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 563.4KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 599.8KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 628.4KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 656.5KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 685.1KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 712.7KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 634.7KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 661.4KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 688.6KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 679.5KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 705.1KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 730.7KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 756.5KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 757.1KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 769.1KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 791.8KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 816.1KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 813.7KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 834.5KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 856.7KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 885.2KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 905.6KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 925.5KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 947.2KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 966.2KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 982.3KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 911.7KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 931.5KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 931.0KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 948.0KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 963.7KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 980.9KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 995.0KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [1010.6KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [1035.4KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [1047.8KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [1072.5KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [1091.1KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [1109.6KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [1126.7KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [1146.8KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [1164.5KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [1159.6KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [1180.0KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [1196.6KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [1212.8KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [1209.1KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [1222.8KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [1239.0KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [1254.5KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [1268.8KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [1288.7KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [1302.0KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [1318.0KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1333.2KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1347.1KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1359.9KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [1379.3KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1390.8KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1410.0KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [1422.8KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1435.8KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1451.5KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1466.2KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [1479.5KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1492.7KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1510.6KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1526.1KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [1530.2KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1542.8KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1556.7KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1572.0KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [1586.6KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1514.0KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1528.9KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [1546.6KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1561.0KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1578.0KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1585.5KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [1598.6KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1612.8KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1626.8KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1641.5KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [1579.8KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1594.5KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1608.1KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1624.0KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [1638.8KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1653.5KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1673.2KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1683.0KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [1702.7KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1717.5KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1732.2KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [1745.7KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1761.7KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1776.4KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1765.2KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [1784.6KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1797.9KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1813.7KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1828.2KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [1842.7KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1856.0KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1871.8KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1886.3KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [1900.8KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1920.2KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1933.5KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [1949.3KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1963.8KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1978.3KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [1991.6KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [2007.3KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [2021.9KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [2041.2KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [2055.7KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [2069.0KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [2084.7KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [2099.3KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [2113.8KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [2133.1KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [2142.7KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [2162.1KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [2176.6KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [2191.0KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [2204.3KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [2220.0KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [2234.5KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [2249.0KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [2164.9KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [2176.4KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [2192.6KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [2141.9KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [2148.1KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [2160.4KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [2176.0KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [2163.8KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [2179.7KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [2191.8KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [2203.9KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [2213.4KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [2226.6KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [2238.7KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2210.6KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2220.2KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2233.1KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [2242.6KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2254.3KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2266.1KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2281.1KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [2272.2KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2283.8KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2300.7KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [2310.3KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2323.1KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2312.5KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2324.0KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [2335.5KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2339.7KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2352.2KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2363.7KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [2380.3KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2389.8KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2406.4KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2418.9KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [2430.3KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2441.8KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2456.4KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [2468.9KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2485.5KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2496.9KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2508.4KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [2523.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2535.5KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2547.0KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2563.7KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [2573.1KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2585.6KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2602.3KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2613.7KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [2625.2KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2639.8KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2625.3KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2636.6KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [2653.1KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2662.5KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2674.8KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [2691.3KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2702.6KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2714.0KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2728.4KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [2740.7KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2752.0KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2765.4KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2774.7KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [2781.4KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2785.7KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2786.0KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2797.2KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [2722.9KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2729.5KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2615.7KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [2626.0KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2636.3KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2649.5KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2660.7KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [2671.0KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2686.1KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2694.5KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2705.8KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [2720.7KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2731.0KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2741.4KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2754.5KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [2765.7KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2776.0KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2703.1KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [2710.8KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2725.3KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2736.2KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2732.6KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [2742.5KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2746.6KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2757.4KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2768.2KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [2782.6KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2792.6KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2804.3KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2815.1KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [2825.9KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2835.8KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2847.5KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [2858.3KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2869.1KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2883.5KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2893.4KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [2905.1KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2915.9KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2926.6KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2936.6KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [2948.3KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2959.1KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2953.4KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2964.0KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [2973.9KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2973.2KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2983.8KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [2994.4KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [3008.7KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [3015.8KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [3030.1KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [3040.8KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [3051.4KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [3061.2KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [3072.8KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [3083.5KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [3094.1KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [3108.3KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [3118.1KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [3129.6KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [3136.2KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [3141.6KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [3151.3KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3154.3KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3156.5KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3161.5KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [3167.1KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3176.7KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3181.1KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3184.6KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [3186.6KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3196.2KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3200.5KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3203.8KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [3209.3KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3212.1KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3221.5KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3226.8KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [3230.1KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3231.1KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3237.9KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [3245.6KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3248.8KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3253.9KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3256.5KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [3265.8KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3270.7KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3273.9KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3276.0KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [3280.1KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3287.6KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3084.9KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3094.3KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [3102.9KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3111.6KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3122.6KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [3132.1KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3144.6KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3153.3KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3161.9KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [3173.0KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3182.4KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3191.0KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3203.6KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [3210.7KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3220.1KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3232.7KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3241.3KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [3250.0KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3261.0KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3270.4KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [3175.6KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3187.9KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3194.0KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3206.2KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [3215.4KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3224.5KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3232.5KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3243.1KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [3252.3KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3260.6KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3272.8KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3279.6KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [3291.8KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3300.9KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3309.3KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [3317.6KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3328.3KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3337.0KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3346.2KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [3358.4KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3366.7KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3376.6KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [3384.9KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,......... .......... ..........  [3393.9KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3403.1KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3415.1KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3424.2KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [3433.3KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [3441.7KB/s]
    [ 95%]  .......... .
