MariaDB mysqlstop and mysqlstart shortcuts doesn't work
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Jun 15, 2020.
    12,579
    10:20 PM
    Yeah so it would of cleared the initial install's MariaDB journalctl logs on reboot. Guess only really way to know, is if you tried a fresh CentOS 7 reinstall and Centmin Mod 123.09beta01 install to see if you can reproduce the problem
  2. pamamolf
    4,128
    3:20 PM
    I tested again on a new page and it was ok .... so i am thinking to edit the:
    /usr/bin/mysqlstop/start/restart
    and replace the service command with systemctl to avoid the reinstallation
    is that ok to do for MariaDB and Centminmod ?
    12,579
    10:20 PM
    yeah you can do that, probably should update 123.09beta01 to do that for cmd shortcuts
  4. pamamolf
    4,128
    3:20 PM
    Great !!!!
    As i mention before i think there should be a check if the system is Centos 6 to use the service command and if it is Centos 7 to use the systemctl :)
    Thank you
  5. pamamolf
    4,128
    3:20 PM
    Do you plan to add it in a day or two so i can wait to add it automatically using Centminmod or should i do it manually now?
    12,579
    10:20 PM
    you can do it manually now, will add it later - I don't recall why I haven't done it this way to date so will need to check
  7. pamamolf
    4,128
    3:20 PM
    You did that because some users like me had issues when we tried to restart Mariadb .... at least that's what i remember ....
    But now it seems to have issues (on rare cases) and the service command may not catch the systemct commands and can' find the pid file ?
    Anyway you know better but i think is better to use the default command for each operating system .
    Thank you !
  8. pamamolf
    4,128
    3:20 PM
    Also is it better to use:
    systemctl stop/start/restart mysql
    or
    systemctl stop/start/restart mariadb
    I think the service is mariadb.service and maybe the second one is better to use?
    Which one do you plan to add at Centminmod?
    Thank you !
    12,579
    10:20 PM
    CentOS 7 officially would be mariadb service with Centmin Mod's installed official MariaDB 10 server
