Nginx Nginx 1.23.1 Upgrade issue
Discussion in 'Install & Upgrades or Pre-Install Questions' started by rdan, Sep 2, 2022.
    rdan Premium Member Premium Member
    5,330
    1,338
    10:07 PM
    49,301
    11,296
    12:07 AM
    looks like broken incomplete openssl 1.1.1q download
    tar (child): /svr-setup/openssl-1.1.1q.tar.gz: Cannot open: No such file or directory
    tar (child): Error is not recoverable: exiting now
    tar: Child returned status 2
    tar: Error is not recoverable: exiting now
    shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    Assembler messages:
    Fatal error: can't create help-dummy.o: No such file or directory
    /usr/lib64/libatomic_ops.a found
    tar (child): /svr-setup/pcre-8.45.tar.gz: Cannot open: No such file or directory
    actually more downloads are broken
    tar (child): /svr-setup/srcache-nginx-module_v0.32.tar.gz: Cannot open: No such file or directory
    check your server's connectivity
    Also 124.00stable version is a few commits behind so make sure to run cmupdate first Commits · centminmod/centminmod
  3. rdan
    5,330
    1,338
    10:07 PM
    But nginx update/recompile to 1.22.0 works fine.
  4. rdan
    5,330
    1,338
    10:07 PM
    Is the DIR /svr-setup/ supposed to be empty always?
    Mine has nothing on it.
    49,301
    11,296
    12:07 AM
    nginx version wouldn't have affected this but I did notice your /svr-setup directory is ramdisk mounted as tmpfs. This is only temp setup at initial Centmin Mod install time if it detects if you have enough memory and at end of initial install should remove ramdisk /svr-setup version and copy files to disk based /svr-setup version via a unsetramdisk function. Looks like it didn't do this in your case.
    devtmpfs       devtmpfs   32G     0   32G   0% /dev
    tmpfs          tmpfs      32G     0   32G   0% /dev/shm
    tmpfs          tmpfs      32G  2.4G   29G   8% /run
    tmpfs          tmpfs      32G     0   32G   0% /sys/fs/cgroup
    /dev/md2       xfs       411G  320G   91G  78% /
    tmpfs          tmpfs      32G  100K   32G   1% /tmp
    /dev/nvme0n1p1 vfat      510M  3.6M  507M   1% /boot/efi
    tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
    tmpfs          tmpfs     2.2G     0  2.2G   0% /svr-setup
    noticed from nginx upgrade log complaining of /svr-setup device busy should that could be related
    rm: cannot remove ‘/svr-setup/’: Device or resource busy
    You can manually fix this using these commands
    DIR_TMP=/svr-setup
    mkdir -p "${DIR_TMP}_disk"
    \cp -R ${DIR_TMP}/* "${DIR_TMP}_disk"
    umount -l "${DIR_TMP}"
    mkdir -p "${DIR_TMP}"
    \cp -R ${DIR_TMP}_disk/* "${DIR_TMP}"
    rm -rf "${DIR_TMP}_disk"
    verify with
    df -hT
  6. rdan
    5,330
    1,338
    10:07 PM
    Ow, this server was installed Feb 2018, 4 years ago.
    # df -hT
    tmpfs          tmpfs      32G  9.1M   32G   1% /run
    /dev/md2       xfs       411G  320G   92G  78% /
    tmpfs          tmpfs      32G   44K   32G   1% /tmp
    49,301
    11,296
    12:07 AM
    interesting so the fix I suggested worked right?
  8. rdan
    5,330
    1,338
    10:07 PM
    i don't have directory now.
    49,301
    11,296
    12:07 AM
    whoops missing a step so updated above post but for now just
    DIR_TMP=/svr-setup
  10. rdan
    5,330
    1,338
    10:07 PM
    Missing (")?
    49,301
    11,296
    12:07 AM
    Yeah typo fixed :D
  12. rdan
    5,330
    1,338
    10:07 PM
    After running centmin, this directory is removed :(
    Still can't update nginx properly.
    All other server using same custom_config works fine though :}
    49,301
    11,296
    12:07 AM
    huh? what the?
    re-create the /svr-setup directory and then run centmin.sh debug mode via cmifno debug-menuexit command
    cminfo debug-menuexit
    should save a debug verbose log of a centmin.sh run and 24 exit at /root/centminlogs/debug-menuexit.txt
    Debugging centmin.sh menu option 24 exit routine starting
    Please wait until complete...