            ,,,,,,,,,, ,......... .......... .......... ..........  [3450.7KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [3459.8KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3470.1KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3479.2KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3488.4KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [3499.4KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3508.5KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3517.6KB/s]
    [ 97%]  .......... .......... .......... .......... ..........  [3526.8KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,..  [3536.2KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3545.3KB/s]
    [ 98%]  ..........
            ,,,,,,,,,, .......... .......... .......... ..........  [3054.3KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3052.4KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [3040.8KB/s]
    [ 99%]  ....
            ,,,,...... .......... .......... .......... ..........  [3019.5KB/s]
    [ 99%]  .......... .......... .......... .......... ..........  [3016.1KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,..... ..........  [3005.3KB/s]
    [100%]  .......... .......... .......... .......... ..........  [2922.3KB/s]
    [100%]  ...
    Downloaded 18.4 Megabyte in 6 seconds. (2920.84 KB/s)
    [06:44][[email protected] ~]# axel -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -o openssl-1.1.1c.tar.gz
    Initializing download: https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz
    Starting download
    [  0%]  .......... .......... .......... .......... ..........  [  41.0KB/s]
    [  0%]  .......... .......... .......... .......... ..........  [  79.6KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [  89.6KB/s]
    [  1%]  .......... .......... .......... .......... ..........  [ 115.4KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 145.3KB/s]
    [  2%]  .......... .......... .......... .......... ..........  [ 165.9KB/s]
    [  3%]  .......... .......... .......... .......... ..........  [ 191.7KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 218.0KB/s]
    [  4%]  .......... .......... .......... .......... ..........  [ 247.0KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 258.5KB/s]
    [  5%]  .......... .......... .......... .......... ..........  [ 280.2KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 292.0KB/s]
    [  6%]  .......... .......... .......... .......... ..........  [ 313.2KB/s]
    [  7%]  .......... .......... .......... .......... ..........  [ 335.9KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 357.8KB/s]
    [  8%]  .......... .......... .......... .......... ..........  [ 374.5KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 396.3KB/s]
    [  9%]  .......... .......... .......... .......... ..........  [ 417.4KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 426.2KB/s]
    [ 10%]  .......... .......... .......... .......... ..........  [ 441.6KB/s]
    [ 11%]  .......... .......... .......... .......... ..........  [ 458.3KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 479.5KB/s]
    [ 12%]  .......... .......... .......... .......... ..........  [ 493.2KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 515.8KB/s]
    [ 13%]  .......... .......... .......... .......... ..........  [ 532.8KB/s]
    [ 14%]  .......... .......... .......... .......... ..........  [ 547.2KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 567.0KB/s]
    [ 15%]  .......... .......... .......... .......... ..........  [ 563.3KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 577.8KB/s]
    [ 16%]  .......... .......... .......... .......... ..........  [ 539.8KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 557.0KB/s]
    [ 17%]  .......... .......... .......... .......... ..........  [ 570.2KB/s]
    [ 18%]  .......... .......... .......... .......... ..........  [ 588.1KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 599.3KB/s]
    [ 19%]  .......... .......... .......... .......... ..........  [ 611.2KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 628.3KB/s]
    [ 20%]  .......... .......... .......... .......... ..........  [ 645.1KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 662.5KB/s]
    [ 21%]  .......... .......... .......... .......... ..........  [ 679.2KB/s]
    [ 22%]  .......... .......... .......... .......... ..........  [ 701.4KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 718.1KB/s]
    [ 23%]  .......... .......... .......... .......... ..........  [ 734.0KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 752.1KB/s]
    [ 24%]  .......... .......... .......... .......... ..........  [ 768.8KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 784.0KB/s]
    [ 25%]  .......... .......... .......... .......... ..........  [ 800.7KB/s]
    [ 26%]  .......... .......... .......... .......... ..........  [ 778.0KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 798.4KB/s]
    [ 27%]  .......... .......... .......... .......... ..........  [ 813.6KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 830.0KB/s]
    [ 28%]  .......... .......... .......... .......... ..........  [ 845.9KB/s]
    [ 29%]  .......... .......... .......... .......... ..........  [ 861.0KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 876.2KB/s]
