Wordpress need help for woocommerce plugin
Discussion in 'Blogs & CMS usage' started by narji, Feb 4, 2016.
  1. narji
    narji Member
    69
    6
    10:54 AM
    i have problem using this wordpress plugin for csv product import (
    Woocommerce CSV importer)
    the problem is a popup box containt this massage :"Something went wrong. We could not make a connection with the server. Check your permissions and rights the do ajax requests"
    then stop importing any table from csv
    i'm using this code to install on vps
    curl -O https://centminmod.com/betainstaller-latest.sh && chmod 0700 betainstaller-latest.sh && bash betainstaller-latest.sh
    123.09beta01 branch
    please help
    thank you
    55,801
    12,271
    1:54 PM
    How did you install wordpress ? Was it via centmin.sh menu option 22 auto installer Wordpress Nginx Auto Installer (WP Super Cache) ? If so the default wpsecure conf file at /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname is your domain name, blocks php scripts from executing in wp-content for security
    Below links you can see examples of setting up specific wordpress location matches to punch a hole in the wpsecure blocking to whitelist specific php files that need to be able to run.
    Tried also at wp plugin's support forum WordPress › Support » Please Help Out with Error: Something went wrong. We could not make a connection and WordPress › Support » Woocommerce CSV importer
    55,801
    12,271
    1:54 PM
    Also I just updated both Centmin Mod 123.08stable and 123.09beta01 build's centmin.sh menu option 22 wordpress auto installer routine in inc/wpsetup.inc to pre-whitelist common and popular Wordpress plugins including your woocommerce csv importer plugin.
    Update wpsecure_${vhostname}.conf include file to whilelist most popular and common wordpress plugins which need to run php within plugins directory otherwise their php execution will be blocked by centmin.sh menu option 22's wordpress auto installer /usr/local/nginx/conf/wpincludes/wpsecure_${vhostname}.conf generated includes file
    To update your Centmin Mod builds follow instructions at centminmod.com/upgrade.html and respective version threads below:
    55,801
    12,271
    1:54 PM
    so new your new /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname = your domain include file will look like this
    so replace your existing /usr/local/nginx/conf/wpsecure_${vhostname}.conf contents with the below copy and restart nginx and php-fpm service via
    nprestart
    contents of /usr/local/nginx/conf/wpsecure_${vhostname}.conf
    # Deny access to any files with a .php extension in the uploads directory
    # Works in sub-directory installs and also in multisite network
    location ~* /(?:uploads|files)/.*\.php$ {
    deny all;
    # Whitelist Exception for https://wordpress.org/plugins/theme-check/
    location ~ ^/wp-content/plugins/theme-check/ {
    # Whitelist Exception for https://wordpress.org/plugins/woocommerce/
    location ~ ^/wp-content/plugins/woocommerce/ {
    # Whitelist Exception for https://wordpress.org/plugins/woocommerce-csvimport/
    location ~ ^/wp-content/plugins/woocommerce-csvimport/ {
    # Whitelist Exception for https://wordpress.org/plugins/advanced-custom-fields/
    location ~ ^/wp-content/plugins/advanced-custom-fields/ {
    # Whitelist Exception for https://wordpress.org/plugins/contact-form-7/
    location ~ ^/wp-content/plugins/contact-form-7/ {
    # Whitelist Exception for https://wordpress.org/plugins/duplicator/
    location ~ ^/wp-content/plugins/duplicator/ {
    # Whitelist Exception for https://wordpress.org/plugins/jetpack/
    location ~ ^/wp-content/plugins/jetpack/ {
    # Whitelist Exception for https://wordpress.org/plugins/nextgen-gallery/
    location ~ ^/wp-content/plugins/nextgen-gallery/ {