    Full debug log saved at /root/centminlogs/debug-menuexit.txt
    Inspect Yum Check Times In debug-menuexit.txt log
    2022-09-01 19:49:48 + echo ' checking for YUM updates... please wait...'
    2022-09-01 19:49:48  checking for YUM updates... please wait...
    2022-09-01 19:49:48 +++ awk '/Updated: / {print $1,$2,$3}' /var/log/yum.log
    2022-09-01 19:49:48 +++ tail -1
    2022-09-01 19:49:48 ++ date -d 'Aug 31 19:47:30' +%s
    2022-09-01 19:49:48 + LASTYUMCHECK_EPOCHDATE=1661975250
    2022-09-01 19:49:48 ++ date +%s
    Yum Check Duration: 6.00 seconds
    Debugging centmin.sh menu option 24 exit routine completed
    sanitize and remove sensitive info from /root/centminlogs/debug-menuexit.txt and then share that log here or via PM
    49,301
    11,296
    12:07 AM
    As far as I can tell nothing running centmin.sh will delete /svr-setup from egrep filer
    cat /root/centminlogs/debug-menuexit.txt | egrep -C1 'svr-setup|DIR_TMP'
    2022-09-01 19:54:25 + HN=hostname
    2022-09-01 19:54:25 + DIR_TMP=/svr-setup
    2022-09-01 19:54:25 + CENTMINLOGDIR=/root/centminlogs
    2022-09-01 19:54:25 + TMPFSLIMIT=4000000
    2022-09-01 19:54:25 + '[' '!' -d /svr-setup ']'
    2022-09-01 19:54:25 ++ cat /etc/resolv.conf
    2022-09-01 19:54:25 + [[ -f /usr/local/bin/ccache ]]
    2022-09-01 19:54:25 + [[ ! -f /svr-setup/ccache-4.5.1.tar.gz ]]
    2022-09-01 19:54:25 + [[ -d /svr-setup/ccache-4.5.1 ]]
    2022-09-01 19:54:25 ++ ccache -V
    2022-09-01 19:54:26 + [[ -f /usr/local/bin/axel ]]
    2022-09-01 19:54:26 + [[ ! -d /svr-setup/axel-2.16.1 ]]
    2022-09-01 19:54:26 + fileperm_fixes
    2022-09-01 19:54:26 + ngxmodule_cleanups
    2022-09-01 19:54:26 + '[' -f /svr-setup/nginx-develkit_v0.2.19.tar.gz ']'
    2022-09-01 19:54:26 + '[' -d /svr-setup/ngx_devel_kit-0.2.19 ']'
    2022-09-01 19:54:26 + wpcompfix
  15. rdan
    5,330
    1,338
    10:07 PM
    Let me refresh the code with this for now.
    cmupdate
    cmupdate update-stable
    cmdir
    centmin
    BRB.
  16. rdan
    5,330
    1,338
    10:07 PM
    Sent unmodified code.
    Thanks Eva.
    49,301
    11,296
    12:07 AM
    There's nothing in the log that shows why /svr-setup is being deleted.
    You can install auditd via tools/auditd.sh https://community.centminmod.com/th...td-support-added-in-latest-123-09beta01.9071/
    Then setup an auditd rule for /svr-setup directory like https://community.centminmod.com/th...added-in-latest-123-09beta01.9071/#post-37761
    create and add file /etc/audit/rules.d/svr-setup.rules file with the rule below added setting auditd key = svrsetup
    -w /svr-setup -p wa -k svrsetup
    then run
    cd /usr/local/src/centminmod/tools
    ./auditd.sh updaterules
    then re-create /svr-setup
    mkdir -p /svr-setup
    then run centmin.sh menu and exit or your centmin.sh menu option 4 and exit
    then check auditd rule key svrsetup with command
    ausearch -k svrsetup
    and separate saved output for command
    ausearch -k svrsetup | aureport -f
    and then post output to a pastebin link as it may contain a lot of entries
  18. rdan
    5,330
    1,338
    10:07 PM
    This can be closed now (for this specific site and server) as I migrated to a new server.
    I can't debug it further.
    49,301
    11,296
    12:07 AM
    Good to hear it's resolved. Though was a strange issue!