    [ 30%]  .......... .......... .......... .......... ..........  [ 893.3KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 909.1KB/s]
    [ 31%]  .......... .......... .......... .......... ..........  [ 930.2KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 946.0KB/s]
    [ 32%]  .......... .......... .......... .......... ..........  [ 961.2KB/s]
    [ 33%]  .......... .......... .......... .......... ..........  [ 973.2KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [ 971.4KB/s]
    [ 34%]  .......... .......... .......... .......... ..........  [ 983.7KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [ 999.1KB/s]
    [ 35%]  .......... .......... .......... .......... ..........  [1012.2KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1029.3KB/s]
    [ 36%]  .......... .......... .......... .......... ..........  [1041.9KB/s]
    [ 37%]  .......... .......... .......... .......... ..........  [1053.6KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1069.4KB/s]
    [ 38%]  .......... .......... .......... .......... ..........  [1081.8KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1093.3KB/s]
    [ 39%]  .......... .......... .......... .......... ..........  [1104.6KB/s]
    [ 40%]  .......... .......... .......... .......... ..........  [1119.6KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1135.6KB/s]
    [ 41%]  .......... .......... .......... .......... ..........  [1136.1KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1150.3KB/s]
    [ 42%]  .......... .......... .......... .......... ..........  [1163.7KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1092.1KB/s]
    [ 43%]  .......... .......... .......... .......... ..........  [1105.9KB/s]
    [ 44%]  .......... .......... .......... .......... ..........  [1119.6KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1125.4KB/s]
    [ 45%]  .......... .......... .......... .......... ..........  [1142.2KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1155.8KB/s]
    [ 46%]  .......... .......... .......... .......... ..........  [1168.9KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1182.5KB/s]
    [ 47%]  .......... .......... .......... .......... ..........  [1197.2KB/s]
    [ 48%]  .......... .......... .......... .......... ..........  [1210.8KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1209.7KB/s]
    [ 49%]  .......... .......... .......... .......... ..........  [1227.7KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1237.8KB/s]
    [ 50%]  .......... .......... .......... .......... ..........  [1251.4KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1264.8KB/s]
    [ 51%]  .......... .......... .......... .......... ..........  [1277.1KB/s]
    [ 52%]  .......... .......... .......... .......... ..........  [1291.1KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1304.5KB/s]
    [ 53%]  .......... .......... .......... .......... ..........  [1304.1KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1320.0KB/s]
    [ 54%]  .......... .......... .......... .......... ..........  [1332.1KB/s]
    [ 55%]  .......... .......... .......... .......... ..........  [1345.3KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1355.6KB/s]
    [ 56%]  .......... .......... .......... .......... ..........  [1367.5KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1379.6KB/s]
    [ 57%]  .......... .......... .......... .......... ..........  [1392.8KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1400.6KB/s]
    [ 58%]  .......... .......... .......... .......... ..........  [1413.4KB/s]
    [ 59%]  .......... .......... .......... .......... ..........  [1429.0KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1441.6KB/s]
    [ 60%]  .......... .......... .......... .......... ..........  [1454.7KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1463.9KB/s]
    [ 61%]  .......... .......... .......... .......... ..........  [1414.4KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1425.7KB/s]
    [ 62%]  .......... .......... .......... .......... ..........  [1438.8KB/s]
    [ 63%]  .......... .......... .......... .......... ..........  [1451.3KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1467.9KB/s]
    [ 64%]  .......... .......... .......... .......... ..........  [1478.1KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1490.5KB/s]
    [ 65%]  .......... .......... .......... .......... ..........  [1502.5KB/s]
    [ 66%]  .......... .......... .......... .......... ..........  [1516.0KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1528.5KB/s]
    [ 67%]  .......... .......... .......... .......... ..........  [1539.9KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1556.5KB/s]
    [ 68%]  .......... .......... .......... .......... ..........  [1565.8KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1582.5KB/s]
    [ 69%]  .......... .......... .......... .......... ..........  [1594.4KB/s]
    [ 70%]  .......... .......... .......... .......... ..........  [1606.9KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1619.4KB/s]
    [ 71%]  .......... .......... .......... .......... ..........  [1631.8KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1644.3KB/s]
    [ 72%]  .......... .......... .......... .......... ..........  [1656.8KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1673.4KB/s]
