SSL Needing help installing
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Jake, Apr 8, 2016.
  1. Jake
    Jake Member
    76
    12:04 PM
    NA
    Maria DB 5.5
    Hello,
    I am needing help... I am not fully understanding the instructions...
    This is the error I am getting this error
    nginx: [warn] invalid parameter "spdy": ngx_http_spdy_module was superseded by n
    It still works but the website now throws up a 404 ERROR
    I tried this
      return 302 https://$server_name$request_uri;
    # https SSL SPDY vhost
            listen 443 ssl spdy;
                server_name domain.com;
            ssl_dhparam /usr/local/nginx/conf/ssl/domaincom/dhparam.pem;
            ssl_certificate      /usr/local/nginx/conf/ssl/domaincom/ssl-unified.crt;
            ssl_certificate_key  /usr/local/nginx/conf/ssl/domaincom/ssl.key;
            ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
            ssl_session_cache      shared:SSL:10m;
            ssl_session_timeout  10m;
            ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
            add_header Strict-Transport-Security "max-age=31536000; includeSubdomains;";
            # nginx 1.5.9+ or higher
            # http://nginx.org/en/docs/http/ngx_http_spdy_module.html#spdy_headers_comp
            # http://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_buffer_size
            # spdy_headers_comp 0;
            # ssl_buffer_size 4k;
            # enable ocsp stapling
            resolver 8.8.8.8;
            ssl_stapling on;
            ssl_stapling_verify on;
            ssl_trusted_certificate /usr/local/nginx/conf/ssl/domaincom/ssl-trusted.crt;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
         ## redirect https://www to https://non-www
         ## uncomment if needed
         # if ($host = 'www.domain.com' ) {
         #   return 302 https://$server_name$request_uri;
    # include /usr/local/nginx/conf/block.conf;
      #autoindex  on;
      include /usr/local/nginx/conf/errorpage.conf;
  2. rdan
    1,412
    10:04 AM
    On line:
    Remove spdy or replace it with http2.
    55,803
    12,272
    12:04 PM
    what version of centmin mod you using ? latest 123.08stable and 123.09beta01 updated code automatically adjusts all old spdy configured nginx vhosts when you run centmin.sh menu option 4 to update nginx.
    When was last time you ran centmin.sh menu option 4 to update nginx ?
    I'd update to latest 123.08stable or 123.09beta01 code via centmin.sh menu option 23 submenu option 2 and then run centmin.sh menu option 4 to update to nginx 1.9.14 to automatically switch from spdy to http/2 supported nginx vhosts as there's many more updates in centmin mod code that you'd benefit from if you haven't ran centmin.sh menu option 4 in ages as it seems that might be the case as i added spdy to http/2 auto switch routine back around nginx 1.9.3-1.9.5 which was around 7-9+ months ago.
    Getting Started Guide step 19 outlines also how to keep Centmin Mod code updated or how to switch version branches.
    Centmin Mod LEMP stack's script code is constantly updated for improvements, bug fixes and security fixes so keeping the Centmin Mod code up to date is important. With Centmin Mod 1.2.3-eva2000.08) (123.08stable) and higher releases, a newly added centmin.sh menu option 23 allows much easier code updates and version branch swicthing via Git backed environment you can setup. For full details read the following links:
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to. You can easily update within a Centmin Mod version branch or switch version branches via centmin.sh menu option 23 outlined here.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at How to upgrade Centmin Mod software installed on your server.
  4. Jake
    Jake Member
    76
    12:04 PM
    NA
    Maria DB 5.5
      server_name hastehosting.com www.hastehosting.com;
      return 302 https://www.hastehosting.com$request_uri;
            listen 443 ssl http2;
                server_name hastehosting.com;
            ssl_dhparam
    /usr/local/nginx/conf/ssl/hastehostingcom/dhparam.pem;
            ssl_certificate
    /usr/local/nginx/conf/ssl/hastehostingcom/ssl-unified.crt;
            ssl_certificate_key
    /usr/local/nginx/conf/ssl/hastehostingcom/hastehostingcom.key;
            ssl_ciphers
            ssl_prefer_server_ciphers on;
            #add_header X-Content-Type-Options "nosniff"; add_header
            #X-Frame-Options DENY;
            # spdy_headers_comp 0; ssl_buffer_size 4k; enable ocsp stapling
            resolver 8.8.8.8;
            ssl_stapling on;
    /usr/local/nginx/conf/ssl/hastehostingcom/ssl-trusted.crt;
      # limit_conn limit_per_ip 16; ssi on;
      access_log /home/nginx/domains/hastehosting.com/log/access.log
      error_log /home/nginx/domains/hastehosting.com/log/error.log;
      root /home/nginx/domains/hastehosting.com/public;
    # ngx_pagespeed & ngx_pagespeed handler include
    #/usr/local/nginx/conf/pagespeed.conf; include
    #/usr/local/nginx/conf/pagespeedhandler.conf; include
    #/usr/local/nginx/conf/pagespeedstatslog.conf;
         ## redirect https://www to https://non-www uncomment if needed
    # block common exploits, sql injections etc include
    # /usr/local/nginx/conf/block.conf;
      # Enables directory listings when index file not found autoindex on;
    I am seeing things redirecting to just "https://www.
    Thats it nothing after the www.
    Am I missing something else?
    55,803
    12,272
    12:04 PM
    which is main domain access via www or non-www ?
    if it's www, then you have incorrect 302 redirect as HTTP/2 SSL server_name is non-www and needs to change to www version
                server_name www.hastehosting.com;
