Beta Branch nginx 1.11.5 default
Discussion in 'Centmin Mod Github Commits' started by eva2000, Oct 12, 2016.
    59,480
    12,536
    8:29 PM
  2. raciasolvo
    raciasolvo Member
    98
    11
    1:29 PM
    Nginx 1.11.6
    MariaDB 10.0.27
    nginx does not start
    59,480
    12,536
    8:29 PM
    after you switch back to 123.09beta01 and ran centmin.sh menu option 4, can you post the contents of /svr-setup/nginx-1.11.5/objs/autoconf.err to pastebin or gist.github.com if you still get same error lot of the nginx_upgrade.log
  4. raciasolvo
    raciasolvo Member
    98
    11
    1:29 PM
    Nginx 1.11.6
    MariaDB 10.0.27
    gist:6a44f9391d8453bf2ee9e2a5c82d7f31 · GitHub
    59,480
    12,536
    8:29 PM
    ah there's the problem right at the top, it's gcc march=native related to your server's cpu processor detected module
    checking for --with-ld-opt="-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib"
    error: unknown target CPU 'pentium-m'
    what cpu does your server have from command output
    cat /proc/cpuinfo
  6. raciasolvo
    raciasolvo Member
    98
    11
    1:29 PM
    Nginx 1.11.6
    MariaDB 10.0.27
    Agree
    # cat /proc/cpuinfo
    processor       : 0
    vendor_id       : GenuineIntel
    cpu family      : 6
    model           : 13
    model name      : QEMU Virtual CPU version 2.3.0
    stepping        : 3
    microcode       : 0x1
    cpu MHz         : 2194.916
    cache size      : 4096 KB
    physical id     : 0
    siblings        : 1
    core id         : 0
    cpu cores       : 1
    apicid          : 0
    initial apicid  : 0
    fpu             : yes
    fpu_exception   : yes
    cpuid level     : 4
    wp              : yes
    flags           : fpu de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pse36 clflush mmx fxsr sse sse2 syscall nx lm rep_good nopl pni cx16 hypervisor lahf_lm abm
    bogomips        : 4389.83
    clflush size    : 64
    cache_alignment : 64
    address sizes   : 46 bits physical, 48 bits virtual
    power management:
    59,480
    12,536
    8:29 PM
  8. raciasolvo
    raciasolvo Member
    98
    11
    1:29 PM
    Nginx 1.11.6
    MariaDB 10.0.27
    thanks for Centmin Mod :D
  9. raciasolvo
    raciasolvo Member
    98
    11
    1:29 PM
    Nginx 1.11.6
    MariaDB 10.0.27
    nginx configure options (alternate ordering):
    ./configure --with-ld-opt="-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib" --with-cc-opt="-m64 -mtune=native -mfpmath=sse -g -O3 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-sign-compare -Wno-string-plus-int -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion -Wno-c++11-compat-deprecated-writable-strings -Wno-write-strings" --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_stub_status_module --with-http_secure_link_module --add-module=../nginx-module-vts --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.0 --add-module=../ngx_cache_purge-2.3 --add-module=../ngx_devel_kit-0.3.0 --add-module=../set-misc-nginx-module-0.31 --add-module=../echo-nginx-module-0.60 --add-module=../redis2-nginx-module-0.13 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.17 --add-module=../srcache-nginx-module-0.31 --add-module=../headers-more-nginx-module-0.31 --with-pcre=../pcre-8.39 --with-pcre-jit --with-http_ssl_module --with-http_v2_module --with-openssl=../libressl-2.4.3
    checking for OS
     + Linux 3.10.0-327.36.2.el7.x86_64 x86_64
    checking for C compiler ... found
     + using Clang C compiler
     + clang version: 3.4.2 (tags/RELEASE_34/dot2-final)
    checking for --with-ld-opt="-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib" ... found
    checking for -Wl,-E switch ... found
    checking for gcc builtin atomic operations ... found
    checking for C99 variadic macros ... found
    checking for gcc variadic macros ... found
    checking for gcc builtin 64 bit byteswap ... found
    Wed Oct 12 09:52:09 UTC 2016
    Success: Nginx configure ok
    nginx -V
    nginx version: nginx/1.11.5
    built with LibreSSL 2.4.3
    TLS SNI support enabled
    # nginx -t
    # service nginx status
    ● nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
       Loaded: loaded (/etc/rc.d/init.d/nginx)
       Active: active (running) since Wed 2016-10-12 09:54:33 UTC; 7min ago
      Process: 12096 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=0/SUCCESS)
     Main PID: 12103 (nginx)
       CGroup: /system.slice/nginx.service
               ├─12103 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
               └─12104 nginx: worker process
    Oct 12 09:54:33 systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Oct 12 09:54:33 nginx[12096]: Starting nginx: [  OK  ]
    Oct 12 09:54:33 systemd[1]: Started SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
    Renamed to 123.09stable ;)
    59,480
    12,536
    8:29 PM