    [ 73%]  .......... .......... .......... .......... ..........  [1685.9KB/s]
    [ 74%]  .......... .......... .......... .......... ..........  [1697.8KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1710.8KB/s]
    [ 75%]  .......... .......... .......... .......... ..........  [1723.3KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1735.7KB/s]
    [ 76%]  .......... .......... .......... .......... ..........  [1747.7KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1764.3KB/s]
    [ 77%]  .......... .......... .......... .......... ..........  [1773.6KB/s]
    [ 78%]  .......... .......... .......... .......... ..........  [1790.2KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [1802.7KB/s]
    [ 79%]  .......... .......... .......... .......... ..........  [1814.1KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [1826.6KB/s]
    [ 80%]  .......... .......... .......... .......... ..........  [1840.1KB/s]
    [ 81%]  .......... .......... .......... .......... ..........  [1852.5KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [1852.9KB/s]
    [ 82%]  .......... .......... .......... .......... ..........  [1862.3KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [1873.5KB/s]
    [ 83%]  .......... .......... .......... .......... ..........  [1886.9KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [1900.2KB/s]
    [ 84%]  .......... .......... .......... .......... ..........  [1911.5KB/s]
    [ 85%]  .......... .......... .......... .......... ..........  [1922.8KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [1936.2KB/s]
    [ 86%]  .......... .......... .......... .......... ..........  [1949.5KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [1965.9KB/s]
    [ 87%]  .......... .......... .......... .......... ..........  [1977.2KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [1988.5KB/s]
    [ 88%]  .......... .......... .......... .......... ..........  [2001.9KB/s]
    [ 89%]  .......... .......... .......... .......... ..........  [2015.2KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [2026.5KB/s]
    [ 90%]  .......... .......... .......... .......... ..........  [2041.8KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, .......... ..........  [2054.1KB/s]
    [ 91%]  .......... .......... .......... .......... ..........  [2066.4KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [2078.6KB/s]
    [ 92%]  .......... .......... .......... .......... ..........  [2091.4KB/s]
    [ 93%]  .......... .......... .......... .......... ..........  [2103.8KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [2116.1KB/s]
    [ 94%]  .......... .......... .......... .......... ..........  [2128.3KB/s]
    [ 95%]  ..
            ,,........ .......... .......... .......... ..........  [2141.6KB/s]
    [ 95%]  .......... .......... .......... .......... ..........  [2148.9KB/s]
    [ 96%]  .......... .......... .......... .......... ..........  [2110.4KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,..  [1793.4KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,,,,  [1707.5KB/s]
    [ 98%]  .......... .......... .......... .......... ..........  [1669.3KB/s]
    [ 98%]  ..
            ,,........ .......... .......... .......... ..........  [1495.9KB/s]
            ,,,,,,,,,, ,,,,,,,,,, ,......... .......... ..........  [1492.6KB/s]
    [ 99%]  ......
    Downloaded 8.5 Megabyte in 5 seconds. (1491.31 KB/s)
    [06:44][[email protected] ~]# wget -4v https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz -O php-5.6.40.tar.gz
    --2019-06-25 06:44:09--  https://centminmod.com/centminmodparts/php/php-5.6.40.tar.gz
    Resolving centminmod.com... 104.20.230.85, 104.20.231.85
    Connecting to centminmod.com|104.20.230.85|:443... connected.
    Length: 19305795 (18M) [application/octet-stream]
    php-5.6.40.tar.gz                                    100%[===================================================================================================================>]  18.41M  5.26MB/s    in 3.5s
    2019-06-25 06:44:14 (5.26 MB/s) - ‘php-5.6.40.tar.gz’ saved [19305795/19305795]
    [06:44][[email protected] ~]# wget -4v https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz -O openssl-1.1.1c.tar.gz
    --2019-06-25 06:44:22--  https://centminmod.com/centminmodparts/openssl/openssl-1.1.1c.tar.gz
    Length: 8864262 (8.5M) [application/octet-stream]
    openssl-1.1.1c.tar.gz                                100%[===================================================================================================================>]   8.45M  3.18MB/s    in 2.7s
    2019-06-25 06:44:25 (3.18 MB/s) - ‘openssl-1.1.1c.tar.gz’ saved [8864262/8864262]
    41,646
    9,380
    8:25 AM
    looks like openssl and php downloads work for IPv4 wget/axel/curl but fail for IPv6 connections so your server's IPv6 connectivity might be flaky or not working properly so probably best when you setup server on fresh centos to disable IPv6 before installing centmin mod though centmin mod 123.09beta01 has been updated to where possible download from IPv4 connections only and not IPv6 so probably it's worth trying a fresh centmin mod 123.09beta01 install now.
  14. jellday
    jellday Member
    51
    6:25 AM
    1.4.6
    5.5
    Yep, everything works fine now.
    41,646
    9,380
    8:25 AM
    Good to know looks like you had a temporary network connectivity issue then - hopefully