    # Whitelist Exception for https://wordpress.org/plugins/tinymce-advanced/
    location ~ ^/wp-content/plugins/tinymce-advanced/ {
    # Whitelist Exception for https://wordpress.org/plugins/updraftplus/
    location ~ ^/wp-content/plugins/updraftplus/ {
    # Whitelist Exception for https://wordpress.org/plugins/wordpress-importer/
    location ~ ^/wp-content/plugins/wordpress-importer/ {
    # Whitelist Exception for https://wordpress.org/plugins/wordpress-seo/
    location ~ ^/wp-content/plugins/wordpress-seo/ {
    # Whitelist Exception for https://wordpress.org/plugins/wpclef/
    location ~ ^/wp-content/plugins/wpclef/ {
    # Whitelist Exception for https://wordpress.org/plugins/mailchimp-for-wp/
    location ~ ^/wp-content/plugins/mailchimp-for-wp/ {
    # Whitelist Exception for https://wordpress.org/plugins/wp-optimize/
    location ~ ^/wp-content/plugins/wp-optimize/ {
    # Whitelist Exception for https://wordpress.org/plugins/si-contact-form/
    location ~ ^/wp-content/plugins/si-contact-form/ {
    # Whitelist Exception for https://wordpress.org/plugins/akismet/
    location ~ ^/wp-content/plugins/akismet/ {
    # Whitelist Exception for https://wordpress.org/plugins/bbpress/
    location ~ ^/wp-content/plugins/bbpress/ {
    # Whitelist Exception for https://wordpress.org/plugins/buddypress/
    location ~ ^/wp-content/plugins/buddypress/ {
    # Whitelist Exception for https://wordpress.org/plugins/all-in-one-seo-pack/
    location ~ ^/wp-content/plugins/all-in-one-seo-pack/ {
    # Whitelist Exception for https://wordpress.org/plugins/google-analytics-for-wordpress/
    location ~ ^/wp-content/plugins/google-analytics-for-wordpress/ {
    # Whitelist Exception for https://wordpress.org/plugins/regenerate-thumbnails/
    location ~ ^/wp-content/plugins/regenerate-thumbnails/ {
    # Whitelist Exception for https://wordpress.org/plugins/wp-pagenavi/
    location ~ ^/wp-content/plugins/wp-pagenavi/ {
    # Whitelist Exception for https://wordpress.org/plugins/wordfence/
    location ~ ^/wp-content/plugins/wordfence/ {
    # Whitelist Exception for https://wordpress.org/plugins/really-simple-captcha/
    location ~ ^/wp-content/plugins/really-simple-captcha/ {
    # Whitelist Exception for https://wordpress.org/plugins/ml-slider/
    location ~ ^/wp-content/plugins/ml-slider/ {
    # Whitelist Exception for https://wordpress.org/plugins/black-studio-tinymce-widget/
    location ~ ^/wp-content/plugins/black-studio-tinymce-widget/ {
    # Whitelist Exception for https://wordpress.org/plugins/disable-comments/
    location ~ ^/wp-content/plugins/disable-comments/ {
    # Whitelist Exception for https://wordpress.org/plugins/better-wp-security/
    location ~ ^/wp-content/plugins/better-wp-security/ {
    # Whitelist Exception for http://wlmsocial.com/
    location ~ ^/wp-content/plugins/wlm-social/ {
    # Whitelist Exception for mediagrid timthumb
    location ~ ^/wp-content/plugins/media-grid/classes/ {
    # Block PHP files in content directory.
    location ~* /wp-content/.*\.php$ {
      deny all;
    # Block PHP files in includes directory.
    location ~* /wp-includes/.*\.php$ {
      deny all;
    # Block PHP files in uploads, content, and includes directory.
    location ~* /(?:uploads|files|wp-content|wp-includes)/.*\.php$ {
      deny all;
    # Make sure files with the following extensions do not get loaded by nginx because nginx would display the source code, and these files can contain PASSWORDS!
    location ~* \.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl)$|^(\..*|Entries.*|Repository|Root|Tag|Template)$|\.php_
    return 444;
    #nocgi
    location ~* \.(pl|cgi|py|sh|lua)$ {
    return 444;
    #disallow
    location ~* (w00tw00t) {
    return 444;
    location ~* /(\.|wp-config\.php|wp-config\.txt|changelog\.txt|readme\.txt|readme\.html|license\.txt) { deny all; }
