Letsencrypt New domain ssl issued not trust problem
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Jinbo, Dec 1, 2020.
  1. Jinbo
    Jinbo New Member
    6:31 AM
    centmin menu choose option 2 add new domain.
    It's new domain nginx vhost site setup for first time!
    letsencrypt option below choose 4
    Result in NET::ERR_CERT_INVALID (domain untrust)
    If letsencrypt option below choose 3
    Then domain works fine.
    Maybe done letsencrypt ssl first then redirect www to non www domain will work.
    55,247
    12,253
    7:31 PM
    First try running your intended SSL certificate domain through the letsdebug.net online testing tool to check for potential errors with HTTP-01 validation. If you created Centmin Mod 123.09beta01 or higher Nginx site with Letsencrypt via centmin.sh menu option 2, 22 or nv command line, you now also have an automatic letsdebug.net API check log saved at /root/centminlogs/letsdebug-yourdomain.com-${DT}.log where yourdomain.com is domain specified during nginx vhost creation and DT is date/timestamp. Inspecting the /root/centminlogs/letsdebug-yourdomain.com-${DT}.log log will also give you clues as to why letsencrypt SSL certificate issuance failed.
    If you're seeing a Centmin Mod's self-signed untrusted ssl certificate instead of letsencrypt ssl certificate, then that's acmetool.sh and centminmod's fallback if letsencrypt verification fails to obtain letsencrypt ssl cert, it falls back to centmin mod self-signed ssl certificate on https port 443 side so to preserve the https nginx vhost
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
    echo | openssl s_client -connect yourdomain.com:443
    SSLLabs Test
    Also run your HTTPS domain site through SSLLabs tester at SSL Server Test (Powered by Qualys SSL Labs) if it says untrusted SSL cert and prompts to continue the test, continue the test.
